Old 6th February 2018, 22:33   #15501  |  Link
phred1
New install -> decoding error
Fresh install of Win 10 Pro, new download of RipBot264 (v1.22.0).
At first run of Ripbot: complains over missing Haali Media Splitter so I download and install it.
At second run: starts fine, I add a file for conversion and click OK. In the bottom of the app window progress info flashes by. Last text I see is "Gathering information.." then a more-or-less empty window opens saying "Decoding Error".
I've tried updating to v1.22.1 but the issue persists. What am I doing wrong?
In the file "test.log" the last line is "C:\Temp\RipBot264temp\job1\getinfo.avs: Unknown error occurred"
BTW, thanks for a great app!
phred1 is offline   Reply With Quote
Old 7th February 2018, 10:02   #15502  |  Link
byteshare
ByteShare
byteshare's Avatar
Try using an image service as attached photos don't tend to get approved. Sounds like AVISynth might not be installed correctly. If you go the job (click on it) and click Edit > AviSynth > Preview Script does it work or do you get an error (might need to click play to see if you have an error).
Old 7th February 2018, 10:02   #15503  |  Link
byteshare
ByteShare
byteshare's Avatar
Is it possible to have a manual option for the crop settings in the batch mode rather than only auto crop?
Old 7th February 2018, 11:51   #15504  |  Link
https://support.microsoft.com/en-us/...al-c-downloads
Cropping manually in batch mode may be dangerous! You may easily crop to much!
Old 7th February 2018, 15:39   #15505  |  Link
phred1
Sweet, that did it! Thanks!
Old 7th February 2018, 16:39   #15506  |  Link
byteshare
ByteShare
byteshare's Avatar
I completely agree, but when I'm working with a batch of file with all the same crop it is nice to have them uniform. Sometimes the auto crop decides to under crop as well.
Currently, I'm working with some old DVDs and I'd rather over crop by 2px then under...trying for a simple 4px on the left and the right.
Another question,
I've been generating time codes for variable frame rate files manually for a while then importing them back into the encoded file afterwards. I've seen at least one other application do this automatically but it isn't as awesome as RipBot. This comes up with cartoons generally older ones, and/or on DVD. Often they are trying to save work by having 1 frame stay for longer or slow frame rate in spots, etc...
A batch to add timecodes looks like:
FOR %%A IN (*.mkv) DO "..\mkvtoolnix\mkvmerge.exe" -o "..\output\%%A" --timecodes "0:%%~dpnA.mkv.avs_timecodes.txt" "%%~A"
AVISynth Script for exporting timecodes from a file looks like:
video0 = FFVideoSource("C:\FileName.mkv", timecodes="C:\FileName.mkv_timecodes.txt")
Don't know if you can export timecodes from the source from MKVMerge directly? Just thought about it for the first time lol.
Old 7th February 2018, 19:24   #15507  |  Link
@soneca
x64 framesever debug mode has appeared!
https://forum.videohelp.com/threads/...de-FrameServer
Old 8th February 2018, 12:44   #15508  |  Link
Create custom script and save it in Tools\AviSynth plugins\Scripts\Custom
CropDVD.avs (left,top,right,bottom)
#Crop
video=Crop(video,2,2,-2,-2)
Do not forget to select this script in batch mode!
Old 8th February 2018, 12:45   #15509  |  Link
dracore
hello, im having issues with dolby atmos audio when i encode it to ac3 640kbs all the audio is jumbled up and distorted - is there a fix for this please
dracore is offline   Reply With Quote
Old 8th February 2018, 12:51   #15510  |  Link
In demux window select CORE
Old 8th February 2018, 13:23   #15511  |  Link
soneca
@soneca
Cool, great news!
I'll test later.
Thanks for the info!
Old 8th February 2018, 16:46   #15512  |  Link
byteshare
ByteShare
byteshare's Avatar
#Crop
I had thought about that but wasn't sure how to combine it with my other custom scripts like this one:
Loadplugin("C:\RipBot264v1.22.0\Tools\AviSynth plugins\masktools\masktools2.dll")
Loadplugin("C:\RipBot264v1.22.0\Tools\AviSynth plugins\mvtools\mvtools2.dll")
Loadplugin("C:\RipBot264v1.22.0\Tools\AviSynth plugins\Custom\dither.dll")
Loadplugin("C:\RipBot264v1.22.0\Tools\AviSynth plugins\Custom\avstp.dll")
Import("C:\RipBot264v1.22.0\Tools\AviSynth plugins\Custom\LSFmod.avsi")
Loadplugin("C:\RipBot264v1.22.0\Tools\AviSynth plugins\RgTools\RgTools.dll")
Import("C:\RipBot264v1.22.0\Tools\AviSynth plugins\Custom\SMDegrain.avsi")
Loadplugin("C:\RipBot264v1.22.0\Tools\AviSynth plugins\Custom\medianblur2.dll")
Loadplugin("C:\RipBot264v1.22.0\Tools\AviSynth plugins\Custom\smoothadjust.dll")
Import("C:\RipBot264v1.22.0\Tools\AviSynth plugins\Custom\dither.avsi")
Import("C:\RipBot264v1.22.0\Tools\AviSynth plugins\Custom\HQDeringmod_v1.8.avsi")
video=video.SMDegrain(tr=10,thSAD=1000,subpixel=3,contrasharp=true,refinemotion=true,lsb=true,pel=1).HQDeringmod(nrmode=2,Y=3,U=3,V=3,lsb=False,thr=255.0,darkthr=255.0)
Old 8th February 2018, 18:05   #15513  |  Link
Old 8th February 2018, 21:15   #15514  |  Link
Wishbringer
Silent Reader
Wishbringer's Avatar
Do something else. Start CMD.exe and then run job1_EncodeAudio1.cmd from console.
Ps. Do not add any pauses!
PS D:\Temp\RipBot264temp\job1> .\job1_EncodeAudio1.cmd
D:\Temp\RipBot264temp\job1>cd "E:\RipBot264v1.22.1\tools\ffmpeg\bin\"
D:\Temp\RipBot264temp\job1>del "D:\Temp\RipBot264temp\job1\AUDIO1_max_volume.txt"
D:\Temp\RipBot264temp\job1\AUDIO1_max_volume.txt konnte nicht gefunden werden
D:\Temp\RipBot264temp\job1>ffmpeg.exe -i "D:\Temp\RipBot264temp\job1\job1_AUDIO1.avs" -af "volumedetect" -vn -sn -dn -f null nul   2>&1  | findstr /I "max_volume:"   | awk.exe -F": " "{print $2}"   | cut.exe -d" " -f1  1>>"D:\Temp\RipBot264temp\job1\AUDIO1_max_volume.txt"
No Audioencoding job started with "normalize".
D:\Temp\RipBot264temp\job1>"E:\RipBot264v1.22.1\tools\ffmpeg\bin\ffmpeg.exe" -i "D:\Temp\RipBot264temp\job1\job1_AUDIO1.avs" -f wav -   | "E:\RipBot264v1.22.1\Tools\fhgaacenc\fhgaacenc.exe" --profile lc --cbr 320 --adts --ignorelength --quiet - "D:\Temp\RipBot264temp\job1\Encoded_Audio_1.aac"
ffmpeg version N-89803-g856b7cae9f Copyright (c) 2000-2018 the FFmpeg developers
  built with gcc 7.2.0 (GCC)
  configuration: --enable-gpl --enable-version3 --enable-sdl2 --enable-bzlib --enable-fontconfig --enable-gnutls --enable-iconv --enable-libass --enable-libbluray --enable-libfreetype --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libopenjpeg --enable-libopus --enable-libshine --enable-libsnappy --enable-libsoxr --enable-libtheora --enable-libtwolame --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx264 --enable-libx265 --enable-libxml2 --enable-libzimg --enable-lzma --enable-zlib --enable-gmp --enable-libvidstab --enable-libvorbis --enable-libvo-amrwbenc --enable-libmysofa --enable-libspeex --enable-amf --enable-cuda --enable-cuvid --enable-d3d11va --enable-nvenc --enable-dxva2 --enable-avisynth --enable-libmfx
  libavutil      56.  7.100 / 56.  7.100
  libavcodec     58.  9.100 / 58.  9.100
  libavformat    58.  3.100 / 58.  3.100
  libavdevice    58.  0.100 / 58.  0.100
  libavfilter     7. 11.101 /  7. 11.101
  libswscale      5.  0.101 /  5.  0.101
  libswresample   3.  0.101 /  3.  0.101
  libpostproc    55.  0.100 / 55.  0.100
Guessed Channel Layout for Input Stream #0.1 : 5.1
Input #0, avisynth, from 'D:\Temp\RipBot264temp\job1\job1_AUDIO1.avs':
  Duration: 02:21:15.97, start: 0.000000, bitrate: 0 kb/s
    Stream #0:0: Video: rawvideo (I420 / 0x30323449), yuv420p, 1920x800, 23.98 fps, 23.98 tbr, 23.98 tbn, 23.98 tbc
    Stream #0:1: Audio: pcm_s16le, 48000 Hz, 5.1, s16, 4608 kb/s
Stream mapping:
  Stream #0:1 -> #0:0 (pcm_s16le (native) -> pcm_s16le (native))
Press [q] to stop, [?] for help
Output #0, wav, to 'pipe:':
  Metadata:
    ISFT            : Lavf58.3.100
    Stream #0:0: Audio: pcm_s16le ([1][0][0][0] / 0x0001), 48000 Hz, 5.1, s16, 4608 kb/s
    Metadata:
      encoder         : Lavc58.9.100 pcm_s16le
size= 4767732kB time=02:21:15.96 bitrate=4608.0kbits/s speed=26.9x
video:0kB audio:4767732kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: 0.000002%
And with Normalize off.
Wishbringer is offline   Reply With Quote
Old 8th February 2018, 21:19   #15515  |  Link
dracore
sorry i didnt say im using a remux of the bluray in mkv container with the dolby atmos kept so i dont get the core option as its not bluray structure
Old 9th February 2018, 12:37   #15516  |  Link
@Wishbringer
I've installed win10 PRO x64 (german version) on virtual machine and audio normalization works flawlessly. Problem is definitely on your side. That's gonna be all from me regarding this issue.
@dracore
use eac3to to extract ac3 core from extracted .thd file.
Old 9th February 2018, 15:59   #15517  |  Link
iSeries
Im having the same issue as Wishbringer - I have increase centre channel ticked in the general settings menu, and within the job I have normalise set (AC3 2.0 192kbps). Muxing fails because the audio job didn't run. If I double click the .cmd job nothing happens.
Old 9th February 2018, 19:07   #15518  |  Link
soneca
@soneca
Atak, did you ever take a test?
This is where I get this message when I load the .avi file.
Old 9th February 2018, 19:44   #15519  |  Link
Not yet... I've been busy with other stuff.
Old 9th February 2018, 19:57   #15520  |  Link
dracore
@Wishbringer
@dracore
thank you that worked perfect
