Old 15th October 2018, 12:32   #6421  |  Link
Boulder
Pig on the wing
Boulder's Avatar
Has anybody made any recent tests with different CTU and TU sizes? I made a quick test yesterday on a 720p encode, and max CTU (and TU) 16 turned out to produce the smallest file but also looked best compared to the original frame. At CTU max 64, the frame was clearly more blurry in places where there were more small details such as hair etc.
Boulder is online now   Reply With Quote
Old 15th October 2018, 14:16   #6422  |  Link
RieGo
Originally Posted by DotJun View Post
I tried a short test clip with avx512 enabled and disabled on a 4K source using the slower preset. FPS went up to 1.37 from 0.84 when I enabled 512.
Encoded clip looks good, no obvious errors that is. File size is roughly the same, but clip length and crf might have something to do with the tiny difference between the two.
afaik avx512 enabled and disabled should produce exact same output. at least on my tests it did. can you share your command line?
RieGo is offline   Reply With Quote
Old 15th October 2018, 19:01   #6423  |  Link
Clare
Pushing Encoding Quality and Speed with x265
Massively Parallel Encoding
from Mile-High Video Workshop videos http://mile-high.video/files/mhv2018/
Clare is offline   Reply With Quote
Old 15th October 2018, 19:27   #6424  |  Link
benwaggoner
Originally Posted by Forteen88 View Post
x265 2.9+2 released now!
http://www.msystem.waw.pl/x265/
Anyone know what the new patch actually does:
rc: Fix rowStat computation in const-vbv
It looks like it might fix a serious issue in a given RC mode, but it isn't actually self-documenting.
Ben Waggoner
My Compression Book
Old 16th October 2018, 06:32   #6425  |  Link
Jamaika
Something seems to me that these aren't the only x265 bugs.
Github is still at 2.8. There will probably be some fixes to implement version 2.9.
Old 16th October 2018, 06:43   #6426  |  Link
Boulder
Pig on the wing
Boulder's Avatar
Tests with 4K and 1080p encodes also showed the same behaviour. It's quite strange as it's said that the big thing in HEVC is that it can use larger CTUs than AVC to increase efficiency and that the bigger the CTU is, the less bitrate should be required. It doesn't seem to be like this at least in CRF mode. Too bad it's not allowed to use 16x16 CTUs with 1080p or 4K encodes if they are to be compliant.
Old 16th October 2018, 07:57   #6427  |  Link
Bitbucket recently provided tag v2.9; but the "tip" is currently in the "stable" branch, not in "default".
Still, there seems to be a lack of communication recently. I reported compiler warnings of GCC 8.x already 2 times, and nobody replied until today.
Old 16th October 2018, 09:22   #6428  |  Link
SmilingWolf
I am maddo saientisto!
SmilingWolf's Avatar
Don't get me wrong, I have nothing but the conspiracy theories in my head, BUT, seeing as MulticoreWare sells en/decoding products, I wouldn't be surpised to see some announcement around the turn of the year about their work on some of the new codecs, be it AV1 or VVC.
But that's probably just me wishfully hoping for a sane AV1 encoder with proper performance, multithreading, profiles and documentation...
SmilingWolf is offline   Reply With Quote
Old 16th October 2018, 16:10   #6429  |  Link
benwaggoner
It would be helpful to see the command line used, or at least bitrate/CRF.
Larger CTUs are definitely helpful at lower bitrates. Comparing at high perceptual quality can bring in other subtler differences between modes.
I've even been able to see a slight improvement at sub-SD resolutions using CTU 64 at very low bitrates.
Ben Waggoner
My Compression Book
Old 16th October 2018, 17:02   #6430  |  Link
Boulder
Pig on the wing
Boulder's Avatar
Source was 4K, downsampled to 1080p. These are the basic parameters that I've set:
--input-depth 16
--dither
--profile main10
--min-keyint 5
--keyint 480
--merange 44
--splitrd-skip
--preset veryslow
--rc-lookahead 60
--deblock -2:-2
--no-strong-intra-smoothing
--no-sao
--qcomp 0.8
--aq-mode 3
--aq-strength 0.8
--ctu 64
--max-tu-size 32
--rdpenalty 1
--qg-size 16
--tu-inter-depth 4
--tu-intra-depth 4
--limit-tu 4
--limit-refs 3
--max-merge 2
--rd-refine
--ref 6
--bframes 10
--crf 19
I've then also tested ctu 32 with max-tu-size 32 or 16.
In the 1080p encode, the bitrate is as follows:
CTU 64 / TU 32 - 15078 kbps
CTU 32 / TU 32 - 14608 kbps
CTU 32 / TU 16 - 14472 kbps
Of these, CTU 32 / TU 32 resembles the original the most. It's interesting that setting TU 16 also causes distortion in the same areas as CTU 64 / TU 32. I checked areas like eyes, hair etc. which have easily some sort of distortion because there are many fine lines and things that can be compared quite easily.
I've just started testing what CRF value is visually enough for 1080p so the final bitrate will probably be lower than what I got from my tests. I'd estimate CRF 20-21 would be the final value.
Old 16th October 2018, 17:11   #6431  |  Link
benwaggoner
Source was 4K, downsampled to 1080p. These are the basic parameters that I've set...
Target CRF will also depend on other parameters, if you are still adjusting those.
Overall, that is a very idiosyncratic set of options. Nothing looks wrong (and I'd love to hear who you picked some of those!, but it's definitely outside of any combination of settings that MCW would be doing psychovisual optimization for.
I'm curious about why you chose these particular settings:
  • --merange 44
  • --splitrd-skip
  • --max-merge 2
  • --deblock -2:-2
  • --rdpenalty 1
  • --qg-size 16
  • --bframes 10
Is this for encoding anime or some other kind of synthetic or mixed synthetic/natural image encoding?
Ben Waggoner
My Compression Book
Old 16th October 2018, 17:28   #6432  |  Link
Boulder
Pig on the wing
Boulder's Avatar
My sources are just regular movies or TV series. I'll tune CRF as the last item once I've got all the rest in place.
--merange 44, basically lowering it from the default 57 which I understand is meant for 4K. For 720p, I've used 38 all the time. I think this is remains of littlepox's set of "tune film" parameters.
--splitrd-skip, in my old notes, I didn't find it cause any ill effects. Do you have any specific information why it's a "bad idea"?
--max-merge 2, values 3-4 tested and it caused blur. One of the things in x265 that is different from x264 - the slower presets don't mean similar quality at lower final bitrate
--deblock -2:-2, no need for intense deblocking according to my tests
--rdpenalty 1, trying to favour smaller blocks.
--qg-size 16, tested values from 64 to 8, 16 looked best (in terms of distortion in small details again) when compared frame-by-frame. Tested with a 720p encode, so I'll need to check that also with 1080p later.
--bframes 10, some video utilizes a lot of B-frames for some reason. Not a big slowdown so I've kept it at that all the time.
Old 16th October 2018, 17:52   #6433  |  Link
benwaggoner
It's not THAT frame size dependent, but 44 is probably fine.
No reason it would be a bad idea; I just haven't seen it used before. Generally parameters that have a reliable quality/speed tradeoff are in a preset. But it isn't listed as experimental...
Anyone from MultiCoreWare care to weigh in? What's the tradeoff? Is this something that should get added to the faster presets, or default to On but off in --preset placebo?
Yeah, with the many more tools available in HEVC, the differences between presets are greater. Odd that it causes blur; this should be a speed/quality tradeoff. You should file an issue here with repro details: https://bitbucket.org/multicoreware/...ew&status=open
Well, to improve compression efficiency. Did you see any issues with using 0:0?
Have you seen any experimental validation of it helping in x265 2.4+? I found places where it was helpful in older versions, but not recently.
I would expect it would look better, but at some cost to efficiency due to the signaling overhead. --opt-cu-delta-qp might help that some. What sorts of bitrates are you targeting/getting?
Why 10 specifically? I'd use either 8 (most tested, as it's in the slower+ presets) or 16 (maximum allowed).
Ben Waggoner
My Compression Book
Old 16th October 2018, 18:09   #6434  |  Link
Boulder
Pig on the wing
Boulder's Avatar
I think the general problem is that the presets and tunings are really old. I'm quite sure things are very much different now compared to what they were when most of the parameters and settings were come up with. Also, we are still missing the most common tuning which is --tune film. I would very much like to see what the creators of the encoder think of proper settings as they should know the internal workings best.
I recall someone else also complaining about max-merge for smoothing things if the value is too big. I'll need to retest and file a bug report if it's still reproducable. It's been some time since I tested it.
Will also retest deblock 0:0. When I tested it earlier, I did find it smooth things slightly so I went one notch down from the standard -1:-1 of x264's --tune film.
--rdpenalty 1 is something I have not tested recently.
--qg-size 16 does cause the bitrate to jump compared to 32 or 64, but it's worth it in my opinion.
I had tested it with a 720p encode with quite a big filesize difference:
qg-size 64 : 3147,41 kbps
qg-size 32 : 3648,01 kbps
qg-size 16 : 3954,23 kbps
It is something I need to separately retest for 1080p. The bitrates fluctuate a lot, I'd say between 2.5 - 6 Mbps for 720p encodes. I have no specific target so I just use CRF 19.
10 B-frames because for some quite noisy sources, I noticed that 8 consecutive B-frames were being used 5-10% of the time. Setting ten usually meant that the longest sequence was used 1-2% of the time.
Old 16th October 2018, 20:46   #6435  |  Link
jlpsvk
Is there a downside to enabling avx512 on an intel X chip?
Sent from my iPhone using Tapatalk
Heat.
AMD Ryzen 9 5950X, 32GB DDR4-3200 CL16, RTX 3060, 2TB NVMe PCIE4.0, NAS with 8x16TB HDD
jlpsvk is offline   Reply With Quote
Old 17th October 2018, 02:09   #6436  |  Link
benwaggoner
Originally Posted by jlpsvk View Post
Heat.
Would it be hotter? Or would it just be slower due to thermal throttling.
I wouldn't be surprised if Intel's next big microarchitecture revision makes AVX512 useful in cases where it isn't today. We saw the same thing with Skylake and AVX2.
Ben Waggoner
My Compression Book
Old 17th October 2018, 03:52   #6437  |  Link
Wolfberry
Helenium(Easter)
Wolfberry's Avatar
No reason it would be a bad idea, I just haven't seen it used before. Generally parameters that have a reliable quality/speed tradeoff are in a preset. But it isn't listed as experimental...
Anyone from multicoreware care to weigh in? What's the tradeoff? Is this something that should get added to the faster presets, or default to on but off in --preset placebo?
In fact, this skip is not a fast skip algorithm.
As the sum of split cost is larger than none split CU's best cost (both rdcost of sub-cu and none split CU are without split flag cost), which means splitting into 4 parts at this depth of cu is a worse case compared with none split CU. So that, the remain N * 1/4 parts of CU analysis is useless.
If I understood the patch comment in the mailing list correctly, it should speed up intra split cost calculation a little while possibly preserving identical output.
splitrd-skip sounds like a small speedup with no trade off, but still disabled by default (according to the doc)
Monochrome Anomaly
Wolfberry is offline   Reply With Quote
Old 17th October 2018, 11:10   #6438  |  Link
This will require 10nm process. 14nm++++++++++++ has reached its thermal limits. Upcoming 8C/16T CPUs already are very hot at 5GHz.
Old 17th October 2018, 15:51   #6439  |  Link
RieGo
in my personal experience avx512 isn't generating much more heat than avx2 - on x265
so as long as you are only using it on x265 and use a safe thermal throttling setting u should be fine imho
in case i am wrong and anyone else has different results please correct me
Old 18th October 2018, 07:08   #6440  |  Link
Boulder
Pig on the wing
Boulder's Avatar
I've done some testing on a 1080p encode, basically I've set CRF 21 and then tested one parameter at a time by comparing still frames. I know it's not the optimal way but it is very hard to notice the differences in motion. What I've tried to compare are areas which show distortion quite well, such as eyes and their surroundings, hair etc. I've also tried picking frames from fast motion and almost still scenes.
I'll post my results as soon as I finish the 720p tests. From what I can tell is that 1080p requires slightly different parameters, but of course it could be that things have changed so much under the hood that my set of parameters have been obsolete all the time
What I already found strange is that deblock doesn't really affect bitrate. For example deblock 6:6 ended up around the same size as deblock 0:0.
