Old 21st September 2009, 23:08   #1001  |  Link
carlmart
Carlos Martinez
1.
Are you sure you have selected FIRST 'Preferences'/'AudioVideo'/'Video Standard' (as NTSC) and THEN you load your input title?
Oh, that was it! OK. Thanks.
A 1.66 letterboxed to 4:3 DAR DVD should be kept as it is because that does not involve any re-encoding, while going to 16:9 does. Remember that every time you re-encode, you loose quality. I think you can always adjust your plasma screen DAR settings without much pain.
Re-encoding can and can not be bad. I do tests before carrying on with it. For this film I did just what you suggest: using the TV zoom settings, which lost me the subtitles, and the DVD zoom capability (which I never used), that kept the sub positions but changed the aspect ratio, cropping things away.
But a clever use of avisynth tools is allowring me to do great quality resizings.
I would not give you a ready-to-copy AviSynth script. I would like you to play a little bit with AviSynth (basic) functions to write a working script by yourself. Don't be lazy, my friend! Just try, I can assure that your satisfaction will be great.
In my case it's not laziness, but ignorance. In any case, didn't you read my note above on how I solved the resizing issue? It works like a charm.
carlmart is offline   Reply With Quote
Old 22nd September 2009, 00:30   #1002  |  Link
davidcw
Multithreading support for HC Encoder
Hi MrC,
Would it be possible to run multithreading support for HC, as is done with DVD Rebuilder to speed up encoding when using HC?
davidcw is offline   Reply With Quote
Old 22nd September 2009, 12:41   #1003  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
Great! Go on with AviSynth exploring.
If you mean to activate the *SMP command in HCenc ini file, it is already implemented.
Bye
MrC
AVStoDVD Homepage
AVStoDVD @ Doom9 Forum
Old 28th September 2009, 01:36   #1004  |  Link
MysticE
Ok, got the issue: when NTSC 23.976 fps is soft pulldown to 29.97 it retains the original encoded video frames. Even if DVD displayed frames are more (29.97/23.976 ratio). Surely MPEG2 experts can give more accurate details than me.
So right now chapter positioning in NTSC 23.976 to 29.97 projects is wrong. Bug will be fixed with next release.
Bye
Eagerly awaiting.
For those interested I found a great little app to fix things.
http://www.softpedia.com/get/CD-DVD-...-Creator.shtml
Simply load up the first VOB, set chapter length and Author. Works great and is also a great demultiplexer.
MysticE is offline   Reply With Quote
Old 28th September 2009, 10:40   #1005  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
You are right. I am bit late.
In 2.2.2 release I'm adding a very elementary DVD parsing tool and support to DGIndex files. Those feats are not the very core of AVStoDVD, but I have put them in the ToDo list for a long long time. Their purpose is to have a sort of "re-authoring" capability directly inside AVStoDVD, without running multiple programs.
Anyway, here you are 2.2.2 Alpha 090928:
Part 1
Part 2
and the release note:
- Some bugs fixed
- Added 'DVD Parse' new form (experimental)
- Added 'DGIndex' 1.5.0 to AVStoDVD Installer package
- Added 'VobSub.dll' 2.23 and 'VSConv' 1.2.5 to AVStoDVD Installer package
- Added support to DGIndex Project files (*.d2v) as input files
- Added trim capability to DVD compliant streams (video and audio)
- Added 'Advanced Project Settings' state saving to Windows Registry
- Added 'Sharpen' AviSynth filter in 'Title Edit'/'AviSynth'
- Added 'Fade In/Out' AviSynth filter in 'Title Edit'/'AviSynth'
- Added 'KernelDeint' AviSynth deinterlacing filter (by Donald Graft) in 'Title Edit'/'AviSynth'
- Added warning about multiple video tracks input titles (not properly handled)
- Added warning about input titles with Extended ASCII chars (Asc(char) > 127)
- Improved handling and encoding of interlaced videos
- Change video/audio Muxer: from ImagoMPEG-Muxer to FFmpeg
- Removed ImagoMPEG-Muxer from AVStoDVD package
- Light restyling of Button Generator form
- Updated input video file list (added mts files)
- MediaInfo updated to 0.7.21
- ImgBurn updated to 2.5.0.0
Sorry for files splitting but GooglePages max upload size is 10 MB.
Let me know if the NTSC bug is solved and if there are any new.
Bye
MrC
AVStoDVD Homepage
Old 28th September 2009, 12:22   #1006  |  Link
loekverhees
I am trying to put 12 videos on a DVD. Each video is about 35 minutes. I choose a DVD-5 for output, but when AVStoDVD is finished, the output folder is around 8 GB, so this doesn't fit on a DVD-5. Is there a way to let AVStoDVD calculate the avarage bitrate so that everything will fit on a DVD-5?
loekverhees is offline   Reply With Quote
Old 28th September 2009, 12:50   #1007  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
Dear loekverhees,
7 hours video footage is frankly too much for a DVD-5. Take note that AVStoDVD does calculate the avg bitrare, until it reach min bitrate allowed, set by default at 2500 kbps. If you really want to put all that stuff, then:
- go to 'Preferences'/'AudioVideo'
- change 'Video Lower Avg BitRate' from 2500 to 500 kbps
- change 'DVD Video Resolution' from AUTO to VCD
- decrease 'DVD Audio BitRate' from 192 to 96 kbps (optional)
Enjoy
Bye
MrC
AVStoDVD Homepage
Old 28th September 2009, 18:01   #1008  |  Link
loekverhees
Thanks, it works. The smaller resolution is not an issue, since the source had a resolution of 320x180 anyway. Only thing I noticed: when the filename has an umlaut (like ë and ü), the .bat-file for audio encoding crashes. But I can safely, I think, close that window and AVStoDVD will just continue.
Old 28th September 2009, 20:28   #1009  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
I know, filename with extended ASCII chars are always a problem. In the new 2.2.2 Alpha you will be prompted that it is better to have only standard ASCII chars.
Bye
MrC
AVStoDVD Homepage
Old 8th October 2009, 20:30   #1010  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
Well, do no complaints about 2.2.2 Alpha mean that everything is fine? Or that interest is going down?
Anyway here you are the changelog of 2.2.2 Final:
- Added possibility to load DVD Menu settings from a saved AVStoDVD Project
- Changed DVD-5 size: from 4435 to 4450 MB
- Changed video/audio Muxer: from ImagoMPEG-Muxer to FFmpeg
Enjoy
Bye
MrC
AVStoDVD Homepage
Old 8th October 2009, 21:40   #1011  |  Link
Filbert
Bye
At least all my problems seem to be solved, and no, interest is not going down. I will install AVStoDVD in our pc-room as the standard video to dvd conversion tool...
Thanx for your work, Filbert
Filbert is offline   Reply With Quote
Old 8th October 2009, 22:54   #1012  |  Link
MysticE
Well I installed this version:
http://sourceforge.net/projects/avstodvd/files/
Ran this File through it.
Complete name                    : C:\PU_6c_SM.mp4
Format                           : MPEG-4
Format profile                   : Base Media
Codec ID                         : isom
File size                        : 1.45 GiB
Duration                         : 1h 51mn
Overall bit rate                 : 1 863 Kbps
Encoded date                     : UTC 2009-06-21 08:05:15
Tagged date                      : UTC 2009-06-21 08:05:15
Video
Format                           : AVC
Format/Info                      : Advanced Video Codec
Format profile                   : Main@L4.1
Format settings, CABAC           : Yes
Format settings, ReFrames        : 3 frames
Codec ID                         : avc1
Codec ID/Info                    : Advanced Video Coding
Duration                         : 1h 51mn
Bit rate mode                    : Variable
Bit rate                         : 1 660 Kbps
Maximum bit rate                 : 12.0 Mbps
Width                            : 1 280 pixels
Height                           : 544 pixels
Display aspect ratio             : 2.35
Frame rate mode                  : Constant
Frame rate                       : 23.976 fps
Resolution                       : 24 bits
Colorimetry                      : 4:2:0
Scan type                        : Progressive
Bits/(Pixel*Frame)               : 0.099
Stream size                      : 1.29 GiB (89%)
Writing library                  : x264 core 67 r1169M ab85c9b
Encoded date                     : UTC 2009-06-21 02:57:21
Tagged date                      : UTC 2009-06-21 08:06:26
Audio
Format                           : AAC
Format/Info                      : Advanced Audio Codec
Format version                   : Version 4
Format profile                   : LC
Format settings, SBR             : No
Codec ID                         : 40
Duration                         : 1h 51mn
Bit rate                         : 200 Kbps
Maximum bit rate                 : 296 Kbps
Channel(s)                       : 6 channels
Channel positions                : Front: L C R, Rear: L R, LFE
Sampling rate                    : 48.0 KHz
Resolution                       : 16 bits
Stream size                      : 159 MiB (11%)
Encoded date                     : UTC 2009-06-21 08:06:16
Again chapters were off. The last chapter hit at about the 1:28 minute mark. The amount of chapters seemed correct @ 23, but they also seemed to be only 4 min. long (i have it set @ 5 min.)
Here's the only log I had.
<10/8/2009 1:19:44 PM>
START PROCESS
PROJECT SETTINGS
DVD Video Standard: NTSC
DVD Titles number: 1
DVD Size: 4450/4450 MB (100%)
DVD Output Setup: DVD Folder
DVD Label: PU_6C_SM 222
DVD Menu: No Menu
Output Folder: G:\AVStoDVD
Save Log file: Yes
Delete Temp Process Files: Yes
Delete Working Files: Yes
Edit Command Parameters: No
Post Process Task: Show Progress Status window
TITLE 1 SOURCE FILES
Video: C:\PU_6c_SM.mp4
Info: AVC - 1660 kbps - 1280x544 - DAR 2.353 - 23.976 fps - Progressive - 1:51:27 hours - 160342 frames
Audio: C:\PU_6c_SM.mp4
Info: AAC LC - 199 kbps - VBR - 48000Hz - 6ch - 1:51:27 hours
Subs:
[MediaInfoLib - v0.7.21]
AVISYNTH SCRIPT
Import("C:\Program Files\AVStoDVD\Lib\A2DSource.avsi")
Video = A2DVideoSource("C:\PU_6c_SM.mp4", CacheFolder = "C:\DOCUME~1\Johnny\LOCALS~1\Temp")
Audio = A2DAudioSource("C:\PU_6c_SM.mp4", CacheFolder = "C:\DOCUME~1\Johnny\LOCALS~1\Temp")
Video = Video.ConvertToYV12
#Using DGPulldown to upsize FPS
Video = Video.Crop(16,0,-16,0)
Video = Video.AddBorders(0,79,0,79)
Video = Video.Lanczos4Resize(720,480)
AudioDub(Video, Audio)
Encoding Profile: HCenc VBR 2-pass
Target Video FileSize: 3988 MB
HCenc Parameters: -ini "C:\DOCUME~1\Johnny\LOCALS~1\Temp\PU_6C_SM 222_0_PU_6c_SM.HCenc.ini"
HCenc ini file:
*INFILE C:\DOCUME~1\Johnny\LOCALS~1\Temp\PU_6C_SM 222_0_PU_6c_SM.avs
*AVSRELOAD
*OUTFILE G:\AVStoDVD\PU_6C_SM 222_0_PU_6c_SM.m2v
*LOGFILE C:\DOCUME~1\Johnny\LOCALS~1\Temp\PU_6C_SM 222_0_PU_6c_SM.HCenc.log
*MAXBITRATE 9000
*BITRATE 5002
*PROFILE BEST
*ASPECT 16:9
*PROGRESSIVE
*BIAS 50
*DC_PREC 9
*MATRIX MPEG
*AQ 1
*LUMGAIN 0
*SMP
*PRIORITY IDLE
*WAIT 2
<10/8/2009 4:00:26 PM>
END VIDEO ENCODING OPERATIONS
A2DVideoSource: DirectShowSource
Created File: G:\AVStoDVD\PU_6C_SM 222_0_PU_6c_SM.m2v (3989.1 MB)
OUTPUT VIDEO INFO: MPEG-2 Video - 5043 kbps - 720x480 - DAR 1.778 - 23.976 fps - Progressive - 1:51:21 hours - 160186 frames
START PULLDOWN OPERATIONS
DGPulldown Parameters: "G:\AVStoDVD\PU_6C_SM 222_0_PU_6c_SM.m2v" -srcfps 23.976 -destfps 29.97 -inplace -bff
<10/8/2009 4:07:01 PM>
END PULLDOWN OPERATIONS
DGPulldown executed on File: G:\AVStoDVD\PU_6C_SM 222_0_PU_6c_SM.m2v (3989.1 MB)
OUTPUT VIDEO INFO: MPEG-2 Video - 5038 kbps - 720x480 - DAR 1.778 - 23.976 fps - Progressive (2:3 Pulldown) - 1:51:27 hours - 160344 frames
<10/8/2009 4:07:02 PM>
START AUDIO ENCODING OPERATIONS
Wavi+Aften Parameters: "C:\DOCUME~1\Johnny\LOCALS~1\Temp\PU_6C_SM 222_0_PU_6c_SM.avs" - | "C:\Program Files\AVStoDVD\Aften\aften.exe" -b 448 - "G:\AVStoDVD\PU_6C_SM 222_0_PU_6c_SM.ac3"
<10/8/2009 4:10:53 PM>
END AUDIO ENCODING OPERATIONS
A2DAudioSource: DirectShowSource
Created File: G:\AVStoDVD\PU_6C_SM 222_0_PU_6c_SM.ac3 (357.2 MB)
OUTPUT AUDIO INFO: AC3 - 448 kbps - CBR - 48000Hz - 6ch - 1:51:27 hours
START DVD AUTHORING OPERATIONS
BatchMux Parameters: -arglist "C:\DOCUME~1\Johnny\LOCALS~1\Temp\PU_6C_SM 222_0_BatchMux.ini"
BatchMux ini file:
-d "G:\AVStoDVD\PU_6C_SM 222_0\VIDEO_TS"
-mxp "C:\DOCUME~1\Johnny\LOCALS~1\Temp\PU_6C_SM 222_0_MuxMan.mxp"
-l "C:\DOCUME~1\Johnny\LOCALS~1\Temp\PU_6C_SM 222_0_MuxMan.log"
-muxman "C:\Program Files\AVStoDVD\MuxMan"
-prio LOW
-v "G:\AVStoDVD\PU_6C_SM 222_0_PU_6c_SM.m2v"
-vidmode LB
-a1 "G:\AVStoDVD\PU_6C_SM 222_0_PU_6c_SM.ac3"
-a1lang en
-cellfr "C:\DOCUME~1\Johnny\LOCALS~1\Temp\PU_6C_SM 222_0_PU_6c_SM_MuxMan.txt"
-progfr "C:\DOCUME~1\Johnny\LOCALS~1\Temp\PU_6C_SM 222_0_PU_6c_SM_MuxMan.txt"
-chapfr "C:\DOCUME~1\Johnny\LOCALS~1\Temp\PU_6C_SM 222_0_PU_6c_SM_MuxMan.txt"
<10/8/2009 4:16:41 PM>
END DVD AUTHORING OPERATIONS
Created Folder: G:\AVStoDVD\PU_6C_SM 222_0 (4436.8 MB)
Log file created by AVStoDVD Release 2.2.2
Could not find these:
I rebooted and started again. I checked the chapters in the preview and they go to the end at 5 min intervals. Will report back in a few hours.
Old 8th October 2009, 23:49   #1013  |  Link
hlrsnd
@MrC: I appreciate your work. Keep it up. Thanks.
hlrsnd is offline   Reply With Quote
Old 9th October 2009, 15:59   #1014  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
@MysticE
wait, could you try with this "exe-only" update:
http://avstodvd.googlepages.com/AVSt..._Fix_091009.7z
Bye
MrC
AVStoDVD Homepage
Old 9th October 2009, 20:28   #1015  |  Link
MysticE
@MysticE
Bye
Well I'll give it a shot as rebooting and resetting defaults did not cure the problem.
Old 10th October 2009, 06:40   #1016  |  Link
MysticE
Alright, tried the new EXE, Got these pop ups. But it turns out there was a properly chaptered DVD created (go figure).
Here's the AVS log.
<10/9/2009 3:29:44 PM>
START PROCESS
PROJECT SETTINGS
DVD Label: P6C newEXE
DVD Menu: No Menu
Save Log file: Yes
Subs:
AVISYNTH SCRIPT
HCenc Parameters: -ini "C:\DOCUME~1\Johnny\LOCALS~1\Temp\P6C newEXE_0_PU_6c_SM.HCenc.ini"
HCenc ini file:
*INFILE C:\DOCUME~1\Johnny\LOCALS~1\Temp\P6C newEXE_0_PU_6c_SM.avs
*AVSRELOAD
*OUTFILE G:\AVStoDVD\P6C newEXE_0_PU_6c_SM.m2v
*LOGFILE C:\DOCUME~1\Johnny\LOCALS~1\Temp\P6C newEXE_0_PU_6c_SM.HCenc.log
*MAXBITRATE 9000
*BITRATE 5002
*PROFILE BEST
*ASPECT 16:9
*PROGRESSIVE
*BIAS 50
*DC_PREC 9
*MATRIX MPEG
*AQ 1
*LUMGAIN 0
*SMP
*PRIORITY IDLE
*WAIT 2
<10/9/2009 6:12:15 PM>
Created File: G:\AVStoDVD\P6C newEXE_0_PU_6c_SM.m2v (3989.1 MB)
DGPulldown Parameters: "G:\AVStoDVD\P6C newEXE_0_PU_6c_SM.m2v" -srcfps 23.976 -destfps 29.97 -inplace -bff
<10/9/2009 6:19:03 PM>
DGPulldown executed on File: G:\AVStoDVD\P6C newEXE_0_PU_6c_SM.m2v (3989.1 MB)
Wavi+Aften Parameters: "C:\DOCUME~1\Johnny\LOCALS~1\Temp\P6C newEXE_0_PU_6c_SM.avs" - | "C:\Program Files\AVStoDVD\Aften\aften.exe" -b 448 - "G:\AVStoDVD\P6C newEXE_0_PU_6c_SM.ac3"
<10/9/2009 6:24:28 PM>
Created File: G:\AVStoDVD\P6C newEXE_0_PU_6c_SM.ac3 (357.2 MB)
<10/9/2009 6:24:29 PM>
BatchMux Parameters: -arglist "C:\DOCUME~1\Johnny\LOCALS~1\Temp\P6C newEXE_0_BatchMux.ini"
BatchMux ini file:
-d "G:\AVStoDVD\P6C newEXE_0\VIDEO_TS"
-mxp "C:\DOCUME~1\Johnny\LOCALS~1\Temp\P6C newEXE_0_MuxMan.mxp"
-l "C:\DOCUME~1\Johnny\LOCALS~1\Temp\P6C newEXE_0_MuxMan.log"
-prio LOW
-v "G:\AVStoDVD\P6C newEXE_0_PU_6c_SM.m2v"
-vidmode LB
-a1 "G:\AVStoDVD\P6C newEXE_0_PU_6c_SM.ac3"
-a1lang en
-cellfr "C:\DOCUME~1\Johnny\LOCALS~1\Temp\P6C newEXE_0_PU_6c_SM_MuxMan.txt"
-progfr "C:\DOCUME~1\Johnny\LOCALS~1\Temp\P6C newEXE_0_PU_6c_SM_MuxMan.txt"
-chapfr "C:\DOCUME~1\Johnny\LOCALS~1\Temp\P6C newEXE_0_PU_6c_SM_MuxMan.txt"
<10/9/2009 7:23:01 PM>
PROCESS ABORTED DURING DVD AUTHORING OPERATIONS!
CHECK FOLLOWING FILES FOR MORE DETAILS:
AVSTODVD LOG FILE <G:\AVSTODVD\P6C NEWEXE_0.LOG>
BATCHMUX LOG FILE <G:\AVSTODVD\P6C NEWEXE_0_BATCHMUX.LOG>
<10/9/2009 7:23:04 PM>
Log file created by AVStoDVD Release 2.2.2 Fix build 091009
Here's the BatchMux log.
BatchMux version                   --> 1.3
Destination Folder                 --> G:\AVStoDVD\P6C newEXE_0\VIDEO_TS
MuxMan Script File                 --> C:\DOCUME~1\Johnny\LOCALS~1\Temp\P6C newEXE_0_MuxMan.mxp
MuxMan Log String                  --> -l "C:\DOCUME~1\Johnny\LOCALS~1\Temp\P6C newEXE_0_MuxMan.log"
Folder of the MuxMan executable    --> C:\Program Files\AVStoDVD\MuxMan
Check presence of MuxMan.exe       --> PASSED
Segment #1 - Video File #1         --> G:\AVStoDVD\P6C newEXE_0_PU_6c_SM.m2v
Checking asset for importing as    --> M2V, M1V, MPV
Video Coding Mode                  --> MPEG-2
Video Resolution (Nominal)         --> (720x480)
MPEG-2 Aspect Ratio (DAR)          --> 16:9
Video Frame Rate                   --> 29,97 fps
Video Bitrate (Nominal, Kbps)      --> 8789
VBV Buffer Size (Kbyte)            --> 224
Segment #1 - Video Display Mode    --> LB
Segment #1 - Audio #1 File #1      --> G:\AVStoDVD\P6C newEXE_0_PU_6c_SM.ac3
Segment #1 - Audio Lang Code #1    --> en
Segment #1 - Timeframe file        --> C:\DOCUME~1\Johnny\LOCALS~1\Temp\P6C newEXE_0_PU_6c_SM_MuxMan.txt
Segment #1 - Total Nr of Cells     --> 23
Segment #1 - Total Nr of Programs  --> 23
Segment #1 - Total Nr of Chapters  --> 23
Started preparation of             --> MUXMAN SCRIPT
Completed preparation of           --> MUXMAN SCRIPT
MuxMan RunString                   --> -run
Strings (local stack - bytes)      --> 814
Time Codes (local heap - bytes)    --> 841
Static memory usage %              --> 1.26
Starting MuxMan Authoring with     --> LOW task priority
MuxMan Authoring                   --> COMPLETE
Printing out                       --> MUXMAN LOG
-- MuxMan version 0.15R
-- Opened script file C:\DOCUME~1\Johnny\LOCALS~1\Temp\P6C newEXE_0_MuxMan.mxp
-- Accepted video G:\AVStoDVD\P6C newEXE_0_PU_6c_SM.m2v size = 4182867311
-- Accepted audio G:\AVStoDVD\P6C newEXE_0_PU_6c_SM.ac3
-- 18:24:32 Begin multiplex VTS01.
-- Title Segment List
-- Seg1
-- Maximum audio duration 400866 fields.
-- Starting scene Seg1_Scn1 at 00:00:00:00
-- Starting scene Seg1_Scn2 at 00:05:00:07, requested for 00:05:00:00
-- Starting scene Seg1_Scn3 at 00:10:00:09, requested for 00:10:00:00
-- Starting scene Seg1_Scn4 at 00:15:00:12, requested for 00:15:00:00
-- Starting scene Seg1_Scn5 at 00:20:00:09, requested for 00:20:00:00
-- Starting scene Seg1_Scn6 at 00:25:00:02, requested for 00:25:00:00
-- Starting scene Seg1_Scn7 at 00:30:00:04, requested for 00:30:00:00
-- Starting scene Seg1_Scn8 at 00:35:00:00
-- Starting scene Seg1_Scn9 at 00:40:00:09, requested for 00:40:00:00
-- Starting scene Seg1_Scn10 at 00:45:00:07, requested for 00:45:00:00
-- Starting scene Seg1_Scn11 at 00:50:00:06, requested for 00:50:00:00
-- Starting scene Seg1_Scn12 at 00:55:00:02, requested for 00:55:00:00
-- Starting scene Seg1_Scn13 at 01:00:00:04, requested for 01:00:00:00
-- Starting scene Seg1_Scn14 at 01:05:00:04, requested for 01:05:00:00
-- Starting scene Seg1_Scn15 at 01:10:00:14, requested for 01:10:00:00
-- Starting scene Seg1_Scn16 at 01:15:00:02, requested for 01:15:00:00
-- Starting scene Seg1_Scn17 at 01:20:00:00
-- Starting scene Seg1_Scn18 at 01:25:00:12, requested for 01:25:00:00
-- Starting scene Seg1_Scn19 at 01:30:00:05, requested for 01:30:00:00
-- Starting scene Seg1_Scn20 at 01:35:00:14, requested for 01:35:00:00
-- Starting scene Seg1_Scn21 at 01:40:00:10, requested for 01:40:00:00
-- Starting scene Seg1_Scn22 at 01:45:00:00
-- Starting scene Seg1_Scn23 at 01:50:00:10, requested for 01:50:00:00
-- SeqEnd at F9517D6B.
-- Bytes remaining in buffer = 0.
-- Bitrate - avg: 5565026, min: 458293 (lba 0), max: 9820579 (lba 1751284).
-- Shortest GOP has 5 fields, longest GOP has 30 fields.
-- Fields: 400865, VOBU: 12769, Sectors: 2271581.
-- 18:31:02 Begin multiplex VMG.
-- 18:31:02 End multiplex.
Segment memory resources           --> RELEASED
Local Stack memory                 --> RELEASED
File i/o structures                --> DEALLOCATED
Tired of messing with it. From now on I'll be outputting as elementary streams and using Simple DVD Creator to finish.
Old 10th October 2009, 11:43   #1017  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
Ok, thanks for the debug.
Bye
MrC
AVStoDVD Homepage
Old 10th October 2009, 16:34   #1018  |  Link
Richardw322
Just downloaded the new 2.2.2, and I was wondering, should I uninstall 2.2.1 first, or can I just install 2.2.2 over 2.2.1? BTW great work on this program!!
EDIT
I just went to the home page, and the link still says 2.2.1, even though it downloads 2.2.2
Richardw322 is offline   Reply With Quote
Old 10th October 2009, 21:21   #1019  |  Link
MrC
AVStoDVD Dev
MrC's Avatar
It is surely better to uninstall a previous release and then install the new one.
Thanks! Just updated it.
Bye
MrC
AVStoDVD Homepage
Old 13th October 2009, 08:00   #1020  |  Link
minda76
Thanks for a new nersion, but i can't create NTSC DVD, i always get BatchMux error "is not a legal mpeg2" or something like that. Here is the log files:
<2009.10.12 23:52:11>
START PROCESS
PROJECT SETTINGS
DVD Label: DVD
DVD Menu: No Menu
Output Folder: C:\DVD1
Save Log file: Yes
Delete Temp Process Files: No
Delete Working Files: No
Video: C:\DVD\10000 BC.ts
Info: VC-1 - 15677 kbps - 1920x1080 - DAR 1,778 - 23,976 fps - Progressive - 1:48:55 hours - 156699 frames
Audio: C:\DVD\10000 BC.ts
Info: AC3 - 640 kbps - CBR - 48000Hz - 6ch - 1:48:55 hours
Subs:
AVISYNTH SCRIPT
Import("C:\Temp\AVStoDVD_222_NoInstall\Lib\A2DSource.avsi")
Video = A2DVideoSource("C:\DVD\10000 BC.ts", CacheFolder = "C:\Windows\Temp")
Audio = A2DAudioSource("C:\DVD\10000 BC.ts", CacheFolder = "C:\Windows\Temp")
Video = Video.Spline64Resize(720,480)
Target Video FileSize: 4046,9 MB
HCenc Parameters: -ini "C:\Windows\Temp\DVD_0_10000 BC.HCenc.ini"
HCenc ini file:
*INFILE C:\Windows\Temp\DVD_0_10000 BC.avs
*AVSRELOAD
*OUTFILE C:\DVD1\DVD_0_10000 BC.m2v
*LOGFILE C:\Windows\Temp\DVD_0_10000 BC.HCenc.log
*MAXBITRATE 9000
*BITRATE 5194
*PROFILE BEST
*ASPECT 16:9
*PROGRESSIVE
*BIAS 50
*DC_PREC 9
*MATRIX MPEG
*AQ 0
*LUMGAIN 0
*SMP
*PRIORITY IDLE
*WAIT 2
<2009.10.13 03:50:01>
Created File: C:\DVD1\DVD_0_10000 BC.m2v (4042,2 MB)
OUTPUT VIDEO INFO: MPEG-2 Video - 5229 kbps - 720x480 - DAR 1,778 - 23,976 fps - Progressive - 1:48:49 hours - 156543 frames
DGPulldown Parameters: "C:\DVD1\DVD_0_10000 BC.m2v" -srcfps 23.976 -destfps 29,97 -inplace -bff
<2009.10.13 09:23:17>
DGPulldown executed on File: C:\DVD1\DVD_0_10000 BC.m2v (4042,2 MB)
Wavi+Aften Parameters: "C:\Windows\Temp\DVD_0_10000 BC.avs" - | "C:\Temp\AVStoDVD_222_NoInstall\Aften\aften.exe" -b 384 - "C:\DVD1\DVD_0_10000 BC.ac3"
<2009.10.13 09:27:39>
Created File: C:\DVD1\DVD_0_10000 BC.ac3 (299,2 MB)
OUTPUT AUDIO INFO: AC3 - 384 kbps - CBR - 48000Hz - 6ch - 1:48:55 hours
BatchMux Parameters: -arglist "C:\Windows\Temp\DVD_0_BatchMux.ini"
BatchMux ini file:
-d "C:\DVD1\DVD_0\VIDEO_TS"
-mxp "C:\Windows\Temp\DVD_0_MuxMan.mxp"
-l "C:\Windows\Temp\DVD_0_MuxMan.log"
-muxman "C:\Temp\AVStoDVD_222_NoInstall\MuxMan"
-prio LOW
-v "C:\DVD1\DVD_0_10000 BC.m2v"
-vidmode LB
-a1 "C:\DVD1\DVD_0_10000 BC.ac3"
-a1lang ru
-cellfr "C:\Windows\Temp\DVD_0_10000 BC_MuxMan.txt"
-progfr "C:\Windows\Temp\DVD_0_10000 BC_MuxMan.txt"
-chapfr "C:\Windows\Temp\DVD_0_10000 BC_MuxMan.txt"
<2009.10.13 09:30:08>
AVSTODVD LOG FILE <C:\DVD1\DVD_0.LOG>
BATCHMUX LOG FILE <C:\DVD1\DVD_0_BATCHMUX.LOG>
Destination Folder                 --> C:\DVD1\DVD_0\VIDEO_TS
MuxMan Script File                 --> C:\Windows\Temp\DVD_0_MuxMan.mxp
MuxMan Log String                  --> -l "C:\Windows\Temp\DVD_0_MuxMan.log"
Folder of the MuxMan executable    --> C:\Temp\AVStoDVD_222_NoInstall\MuxMan
Segment #1 - Video File #1         --> C:\DVD1\DVD_0_10000 BC.m2v
WARNING - Frame Rate Code 1 not allowed for DVD.
          Video Frame Rate can not be established.
          Proceeding by setting it to 29,97 fps.
Segment #1 - Audio #1 File #1      --> C:\DVD1\DVD_0_10000 BC.ac3
Segment #1 - Audio Lang Code #1    --> ru
Segment #1 - Timeframe file        --> C:\Windows\Temp\DVD_0_10000 BC_MuxMan.txt
Segment #1 - Total Nr of Cells     --> 11
Segment #1 - Total Nr of Programs  --> 11
Segment #1 - Total Nr of Chapters  --> 11
Strings (local stack - bytes)      --> 606
Time Codes (local heap - bytes)    --> 409
Static memory usage %              --> 0.77
-- Opened script file C:\Windows\Temp\DVD_0_MuxMan.mxp
-- Rejected sp r/fr C:\DVD1\DVD_0_10000 BC.m2v
-- Accepted audio C:\DVD1\DVD_0_10000 BC.ac3
-- No video file declared
Is there a bug?
minda76 is offline   Reply With Quote
[IMG] code is Off
