Go Back   Doom9's Forum > General > Newbies
Old 9th August 2008, 14:11   #21  |  Link
CTYves
mx rider
Is there a command that makes it respect the fps of the input video?
Upload your mororized sports video to www.carbtube.com and earn a little money on the side from them.
CTYves is offline   Reply With Quote
Old 9th August 2008, 14:18   #22  |  Link
dat720
if you leave the fps command out it will use the input fps, but mencoder see's that video as 100fps, which is why the video finishes playing before the audio after it's been encoded.
dat720 is offline   Reply With Quote
Old 9th August 2008, 14:28   #23  |  Link
dat720
"D:\VidTools\AutoMen\mencoder.exe" %1 -o "%~dpn1.youtube.flv" -mc 0 -demuxer lavf -of lavf -ovc lavc -lavcopts vcodec=flv:vbitrate=448:autoaspect:mbd=2:mv0:trell:v4mv:cbp:last_pred=3:predia=2:dia=2:precmp=2:cmp=2:subcmp=2:preme=2 -vf scale=320:240 -oac mp3lame -lameopts abr:br=56 -srate 22050
This command has better results, the demuxer is specified as lavf, which seems to have better success detecting the fps, but the audio is still choppy, even tho it is now using lame and not libmp3lame..... im stumped.
Old 9th August 2008, 14:36   #24  |  Link
CTYves
mx rider
Yes, it is. I tried it with "-srate 44100" too, but that didn't help. Same choppyness.
Old 11th August 2008, 11:04   #25  |  Link
manono
Originally Posted by dat720 View Post
Here is the Transformers trailer i did but it seems youtube totally raped the video, it looks much better from the original flv....
It looks better when you play the "High Quality" MP4 version:
http://www.youtube.com/watch?v=0lf9BBS7eDk&fmt=18
Not much better, but a little bit. You could get much better results by uploading a higher resolution video for them to reencode. They recommend 640x480, although I make mine 512x384 usually (or some widescreen equivalent like 640x272 or whatever). And they say they prefer XviD/DivX AVIs. Their reencoded "High Quality" MP4s have a 480 width, so you'd best upload something with at least that width.
manono is offline   Reply With Quote
Old 11th August 2008, 11:39   #26  |  Link
dat720
I was under the assumption that if you uploaded a compliant mp4 it left it alone rather than recoding.....
Old 11th August 2008, 12:05   #27  |  Link
manono
Nah, they reencode everything these days. Didn't your nasty looking trailer tell you as much? I'm sure what you uploaded didn't look like that.
Of course, that trailer was pretty difficult to compress, but it would still look quite a bit better (the High Quality version, anyway, and not the Standard Version), if you uploaded a higher resolution source for them to ruin.
Their Standard Quality is 320x240 FLV, so not much point in uploading a 320x240 MP4. Their High Quality is 480x360 MP4. One of them is. Their other High Quality version is 480x360 FLV, but they may be phasing them out. I uploaded 4 videos today and none had the High Quality FLV made available, only High Quality MP4.
Old 11th August 2008, 12:39   #28  |  Link
dat720
Well yeah it did, but in the past i've uploaded content which looked just as good as the original......
I might reencode that 1080p trailer and see how it looks after a upload at 640x480 or something.
That is after this x264 encode finishes, it's only got 2000 minutes to go :/ i'm so buying a quad with my next pay check
conversion, convert, flv, mencoder
