Old 10th July 2018, 09:06   #51701  |  Link
Asmodian
Originally Posted by heiseikiseki View Post
I don't why if I turn on the showadvancestep then the rendering time would increase.
To elaborate on what huhn said, ShowRenderSteps needs to measure how long each step takes and to do this an extra flush is needed after each step, this slows down rendering overall. This is only true when the OSD is open.
madVR options explained
Old 10th July 2018, 11:42   #51702  |  Link
heiseikiseki
Oh!! Thanks for the explain!
heiseikiseki is offline   Reply With Quote
Old 10th July 2018, 13:41   #51703  |  Link
zeus0r
hey there!
HDR passthrough via madvr is working fine and it puts my TV into HDR mode like it should. problem is: the picture is waaay too dark then. in dim scenes you can't even recognize faces properly.
so i tried the same files with the TV's internal mediaplayer -> perfect picture, not that dark.
any idea what could cause this?
4k SDR clips look wonderful via mpc-hc so it definitely is a HDR-specific problem.
my setup:
- philips 55pos901 oled tv
- gtx 980
- win 7
- mpc-hc + lavfilters + madvr (latest versions)
zeus0r is offline   Reply With Quote
Old 10th July 2018, 16:23   #51704  |  Link
mclingo
could it simply be that HDR is invoking a different profile on your TV which is set to FULL instead of LIMITED?
Old 10th July 2018, 17:58   #51705  |  Link
Warner306
I updated my driver and tried to do the manual method of creating a custom resolution.
First, I edited the EDID custom resolution created by madVR. The only thing that was different was the total number of pixels. This was entered and I played something. No change.
I deleted the custom resolution and started over. This time, when I finished, the driver entered the resolution as 23 Hz instead of 24 Hz. Still no go.
I then used CRU to create a custom resolution. It did not put anything into the GPU control panel, but the option to choose 24 Hz was removed, so it appeared to apply the correct EDID override. Played something and still no change.
So my apologies to the person I told to use the manual method of creating a custom resolution, as I couldn't figure it out, either.
The current driver doesn't seem to respond to anything but the default EDID. Not sure how common this is.
Custom resolutions are a total crapshoot...
Old 10th July 2018, 21:59   #51706  |  Link
SirSwede
LAN Access - Let me see if I have understood this correctly
Please, let me see if I have understood the function LAN Access correctly:
If the menu says "Enable LAN Access", then LAN Access is disabled?
If the menu says "Disable LAN Access", then LAN Access is enabled?
Have I understood this correctly?
Thank you in advance!
SirSwede is offline   Reply With Quote
Old 10th July 2018, 22:26   #51707  |  Link
Asmodian
That is correct, yes.
Old 11th July 2018, 10:04   #51708  |  Link
zeus0r
you mean a different picture settings profile?! (nope, it's the same)
Old 11th July 2018, 10:51   #51709  |  Link
MishNZ
Video delay after initial start in DX11 Exclusive Mode
I use DSplayer with MadVR and I have everything set so that HDR passthrough works correctly. My display is 10bit so I use DX11 exclusive mode to get everything flowing correctly. The only downside is that with DX11 exclusive mode the audio starts and continues correctly while the video plays for a second then pauses for about five seconds then continues normally. This doesn't happen if I turn off exclusive mode. It also doesn't happen when seeking, just on initial playback. Any ideas?
Windows 10, GTX1050Ti.
MishNZ is offline   Reply With Quote
Old 11th July 2018, 12:19   #51710  |  Link
mclingo
Hi, this is fairly normal behaviour i'm afraid, this is unlikely to change, I get similar issues, mine plays audio for a second with a black screen, then starts after about 2-3 seconds but then plays perfectly fine. You just need to find a way to live with it mate.
Old 11th July 2018, 12:30   #51711  |  Link
I have a similar issue under Windows 7, normal 8 bit display, no HDR, even with small video dimensions and in windowed mode in MPC-HC: The video starts with several seconds blackness but plays fine if I return to the start. If you say it belongs to DX11 Exclusive mode, I will try turning it off (if it was at all enabled), but right now I am not at the PC with this problem...
Old 11th July 2018, 13:09   #51712  |  Link
iSeries
Another oddity for me with Win 10 (with Nvidia 1050ti). I was on 1709 and all of a sudden started getting audio drops when bitstreaming, however, other than that playback was perfect in D3D11 fullscreen windowed (neither overlay or FSE would work well). I clean installed 1803, which fixed the bitstreaming issue - however I now have a new issue (and maybe it's not an issue, I don't know). In D3D11 windowed mode playback starts out as it did before, the refresh rate jumps around a little bit, and then after some seconds it locks....but now after a minute or two, the refresh rate starts getting erratic again, jumping around, and it stays like that for the duration of playback. I am using smooth motion so no frames are reported as dropped.
But now all of a sudden FSE works perfectly - refresh rate is rock solid after a few seconds of playback. Overlay is also now usable, before I was getting frame drops every minute or so for no reason, and I tested it for 15 minutes and didn't get any frame drops, and just as FSE, refresh rate is stable.
So the issue is only with fullscreen windowed. This is with both the latest Nvidia driver and with 385.28. Focus assist / game bar and all that other nonsense is turned off. Anyone else seeing this with windowed mode, or is it just me lol.
Old 11th July 2018, 13:09   #51713  |  Link
Originally Posted by zeus0r View Post
hey there!
my setup:
- gtx 980
- win 7
for a test
go to the nvidia control panel and change the output color format to YCbCr 4:2:2 and test again.
Old 11th July 2018, 17:28   #51714  |  Link
zeus0r
for a test
same dark mess...
i'll install win10, maybe it really is a win7 problem.
Old 11th July 2018, 18:33   #51715  |  Link
Warner306
hey there!
That's the image I would expect if your display didn't activate its tone mapping.
Old 11th July 2018, 18:43   #51716  |  Link
Warner306
How about this for a denoising filter in madVR?
NVIDIA's AI can fix bad photos by looking at other bad photos
Check out the video at the end. It is pretty impressive, but there is a little loss in sharpness.
It looks like that button in the movies that enhances security footage.
Old 11th July 2018, 20:03   #51717  |  Link
Those AI algorithms from NVIDIA are all quite impressive, but way too slow for realtime video use. Its more like something for offline processing of really bad videos.
Old 11th July 2018, 20:27   #51718  |  Link
Asmodian
Also, in regards to CSI style effects - the AI is adding fake detail that looks correct based on many other photos, not pulling the details from the image itself. Very impressive for viewing bad photos or videos but not great for identifying someone or similar forensic applications.
Old 12th July 2018, 04:29   #51719  |  Link
Warner306
It could probably be taught to recognize faces. In the end, it might not be any better than manual adjustment, but in real-time. Even though it takes milliseconds to render one image, getting it to run every 16-40 ms for video would likely be impossible as nevcairiel said.
Another of example of how deep learning is coming for everyone's job. Silicon Valley is obsessed with it. They can diagnose cancer in an MRI scan in 10 seconds using current neural networks.
Old 12th July 2018, 06:27   #51720  |  Link
zeus0r
and what could be the reason for that? win7?
