22nd February 2020, 02:32 | #7202 | Link | ||
However, if you just change the timestamps so the video runs a different speed, thats not really "resampling", for resampling to take place, the video frames need to actually change. What its really about is that you are seemingly alternating between resampling audio and resampling video - or you assumed the mpv "display-resample" mode did something else then it actually does (because that resamples audio), leading to confusion. And since we're talking about a mobile solution with power efficiency in mind, resampling audio like this is also far cheaper then resampling video (properly). Quote:
MPC-HC doesn't have this function built-in, but its achievable with little effort.
LAV Filters - open source ffmpeg based media splitter and decoders Last edited by nevcairiel; 22nd February 2020 at 02:45. |
22nd February 2020, 02:44 | #7203 | Link |
resampling video (i still think the term is miss leading) only has 23-60 samples a while audio has 44100 or more that means the error added by resampling in audio is very low and the error in video can be devastating like smooth motion at 23p with a 23p source the result is close to useless but 23p at 60p is fine. the next problem is it cost massively more processing power.
22nd February 2020, 06:16 | #7204 | Link |
mpv wiki - display-sync
mpv wiki - Motion-based interpolation and Smoothmotion We do not plan to implement anything like this in the near future. Perhaps we will try to use D3D11 VP functions for Nvidia, see Rate Conversion Caps in DXVA Checker. But even this will take a long time, so it's better not to wait for it and not to worry. So, if you are in a hurry, you can implement the features yourself or find people who can do it (I believe these people exist).
22nd February 2020, 09:56 | #7205 | Link |
Angel of Night
Resampling video to match audio just sounds like a huge waste of cpu/gpu power, when the algorithms to perfectly resample audio can run on a P3 in realtime. On the other hand, people mine bitcoin, so I guess that ship has sailed.
Resampling video exists to match monitor refresh rates, not audio timing. With the increasing adoption of G-sync and Freesync, the need for that is disappearing as players start to use that. Beyond that, the benefits of things like black-frame-insertion and frame blending have been contentious at best. |
22nd February 2020, 15:02 | #7208 | Link |
You are probably right if you want to be precise.
Well, thanks @ mpc be devs for evaluating. In the meantime, I'll be continuing using display-resample mode, which plays judder test videos even without any audio smoothly, doesn't "devastate" the result and neither is "smooth motion". People in their ivory tower of limited scope may continue thinking otherwise, totally ok with me. |
22nd February 2020, 22:58 | #7210 | Link |
So I've remuxed a 23,976fps judder test video together with an audio track, playback with ReClock (32 bit only binary, srsly?) at 48Hz shows stutter, while mpv display-resample does not.
Why? (Don't anybody come up with smooth motion...) |
24th February 2020, 19:46 | #7211 | Link |
Turns out not only Kodi but also mpv (using hwdec=nvdec) can play UHD/4K using GT 1030 2GB, mpc fails even with LAV Decoder and NVIDIA CUVID.
24th February 2020, 23:21 | #7212 | Link |
I have 1030 2Gb and perfect playback 4K 10Bit 60fps in MPC-BE.
24th February 2020, 23:58 | #7213 | Link | |
V: HEVC, Main 10@L5.1@High, 3840x2076, 59.940 FPS, 20.4 Mb/s A: AC-3, 640 kb/s, 6ch, 48.0 kHz
25th February 2020, 01:19 | #7215 | Link | |
Test on https://4kmedia.org/sony-bravia-uhd-hdr-4k-demo/ - perfect playback.
25th February 2020, 01:23 | #7216 | Link |
Neither works.
25th February 2020, 01:43 | #7217 | Link |
Please try this:
http://www.mediafire.com/file/kbn371...niMan.mkv/file Here in mpv it's crazy jerky and in mpc it's slow mo with audio dropouts.
25th February 2020, 01:47 | #7218 | Link |
Perfect playback. Test in MPC-BE using EVR-CP/MPC-VR(DX9) + internal filter(DXVA2 Native), MPC-VR DX11 + LAV DX11 Native.
Show screenshot in MPC-BE with statictics(Ctrl+J).
25th February 2020, 02:18 | #7219 | Link | |
https://postimg.cc/G9hzy0fN edit: Please also show screenshot.
https://github.com/stax76/software-list https://www.youtube.com/@stax76/playlists Last edited by stax76; 25th February 2020 at 02:22. |
25th February 2020, 02:24 | #7220 | Link | |
