8th June 2020, 09:56 | #7441 | Link |
I don't think so, you can take a look at the commit messages on sf.net
9th June 2020, 01:06 | #7443 | Link |
The option of 'swap effect' became 'flip' with fullscreen exclusive mode, while the setting is 'Discard'. Is it the expected behavior?
BTW, I think there should be somewhere place show the exclusive mode status when ctrl-K hit, which probably is already in your development schedule. Last edited by Anima123; 9th June 2020 at 02:31. |
9th June 2020, 06:45 | #7444 | Link | |
9th June 2020, 09:23 | #7446 | Link |
You can try to install - but for DVD playback using system filters/interfaces.
9th June 2020, 18:28 | #7447 | Link |
Is "dslibdvdnav" working fine? As good as DVD Navigator?
MPC-BE 1.6.11 and Nightly builds | VideoRenderer | ImageSource | ScriptSource | BassAudioSource |
10th June 2020, 08:45 | #7448 | Link |
I have found this alternative DVD Navigator only a few days ago and so far every tested DVD worked fine but since HC is not my main player I checked only ca. 10 DVDs or so.
Would be nice if you could add support for it. |
10th June 2020, 10:41 | #7449 | Link |
I don't know how - but MPC-HC don't have special code for support dslibdvdnav.
And - what better to use libdvdnav ?
10th June 2020, 11:21 | #7450 | Link |
Sorry, I misinterpreted the fact that HC is not showing the path of the used DVD Navigator as it is using dslibdvdnav but it does use the same OS version as BE does. So please forget that.
Thanks for all the hard work ! |
11th June 2020, 11:48 | #7452 | Link |
<< And - what better to use libdvdnav ? >> The version of libdvdnav which is integrated in MPC-BE is obviously sub-optimal (…hem, better to say it is broken, AFAIK…)… The navigation commands from the VTS to the VMG domain are not implemented properly in this version of the library. Consequently the jumps back and forward between titles and menus are leading to playback errors or stops. A good (recent) example where the DVD navigation from libdvdnav fails is reported here: https://forum.doom9.org/showthread.php?t=177379 I must say that I don't know if dslibdvdnav is better and/or suitable to solve the reported problem. Anyway, it would be very nice to have a more solid DVD navigation implemented within MPC-BE... EDIT - Also, I am not sure that the last available release of the libdvdnav library (6.1.0 of March 2020) is fixing this issue, nevertheless it is worth to try... Cheers, SD Last edited by Sir Didymus; 11th June 2020 at 20:50. Reason: Detailing and suggestion to upgrade the libdvdnav lib... |
12th June 2020, 06:20 | #7456 | Link |
On pause MPC-BE don’t prevent screen saver.
12th June 2020, 08:08 | #7457 | Link |
Thx - fixed.
12th June 2020, 10:30 | #7458 | Link |
If you want to save oled then don't pause the video at all
12th June 2020, 15:05 | #7459 | Link | |
But I think it's open source and could be integrated and improved. |
