29th January 2021, 20:22 | #8261 | Link | |
The "UseUrl" parameter can be helpful. This parameter is used for example foobar2000. But I don’t know how to check if this parameter works.
30th January 2021, 10:12 | #8263 | Link |
If you want to update the translation:
Download this mplayerc.fr.rc.txt file: https://sourceforge.net/p/mpcbe/code...yerc.fr.rc.txt I personally download it 2 times and rename one of it to the actual commit number like here 5994.txt Edit both files in Notepad++ (open source advanced text editor) and edit the mplayerc.fr.rc.txt, then you can compare both with built in extension "Compare" the differences. Note: you must install the extension Compare in plugins options. I know there might be better text editors, built Notepad++ does what I need and also preserves text coding of the file like UTF-8, with or without BOM and I am happy with it Last edited by Klaus1189; 30th January 2021 at 10:15. |
30th January 2021, 15:59 | #8264 | Link |
If these lines are not added to the Logitech Setpoint application "players.ini" file, the keyboard multimedia keys cannot be used with MPC-BE.
"players.ini" default location: "C:\Program Files\Logitech\SetPointP" Code:
[Players] mpcbe=wac,mpc-be.exe,MPC-BE,xxx,xxx,xxx,xxx,xxx,xxx,xxx,0,1,MPC-BE mpcbe64=wac,mpc-be64.exe,MPC-BE,xxx,xxx,xxx,xxx,xxx,xxx,xxx,0,1,MPC-BE x64 [Players.Seek] mpcbe=wac,xxx,xxx,1,1 mpcbe64=wac,xxx,xxx,1,1 [Players.Rewind] mpcbe=wac,xxx,xxx,1,1 mpcbe64=wac,xxx,xxx,1,1 |
30th January 2021, 16:20 | #8265 | Link |
@cmhrky
The player will not edit the settings of other applications.
31st January 2021, 05:53 | #8267 | Link |
About SVG graphics (toolbar.svg and flybar.svg).
I made a small utility svg2png that converts SVG to PNG using the Nano SVG library. This same library is used to render some of the controls in the MPC-BE and MPC-HC players.
31st January 2021, 19:59 | #8270 | Link |
Acid fr0g
I have bought the DTS Headphone:X from MS store and it automatically installed DTS:X decoder that is pure garbage for movies.
Is there any way to prefer the LAV Audio decoder within MPC-BE? I have tried to play with external filter settings but no success.
@turment on Telegram |
1st February 2021, 01:46 | #8271 | Link |
I am using the codecs found here:
http://codecguide.com/download_kl.htm To be more specific, Mega. Also using MPC-BE. In both MPC-HC and BE I opted for the ffdshow audio processor, only due to its capacity to increase the volume (plus 5 dB). My headphone isn't too loud even at 100%. So I changed MPC settings to prefer ffdshow to handle audio tracks. When I downloaded this track: https://soundcloud.com/vincentsejourne/epilogue Created by this author... a MP3... And tried to listen at the 7 second moment... I could hear a background noise, for more or less 2 seconds. Then I opened the same MP3 with Sound Forge, and told both MPC to disable ffdshow audio processor. The noise wasn't there. So why this is happening? Could it be a bug? And what options do I have for increasing the volume beyond 100%? My headphone is a Sennheiser 598 SR. MEDIAINFO data: https://pastebin.com/NsVbthYD |
1st February 2021, 02:27 | #8272 | Link | |
1st February 2021, 04:42 | #8273 | Link | |
Something Else
1st February 2021, 20:03 | #8276 | Link |
1st February 2021, 20:19 | #8277 | Link | ||
If so why the LAV Audio Decoder lacks that option while ffdshow audio processor (with the aforementioned bug) has it? |
1st February 2021, 20:59 | #8278 | Link |
I hope you realize sooner or later that LAV filters have nothing to do with MPC-BE. Also, if this option wasn't added in the past few years then there's a good reason for it.
1st February 2021, 22:03 | #8279 | Link |
because changing audio over 100 % has a extrem high chance of creating clipping and that really really bad just plain wrong.
the alternative to make audio "louder" without clipping is DRC dynamic range compression this just lowers audio quality and a filter like AC3 filter can do that. |
2nd February 2021, 04:56 | #8280 | Link |
MPC-BE 1.5.6 (build 6000) stable with digital signature (SF.net).
List of changes. MPC-BE Nightly builds: main file store, alternative 1, alternative 2 Also new and old versions can be found on VideoHelp.com. Last edited by v0lt; 2nd February 2021 at 14:21. |
