Old 6th July 2016, 13:45   #2001  |  Link
Groucho2004
Originally Posted by sl1pkn07 View Post
any installer for dummies?
Here. This installer does not include the VC runtimes. If you need them, use the ones from ultim's dl location. I highly recommend to use ricktendo's All In One runtime installer, very compact and all versions you'll ever need included.
Groucho's Avisynth Stuff
Groucho2004 is offline
Old 6th July 2016, 14:01   #2002  |  Link
sl1pkn07
Pajas Mentales...
thanks for the installer, but don't work with XP. no need the runtimes, because i want to install throught wine (vc2015 is installed by winetricks)
the workground is set wine to windows7, install avs+ and back to winxp
greetings
[AUR] Vapoursynth Stuff
[AUR] Avisynth Stuff
sl1pkn07 is offline
Old 6th July 2016, 14:05   #2003  |  Link
Groucho2004
The installer doesn't work on XP?
Old 6th July 2016, 14:10   #2004  |  Link
Reel.Deel
Maybe this?
Originally Posted by qyot27 View Post
Sidenote: similar to what happened a couple years ago with VS 2013 builds, Wine 1.9.x (i.e. the current dev branch) cannot use binaries built with VS 2015 yet. Even if you do have all the correct redist dlls available.
Reel.Deel is offline
Old 6th July 2016, 14:16   #2005  |  Link
sl1pkn07
Pajas Mentales...
what the hell. in the first time i run the installer don't work. spawn a installer error window about the version of the windows. then switch to win7, install it and back to windows xp
now with winxp again, the installer works ok :?
shi......
sorry for the noise
sl1pkn07 is offline
Old 6th July 2016, 14:32   #2006  |  Link
pinterf
I'm aware of how much memory these frame sizes need (more or less).
I'm not sure if you realize that the point of that script is simply to force Avisynth to run out of memory and see how it behaves.
So, the only question is why the new version behaves differently.
Meanwhile the resizer memory question solved (why it seemed to use so big intermediate frame)
And I have learned that these are not the same
setmemorymax(16000)
setmemorymax(16000)
n = 5
colorbars(width = 1920 * n, height = 1080 * n, pixel_type = "rgb32").killaudio().assumefps(25, 1)
turnleft().pointresize(width() - 1920, height() - 1080)
result is 7680x4320
Flow: orig 9600x5400
-> turnleft 5400x9600
-> resize to 7680x4320 =
resize_horiz 5400x9600->7680x9600 (huge!)
resize_vert 7680x9600->7680x4320
or
turnleft()
result is 3480x8520
pinterf is offline
Old 6th July 2016, 14:39   #2007  |  Link
pinterf
Accidental.
Now (maybe the running programs changed the memory consumption a bit) my test even did not return from a simple malloc.
While there is intensive memory swapping in the background.
So frame reservation error is caught, C++ object reservations and internals can cause C0000005 in the VC runtime, or other buffer reservations (Avisynth BufferPool for temporary buffers) can result in silent death in malloc when it cannot reserve e.g. a 2G memory area.
pinterf is offline
Old 6th July 2016, 15:21   #2008  |  Link
ultim
AVS+ Dev
ultim's Avatar
Accidental.
Here is a quick guess, but I will only be able to check it later in the evening.
The new resizers in the MT-branch use the IScriptEnv2->Allocate() to request temporary storage instead of requesting frame buffers (this is both faster and more memory-efficient). But if I remember correctly, Allocate() returns a NULL pointer when it runs out of memory instead of throwing an exception. My bet is that the resizers don't inspect the return value for error and so you get an access violation due to NULL-pointer dereference. If this guess is correct, the fix is to check the return value of allocate inside the resizer for NULL, and if NULL, call env->Throw().
AviSynth+
ultim is offline
Old 6th July 2016, 15:22   #2009  |  Link
MysteryX
Soul Architect
MysteryX's Avatar
AviSynthShader released with updated headers + cleaned up the files mess
MysteryX is offline
Old 6th July 2016, 15:30   #2010  |  Link
real.finder
Originally Posted by tormento View Post
@real.finder
Can you please explain me the following changes?
  1. add Prefilter auto 16 (lsb) support
  2. add TV_range bool
  3. less lsb if not use lsb things and get ready for yv16 and yv24
"add Prefilter auto 16 (lsb) support" mean you can use 16bit (stack) not just the 8 bit normal one in external Prefilter
"add TV_range bool" see this http://avisynth.nl/index.php/Limiter and this http://avisynth.nl/index.php/Luminan...ance_levels.3F
anyway, TV_range is true by default, that will use Dither_Luma_Rebuild(S0=1.0,c=0.0625) see here http://avisynth.nl/index.php/SMDegrain#Introduction
if set TV_range to false then Dither_Luma_Rebuild will not be used
"less lsb if not use lsb things and get ready for yv16 and yv24"
SMDegrain was using KNLmeans with lsb (16bit) even without using lsb in setting, and "get ready for yv16 and yv24" this is for the future
See My Avisynth Stuff
real.finder is offline
Old 6th July 2016, 15:34   #2011  |  Link
tormento
Acid fr0g
tormento's Avatar
Let TV_range true is good or evil?
@turment on Telegram
tormento is offline
Old 6th July 2016, 15:38   #2012  |  Link
real.finder
good for DVD and BD and tv things
Old 6th July 2016, 15:40   #2013  |  Link
tormento
Acid fr0g
tormento's Avatar
And, I imagine, evil for computer generated things and photos, correct?
tormento is offline
Old 6th July 2016, 15:43   #2014  |  Link
real.finder
didn't try, but yes, it's wrong in these cases
Old 6th July 2016, 15:51   #2015  |  Link
Groucho2004
Originally Posted by MysteryX View Post
Why do you post this here? Trying to get your post count up? You already announced it in your own thread.
Is this now becoming a permanent thing that you fill almost every thread on this forum with your random ramblings?
Old 6th July 2016, 16:01   #2016  |  Link
pinterf
Resizers do not check allocation result. But in my test, they even dont reach the checking point. Provided if the OS is in low memory situation too. In this case I do not care the meaningful error report when even task manager response time is some minutes because of swapping
pinterf is offline
Old 6th July 2016, 16:18   #2017  |  Link
Groucho2004
Here's a funny one:
Script:
setmemorymax(16000)
n = 30
colorbars(width = 1920 * n, height = 1080 * n, pixel_type = "yv12").killaudio().assumefps(25, 1)
temporalsoften(4,4,8,15,2)
Error:
AVSMeter 2.3.0 (x64) - Copyright (c) 2012-2016 Groucho2004
AviSynth+ 0.1 (r2022, MT, x86_64) (0.1.0.0)
Requested buffer size of 18446744072213944351 is too large
(F:\Test\test.avs, line 3)
Avisynth want's to allocate 18 exabytes
Looks like 2^64 - 18446744072213944351 would be the correct value.
Old 6th July 2016, 18:21   #2018  |  Link
ultim
AVS+ Dev
ultim's Avatar
That doesn't always happen. Groucho reported he got an access violation at least once, and those with fast swap (SSD) or no swap at all because they turned it off would also crash. Anyway, I'm calling dibs on this fix.
On a different topic: I've got a private branch with some stuff not in MT, because it changes ScriptEnv2, so I don't want to mix it in unless it's ready. This way others can still merge from me or builds can be issued without breaking stuff too early. I think I've got a way to go about the MT-related issues, but I need to try it out to see if the theory works. Other unrelated fixes I will try to put in MT directly.
AviSynth+
ultim is offline
Old 6th July 2016, 18:30   #2019  |  Link
Wilbert
feature requests:
1) ConvertToYUV400 (same naming as ConvertYUV444, instead of ConvertToY16/32),
2a) PRGB colorformats (for the new bit-depths)
2b) ConvertToPRGB (planar RGB: PRGB <-> YUV420/YUV422 via in between format YUV444),
3) script functions which give the bit-depth.
Question: what happens when doing for example ConvertToYV12(available options) on a 16/32 bit YUV source? Is that implemented already?
Wilbert is offline
Old 6th July 2016, 19:17   #2020  |  Link
ultim
AVS+ Dev
ultim's Avatar
Originally Posted by Wilbert View Post
feature requests:
1) There is already ConvertToY() (without bit depth specification), but ConvertToYUV400() can be added as an alias for consistency with the other functions.
2) There are multiple RGB and multiple YUV color spaces, so at least >1 need to be supported to give correct results in most cases, if one wants to convert RGB<->YUV. When and if at all this will be done is better asked to pinterf, unless someone else steps up to implement it.
3) Sure.
EDIT:
IMHO those functions with exact bit depth specification should stay true to their name. For me it would be weird and unexpected if ConvertToYV24() produces float pixels at one point, since that is not YV24. So my stand on this is that ConvertToYV24() should be a shortcut for ConvertToYUV444().ConvertTo8Bits() (and similarly for other old functions).
AviSynth+
ultim is offline
