Old 3rd January 2018, 20:40   #3841  |  Link
wonkey_monkey
Formerly davidh*****
wonkey_monkey's Avatar
Quick question: when creating a NewVideoFrame, is pitch guaranteed to always be rowsize rounded up to a 32-byte boundary?
wonkey_monkey is offline
Old 3rd January 2018, 22:19   #3842  |  Link
Myrsloik
Professional Code Monkey
Myrsloik's Avatar
Nope. If you end up running in vapoursynth's compatibility it can be 64 byte alignment too. Sometimes. There are also some cpu cache reasons to avoid row sizes that are a certain multiple. So a future implementation may pad the rowsize to avoid that.
Don't assume anything, it'll break future compatibility.
Myrsloik is offline
Old 3rd January 2018, 22:53   #3843  |  Link
wonkey_monkey
But it will be consistent for a particular clip? So if I call NewVideoFrame(vi), get the pitch, and immediately discard the frame, is it safe to assume the pitch will be the same for all future frames created?
I'm trying to be extremely efficient with something.
Old 3rd January 2018, 23:02   #3844  |  Link
Myrsloik
Myrsloik's Avatar
In vapoursynth it's guaranteed that the stride/pitch is the same. For all frames if they have the same type.
I checked the Avisynth source and the stride will always be the same there too. For NewVideoFrame, not for frames returned from GetFrame obviously.
Myrsloik is offline
Old 4th January 2018, 13:36   #3845  |  Link
pinterf
Since r2544 the frame alignment is 64 bytes, and pitch/stride size is padded to 64 as well, independently of possible AVX512 support.
pinterf is offline
Old 4th January 2018, 19:12   #3846  |  Link
bilditup1
bilditup1's Avatar
Does the KAISER patch have any implications for avs performance?
bilditup1 is offline
Old 4th January 2018, 19:37   #3847  |  Link
It will probably delay every call to a Windows system function which switches from user space to kernel space.
LigH is offline
Old 10th January 2018, 09:02   #3848  |  Link
pinterf
There was no change, what happens when you call Eval with the clip as the first parameter? (not tried, I hope syntax is OK)
  AVSValue eval_args[] = { clip, env->SaveString("Subtitle(\"Hello world!\")") };
  AVSValue val = env->Invoke("Eval", AVSValue(eval_args, 2));
pinterf is offline
Old 11th January 2018, 08:51   #3849  |  Link
pinterf
Originally Posted by Stephen R. Savage View Post
Eval does not take a clip argument: http://avisynth.nl/index.php/Internal_functions#Eval. The issue seems to be variable scoping.
Then it's not documented.
This other form is for OOP notation, that is clip.Eval("....").
Saves current "last", sets "last" to clip, calls Eval then restores previous "last".
https://github.com/pinterf/AviSynthP...cript.cpp#L191
https://github.com/pinterf/AviSynthP...cript.cpp#L416
But I agree, this is scoping problem, similar to the earlier (still not solved) issue with conditional/runtime functions setting "current_frame" and "last" in a multithreading environment.
pinterf is offline
Old 11th January 2018, 13:29   #3850  |  Link
Gavino
Avisynth language lover
This was added in Avisynth 2.6.0 Alpha 5.
Originally Posted by IanB View Post
Here is the 5th official release of Avisynth 2.6
Changelist
Additions
* Added Eval(clip, string name, string) alias for oop processing of argument.
GScript and GRunT - complex Avisynth scripting made easier
Gavino is offline
Old 11th January 2018, 18:33   #3851  |  Link
pinterf
Thanks to raffriff42, who provided me a nice skeleton page, Expr got an info page.
It's still ugly, I'll format it properly when I'm fiddling out how to do that. Now I only poured some infos there.
Enjoy (or not ) http://avisynth.nl/index.php?title=Expr
pinterf is offline
Old 11th January 2018, 23:49   #3852  |  Link
wonkey_monkey
With a YUVA clip, IsY() and IsYUV() seem to return false. Is that intended behaviour? I've been relying on https://forum.doom9.org/showthread.php?p=1783714 as a reference on colour spaces, but it's not clear on this point.
Also that page makes reference to ComponentCount but the latest avisynth.h only seems to have NumComponents...? Is the latter the eventual form of the former, I guess?
If anybody ever thinks of it, HasY(), HasU(), HasG(), HasA() etc would be awesome...
Old 12th January 2018, 00:29   #3853  |  Link
raffriff42
Retried Guesser
raffriff42's Avatar
YUV444P8 is YUV but not YUVA or Y-only
YUVA444P8 is YUVA but not YUV or Y-only
Y8 is Y and YUV but not YUVA
I tried to create a hierarchy (tree view) on the Avisynthplus_color_formats page.
See also the Clip_properties page.
HasA() exists and it's called HasAlpha.
HasU() does not exist, but you can call try { ExtractU } catch { ...}
raffriff42 is offline
Old 12th January 2018, 00:38   #3854  |  Link
wonkey_monkey
Thanks - seems a little messy but I think it's clearer. Do all Y-only formats return IsYUV()=true? Or just Y8?
Old 12th January 2018, 01:23   #3855  |  Link
raffriff42
Retried Guesser
raffriff42's Avatar
All the tests hold true regardless of bit depth.
If you want more confusion, consider that the new RGB(A) formats are planar; you can't call ConvertBits(x) on an RGB32 clip, you must call ConvertToPlanarRGBA first. I have posted a utilities script, called Utils-r41.avsi, that (among other things) hides this complexity behind To16bit and ToHibit(bits)
Old 12th January 2018, 03:33   #3856  |  Link
qyot27
qyot27's Avatar
Two nitpicks:
There's a typo on YUVA444P claiming classic AviSynth has it.
The YUV422P10 entry is showing v210's data. IMO, v210 being interleaved and VfW-only should only be mentioned in the footnotes at the bottom, not in the table itself. The notes column could read like:
aka P210 (special-case: V210 output available via override§)
(or 'global OPT_Enable_V210()' instead of 'override'). But as it is right now, it's highly misleading since YUV422P10 is planar, is used internally in AviSynth+, and isn't VfW-only.
Well, for ConvertBits(16) you'd get RGBA64 - and as far as I'm aware, that should preserve the alpha. The question is whether RGBA64 is actually useful, or whether most destination programs expect 16-bit planar RGBA if working with >8bit and alpha.
qyot27 is offline
Old 12th January 2018, 04:39   #3857  |  Link
raffriff42
Retried Guesser
raffriff42's Avatar
qyot27, thanks for fact-checking, I'll fix.
IIRC I used to get an error trying that, but you're right, it works.
Old 12th January 2018, 10:15   #3858  |  Link
wonkey_monkey
I don't see it in the avisynth.h dated 20171207. I'll use NumComponents()==4, it seems like that should work.
Old 12th January 2018, 10:41   #3859  |  Link
pinterf
HasAlpha is an Avisynth+ script function and has no direct mapping to a VideoInfo helper function.
https://github.com/pinterf/AviSynthP...ript.cpp#L1400
pinterf is offline
Old 12th January 2018, 15:41   #3860  |  Link
pinterf
Don't know if vmovntdqa reg,reg is valid or not but it seems to be not. The crash occurs in merge_avx2:
      00070	8d 40 20	 lea	 eax, DWORD PTR [eax+32]
      ; 70   :       __m256i src1  = _mm256_stream_load_si256(reinterpret_cast<__m256i*>(p1+x));
      00073	c5 fe 6f 40 e0	 vmovdqu ymm0, YMMWORD PTR [eax-32]
      00078	c4 e2 7d 2a c8	 vmovntdqa ymm1, ymm0            ****CRASH HERE! ILLEGAL INSTRUCTION VS15.5.1!!!****
      ; 71   :       __m256i src2  = _mm256_stream_load_si256(const_cast<__m256i*>(reinterpret_cast<const __m256i*>(p2+x)));
      0007d	c5 fe 6f 44 02 e0		 vmovdqu ymm0, YMMWORD PTR [edx+eax-32]
      00083	c4 e2 7d 2a c0	 vmovntdqa ymm0, ymm0
Will update to 15.5.2 and see what happens.
EDIT:
With VS 15.5.2 the code still fails. Replaced stream_load with normal load, it's O.K.
Two weeks ago I have reported it and made a minimal project for MS which still exhibited the problem. And they fixed. One less bug.
https://developercommunity.visualstu...tream-loa.html
pinterf is offline
