Old 21st May 2014, 09:29   #1  |  Link
mdalacu
mdalacu's Avatar
dmMediaConverter v2.5.5
dmMediaConverter is a crossplatform FFmpeg frontend (GUI) exposing some of its features. It is intended to be simple and easy to use but also to be able to achieve complex tasks. I have inspired myself from a lot of media converters like Handbrake, WinFF and MkvMergeGui. One feature was lacking from most of them, video stream copy (pass through), that made me build this.
For download and more details, here:
https://sites.google.com/site/dmsimp...MediaConverter
If i have posted in the wrong subforum, please move the thread.
Also i will appreciate any kind of feedback.
mdalacu is offline   Reply With Quote
Old 21st May 2014, 17:21   #2  |  Link
sef
Thanks Marius!.. I will test .. (both, Linux and Windows)
sef is offline   Reply With Quote
Old 27th May 2014, 11:01   #3  |  Link
mdalacu
mdalacu's Avatar
Version 0.9.5 is up!
http://dmsimpleapps.blogspot.ro/2014...converter.html
Old 28th May 2014, 09:27   #4  |  Link
mdalacu
mdalacu's Avatar
v0.9.7
Added support for VP8, VP9, Vorbis and Opus. So, now you can save in webp format.
Old 30th May 2014, 10:12   #5  |  Link
mdalacu
mdalacu's Avatar
v0.9.8
Version 0.9.8 is up. With this release i will provide DEB files for easy instalation on Debian and flavors (Ubuntu, Mint , etc).
Old 2nd July 2014, 08:13   #6  |  Link
mdalacu
mdalacu's Avatar
Is there a problem with the app, because i can not see the thread anymore? Is the app in the same situation as potplayer?
Thank you.
Old 2nd July 2014, 17:39   #7  |  Link
Asmodian
The forum defaults to only display one month of threads, I don't think anyone has accused you of violating any licences.
It looks like a nice GUI, I would give it a try but I am a CLI user.
Old 3rd July 2014, 18:08   #8  |  Link
mdalacu
mdalacu's Avatar
Version 0.9.9. is up!
Old 22nd August 2014, 06:09   #9  |  Link
mdalacu
mdalacu's Avatar
Major release!
dmMediaConverter v1.0.0
New Features!
- Stream Profiles!
- Bulk Convert mode! Convert multiple files at once.
- 2 pass encoding for video codecs
- DeShake filter (not so good ...)
- Creation_time tag
- HiDPI support
- Added all ISO 639-2 language codes
- Added color coded stream types for easy identification.
I hope you like it and please, provide feedback.
thanks.
Old 22nd August 2014, 06:28   #10  |  Link
Sparktank
47.952fps@71.928Hz
Sparktank's Avatar
How interesting.
Though, it's a bit tricky to download with the Google thing.
View defaults to tiles instead of list/details.
Plus I had to refresh page a couple times before downloaded started for me.
Thanks for the update. I'll give it a whirl sometime. Get something going for my Sony media player.
Win10 (x64) build 19041
NTSC | DVD: R1 | BD: A
Sparktank is offline   Reply With Quote
Old 22nd August 2014, 06:57   #11  |  Link
mdalacu
mdalacu's Avatar
Originally Posted by Sparktank View Post
How interesting.
I think you are right ... default view mode in GDrive is a little annoying, but for me it is very reliable, i never had an issue with it and that was the main reason to host the files there.
I will thing for an alternate location.
Thank you for your feedback.
Old 22nd August 2014, 21:50   #12  |  Link
foxyshadis
Angel of Night
foxyshadis's Avatar
GDrive is a bit finicky, since it uses a lot of Javascript, and the default view (grid) doesn't work for your names, since all files look like "dmmediaconverter...". You should add "#list" to your download link.
Dropbox is a great alternate location, it's easy to share whole folders once and copy whatever you want into them later.
Old 23rd August 2014, 09:56   #13  |  Link
mdalacu
mdalacu's Avatar
Great tip, i will modify the link.
Regardind Dropbox, GDrive can do the same, you don't have to specify explicit permisions for uploaded files on a shared folder. In my country i can upload to GDrive with ~9 MB/s and on Dropbox with only 800 KB/s.
Old 25th August 2014, 09:18   #14  |  Link
7ekno
Awesome app! Just had a play with the windows version and it's coming along nicely
The only thing I miss is the extra ~ 15% speed of a 64bit x264!
How difficult are 64bit versions of this sort of thing (I assume FFMPEG have a native 64 bit version)?!?
7ek
Old 25th August 2014, 10:13   #15  |  Link
mdalacu
mdalacu's Avatar
7ek
They are not but i didn't think anyone would need such a version. Is the speed benefit real or placebo?
If it is real then i would take this into consideration since on linux i already provide a 64bit version.
Thanks for suggesting this.
Old 12th September 2014, 21:16   #16  |  Link
mdalacu
mdalacu's Avatar
ANOTHER BIG RELEASE! v1.1.0
- Added Preferences in main menu. Please learn how to use Latest option because in the feature i will not ship FFmpeg anymore.
- Added Test Run.
- Now you can rearrange and remove source files.
- Metadata edit for stream and container.
- Show complete stream and container info.
- x264 and x265 extra settings field (ex. put there bluraycompat, etc)
- More output container options.
- On failure does not clear settings.
Have fun and, please, provide feedback!
Thx.
Old 16th September 2014, 11:28   #17  |  Link
mdalacu
mdalacu's Avatar
Version v1.2.0 is up, mainly bug fixing.
Old 19th September 2014, 13:53   #18  |  Link
GodRealm
Not working 2 pass mode in x265. He's working in ABR.
Other than that, the program is perfect. Good job!
GodRealm is offline   Reply With Quote
Old 19th September 2014, 14:15   #19  |  Link
mdalacu
mdalacu's Avatar
Hi, i have just tested to be sure and for me it is working ... Can you detail the problem a little bit?
Thx.
Old 19th September 2014, 15:41   #20  |  Link
GodRealm
Thx.
In Mediainfo tool appears rc: abr and no rc: 2 pass.
I'm enabling 2 pass mode. But after I finish work, I'll check with Mediainfo, is displayed information --rc as abr and not as 2 pass.
ffmpeg, frontend, gui, handbrake, linux
