Old 5th May 2021, 20:17   #741  |  Link
LeXXuz
18 years and counting...
LeXXuz's Avatar
I see. The mdgSAD=thSAD note in the script confused me a little. Thanks!
LeXXuz is offline   Reply With Quote
Old 27th May 2021, 14:53   #742  |  Link
GMJCZP
GMJCZP's Avatar
Real.finder:
Your latest version of DeHaloHmod does not contain the Camembert function (which is called internally) as if the version 2.38 I have.
By law and justice!
GMJCZP's Arsenal
GMJCZP is offline   Reply With Quote
Old 27th May 2021, 15:03   #743  |  Link
real.finder
Originally Posted by GMJCZP View Post
Real.finder:
it's moved to Zs_RF_Shared.avsi
See My Avisynth Stuff
Old 27th May 2021, 15:43   #744  |  Link
GMJCZP
GMJCZP's Avatar
Ok, thanks.
By law and justice!
GMJCZP's Arsenal
Old 30th May 2021, 17:27   #745  |  Link
Dogway
Do I need a plugin for sh_GetUserGlobalIMTint()? I don't get any output from it, not a number at least.
[i7-4790K@Stock::GTX 1070] AviSynth+ filters and mods on GitHub
Old 30th May 2021, 17:31   #746  |  Link
real.finder
see here https://forum.doom9.org/showpost.php...&postcount=574
Old 8th June 2021, 18:30   #747  |  Link
real.finder
SMDegrain now NotSMDegrain in Community tree, since Dogway back to update SMDegrain
Old 9th June 2021, 00:45   #748  |  Link
kedautinh12
Why NotSMDegrain?? I think SMDegrain2 is beautiful name. In the future if you continue development i think you need rename LSFmod to LSFmod2, grainfactorymod to grainfactorymod2
Old 9th June 2021, 10:38   #749  |  Link
real.finder
Originally Posted by kedautinh12 View Post
Why NotSMDegrain??
because it's not simple anymore
Old 26th June 2021, 20:53   #750  |  Link
Ripmann
How about SMDegrainRF (Real.Finder)?
Also, I checked for the latest available version by Dogway and it's still very old. Was it already updated somewhere else, or the update is just in plans for now? What are the expected differences between the two scripts?
Old 26th June 2021, 21:39   #751  |  Link
real.finder
NotSMDegrain will not keep it update with Dogway SMDegrain, if it do then it will be waste of efforts, the points I kept it as NotSMDegrain are since it based on very known version of Dogway SMDegrain for long time and I kinda use it for things that not Degrain, also since new Dogway SMDegrain dropped many things and only work in newer avs+
Old 28th June 2021, 19:39   #752  |  Link
LeXXuz
LeXXuz's Avatar
After playing around with SMDegrain for quite some time, I have to say that "contrasharp=true" routine does a pretty good job in retaining fine detail.
A much better one as plain LSF/mod for my taste.
So I was wondering is it possible to implement this into dfttestMC somehow?
Old 29th June 2021, 01:19   #753  |  Link
real.finder
you can use it as ContraSharpeningHD https://github.com/realfinder/AVS-St...ared.avsi#L576
but it will not act as "ContraSharpeningHD" but "ContraSharpening" HD case will need doing "global" for motion analysis mvtools things
Old 29th June 2021, 09:00   #754  |  Link
LeXXuz
LeXXuz's Avatar
Is there a way to get super, cb1 and cf1 for HD sharpening mode out of dfttestMC?
I can get HD mode to work with running SMDegrain to just get the vectors. Like:
SMDDegrain() (vectors only, added two lines to globals for cb1 and cf1, so I can leave contrasharp=false)
dfttestMC()
ContraSharpeningHD()
However, that really eats up my system memory.
Old 29th June 2021, 20:55   #755  |  Link
zorr
In the latest test version of AviSynth you could store the clips into frame properties. https://forum.doom9.org/showthread.p...05#post1946405
zorr is offline   Reply With Quote
Old 30th June 2021, 18:55   #756  |  Link
real.finder
dfttestMC()
I will think about this later. its too hot here to do anything
Old 1st July 2021, 03:26   #757  |  Link
real.finder
try https://github.com/realfinder/AVS-St...2df572436ccb75
Old 1st July 2021, 04:23   #758  |  Link
kedautinh12
Old 1st July 2021, 11:25   #759  |  Link
LeXXuz
LeXXuz's Avatar
No worries. I'm already wondering how much difference in 'quality' or even speed there might be between HD-mode and normal mode.
Old 25th July 2021, 20:44   #760  |  Link
hello_hello
real.finder,
ResizeX seems to have issues. Try this with any source and you'll see what I mean.
ResizeX(width(),height(), 100,100,0,0)
Cheers.
avisynth, avs script, avs+, banding, generator, hbd, mod
