Old 23rd July 2017, 18:35   #26301  |  Link
worknstiff
Thanks jdobbs, I must have forgotten that option. This is activated using alternate output to MKV right?
Old 23rd July 2017, 21:01   #26302  |  Link
Yes it is. Remember, only forced subtitles are hard encoded, so make sure your force them on.
Old 23rd July 2017, 21:37   #26303  |  Link
In case of selecting mkv container as the output, even if I "turn on" a subtitle stream in the stream tab by using the right mouse button, after finishing the project media info tells this stream is not forced, but normal.
Make sure you force it on just before encoding. The setting is not persistent, and other changes or closing/opening BD-RB can reset it.
Old 25th July 2017, 21:39   #26304  |  Link
AmigaFuture
AmigaFuture's Avatar
Anybody else experiencing issues with e-mail delivery of notifications related to new posts? Until today I don't think I've gotten any in over a week at least -- even though there have been plenty of posts.
I've noticed some problems with it. Like Lathe, if I don't post for a bit or don't login to read some then notifications stop. I usually keep a Firefox Tab for when it's running or Saved when exited which reloads to where I left it.
But that won't always cause new replies to send a notification.
Old 25th July 2017, 22:39   #26305  |  Link
AmigaFuture
@Lathe
First it a small g
Second, please accept this in the spirit it was meant,
That's a cute money! Looks like Gene Simmons after "eating" a very...ummmmm, unclean place with that tongue of his. With a Capital "G" and "S". ;-)
Old 26th July 2017, 03:55   #26306  |  Link
MrVideo
MrVideo's Avatar
Strangest money I've ever seen.
Old 26th July 2017, 07:33   #26307  |  Link
Lathe
Lathe's Avatar
You sharp-eyed B@stard, I missed that!
Old 26th July 2017, 21:36   #26308  |  Link
gonca
We'll type bigger next time
Old 28th July 2017, 04:58   #26309  |  Link
Lathe
Lathe's Avatar
Well... you know what they say...
The bigger the type, the smaller the...
Old 28th July 2017, 08:35   #26310  |  Link
varekai
varekai's Avatar
okeyyy...
Old 28th July 2017, 10:45   #26311  |  Link
gonca
The bigger type is just for you, so...
Old 28th July 2017, 23:49   #26312  |  Link
Lathe
Lathe's Avatar
Originally Posted by varekai View Post
okeyyy...
Heh heh...
Old 28th July 2017, 23:51   #26313  |  Link
Lathe
Lathe's Avatar
Huh uh... good try though...
Old 29th July 2017, 00:29   #26314  |  Link
gonca
We'll just call you tiny Lathe from now on
Old 29th July 2017, 01:50   #26315  |  Link
Lathe
Lathe's Avatar
Old 29th July 2017, 05:08   #26316  |  Link
meadrocks
I'm trying to do Star Wars A New Hope, HEVC, 1920x1080, Auto-AAC, movie only. It states Failed video encode, aborted. I works just fine on x264 encode.
Here's the output from Inspect.
[07/28/17] Checking System Settings
- BD-Rebuilder v0.50.24
- Windows Version: 6.1 [7601]
- Working Path Free Space: 316.44GB
- AVISYNTH Version: 2.6.0.6, Ok
- LAVFILTERS: Ok
- AnyDVD settings check: Ok.
- X264: Ok
- AFTEN: Ok
- FAAC: Ok
- MP4BOX: Ok
- WAVI: Ok
- TSMUXER: Ok
- FRIMEncode: Ok
- FRIMDecode: Ok
[07/28/17] Systems Settings Check complete
In workfiles there's a batch file called X265, I assume this is the command thats failing. I have 300 Gig free disk space.
"C:\BD_Rebuilder50.24\tools\avs2yuv.exe" "C:\DVDRIP\A_NEW_HOPE\BDMV\STREAM\00300.m2ts" -o - | "C:\BD_Rebuilder50.24\tools\x265-64.exe" - --preset medium --slow-firstpass --qpfile "C:\T1\WORKFILES\VID_00300.CHP" --keyint 240 --crf 23 --y4m --stats "C:\T1\WORKFILES\00300.m2ts.hevc.stats" --output "C:\T1\WORKFILES\00300.m2ts.hevc"
When I paste this in a shell window I get the following.
Microsoft Windows [Version 6.1.7601]
Copyright (c) 2009 Microsoft Corporation. All rights reserved.
C:\Users\ampl>"C:\BD_Rebuilder50.24\tools\avs2yuv.exe" "C:\DVDRIP\A_NEW_HOPE\BDM
infile "C:\DVDRIP\A_NEW_HOPE\BDMV\STREAM\00300.m2ts" doesn't look like an avisyn
th script
error: unexpected character "◄"
x265 [error]: unable to open input file <->
C:\Users\ampl>
What else can I give you to help debug this.
meadrocks is offline   Reply With Quote
Old 29th July 2017, 05:59   #26317  |  Link
Weird. There should be an AVS file that is used for input. Can I see the log?
Old 29th July 2017, 06:08   #26318  |  Link
meadrocks
Where is the log file?
Do you mean this info?
[Status]
LABEL=A_NEW_HOPE
VERSION=v0.50.24
SOURCE_SIZE=41562218496
SOURCE_VIDEO_SIZE=41562218496
TARGET_SIZE=4686086144
REDUCTION=.112748700949421
RESIZE_1080=0
RESIZE_1440=0
AUDIO_TO_KEEP=eng;
KEEP_HD_AUDIO=0
SUBS_TO_KEEP=all
BACKUP_MODE=1
MOVIEONLY_TYPE=33
USE_LAVF=0
INSTANCES=1
DGDECNV=0
DGDECIM=0
FRIMSOURCE=0
FFMS2=0
SSIF_MODE=0
QUICK=0
ENCODE_STEP=1.5
[00300]
AUDIO=1000000
PGS=100000000000000000000000000001
APULLDOWN=0
S1440=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=91066718
Old 29th July 2017, 16:35   #26319  |  Link
No. It's what shows in the window while the job is running. It is also saved in the file BD-REBUILDER.LOG in the working folder. It's a simple text file that can be opened with NOTEPAD.
Old 29th July 2017, 16:47   #26320  |  Link
meadrocks
[07/28/17] BD Rebuilder v0.50.24
[21:22:10] Source: A_NEW_HOPE_00800
- Input BD size: 38.71 GB
- Approximate total content: [02:04:44.727]
- Mode: MKV Container, HEVC 1920x1080, Auto-AAC
- Quality: High Quality (Default)
[21:22:10] PHASE ONE, Encoding
- [21:22:10] Processing: VID_00300 (1 of 2)
- [21:22:10] Extracting A/V streams [VID_00300]
- [21:31:47] Reencoding video [VID_00300]
- Rate/Length: 23.976fps, 3,522 frames
- [21:31:48] Reencoding: VID_00300, Pass 1 of 1
[21:31:56] - Failed video encode, aborted
Its just a handful of movies that fail, Star Wars 4, 5, 6, John Wick Ch2, Hacksaw Ridge are a few.
