Old 21st May 2015, 18:16   #201  |  Link
Washka
Washka's Avatar
With Latest beta: StaxRip x64 1.3.1.3 beta (2015-05-21) I got problems with all *.mkv files. I upload encoded sample. Any other version have no this problem. Mp4 have no problems.
I upload sample video to dropbox, audio is Just Mux since it`s ac3.
https://www.dropbox.com/s/1e5ch01jy8...axRip.log?dl=0
https://www.dropbox.com/s/4ggq0kgrgd...ample.mkv?dl=0
First one second is double than audio is not in sync.
Washka is offline   Reply With Quote
Old 21st May 2015, 18:19   #202  |  Link
Havokdan
Havokdan's Avatar
StaxRip x64 have support for TextSub/Vobsub plugin? I dont see in filtters.
Havokdan is offline   Reply With Quote
Old 21st May 2015, 18:35   #203  |  Link
burfadel
Also remember you can still use Nero or FDK AAC.
I was thinking that exactly!
When it doesn't work, it doesn't work consistently, but when it does work it works consistently between encodes. Since the audio encoding happens first, I think I'll just start it again until it works! It's obviously something very minor, I just can't pinpoint what it is. I'm heavily suspecting it's a new bug, I guess that's expected on a beta OS.
Old 21st May 2015, 18:44   #204  |  Link
stax76
stax76's Avatar
I made test where everything worked as usual, the frame rate detection was changed, when you double click the filters you can see StaxRip added AssumeFPS because ffmpeg returns often values that cause problems, maybe it has something to do with this. Maybe I can find something if you post a source clip and log file.
I first removed the plugin and code but later found a x64 version so I re-added the plugin and code, I've not used it recently but believe it should work
Old 21st May 2015, 19:08   #205  |  Link
Havokdan
Havokdan's Avatar
Old 21st May 2015, 21:09   #206  |  Link
luigizaninoni
Remember the three issues with .ts ?:
1-slowing down
2-MT crashing
3- 64-bit plugins missing
Issue n.1 imo is solved:
Instead of FFVideoSource use DSS2mod. Speed is steady throughout the encode. Be very liberal in "cache" and "preroll" parameters. Demux with dsmux. Works with QTGMC, both interlaced and progressive mode.
If it does not saturate CPU, you can run 2 parallel encodes without problems.
Tried also MT, but with filter mode 3 does not even start. With modes 1 and 2 it starts but crashed after a few seconds.
Anyway n.2 is partially solved, given that you can use FrimSource for Qtgmc progressive (not for interlaced, unfortunately.)
N.3 still stands.
luigizaninoni is offline   Reply With Quote
Old 22nd May 2015, 03:40   #207  |  Link
jkilez
Using the new 1.3.1.3 beta, I am getting 7 frames (300ms) of blank video added to the beginning of encoded videos causing audio sync issues. Actually the framecount stays correct (it cuts 300ms at the end), so the problem is more that the video is offset by 300ms. So far I have only had a chance to check this with an AVC source. The problem does not appear when previewing, only in the final encodes and happens regardless of output (1-pass/2-pass, Xvid/x264, AVI/MKV, AC3/MP3/None).
The problem appears to be with the ffms2 indexer that was updated. If I replace the /Apps/Plugins/ffms2 directory with the version that came with 1.3.1.0, there is no delay.
ETA: Just compared encodes from an MPEG-2 (DVD) source:
1.1.9.0 = 0 extra frames
1.3.1.0 = 0 extra frames
1.3.1.3 = 2 extra frames
jkilez is offline   Reply With Quote
Old 22nd May 2015, 09:40   #208  |  Link
Washka
Washka's Avatar
Got same problems. I write about that at Post #201
Old 22nd May 2015, 10:12   #209  |  Link
stax76
stax76's Avatar
Until the problem is solved I suggest using LWLibavVideoSource instead, go to:
Tools > Settings > Source Filters
Replace FFVideoSource every where with LWLibavVideoSource.
Old 22nd May 2015, 12:25   #210  |  Link
burfadel
Just giving feedback on the issue I was having with QAAC. Seems to be resolved now. I did all the stuff you shouldn't need to do (in-depth maintenance and repair stuff related), and it seems to work. Not sure what fixed it, and as long as it works reliably I don't care now ! It appears it wasn't a 100 percent successful transition from build 10074 --> 10122. I guess you should expect things to possibly get muffed, but not sure how going from Windows 7 and 8.1 will be like. Microsoft really needs that to be effectively, 100 percent reliable.
Old 22nd May 2015, 23:17   #211  |  Link
jkilez
Hello everybody,
I was working on a couple of improvements and uploaded a new beta. I still like GUI programming so I improved the AviSynth editor a lot.
I'm pausing StaxRip now again for a while but don't worry, I'll be back and catch up with unanswered questions.
  • Added Decomb x64 plugin
  • Greatly improved AviSynth editor
Thanks for the editor improvements--it is much more usable now.
One quick GUI bug...
Opening the log file for the current project using the menu item Tools->Files->Log File does not work as it is using the wrong file name "%source_name%_StaxRip.log" vs "%target_name%_StaxRip.log".
ETA: Another little bug...
When editing the "XviD 2 pass" encoder profile through "Edit Profiles..." section, it brings up a window listing "Codec Configuration", "Run Compressibility Check", and "Container Configuration" options. The "Codec Configuration" option brings me right to the "Batch Encoder" editing page as expected, but the "Run Compressibility Check" option just runs the compressibility check (if there is one defined) instead of taking me to the edit page.
Old 23rd May 2015, 21:52   #212  |  Link
Patman
Patman's Avatar
Got the same problem. Every mkv file is async. Damn...
Edit1: Run test with updated ffms2... will report later...
Edit2: I've tested two encodes with the new ffms2 2.22 rc1. There were no async in mkv-files anymore... I'll test some other files...
Edit3: With ffms2 2.22 rc1 mkv-files still minimal async... go back to ffms2 2.20... Hope for solution
Patman is offline   Reply With Quote
Old 23rd May 2015, 23:43   #213  |  Link
stax76
stax76's Avatar
I noticed it too today, ffms2 2.20 is fine, the issue was introduced with 2.21, it's also fine to use LWLibavVideoSource: Tools > Settings > Source Filters
Old 25th May 2015, 00:07   #214  |  Link
jkilez
Another bug: The "Options->Misc->Auto Forced Film Threshold (Percent)" is not being honored. MPEG-2 (DVD) sources with a DGIndex "Video Type" of between 95% and 99% Film are listed with a frame rate of 29.97 when they should be 23.976. The same sources work properly in 1.1.9.0.
Old 25th May 2015, 10:13   #215  |  Link
stax76
stax76's Avatar
StaxRip x86 modifies the d2v file for this. With DGDecode x64 there are problems on Win10, on Win7 probably too so it's not used until somebody fixes it.
Both ffms2 and L-Smash-Works have a parameter dealing with NTSC, I can add the parameter to the filter profiles but I don't know yet if it can be automated to set the parameter. I admit I'm pretty clueless about NTSC so how well NTSC is supported depends much on the quality of the feedback I get for it.
Old 25th May 2015, 14:56   #216  |  Link
Anakunda
HI STAX
Trying to load demuxed project into latest beta (.dgi + .h264 file). On source open I get error System eception - Accesss Violation, H:\video\(workset)\test\encode_Source.avs, line 2)
encode_Source.avs is
LoadPlugin("D:\media\DGDecNV\x64 Binaries\DGDecodeNV.dll")
DGSource("H:\video\(workset)\test\source.dgi")
source.dgi is correctly referring to source.h264
What's wrong?
avisynth.dll in C:\Windows\System32\ is version: AviSynth+ 0.1 (r1825, MT, x86_64)
Anakunda is offline   Reply With Quote
Old 25th May 2015, 16:21   #217  |  Link
stax76
stax76's Avatar
There was a problem with DGDecodeNV x64, a new build of DGDecNV was uploaded addressing this problem, it will work if you re-download DGDecNV.
Old 25th May 2015, 16:27   #218  |  Link
Anakunda
Which build? 2047? I already have it.
+ I can't find DGIndexIM anywhere, all links in doom9 thread seem dead, a working mirror?
Old 25th May 2015, 16:38   #219  |  Link
Groucho2004
2049, Link here. 2047 is ancient.
Groucho's Avisynth Stuff
Old 25th May 2015, 16:39   #220  |  Link
Groucho2004
Probably from here.
