Old 16th February 2018, 15:21   #27041  |  Link
Originally Posted by staina View Post
In Windows 10 don't go choose item
Use DirectshoeSource for frame serving
where make mistakes? Help thank you Staina
You have to install LAV Filters for Directshow to be available. See step 2A in the first post of this thread.
Old 18th February 2018, 18:32   #27042  |  Link
Update: I believe I've gotten past the sync issues on UHD-BD backups. I'll know after a couple of full encodes (10-18 hours each). It turns out it was poor attention to detail on my part. I went back and started over, testing every type of encoding sequence -- only to be perplexed when an AVISYNTH encode was in-sync. Apparently I'd done something in my first go-around that made me think it was out of sync also. That pointed to FFMPEG -- and I discovered it was an error in the way I used "-r " in the command line. It looks like a lot of time was wasted on this one due to my own mistakes... but I'll know for certain after this next round of encodes is done.
With a little luck I will be able to post a UHD-BD test version some time this week.
Old 18th February 2018, 20:44   #27043  |  Link
Lathe
Lathe's Avatar
Thanks Boss!
Old 18th February 2018, 21:50   #27044  |  Link
kufo
kufo's Avatar
Glad to her this. Little mistake, big impact. I really want to know, what your new encode will bring.
kufo is offline   Reply With Quote
Old 18th February 2018, 21:52   #27045  |  Link
Ch3vr0n
I'd love to see NVEnc support Hardware decoding and encoding for 3D discs ^^
Old 18th February 2018, 22:01   #27046  |  Link
drmih
If using LAV will it be possible to get the CUDA acceleration using GPU as I'm not sure I want to go back to 1 day encodes?
Old 18th February 2018, 23:03   #27047  |  Link
kufo
kufo's Avatar
A one day encode is even better, than a fault. We all have to do some testing when the new version will ne introduced.
Old 19th February 2018, 02:55   #27048  |  Link
Yes, for frame serving. You can tell LAV to use it in the Video Configuration dialog.
Old 19th February 2018, 02:57   #27049  |  Link
I added a test mode that limits any M2TS to the first 10 minutes so testing can be done without the huge time investment.
Old 19th February 2018, 03:09   #27050  |  Link
I haven't been following NVEnc, since my NVIDIA video card is older. How do you use it now? Via FFMPEG?
Old 19th February 2018, 03:44   #27051  |  Link
gonca
I believe it can be used thru ffmpeg or by NVEncC, a command line app by rigaya
Old 19th February 2018, 12:04   #27052  |  Link
Ch3vr0n
Via CloneBD from elby for my 2d discs. Bdrb is still my go-to for 3d ones but with software encoding it still takes up to half a day. HW enc would cut that down significantly
For comparison
On my new current rig a BD50 to bd25 2d takes around 4-6hrs with bdrb. NVenc with CloneBD does that in 15min's with my GTX 1080.
Sent from my Nexus 6P with Tapatalk
Old 19th February 2018, 12:55   #27053  |  Link
gonca
@Ch3vr0n
Doesn't CloneBD use FFMPEG in the background?
Old 19th February 2018, 14:56   #27054  |  Link
DrinkLyeAndDie
DrinkLyeAndDie's Avatar
@Ch3vr0n
Depending on where you look you'll see it stated that CloneBD is powered by libav or ffmpeg. Elaborate Bytes' page on the product says libav. RedFox's page say ffmpeg. Looking in the application forlder you'll see "drone" files related to both.
DrinkLyeAndDie is offline   Reply With Quote
Old 19th February 2018, 15:00   #27055  |  Link
Ch3vr0n
Oh I know, it's just that under video settings encoding and decoding is done by hardware (though I believe it says 'cuda' in settings instead of the newer NVEnc) .
Old 19th February 2018, 15:05   #27056  |  Link
For comparison
Is the GTX 1080 a Maxwell GPU? The NVEnc writeup I saw says you need Maxwell for H.265 encoding.
Old 19th February 2018, 15:13   #27057  |  Link
gonca
GTX 10-series cards are Pascal GPUs, so they are good for 10 bit HEVC encoding
Old 19th February 2018, 15:56   #27058  |  Link
Ahhh... I wasn't thinking. I guess I misread and it is a minimum of maxwell (I just haven't been keeping up on this stuff). Has anyone tested a GTX 1050? Is it good enough for HEVC encoding? Any minimum amount of memory? I'm thinking about upgrading -- but I need to keep my cost down.
Does the 10 series encodes support B frames when HEVC encoding? Some reading I saw seems to imply it doesn't.
Old 19th February 2018, 16:54   #27059  |  Link
Ch3vr0n
Plenty people use the 1050 in combination with clbd. Though I'd recommend perhaps posting on the RedFox forum section for clbd and tag Pete for the b-frames. He's pretty knowledgeable in that area.
The memory doesn't matter that much I believe, it's the 'cuda/NVEnc' cores that matter that determines the speed.
So if I could wish for 1 thing with bdrb it's HW accelerated de-/encoding.
Old 19th February 2018, 17:43   #27060  |  Link
gonca
No
But if compression is to BD25 it is pretty good, your eyes are the final answer on that
Edit
I can take a 2 hour+ (70GB +) movie using AC3 640 Kbps audio to 15 or 16 GB file
The extra bit rate given to the movie should make it good for normal viewing
Advantage is encode in about 30 to 40 minutes with my settings
