Old 10th May 2018, 17:37   #4041  |  Link
bxyhxyh
I found a bug, when I was trying to minimize rounding errors of resize.blur.blur.blur.resize.sharpen.sharpen.sharpen.sharpen kind of script.
source
source.Spline16Resize(512,384)
source.ConvertTo16bit().Spline16Resize(512,384).ConvertTo8bit()
All resizers and all target resolutions are the same.
bxyhxyh is offline
Old 10th May 2018, 17:53   #4042  |  Link
poisondeathray
I get different results than you. They are the same (or very similar) for me. What version of avisynth+?
poisondeathray is offline
Old 10th May 2018, 17:57   #4043  |  Link
bxyhxyh
Avisynth+ 0.1 r2636.
Ok I checked the release page. It was 2664.
I'm gonna see that.
bxyhxyh is offline
Old 10th May 2018, 17:59   #4044  |  Link
poisondeathray
Try updating?
I'm using r2664 x64
Old 10th May 2018, 18:05   #4045  |  Link
bxyhxyh
Ok. Checked it, it was the same for r2664 x86. Maybe something might be wrong with my end.
I'll try full installer.
bxyhxyh is offline
Old 10th May 2018, 18:06   #4046  |  Link
poisondeathray
The other difference is x86 vs x64 ?
Old 10th May 2018, 18:26   #4047  |  Link
bxyhxyh
Switched to x64 version, still same.
Updated all in one microsoft redistributable, no change.
bxyhxyh is offline
Old 10th May 2018, 22:39   #4048  |  Link
poisondeathray
can you confirm with version() ?
Old 10th May 2018, 23:07   #4049  |  Link
Groucho2004
I can reproduce it. Adding a simple "ConvertToYV12()" (or YV16/YV24) after the source filter (I used "ImageSource()") fixes it.
Groucho's Avisynth Stuff
Groucho2004 is offline
Old 10th May 2018, 23:18   #4050  |  Link
poisondeathray
But that's a problem...
I used ImageSource() too , and it returns RGB24 on the source PNG (as expected)
And I can't reproduce it in RGB24, or YV12, or YV16, or YV24
Old 10th May 2018, 23:26   #4051  |  Link
bxyhxyh
Same for me too.
But I need to convert it to YV24/YV12 after the resizing, so it's really problematic for me.
Well, I can live with converting the source to the YV24 for now I guess.
BTW I'm on Windows 8.1
bxyhxyh is offline
Old 11th May 2018, 00:30   #4052  |  Link
poisondeathray
I'm on Win8.1 too . Haswell (only AVX2) ; maybe some instruction issue ? what CPU ?
What about ConvertTo16Bit only ? or ConvertTo16Bit and the resize only (RGB48) ?
Old 11th May 2018, 00:44   #4053  |  Link
poisondeathray
Or use avsresize (zimg/z.lib) as a workaround
But I'm curious why I can't reproduce bug
ConvertToPlanarRGB()
z_ConvertFormat(512,384,resample_filter="spline16",pixel_type="RGBP16")
Old 11th May 2018, 00:53   #4054  |  Link
bxyhxyh
ConvertTo16Bit and the resize only. Even if I insert some filters before resize, it still is the same.
CPU is Ivy Bridge
bxyhxyh is offline
Old 11th May 2018, 07:57   #4055  |  Link
pinterf
I'll check it soon
EDIT: cannot reproduce. Tested with AVX2, AVX-only, SSE4.1 only builds. (Win10)
Function Diff(clip src1, clip src2)
  return Subtract(src1.ConvertBits(8),src2.ConvertBits(8)).Levels(120, 1, 255-120, 0, 255, coring=false)
source=ImageSource("test.png").Info().trim(0, 100) # 256x224 RGB24
c8=source.Spline16Resize(512,384)
c16=source.ConvertTo16Bit().Spline16Resize(512,384).ConvertTo8Bit()
StackVertical(c8,c16,Diff(c8,c16))
pinterf is offline
Old 11th May 2018, 10:09   #4056  |  Link
Groucho2004
I tested again with this script:
imagesource("3ZWGafM.png", pixel_type = "RGBXX") #XX to be substituted with 24/32/48/64
The resulting image is corrupted for RGB32 and RGB64 but looks fine for RGB24 and RGB48, tested with r2664 and pinterf's test build r2671 on XP32 (no AVX optimization).
Old 11th May 2018, 10:22   #4057  |  Link
tormento
Acid fr0g
tormento's Avatar
Can we play with it too?
@turment on Telegram
tormento is offline
Old 11th May 2018, 10:32   #4058  |  Link
Groucho2004
I suppose pinterf won't object:
http://www.mediafire.com/file/kmq3po...us_r2671tst.7z
Old 11th May 2018, 10:45   #4059  |  Link
pinterf
Ahh, RGB32. Reproduced.
EDIT: RGB64 Turnleft / Turnright issue (which is used in RGB64 resize)
EDIT2: Bug found and fixed. I'll prepare a release in the near future.
pinterf is offline
Old 11th May 2018, 14:21   #4060  |  Link
pinterf
x86 test (mediafire link) (not a release)
(see also readme_history.txt for other interesting changes)
http://www.mediafire.com/file/een9bf...r2671_test2.7z
pinterf is offline
