3rd July 2007, 00:55 | #1 | Link |
RipBot264 v1.18.3 - Simple and easy to use GUI -> IPOD . PSP . CONSOLES . BLURAY
This small app written in Delphi is specially for people looking for something simple without exotic filters and unnecessary settings.
Download .7z -> https://www.mediafire.com/file/z0p8i...1.26.0.7z/file . . . Changelog Code:
v1.26.0 Added: Work Hours (automatic encoding within selected hours) Added: Automatic track name extraction Added: VP9 decoding Changed: Script won't be re-analyzed if there was no change Changed: Multiple jobs can be now removed at once Fixed: Correct colorimetry for DVD sources (ntsc->smpte170m,pal->bt470bg) Fixed: --ctu,--mrange,--min-keyint,--keyint switches won't be automatically inserted to command line if user specified own values for those options Fixed: Output speed option not working correctly with FLAC files Fixed: Typo in encoding command line if "Use Fast First Pass in 2-pass mode" was unchecked [FULL LOG] Last edited by Atak_Snajpera; 3rd January 2021 at 17:47. |
3rd July 2007, 02:32 | #2 | Link |
н∂-αиαтι’
^ nice going mate!
will check it out as i need to do a few vids for ps3. just noticed, u must have ffdshow? i don't really want to install ffdshow as i prefer separate codecs. any way around this? EDIT: just tried it on a lil sample, i wasn't asked to install ffdshow, just started the process. very easy prog to use! Last edited by ~bT~; 3rd July 2007 at 02:51. |
3rd July 2007, 10:54 | #3 | Link |
Very nice GUI,easy to use.
Why not making the first pass faster,like this: Code:
x264.exe --pass 1 --bitrate 800 --stats ".stats" --bframes 3 --filter 0,0 --subme 1 --analyse none --vbv-maxrate 25000 --me dia --thread-input --progress --no-psnr --no-ssim --aq-strength 0 --aq-sensitivity 0 --output NUL "hh.avs" @echo+ x264.exe --pass 2 --bitrate 800 --stats ".stats" --ref 3 --mixed-refs --bframes 3 --subme 5 --b-pyramid --bime --weightb --filter 0,0 --analyse all --8x8dct --vbv-maxrate 25000 --thread-input --progress --no-psnr --no-ssim --aq-strength 0 --aq-sensitivity 0 --output "hh.mkv" "hh.avs" Last edited by Jerry_Sm@rt; 3rd July 2007 at 11:05. |
3rd July 2007, 11:11 | #4 | Link | |||
Jerry_Sm@rt: Quote:
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 3rd July 2007 at 11:25. |
3rd July 2007, 13:59 | #6 | Link |
@Atak_Snajpera
Maybe some psnr loss,but I really can not tell the differences between a fast 1st pass encoded movie and a normal 1st pass encoded movie(same bitrate).If I got a faster cpu, I would not care about it. What's your psp version?3.5?I'm still running 2.71se |
3rd July 2007, 14:10 | #7 | Link |
At the moment my PSP version is still 3.50 but in few days when my Lumines game arrives I will switch to 3.40 OE-A
3rd July 2007, 16:25 | #8 | Link | |
н∂-αиαтι’
EDIT: Those keys are still there. Last edited by ~bT~; 3rd July 2007 at 16:29. |
3rd July 2007, 20:15 | #9 | Link |
Ripbot264 fail to open any supported format & display an error message : '25.0000' is not a valid floating point value. Even if try to open NTSC file ('29.9700' is not.... in this case)
Avisynth v2.57, HaliMediaSpliter, FFdshow & .Net runtime v2.0 are installed properly (i'm using other GUIs with no problems) |
3rd July 2007, 20:36 | #11 | Link |
Problem with decimal symbol has been fixed in new version (v.1.0.1)
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 4th July 2007 at 00:01. |
4th July 2007, 01:21 | #12 | Link |
1- Not all of us are using the MT version of Avisynth, so why do you put SetMode(2) to the script when Deinterlace is activated ?! with official version, your script fail.
2- Tdeint don't give the optimal result with mthreshL=0. In most cases, Tdeint( order=0 or 1, full=false) can produce a good picture (this is my personal opinion). 2- The PC Profile is very slow (i don't try the 2 others), can you add a "balanced" profile. Keep the good work. |
4th July 2007, 02:20 | #14 | Link | |||
http://forum.doom9.org/showthread.php?t=127423 http://forum.doom9.org/showthread.ph...99#post1003599 Quote:
Windows 7 Image Updater - SkyLake\KabyLake\CoffeLake\Ryzen Threadripper Last edited by Atak_Snajpera; 4th July 2007 at 02:30. |
4th July 2007, 10:18 | #17 | Link |
This is one of the prettiest apps I've ever seen! Amazing interface look.
And it just worked w/o problems first time I tried it. Firrst off I think it really needs user-customizable profiles. I think everyone here has some favourite switches and would like to tweak an option or two... However, I like your simple design and minimalistic look very much and would hate to see it bloated and cluttered in any way. It would be great if you could keep this simple elegant feel while adding new options. |
4th July 2007, 15:54 | #18 | Link | ||
4th July 2007, 19:08 | #20 | Link |
OK! I respect your opinion. Custom profiles are under construction. It will take probably few days to implement and testing.
