Old 30th January 2018, 17:49   #15481  |  Link
Wishbringer
Silent Reader
Wishbringer's Avatar
Originally Posted by Waytoogo View Post
Will you please try your latest versions on windows 10. Version 1.20 works fine, but 1.21 and 1.22 refuse to encode mpeg2 video on any windows 10 machine. All I get is green video.
You get green video in Preview.
I imported MPEG2 Videostream from DVD with mkvtoolnix and then imported mkv in RB264.
Now preview works with RB... Silly
Wishbringer is offline   Reply With Quote
Old 30th January 2018, 21:12   #15482  |  Link
Originally Posted by Wishbringer View Post
@Atak_Snajpera:
I have a strange problem since some encodes.
Muxing fails, because there is no audio file.
This happens each time I encode to *.mp4 and AAC-Codec, regardless of source.
When encoding to *.mkv with other codecs, all is fine.
BUT!
While encoding, AAC-File is created.
And while RB still encodes Video, AAC (ready encoded) still exists and can be played without issues.
After muxing (with error) there is no AAC-File anymore.
So it must be deleted after encoding of audio and before shutdown (after job is finished).
Last encode I enabled write-protection after AAC-encode finished and this time muxing completed without errors.
I haven't changed anything at running system except automated CU of Windows10.
Other possible cause could be update of RB.
Edit:
Now am encoding a film with dtsma (preconverted to flac with ripbot) and destination mp4 with aac:
flac-file is there and plays fine, but this time no aac is created, no aac-encoding task in taskmanager.
Works on my "antique" windows 7 as always
C:\>"C:\Users\Dave\Documents\Delphi_Projects\RipBot264\_Compiled\Tools\ffmpeg\bin\ffmpeg.exe" -loglevel panic -i "C:\Temp\RipBot264temp\job1\job1.avs" -strict -1 -f yuv4mpegpipe -   | "C:\Users\Dave\Documents\Delphi_Projects\RipBot264\_Compiled\tools\x264\x264_x64.exe" --colorprim bt709 --transfer bt709 --colormatrix bt709  --crf 20 --fps 24000/1001 --force-cfr  --min-keyint 24 --keyint 240 --frames 5805 --sar 1:1 --level 4.0 --aud --nal-hrd vbr --vbv-bufsize 25000 --vbv-maxrate 25000 --b-pyramid none --stdin y4m --output "C:\Temp\RipBot264temp\video.264" -
y4m [info]: 624x464p 1:1 @ 24000/1001 fps (cfr)
x264 [info]: using SAR=1/1
x264 [info]: using cpu capabilities: MMX2 SSE2Fast SSSE3 SSE4.2 AVX
x264 [info]: profile High, level 4.0
x264 [info]: frame I:81    Avg QP:18.09  size: 23030
x264 [info]: frame P:2370  Avg QP:21.50  size: 12950
x264 [info]: frame B:3354  Avg QP:24.14  size:  6067
x264 [info]: consecutive B-frames:  5.3% 36.7% 49.3%  8.8%
x264 [info]: mb I  I16..4: 11.7% 83.1%  5.1%
x264 [info]: mb P  I16..4:  4.6% 37.9%  2.1%  P16..4: 28.4% 16.1%  7.2%  0.0%  0.0%    skip: 3.6%
x264 [info]: mb B  I16..4:  0.9%  6.7%  0.5%  B16..8: 45.1% 10.5%  2.3%  direct: 8.3%  skip:25.9%  L0:32.8% L1:39.5% BI:27.7%
x264 [info]: 8x8 transform intra:84.4% inter:80.3%
x264 [info]: coded y,uvDC,uvAC intra: 71.4% 88.5% 37.3% inter: 34.9% 38.0% 1.3%
x264 [info]: i16 v,h,dc,p: 33% 23% 15% 28%
x264 [info]: i8 v,h,dc,ddl,ddr,vr,hd,vl,hu: 26% 21% 27%  3%  4%  5%  4%  5%  4%
x264 [info]: i4 v,h,dc,ddl,ddr,vr,hd,vl,hu: 26% 13% 12%  6% 10% 12%  7%  8%  5%
x264 [info]: i8c dc,h,v,p: 39% 22% 23% 16%
x264 [info]: Weighted P-Frames: Y:4.9% UV:4.1%
x264 [info]: ref P L0: 68.9% 17.7%  9.4%  3.9%  0.2%
x264 [info]: ref B L0: 93.1%  6.9%
x264 [info]: kb/s:1748.09
encoded 5805 frames, 219.67 fps, 1748.09 kb/s
C:\>"C:\Users\Dave\Documents\Delphi_Projects\RipBot264\_Compiled\tools\mp4box\mp4box.exe" -tmp "C:\Temp\RipBot264temp"  -add "C:\Temp\RipBot264temp\video.264":name="snoop dogg - sensual seduction" -fps 23.976 -add "C:\Temp\RipBot264temp\job1\Encoded_Audio_1.aac":lang=und -mpeg4  -new "C:\Users\Dave\Desktop\snoop dogg - sensual seduction.mp4"
AVC-H264 import - frame size 624 x 464 at 23.976 FPS
AVC Import results: 5805 samples - Slices: 81 I 2370 P 3354 B - 5883 SEI - 77 IDR
Stream uses forward prediction - stream CTS offset: 2 frames
AAC import  - sample rate 48000 - MPEG-4 audio - 2 channels
Saving C:\Users\Dave\Desktop\snoop dogg - sensual seduction.mp4: 0.500 secs Interleaving
Elapsed Time: 00h:00m:28s
Old 30th January 2018, 21:17   #15483  |  Link
jlpsvk
Guys...turn off UAC completely in Windows 10 in the registry!!!! The first MUST DO THING after W10 installation. Check that...can cause problems.
jlpsvk is offline   Reply With Quote
Old 31st January 2018, 10:14   #15484  |  Link
Wishbringer
Silent Reader
@jlpsvk:
Thats not the cause.
disabled = same behavior
started as admin = same behavior
Old 1st February 2018, 18:06   #15485  |  Link
Wishbringer
Silent Reader
@Atak_Snajpera:
While searching for the cause of not created audio I just disabled "normalize".
Now audio is created and muxed.
Old 1st February 2018, 19:03   #15486  |  Link
Add pause to job1_EncodeAudio1.cmd and run it. Show me what you get. Maybe my script does not like your german version of windows.
Old 1st February 2018, 20:21   #15487  |  Link
jlpsvk
@Atak_Snajpera
Three things I would like you to implement....
1) option to have "Force HDR->SDR to HEVC" "per job" not globally
2) option not to demux audio files when creating jobs - time consuming in case I want to use only video part...
3) when distributed encoding is enabled, video file indexing is done twice.. once when creating the job, once when starting encode, after copying the video file to shared directory...this is also time consuming, when using with 120GB 4K video file... indexing only after copying to shared folder makes sense to me.
Can't wait for you reply.
Old 1st February 2018, 20:34   #15488  |  Link
I can do only 1) for now and maybe 2) if I will have nothing to do in my spare time...
Old 1st February 2018, 21:23   #15489  |  Link
jlpsvk
Even 1) will be great.
Old 1st February 2018, 21:34   #15490  |  Link
Question: Why do you encode some movies as HDR and some as SDR?
Old 1st February 2018, 22:08   #15491  |  Link
jlpsvk
I want to do both..because some family members do not have HDR TV but have 4K (first models)...so i want to put it in one queue, not to do one, re-set settings and do other.
Old 2nd February 2018, 05:22   #15492  |  Link
burt123
burt123's Avatar
You need more computers , each dedicated to different settings.
burt123 is offline   Reply With Quote
Old 2nd February 2018, 12:30   #15493  |  Link
So you what to do two encodes in one job? That's impossible!
I still think that current global method is easier. You create jobs. Encode in HDR mode. Then enable HDR to SDR conversion. Jobs are refreshed. Encode again.
Is this too much???
Old 2nd February 2018, 12:32   #15494  |  Link
jlpsvk
In one queue, not in one job!
Right now the setting is global. So all queued jobs will be encoded in HDR or all in SDR. I want to have more jobs, but one job HDR, one SDR.
Old 2nd February 2018, 14:11   #15495  |  Link
But you do realize that you will have to create two jobs for the same movie? Isn't this more time consuming method?
Old 2nd February 2018, 14:21   #15496  |  Link
jlpsvk
yeah...but then i can run about 10 jobs in one run, and cores will not be idling.
Old 5th February 2018, 19:38   #15497  |  Link
Wishbringer
Silent Reader
pause
cd "E:\RipBot264v1.22.1\tools\ffmpeg\bin\"
pause
del "D:\Temp\RipBot264temp\job1\AUDIO1_max_volume.txt"
pause
ffmpeg.exe -i "D:\Temp\RipBot264temp\job1\job1_AUDIO1.avs" -af "volumedetect" -vn -sn -dn -f null nul 2>&1 | findstr /I "max_volume:" | awk.exe -F": " "{print $2}" | cut.exe -d" " -f1 >> "D:\Temp\RipBot264temp\job1\AUDIO1_max_volume.txt"
pause
for /f "delims=" %%x in (D:\Temp\RipBot264temp\job1\AUDIO1_max_volume.txt) do set VAR=%%x
pause
set VAR=%VAR:-=%
pause
ffmpeg.exe -i "D:\Temp\RipBot264temp\job1\job1_AUDIO1.avs" -af "volume=%VAR%dB" -f wav - | "E:\RipBot264v1.22.1\Tools\fhgaacenc\fhgaacenc.exe" --profile lc --cbr 320 --adts --ignorelength --quiet - "D:\Temp\RipBot264temp\job1\Encoded_Audio_1.aac"
pause
I added a pause each line, because when adding pause at the end, the window closed instant.
When first ffmpeg is tried to execute, dos-window closes without a comment.
Only happens when normalize is "ON".
Old 5th February 2018, 20:27   #15498  |  Link
Do something else. Start CMD.exe and then run job1_EncodeAudio1.cmd from console.
Ps. Do not add any pauses!
Old 6th February 2018, 11:45   #15499  |  Link
GZZ
There is a bug in the encoding server. If you have two or more instance open and need to close one of them or one of them crash, then closing it or killing it in task manager will raise a access violation error in the other encoding server and make them both crash.
GZZ is offline   Reply With Quote
Old 6th February 2018, 11:54   #15500  |  Link
Known bug since forever. Unfixable for now.
Fun fact: It crashes other servers only if server has lower port number
For example. You have two servers :1000 and :2000. Closing server with port 2000 will crash server below. However if you close server with port 1000 then server with higher port number does not crash. Mind blown!
