Old 27th September 2018, 19:13   #27781  |  Link
spotswood
Windows 10 error
The first error has nothing to do with BD Rebuilder, since it isn't using the installer.
Did you run the .BAT file as administrator? Also, make sure you are running it from within that folder.
Yes, ran as Administrator from the BDRB folder, sorry I didn't specify above, post updated...
Originally Posted by Mark_Venture View Post
@spotswood its outlined in step 3.1 in the OP instructions...
But to be honest, when I right click on the bat file and select "run as admin", It seems to fail because it always seems to try and run from C:\windows\system32 instead of the BD Rebuilder folder so it fails (because the OCX isn't in the win\system32 folder).
So its probably better to open an Administrative CMD prompt (Start -> Windows System -> right click on CMD Prompt -> More -> Run As Administrator)... When it launches, while in the window change to the BD-Rebuilder directory, and run the batch file from there (that is where the BAT file and the OCX file reside).... OR edit the BAT file, specify the path to the OCX file... then save/run it.
Thanks for the tip, edited the .bat file, ran as administrator and success. All good now, thanks guys... ;^)
spotswood is offline   Reply With Quote
Old 27th September 2018, 19:24   #27782  |  Link
ggtop
Hi jdobbs,
thank you for the new version. Just installed and it reports itself as v0.60.01 as per INI:
[Options]
VERSION=0.60.0.1
Old 27th September 2018, 22:22   #27783  |  Link
Ch3vr0n
Update, even with software encoding the glitching is still present @jdobbs. So it looks like it didn't work (at least not for me), think it can be safely removed again in the next build. Considering i was the only one even persisting in finding a possible cause for this and a possible solution. Thanks for trying anyway!
Old 28th September 2018, 00:32   #27784  |  Link
Originally Posted by Ch3vr0n View Post
@jdobbs just a heads-up, SPECIAL_3D_MUX isn't documented in changes.txt
- Added a new hidden option SPECIAL_3D_MUX.
  If set to 1 the TSMUXER parameters for
  "insertSEI" and "contSPS" are excluded
  from the video command line in the meta
  file.  Some have reported that this fixes
  pixelation that has been experienced.
This is from changes.txt
Old 28th September 2018, 00:34   #27785  |  Link
Originally Posted by ggtop View Post
Hi jdobbs,
[Options]
VERSION=0.60.0.1
My mistake. I forgot to update the system version number for the compile, but the text labels (such as the form header and the help dialog) should be correct.
Old 28th September 2018, 00:39   #27786  |  Link
Good news. I'll file that one for future reports.
Old 28th September 2018, 00:40   #27787  |  Link
Thanks for the report. I'll remove that option in the next release. Too bad. It would have been good to kill it.
Old 28th September 2018, 04:28   #27788  |  Link
MrVideo
MrVideo's Avatar
Some TV stations in Europe broadcast HD as 720p50 rather than 1080i25. I remember the hot debates about what is better when HD TV was introduced.
Same here, where two OTA networks are 720p59.94 (ABC and FOX). Supposedly the reason was sports. But, that point is moot now, since all of the main cameras that cover sports are high-speed for great slo-mo. That means the slo-mo plays out as if it were 1080p.
IMHO, 720 is HD-lite. Especially now that 4K exists (not OTA, yet) and 8K is around the corner. I've always considered 720 to be inferior HD.
Old 28th September 2018, 09:04   #27789  |  Link
musiclover
He probably means HIDDENOPTS.TXT
Old 28th September 2018, 12:33   #27790  |  Link
FreaQ
Starfish
FreaQ's Avatar
Hi jdobbs,
did not see a reponse regarding my problem.
I updated to 0.60.2 and BD-RB still reencodes even though FORCE_NOENCODE=1 ist set.
Originally Posted by FreaQ View Post
After a long time I tried to use BD-RB today again.
I just wanted to blank some annoying warnings and keep the rest as is.
Even though the option FORCE_NOENCODE=1 is set, BD-RB reencodes the video.
So I tried a dryrun with all extras, movie and warnings enabled. I also set the target size to 55000 MB. At first it was promising, the short warnings were not reencoded. But as soon as the movie kicked in BD-RB startet reencodeing. I aborted the process.
I am not sure if I am missing something. The BD has multiangle (3 angles).
[09.25.18] BD Rebuilder v0.50.25
[14:39:38] Source:
  - Input BD size: 40,89 GB
  - Approximate total content: [02:31:47.906]
  - Target BD size: 53,71 GB
  - Windows Version: 6.2 [9200]
  - Quality: High Quality (Default), Two Pass
[14:39:38] PHASE ONE, Encoding
 - [14:39:38] Processing: VID_00006 (1 of 99)
 - [14:39:38] Extracting A/V streams [VID_00006]
 - [14:39:42] Reencoding video [VID_00006]
 - [14:39:42] Keeping original video (no reencode)
 - [14:39:43] Processing audio tracks
 - [14:39:43] Multiplexing M2TS
 - [14:39:46] Processing: VID_00100 (2 of 99)
 - [14:39:46] Extracting A/V streams [VID_00100]
 - [14:39:50] Reencoding video [VID_00100]
 - [14:39:50] Keeping original video (no reencode)
 - [14:39:50] Processing audio tracks
 - [14:39:50] Multiplexing M2TS
 - [14:50:26] Processing: VID_00339 (89 of 99)
 - [14:50:26] Extracting A/V streams [VID_00339]
 - [14:50:29] Reencoding video [VID_00339]
 - [14:50:29] Keeping original video (no reencode)
 - [14:50:29] Processing audio tracks
 - [14:50:29] Multiplexing M2TS
 - [14:50:33] Processing: VID_00340 (90 of 99)
 - [14:50:33] Extracting A/V streams [VID_00340]
 - [14:50:37] Reencoding video [VID_00340]
 - [14:50:37] Keeping original video (no reencode)
 - [14:50:37] Processing audio tracks
 - [14:50:37] Multiplexing M2TS
 - [14:50:40] Processing: VID_00341 (91 of 99)
 - [14:50:40] Extracting A/V streams [VID_00341]
 - [14:50:44] Reencoding video [VID_00341]
 - [14:50:44] Keeping original video (no reencode)
 - [14:50:44] Processing audio tracks
 - [14:50:44] Multiplexing M2TS
 - [14:50:48] Processing: VID_00810 (92 of 99)
 - [14:50:48] Extracting A/V streams [VID_00810]
 - [14:50:53] Reencoding video [VID_00810]
   - Rate/Length: 23,976fps, 2.214 frames
   - Bitrate: 28.750 Kbs
 - [14:50:53] Reencoding: VID_00810, Pass 1 of 2
 - [14:51:11] Reencoding: VID_00810, Pass 2 of 2
[14:51:16]PHASE ONE aborted by user request
[Options]
VERSION=0.50.0.24
MODE=0
ENCODE_QUALITY=2
ONEPASS_ENCODING=0
AUTO_QUALITY=0
SD_CONVERT=0
OPEN_GOP=0
RESIZE_1080=0
RESIZE_1440=0
RESIZE_720=0
DEINTERLACE=0
SD_TO_1080=0
CONVERT_WIDE=0
DTS_REENCODE=0
AC3_REENCODE=0
AC3_640=1
AC3_192=0
KEEP_HD_AUDIO=1
AVCHD=1
REMOVE_WORKFILES=1
MOVIE_ONLY_LOOP=0
REMOVE_OUTPUT=0
USE_FILTERS=0
BDMV_CERT_ONLY=1
USE_LAVF=0
IVTC_PULLDOWN=1
ASSUME_DVD_PAL=1
UNMASK_CHAPTER=1
COMPLETION_BEEP=0
DGDECNV=0
OUTPUT_3D=0
NEROAAC=0
SUPTITLE=0
AUDIO_TRACK_LIMIT=0
SUBTITLE_TRACK_LIMIT=0
CUSTOM_TARGET_SIZE=55000
ENABLE_TEST=1
ENABLE_BLANKING=1
DTSX_ENABLE=1
AUDIO_TO_KEEP=deu;eng;ger;
SUBS_TO_KEEP=deu;eng;ger;
MIN_M2TS_SIZE=1
BLANK_THRESHOLD=10
TARGET_SIZE=55000
FORCE_NOENCODE=1
ENCODER=0
IGNORE_3D=0
AUDIO_DRC=0
DECODER=2
FRIMSOURCE=0
OUTPUT_SBS=0
PGSTOSRT=0
FreaQ is offline   Reply With Quote
Old 28th September 2018, 15:15   #27791  |  Link
Ch3vr0n
@jdobbs is there a way to do full disc backup, and output to an ssif using structure? I'd test that otherwise
Verstuurd vanaf mijn Nexus 6P met Tapatalk
Old 28th September 2018, 16:41   #27792  |  Link
I didn't add it because if it worked, it would be set and not have to be a hidden option. If it didn't work (as is the case), it will simply go away.
Old 28th September 2018, 16:42   #27793  |  Link
No. To get that structure you have to use TSMUXER to create the ISO, and it only does one file at a time.
Old 28th September 2018, 17:02   #27794  |  Link
Hi jdobbs,
Try turning off "IVTC...pulldown" in SETUP. There are several settings that can prevent noencode mode (in order obey the settings) -- that's the one that is the most common culprit.
Old 28th September 2018, 18:53   #27795  |  Link
Ch3vr0n
In that case, is it difficult for you to add? Maybe the glitching is due to the in-mux and ssif won't glitch. Maybe it's worth a try.
Sent from my Nexus 7 with Tapatalk
Old 28th September 2018, 19:27   #27796  |  Link
More than difficult, virtually impossible without my having to write a piece of software that is equivalent to TSMUXER. Either way... in-mux is 100% within standard and is present on commercial discs -- so in that case the issue is with the player, not TSMUXER or BD-RB.
Have you tried doing a movie-only backup to an ISO to see if the problem still exists? My guess is it will have the same issue.
Old 28th September 2018, 19:33   #27797  |  Link
Ch3vr0n
No worries, just a question. I'll stick with my standard methods then. Process with bdrb, use a standalone I've hooked up to my PC's 3d monitor. Zero glitching, never has. I never doubted bdrb since 3d was first added.
Old 28th September 2018, 23:44   #27798  |  Link
Mark_Venture
UHD question...
So I just did Infinity Wars 4K alt movie only MKV... I forgot, until after it was done, to change it from 1920x1080 intact to another profile to keep it 4K.. there isn't one..
Can I just edit the MISC\Alternate.txt file to add one?
Also, since Infinity Wars 4K/UHD is HDR, the output loses HDR and the color is off...
BUT at least it completes and looks good otherwise
Old 29th September 2018, 01:25   #27799  |  Link
AmigaFuture
AmigaFuture's Avatar
Role Madels update..
I checked further into this..
00000.track_4113.264
All the files from the Playlist are gathered, BD-RB makes a TEMP BD, and before the MKV file is made the that file is created with 0 bytes and the MKV creation fails. There are 41 chapter points for the extras, and a single AC-3 is made while several VC1 files are extracted for the process.
[09/28/18] BD Rebuilder v0.60.02
[16:39:24] Source:  ROLE_MODELS_[UNRATED]_ANYDVD_TAKE_2_00100
  - Input BD size: 5.84 GB
  - Approximate total content: [00:49:49.819]
  - Windows Version: 6.1 [7601]
  - Mode: MKV, Intact Video, Intact Audio
[16:39:26] PHASE ONE, Encoding
 - [16:39:26] Processing: VID_00361 (1 of 81)
 - [16:39:26] Extracting A/V streams [VID_00361]
 - [16:39:33] Reencoding video [VID_00361]
 - [16:39:33] Keeping original video (no reencode)
 - [16:39:33] Processing audio tracks
(Only 1 audio...)
 - [16:45:09] Extracting A/V streams [VID_00441]
 - [16:45:13] Reencoding video [VID_00441]
 - [16:45:13] Keeping original video (no reencode)
 - [16:45:13] Processing: VID_00442 (81 of 81)
 - [16:45:13] Extracting A/V streams [VID_00442]
 - [16:45:18] Reencoding video [VID_00442]
 - [16:45:18] Keeping original video (no reencode)
[16:45:18]PHASE ONE complete
[16:45:18]PHASE TWO - Rebuild Started
 - [16:45:18] Building ALTERNATE OUTPUT Structure
 - Failed in attempt to multiplex: MUX_MOVIE_ONLY.meta
 - Not enought buffer for parse video stream. Current frame num 0
[16:46:25] - Failed to REBUILD
Now what I thought to be a work-around.. Make BD of the particular extras..
[16:54:38] Source:  ROLE_MODELS_[UNRATED]_ANYDVD_TAKE_2_00100
  - Target BD size: 46.26 GB
  - MOVIE-ONLY mode enabled
[16:54:40] PHASE ONE, Encoding
 - [16:54:41] Processing: VID_00361 (1 of 81)
 - [16:54:41] Extracting A/V streams [VID_00361]
 - [16:54:47] Reencoding video [VID_00361]
 - [16:54:47] Keeping original video (no reencode)
 - [16:54:47] Processing audio tracks
 - [16:54:47] Processing: VID_00362 (2 of 81)
 - [17:00:28] Processing: VID_00442 (81 of 81)
 - [17:00:28] Extracting A/V streams [VID_00442]
 - [17:00:33] Reencoding video [VID_00442]
 - [17:00:33] Keeping original video (no reencode)
[17:00:33]PHASE ONE complete
[17:00:33]PHASE TWO - Rebuild Started
 - [17:00:33] Rebuilding BD file Structure
[17:01:33] - Encode and Rebuild complete
[17:01:33] JOB: ROLE_MODELS_[UNRATED]_ANYDVD_TAKE_2 finished.
Now making MKV from it..
[17:05:34] Source:  ROLE_MODELS_[UNRATED]_ANYDVD_TAKE_2_00000
  - Approximate total content: [00:49:49.820]
[17:05:36] PHASE ONE, Encoding
 - [17:05:36] Processing: VID_00000 (1 of 1)
 - [17:05:36] Extracting A/V streams [VID_00000]
 - [17:06:40] Reencoding video [VID_00000]
 - [17:06:40] Keeping original video (no reencode)
 - [17:06:40] Processing audio tracks
[17:06:40]PHASE ONE complete
[17:06:40]PHASE TWO - Rebuild Started
 - [17:06:40] Building ALTERNATE OUTPUT Structure
[17:08:14] - Encode and Rebuild complete
[17:08:14] JOB: ROLE_MODELS_[UNRATED]_ANYDVD_TAKE_2 finished.
Extra 7 or 8 is where the sync is lost..for both BD and MKV.
I think it's the context of MUX_MOVIE_ONLY.meta you asked for?
MUXOPT --no-pcr-on-video-pid --new-audio-pes --demux --vbr --vbv-len=500 --start-time=27000000
V_MS/VFW/WVC1, "Q:\OUTPUT\WORKFILES\00000.track_4113.vc1", fps=23.976, contSPS
Do you have the movie? I'll help if not..
Old 29th September 2018, 12:32   #27800  |  Link
FreaQ
Starfish
FreaQ's Avatar
Thanks. That did the trick.
