28th September 2019, 16:47 | #28821 | Link | |
--------------------- [09/28/19] BD Rebuilder v0.60.25 [16:05:19] Source: STAR_WARS_STORY_-_SOLO_(UHD) - Input BD size: 52,77 GB - Approximate total content: [02:16:43.320] - Target BD size: 91,80 GB - Windows Version: 6.2 [9200] - Auto Quality: Very Good (Very Fast), ABR - Decoding/Frame serving: FFMPEG - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=640 [16:05:19] PHASE ONE, Encoding - [16:05:19] Processing: VID_00058 (1 of 5) - [16:05:19] Extracting A/V streams [VID_00058] - [16:08:00] Reencoding video [VID_00058] - [16:08:00] Keeping original video (no reencode) - [16:08:00] Processing audio tracks - Track 4352 (eng): Keeping original audio - Track 4353 (eng): Keeping original audio - Track 4354 (fra): Keeping original audio - Track 4355 (spa): Keeping original audio - Track 4356 (tha): Keeping original audio - [16:08:00] Multiplexing M2TS - [16:11:55] Processing: VID_00062 (2 of 5) - [16:11:55] Extracting A/V streams [VID_00062] - Extracting video streams [VID_00062] - Extracting audio/subtitle streams [VID_00062] - [17:08:26] Reencoding video [VID_00062] - [17:08:26] Keeping original video (no reencode) - [17:08:26] Processing audio tracks - Track 4352 (eng): Keeping original audio - Track 4353 (eng): Keeping original audio - Track 4354 (fra): Keeping original audio - Track 4355 (spa): Keeping original audio - Track 4356 (tha): Keeping original audio - [17:08:26] Multiplexing M2TS - [17:44:23] Processing: VID_00063 (3 of 5) - [17:44:23] Extracting A/V streams [VID_00063] - [17:44:35] Reencoding video [VID_00063] - [17:44:35] Keeping original video (no reencode) - [17:44:35] Processing audio tracks - Track 4352 (eng): Keeping original audio - Track 4353 (eng): Keeping original audio - Track 4354 (fra): Keeping original audio - Track 4355 (spa): Keeping original audio - Track 4356 (tha): Keeping original audio - [17:44:35] Multiplexing M2TS - [17:44:45] Processing: VID_00064 (4 of 5) - [17:44:45] Extracting A/V streams [VID_00064] - [17:44:57] Reencoding video [VID_00064] - [17:44:57] Keeping original video (no reencode) - [17:44:57] Processing audio tracks - Track 4352 (eng): Keeping original audio - Track 4353 (eng): Keeping original audio - Track 4354 (fra): Keeping original audio - Track 4355 (spa): Keeping original audio - Track 4356 (tha): Keeping original audio - [17:44:57] Multiplexing M2TS - [17:45:12] Processing: VID_00065 (5 of 5) - [17:45:12] Extracting A/V streams [VID_00065] - [17:45:22] Reencoding video [VID_00065] - [17:45:22] Keeping original video (no reencode) - [17:45:22] Processing audio tracks - Track 4352 (eng): Keeping original audio - Track 4353 (eng): Keeping original audio - Track 4354 (fra): Keeping original audio - Track 4355 (spa): Keeping original audio - Track 4356 (tha): Keeping original audio - [17:45:22] Multiplexing M2TS [17:45:34]PHASE ONE complete [17:45:34]PHASE TWO - Rebuild Started - [17:45:34] Rebuilding BD file Structure [17:45:51] - Encode and Rebuild complete [17:45:51] JOB: STAR_WARS_STORY_-_SOLO_(UHD) finished. Last edited by jdobbs; 29th September 2019 at 12:11. |
29th September 2019, 05:07 | #28822 | Link |
One title I am having that issue with is Everest. Here is the BDREBUILDER.INI
[Options] VERSION=0.60.0.25 ENCODER=0 MODE=0 ENCODE_QUALITY=5 ONEPASS_ENCODING=2 AUTO_QUALITY=0 TARGET_SIZE=23500 AUDIO_TO_KEEP=eng; SUBS_TO_KEEP=all SD_CONVERT=0 OPEN_GOP=0 RESIZE_1080=0 RESIZE_1440=0 RESIZE_720=0 DEINTERLACE=1 SD_TO_1080=0 IGNORE_3D=0 CONVERT_WIDE=0 DTS_REENCODE=0 AC3_REENCODE=0 AC3_640=1 AC3_192=0 KEEP_HD_AUDIO=1 AUDIO_DRC=0 DECODER=0 AVCHD=1 REMOVE_WORKFILES=1 REMOVE_OUTPUT=0 USE_FILTERS=0 BDMV_CERT_ONLY=0 IVTC_PULLDOWN=0 ASSUME_DVD_PAL=0 FRIMSOURCE=0 COMPLETION_BEEP=0 OUTPUT_SBS=0 NEROAAC=0 SUPTITLE=0 AUDIO_TRACK_LIMIT=1 SUBTITLE_TRACK_LIMIT=0 CUSTOM_TARGET_SIZE=23500 MOVIEONLY_TYPE=3 ALTCRF=23 ALT_TARGET=1024 ALTMETHOD=1 ALTAUTOCROP=0 ALT_CRF_TARGET=1024 PGSTOSRT=0 SUPPRESS_FF_WARNING=1 MENU_BACKGROUND=C:\BD_Rebuilder\Misc\colorado-mountains2.jpg MENU_AUDIO=C:\BD_Rebuilder\tools\blankclip\blank.ac3 IMPORT_THRESHOLD=15 QUICK_PLAY_THRESHOLD=10 MENU_AUTO_BACKGROUND=1 MENU_AUTO_DVDAUDIO=1 MENU_PLAY_SEQUENTIAL=0 MENU_START_WITH_MENU=1 IMPORT_LIMIT_LANG=0 IMPORT_KEEP_PLAYALL=0 [Paths] WORKING_PATH=F:\00 - 4K ENCODING\ DGIndexNV=C:\Program Files (x86)\dgdecnv2051\DGIndexNV.exe DGDecNV=C:\Program Files (x86)\dgdecnv2051\DGDecodeNV.dll SOURCE_PATH=F:\MOVIES (UHD)\EVEREST (UHD)\ Acerjen Last edited by jdobbs; 29th September 2019 at 13:25. |
29th September 2019, 12:40 | #28823 | Link | |
I have encoded numerous discs... and none have that issue. Just to test your report I have done two more (wasting more than 30 hours of my video computer's time encoding) -- and both came out with the times being exactly what they should have been. |
29th September 2019, 13:21 | #28826 | Link | |
Tested disc "Pirates of the Caribenean - Dead Man tell no tales" UHD. Did not removed anything from the disc and just rebuilded (no vídeo encode, no áudio/subtitles removal) The rebuilded file is smaller and check the Windows time info. Original: 02:09:06 Rebuilded: 01:43:34 BD Info reports the same time on original and rebuilded but the m2ts it´s smaller. Last edited by FilipeAmadeuO; 29th September 2019 at 13:23. |
29th September 2019, 13:24 | #28828 | Link | |
Can you play back the end of the two files and see if they match? I want to see if the time discrepancy is in the M2TS itself, or the what is reported in the CLPI. I suspect it may be in the CLPI based on what I saw in SOLO. But if part of the file isn't being encoded -- that may be a bigger issue outside of BD-RB (and a lot harder to fix). Last edited by jdobbs; 29th September 2019 at 13:33. |
29th September 2019, 14:03 | #28829 | Link | |
29th September 2019, 14:12 | #28830 | Link | |
My BD Rebuilder.ini:
[Options] VERSION=0.60.0.25 MODE=0 ENCODER_MENU=1 ENCODE_QUALITY=5 ONEPASS_ENCODING=2 AUTO_QUALITY=0 AUDIO_TO_KEEP=deu;gem;ger; SUBS_TO_KEEP=deu;gem;ger;gmh;goh;gsw; SD_CONVERT=0 OPEN_GOP=1 RESIZE_1080=0 DEINTERLACE=0 SD_TO_1080=0 CONVERT_WIDE=0 DTS_REENCODE=0 AC3_REENCODE=0 AC3_640=0 AC3_192=0 KEEP_HD_AUDIO=1 AVCHD=0 REMOVE_WORKFILES=1 MOVIE_ONLY_LOOP=1 REMOVE_OUTPUT=1 USE_FILTERS=0 BDMV_CERT_ONLY=0 USE_LAVF=1 IVTC_PULLDOWN=0 ASSUME_DVD_PAL=0 UNMASK_CHAPTER=0 COMPLETION_BEEP=0 DGDECNV=0 AUDIO_TRACK_LIMIT=0 SUBTITLE_TRACK_LIMIT=0 CUSTOM_TARGET_SIZE=66000 TARGET_SIZE=47366 AUTO_BURN=2 MOVIEONLY_TYPE=40 ALTCRF=18 ARCHIVE_265=1 ARCHIVE_AUDIO=100 ARCHIVE_CRF=16 ARCHIVE_ENABLE=1 ARCHIVE_LIMIT=1 ALT_TARGET=7800 ALTMETHOD=0 ALTAUTOCROP=0 QUICK_EXTRAS=0 OUTPUT_3D=0 RESIZE_1440=0 RESIZE_720=0 NEROAAC=0 SUPTITLE=0 IGNORE_3D=0 OUTPUT_SBS=0 ENCODER_MENU=1 HC_PROFILE=BEST IMPORT_HEVC_INTACT=1 MIN_M2TS_SIZE=20 NEW_CRF_PREDICTION=1 MULTIPROCESS=0 THREADS=auto BD5_SIZE=4520 BD9_SIZE=8200 BD25_SIZE=23200 QUALITY_ULTRA=1 FRIMSOURCE=0 ENCODER=0 DGDECIM=1 FRIM_SW_DECODE=1 FRIM_SW_ENCODE=1 PRIORITY_CLASS=1 MENU_BACKGROUND=C:\BD_Rebuilder\misc\menuback.jpg IMPORT_THRESHOLD=15 QUICK_PLAY_THRESHOLD=10 MENU_AUTO_BACKGROUND=1 MENU_PLAY_SEQUENTIAL=0 MENU_START_WITH_MENU=1 DECODER=2 AUDIO_DRC=0 MENU_AUTO_DVDAUDIO=1 IMPORT_LIMIT_LANG=0 IMPORT_KEEP_PLAYALL=0 ALT_CRF_TARGET=4000 PGSTOSRT=0 [Paths] SOURCE_PATH=E:\4K BLU RAY\CLIFFHANGER.1993.2160P WORKING_PATH=Q:\4K\ Quote:
Creed - Rockys Legacy 2015 Creed II 2018 Allied 2016 Cliffhanger Studio Canal Version 1993 The little Mermaid 1989 Wildes Venedig Ballon 2018 Apollo 13 1995 Asterix 2018 Ghostbuster 1984 I deleted the most backups. Today I'm testing more and send logs to Jdobbs. Last edited by Michi; 29th September 2019 at 19:25. |
29th September 2019, 15:46 | #28831 | Link |
Wildes Venedig Log:
[09.29.19] BD Rebuilder v0.60.25 [14:57:43] Source: WILDES_VENEDIG - Input BD size: 25,80 GB - Approximate total content: [00:53:08.921] - Target BD size: 22,66 GB - Windows Version: 6.2 [9200] - Quality: Good (Fastest, BD-25+), ABR - Decoding/Frame serving: FFMPEG - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=448 [14:57:43] PHASE ONE, Encoding - [14:57:43] Processing: VID_00005 (1 of 1) - [14:57:43] Extracting A/V streams [VID_00005] - [15:01:25] Reencoding video [VID_00005] - Source Video: HEVC, 3840x2160 - Rate/Length: 25,000fps, 78.047 frames - Bitrate: 35.000 Kbs - [15:01:25] Reencoding: VID_00005, Pass 1 of 1 - [16:38:08] Video Encode complete - [16:38:08] Processing audio tracks - Track 4352 (deu): Keeping original audio - Track 4353 (deu): Keeping original audio - [16:38:09] Multiplexing M2TS [16:44:47]PHASE ONE complete [16:44:47]PHASE TWO - Rebuild Started - [16:44:47] Rebuilding BD file Structure [16:44:51] - Encode and Rebuild complete [16:44:51] Writing BD structure to ISO file - ImgBurn completed successfully - WILDES_VENEDIG folder removed. - WORKFILES folder removed. [16:45:12] JOB: WILDES_VENEDIG finished. |
29th September 2019, 17:56 | #28832 | Link | |
I ask because the source path looks like something that was downloaded. |
29th September 2019, 18:32 | #28834 | Link | |
Just checked the movie , and the length of the film is 02:09:06 ... I did Toy story 4 , it has many m2ts files, around 126 .. took the unwanted streams out , and worked a treat ..have my size set at stupid size 900500 , because I only take out streams , these days . |
29th September 2019, 18:57 | #28835 | Link | |
29th September 2019, 19:25 | #28838 | Link |
Ghostbuster 1984:
[16:46:48] Source: GHOSTBUSTERS.1984 - Input BD size: 57,65 GB - Approximate total content: [02:09:54.241] - Target BD size: 22,66 GB - Windows Version: 6.2 [9200] - Quality: Good (Fastest, BD-25+), ABR - Decoding/Frame serving: FFMPEG - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=448 [16:46:48] PHASE ONE, Encoding - [16:46:48] Processing: VID_00001 (1 of 2) - [16:46:48] Extracting A/V streams [VID_00001] - [16:51:44] Reencoding video [VID_00001] - Source Video: HEVC, 3840x2160 - Rate/Length: 23,976fps, 151.248 frames - Bitrate: 26.056 Kbs - [16:51:44] Reencoding: VID_00001, Pass 1 of 1 - [20:09:52] Video Encode complete - [20:09:52] Processing audio tracks - Track 4355 (deu): Keeping original audio - [20:09:53] Multiplexing M2TS - [20:17:55] Processing: VID_00100 (2 of 2) - [20:17:55] Extracting A/V streams [VID_00100] - [20:17:59] Reencoding video [VID_00100] - Source Video: HEVC, 3840x2160 - Rate/Length: 23,976fps, 346 frames - Bitrate: 7.723 Kbs - [20:17:59] Reencoding: VID_00100, Pass 1 of 1 - [20:18:19] Video Encode complete - [20:18:19] Processing audio tracks - Track 4352 (eng): Keeping original audio - [20:18:19] Multiplexing M2TS [20:18:23]PHASE ONE complete [20:18:23]PHASE TWO - Rebuild Started - [20:18:23] Rebuilding BD file Structure [20:18:35] - Encode and Rebuild complete [20:18:35] Writing BD structure to ISO file - ImgBurn completed successfully - GHOSTBUSTERS.1984 folder removed. - WORKFILES folder removed. [20:19:08] JOB: GHOSTBUSTERS.1984 finished. |
29th September 2019, 19:53 | #28839 | Link | |||
@Michi
Just because you edit the path from Quote:
That is a pirated release, which means most likely Quote:
