Old 8th April 2016, 07:56   #37401  |  Link
AngelGraves13
Nevermind.
AngelGraves13 is offline   Reply With Quote
Old 8th April 2016, 11:11   #37402  |  Link
bbsc
Feature request.
Thanks madshi for this great software and support. Now madVR works just excellent in my old HTPC.
I'd like to ask for adding one feature, if possible.
There's "display modes madVR may switch to" string in settings and it works Ok.
Is it possible to add "default display mode" string with a single mode madVR would have to switch to when exiting?
I'd like to have this setting because the system stuck in 24p after rebooting in an unusual way, i.e. when pausing or playing video.
With this setting it would return to usual 50p or 60p after the next play/stop.
Thank you in advance.
bbsc is offline   Reply With Quote
Old 8th April 2016, 17:51   #37403  |  Link
madVR should already return back to the default refresh rate.
at least thre is an option for that: "restore original display mode..."
Old 8th April 2016, 18:03   #37404  |  Link
sneaker_ger
He means in case of a crash, so madVR has no change to trigger a return. Personally, I'd probably just use a specific display mode changer, write a short batch file and put it into Window's auto-start folder.
E.g. "reset_display_mode.bat":
c:\dc.exe -width=1920 -height=1080 -depth=32 -refresh=60
http://12noon.com/?page_id=80
Old 9th April 2016, 00:25   #37405  |  Link
CarlosCaco
of cause lanczos 4 is sharper. more tabs sinc based algorithm = sharper image.
that doesn't mean lanczos4 is a better choice.
the math used on the image should have the same results. if it is different something else is the cause.
I did not said its better, only coment its look like sharper because the guy says that 4 is smoother than 3
Desktop, i5 2500, 8GB, N570 GTX TF III PE/OC
Asus X555LF, i7-5500U, 6GB Ram, Nvidia 930m/HD 5500
Windows 8.1 Pro x64
CarlosCaco is offline   Reply With Quote
Old 9th April 2016, 00:29   #37406  |  Link
CarlosCaco
Does anyone who have an nvidia gpu see any difference with triple buffering enabled on nv control panel? Should i enable this?
Windows 8.1 Pro x64
Old 9th April 2016, 00:35   #37407  |  Link
leave everything at application controlled
Old 9th April 2016, 01:01   #37408  |  Link
CarlosCaco
Triple buffering don t have application controled option only on and off
Windows 8.1 Pro x64
Old 9th April 2016, 01:35   #37409  |  Link
aufkrawall
This setting is just for OpenGL and probably it's even for OpenGL just a corpse entry without any effect, like e.g. LOD bias clamp option.
Old 9th April 2016, 04:11   #37410  |  Link
neno
Hi~
I have two OS, and I need to use different madvr settings to them.
Can anyone tell me how to save all the settings in madvr or any way to load different settings?
Thanks very much!
neno is offline   Reply With Quote
Old 9th April 2016, 09:32   #37411  |  Link
chros
chros's Avatar
First of all, if you use madvr for a long time then it's wise to configure it from scratch on the new system, then copy its settings from there to the old one and modify it there. (I had problems in the past with my 4 years old settings, because I forgot that I had modified some d3d settings in it.)
Option 1: copying the settings.bin file from the madvr folder if it exist. The folder on both OS has to be writable.
Option 2. exporting and importing the registry entry using regedit:
HKEY_CURRENT_USER\Software\madshi
Old 9th April 2016, 12:07   #37412  |  Link
bbsc
Excellent.
Thank you.
The case is closed
Old 9th April 2016, 18:35   #37413  |  Link
XMonarchY
So has anyone figured out why some 1080p23/24 H.264 content runs perfectly with NNEDI3 Chroma Upscaling and NNEDI3 Luma Doubling @ 1080p @ 23/24Hz, while other 1080p23/24 H.264 content ends up having severe frame delays or drops?
Old 9th April 2016, 18:41   #37414  |  Link
sneaker_ger
Define "1080p". Both 1920x1080 active pixels or some with cropping/black bars?
Old 9th April 2016, 19:58   #37415  |  Link
AngelGraves13
SuperRes doesn't work with deinterlacing. Drops my render queue to 1.
IVTC works, but isn't suitable for most DVD content as the cadence breaks can be very jarring.
Old 9th April 2016, 20:18   #37416  |  Link
baii
Probably your GPU is not powerful enough, native deinterlace usually mean 50 or 60fps.
Sent from my 306SH using Tapatalk
baii is offline   Reply With Quote
Old 9th April 2016, 20:54   #37417  |  Link
XMonarchY
Ah! I just realized that 16:9 films are the ones stuttering and 21:9 films are the ones playing without problems. THANKS!
Now I just have to figure out whether it makes more sense to use:
1. Chroma Upscaling NNEDI3 256n + SuperRes (Strength 3) without Image Doubling OR 2. Some other Chroma Upscaling settings with Image Doubling NNEDI3 32n (set to Always) to get the best image possible without dropped frames in 16:9 films. I don't think its possible though...
I guess I need to make comparison shots and make a decision!
Old 9th April 2016, 21:02   #37418  |  Link
can't wait for chroma nnedi3 256 comparison screens.
Old 9th April 2016, 21:04   #37419  |  Link
Betroz
Is this for real?
Betroz's Avatar
Try Chroma Upscaling NNEDI3 128 and Image Doubling/Quad to allways super-xbr, anti-bloating 25.
My HTPC : i9 10900K | nVidia RTX 4070 Super | TV : Samsung 75Q9FN QLED
Betroz is offline   Reply With Quote
Old 9th April 2016, 21:55   #37420  |  Link
AngelGraves13
I've got a 980 gtx. Don't really know what's better besides a Titan. Cpu is an i7.
