Old 23rd June 2018, 08:47   #51481  |  Link
mkohman
Guys apologies in advance if this is going to ruffle some feathers or if this topic has been discussed before....
My current setup is as below :
HTPC >JVC
My HTPC is set to RGB FULL 444
madVR set to 0-256 10bit
JVC projector set to Enhanced / RGB
LAV filters also set to 0-256
My JVC info panel displays RGB when a movie is being played, however everyone else's seems to be showing YUV???
I have Googled JVC YUV OR RGB and in the images section of Google they all seem to display 12bit colour and YUV where as mine displays 12bit RGB...
I use KODI DSPLAYER with LAV filters which are also set to 0-256.. Basically everything in the chain is set to RGB FULL 4.4.4...
Can someone please tell me if this is correct and if so why does everyone else's displays information tab show the colour space as YUV?
Sent from my moto g(6) using Tapatalk
mkohman is offline   Reply With Quote
Old 23rd June 2018, 12:23   #51482  |  Link
because you are sending RGB.
changing the settings in lavfilter to RGB is a very very dumb idea leave it at default.
Old 23rd June 2018, 12:33   #51483  |  Link
mkohman
Thanks but, I think it was at 0-256 by default in lav filter.. shall I change that to 16-235? Also shall I change madvr to 16-235? and keep my HTPC at RGB FULL 4.4.4 and JVC input level Enhanced? Thanks
Old 23rd June 2018, 12:54   #51484  |  Link
the point is not this setting alone it doesn't do anything with madVR but with a combination of other settings. but for what ever reason you like to change everything that is fine by default and correct by default.
sounds wrong to me.
Old 23rd June 2018, 13:15   #51485  |  Link
mkohman
No offence but what you have just written makes absolutely no sense.. I don't understand what you're trying to say. I am asking a very simple question and in return I got a string of sentences which made absolutely no sense to me.. Sorry..
Old 23rd June 2018, 14:01   #51486  |  Link
littleD
littleD's Avatar
http://madshi.net/htpc/page4.html and consider Ycbcr as yuv for simplicity
littleD is offline   Reply With Quote
Old 23rd June 2018, 14:10   #51487  |  Link
mkohman
Thanks for this. Much appreciated but still no idea which to select for madVR or lav filters? Should they be YCbCr or rgb? Thanks
Old 23rd June 2018, 14:48   #51488  |  Link
the YUV or RGB you see at your projector has nothing todo with madVR or lavfilter. it just tells you what the GPU is sending and RGB is fine.
use the default settings for this madVR lavfilter they are there for a reason.
Old 23rd June 2018, 14:58   #51489  |  Link
mkohman
Old 23rd June 2018, 15:16   #51490  |  Link
mkohman
Judging by the images attached below which were both taken from the Kodi Wikipedia Website... I understand that this should be correct :
Desktop set to RGB FULL 4.4.4
madvr set to 0-256
Lav filter and JVC projector set to 16-235
I'll be happy to be corrected if I'm wrong.. Thanks for all the input..
Size:  29.4 KBName:  2.jpeg
Old 23rd June 2018, 15:27   #51491  |  Link
when madVR and the GPU driver are set to full range you need to set your projector to full range. i guess they use the word enhance.
lavfilter has nothing to do with this.
just read this: https://forum.doom9.org/showpost.php...16&postcount=2
attachment need admin approval no one will see them.
Old 23rd June 2018, 15:37   #51492  |  Link
mkohman
Cool.. Thanks.. So I will leave everything as it is
Everything at FULL..
Cheers
Old 23rd June 2018, 16:42   #51493  |  Link
mv
are you using d3d11 for decoding?
Same issue with D3D11 or DXVA Copy-Back. But with D3D11 decoding de-interlacing is not enabled for some reason neither in madVR or LAV so switched to DXVA Copy-Back for now.
Tried to encrease buffer size in LAV splitter but thats is not the case.
mv is offline   Reply With Quote
Old 23rd June 2018, 16:52   #51494  |  Link
d3d11 doesn't support deinterlancing that'S why i ask.
can you make a screen of the OSD?
Old 23rd June 2018, 19:27   #51495  |  Link
Redemption80
Nvidia users who use custom modes, i know while most people were having issues with the driver rejecting this mode, some were not.
What are other Nvidia users doing now? I pretty much stuck with 390.77 for 6 months but out of curiosity i have been testing 398.11 and again can only use the EDID timings. Saying that, while my OCD dislikes the fact i have went from drops every few days to every 12mins, if im honest i can't say i actually noticed them over the course of average TV show.
Anyone who knows anything about drivers think this is a permanent change to the drivers that we will have to just live with?
Redemption80 is offline   Reply With Quote
Old 23rd June 2018, 19:50   #51496  |  Link
Create modes in the NVIDIA control panel, that works on all driver versions for me.
Old 23rd June 2018, 20:11   #51497  |  Link
veggav
Found this statement:
"My main problem with a 4:2:2 transport over HDMI is that a PC is always RGB, and a 4:2:2 transport is YCbCr, so when you play something on a PC the player converts the YCbCr file to RGB, then the graphics card converts it to 4:2:2 YCbCr for HDMI, and the TV again converts it to RGB, its two extra conversions that may (and do) incur extra loss on the image, and has the potential for mis-matching conversion matrices even throwing off your colors entirely."
Is this accurate?
It's impossible to have true YCbCr on PC?
veggav is offline   Reply With Quote
Old 23rd June 2018, 20:24   #51498  |  Link
not perfectly accurate but close enough.
you can't use YCbCr from source to HDMI on a PC.
the solution is simple just use RGB output.
Old 23rd June 2018, 20:24   #51499  |  Link
Originally Posted by veggav View Post
Is this accurate?
This is correct. PCs at least on any configuration that can run madVR are always RGB.
Old 23rd June 2018, 20:50   #51500  |  Link
veggav
This clears some stuff for me to understand
If I set nvidia control panel to "let colors settings be set by application" I believe this will set color based on my TV edid.
I know about chroma subsampling test to see if it' 4:4:4 or 4:2:0.
Is there a way to know if in this situation my pc is using RGB or YCbCr?
