20th April 2019, 03:15 | #55842 | Link |
So I noticed that when I have FSE enabled on Windows 10, I am getting a mismatched composition rate to display rate, 60hz instead of 24hz. Should composition rate even be showing in FSE? If I turn off FSE I get 24hz/24hz. Any inherit disadvantages to leaving FSE off? I do use MadVR for SDR and HDR tonemapping.
20th April 2019, 03:45 | #55843 | Link |
the FSE used in win 10 isn't exclusive anymore it should be there but that how FSE now works. FSE avoids bugs like sending 10 bit to the GPU driver when the GPU has to send 8 bit where it will produce banding (powered by nvidia).
there is a way to get a more "FSE" FSE on win 10 but you should be fine with WFS which can easily get a composition rate mismatch too. HDR-SDR 3D LUT are created for this. this may matter for tone mapping which isn't used here. |
20th April 2019, 03:58 | #55844 | Link | |
20th April 2019, 04:17 | #55845 | Link |
the GPU driver doesn't dither in this case it does in FSE.
it's not a good idea to send the GPU 10 bit (madVR 10 bit output) when the GPU send 8 it to the display anyway. a 10 or 8 bit source have nothing to do with that and shouldn't affect your choice if you send 10 bit to the display or not it's way more complicated this topic but in short you are fine with 8 bit anyway. |
20th April 2019, 04:20 | #55846 | Link | |
20th April 2019, 04:46 | #55848 | Link |
What am I doing wrong here!?
Hi. What am I doing wrong here!?
if (srcWidth == 1920) "1080p" else if (srcWidth == 720) "720p" else if (fps > 30) and (srcWidth == 2160) "4K60" else "4K" It seems that if the screen size is 2160, it always plays the "4K" profile. If I remove the 2160 on line 3, then it works normally... |
20th April 2019, 05:24 | #55849 | Link | ||
why don't you take a more well known working solution?
you should either start from the top or the bottom not in the middle of something. Quote:
same for 2160 which file has a screen width of 2160? 1920, 1280, 3840 are common. just take the example from madshi here and change it to your needs. Quote:
20th April 2019, 06:19 | #55850 | Link | |
if (srcHeight <= 720) "720p" else if (srcHeight <= 1080) "1080p" else if (fps < 31) and (srcHeight <= 2160) "4K" else "4K60" And as huhn mentioned, you should start at the smallest or largest resolution. I prefer starting at the smallest.
madVR options explained |
20th April 2019, 06:52 | #55851 | Link |
QB the Slayer
if (srcHeight < 641) and (deintFps < 25) "720p23 Univisium" elseif (srcHeight < 719) and (deintFps < 25) "720p23 bad crop" elseif (srcHeight < 721) and (deintFps < 25) "720p23" elseif (srcHeight < 1041) and (deintFps < 25) "1080p23 35mm Film" elseif (srcHeight < 1081) and (deintFps < 25) "1080p23" elseif (srcHeight < 2161) and (deintFps < 25) "2160p23" elseif (srcHeight < 577) and (deintFps < 26) "576p25" elseif (srcHeight < 721) and (deintFps < 26) "720p25" elseif (srcHeight < 1081) and (deintFps < 26) "1080p25" elseif (srcHeight < 541) and (deintFps < 31) "540p29" elseif (srcHeight < 721) and (deintFps < 31) "720p29" elseif (srcHeight < 1081) and (deintFps < 31) "1080p29" elseif (srcHeight < 577) and (deintFps < 51) "576p50" elseif (srcHeight < 721) and (deintFps < 51) "720p50" elseif (srcHeight < 541) and (deintFps < 61) "540p59" elseif (srcHeight < 721) and (deintFps < 61) "720p59" elseif (srcHeight < 1081) and (deintFps < 61) "1080p59" That's currently my scaling profiles... as you can see, I start with 23fps content and go all the way down to 60fps, and for each framerate I also start small and go high with the source heights. If you don't watch any of the above content you can remove lines or add lines if something is not there. I continually come across sources the need to be added since they fall between some of these profiles (either source height or framerate) either pushing the GPU too hard or not hard enough. QB
20th April 2019, 09:56 | #55853 | Link |
I'm using the latest mpc-hc (1.8.6) on win10 and when I install madVR(0.92.17) the OSD in mpc changes, its background going from opaque to semi transparent. On many videos, that makes the OSD impossible to read. The only OSD setting in mpc-hc (the OSD font setting) doesn't seem to do anything anymore and I can't find any OSD settings in madVR. Is there anyway I can manually edit some madvr files (settings file, shaders ...) to turn the OSD background back to opaque, or at least change the font color to increase the contrast ? thanks |
20th April 2019, 13:15 | #55854 | Link | |
Edit: You should also make these changes in the Nvidia control panel for that GPU: https://forum.doom9.org/showpost.php...&postcount=151
HOW TO - Set up madVR for Kodi DSPlayer & External Media Players Last edited by Warner306; 20th April 2019 at 16:39. |
20th April 2019, 17:29 | #55855 | Link | |
21st April 2019, 15:23 | #55860 | Link |
MadVR HDR green tint
Hey guys, I need a bit of assistance to this puzzle. Now i've been using VLC3.0.x player for HDR playback (sony XF90 is the display) and it is very comparable but i was suggested by several people that madVR is more precise for HDR playback.
Now I have freshly installed MPC and potplayer just for madVR and for some reason on both players when i select madVR renderer and when i compare it with the VLC, players with madVR have this very feint green tint color to it. Do i have to select something on the madVR to get the best color reproduction that's identical to the blu ray players? So far VLC had the most colorful and precise reproduction to the players with madVR. I'm asking because surely i'm using madVR wrong as it has been suggested by everyone so far that madVR is the closest to the real thing. All the movies are blu ray rips in a remux and they aren't altered and compressed versions but uncompressed both video and audio. |
