Old 22nd January 2020, 20:12   #58401  |  Link
chros
chros's Avatar
I think it's realeted to resizing. E. g. play a 2160p video on 1080p screen:
- normally chroma will be upscaled to 2160 and then both to 1080
- if it's enabled then there won't be chroma doubling
Old 22nd January 2020, 20:37   #58402  |  Link
Asmodian
Originally Posted by SirMaster View Post
Is this really lower quality? And why or in what way would it be lower quality when enabling the option? Why shouldn't we always have that option enabled?
You do get different chroma... whether or not it is worse is more debatable. In testing it does seem better to handle chroma the same as luma but it is one of the least loss of quality options in trade quality for performance.
madVR options explained
Old 22nd January 2020, 21:45   #58403  |  Link
Wilmar
Wilmar's Avatar
Originally Posted by clsid View Post
The screenshot shows "HDR: unknown properties", meaning it can't find the HDR metadata.
Use LAV Video decoder. Disable the internal video decoder and video processor in Potplayer.
Thank you for your answer. But I already use LAV Video decoder:
https://i.imgur.com/HZOJZpJ.png
https://i.imgur.com/1MmvsgE.png
My exported Potplayer settings are here.
Wilmar is offline   Reply With Quote
Old 23rd January 2020, 13:19   #58404  |  Link
IngramAU
Having problems with repeated frames on 24.000fps content. I've nuked my drivers and reset Madvr to default still seeing the same issue (1060GTX.)
Please see attached images. I am not able to access 24.000hz fine tuning. 23.976hz I can.
I nuked my drivers and tried 24 again before fine tuning 23.976 incase it was causing issues didn't make a difference.
IngramAU is offline   Reply With Quote
Old 23rd January 2020, 14:28   #58405  |  Link
hannes69
Attached images in this forum can take a long time until we can see them, so it would be better to upload them to an image hoster.
24.000Hz and 23.976Hz sometimes 'interfere' in certain setups/drivers.
A possible workaround could be to use multiples of these values (so youŽll have e.g. 23.976Hz and 48.000Hz or 47.952Hz and 24.000Hz or 72.000Hz...
Of course this depends on your display deviceŽs capabilities, so your monitor/tv/beamer has to accept these refresh rates.
hannes69 is offline   Reply With Quote
Old 24th January 2020, 01:47   #58406  |  Link
tp4tissue
tp4tissue's Avatar
Originally Posted by mclingo View Post
Hi,this is rough representation of what I am seeing with RX 5700 bug, beginning of bladerunner 2049
https://1drv.ms/u/s!AgvFafeelEBij75e...ll3yw?e=nM5M1Y
Use Madvr's tonemapping, The Tv's tonemapping is prolly poop anyway.
Ghetto | 2500k 5Ghz
Old 24th January 2020, 01:50   #58407  |  Link
tp4tissue
tp4tissue's Avatar
Originally Posted by nsnhd View Post
I have now a full 10-bit path madVR-GPU(gtx 1060)-Display(4k monitor). Is there any disadvantage which I have to pay attention to ?
You need to test it with 10bit/8bit gradient test files. See which one is smoother.
But since 444 60hz only works in 8bit, and autoswitch 23/24hz is hit or miss depending on driver, I've stuck with 8bit.
I've not seen 10bit input produce noticably smoother gradient either because madvr's dithering is great.
Ghetto | 2500k 5Ghz
Old 24th January 2020, 01:57   #58408  |  Link
tp4tissue
tp4tissue's Avatar
the current in progress version killed 1080 by just tonemapping with a version to saying it will be released like that but still.
is this true ? we all have to buy 1080tis now ?
Ghetto | 2500k 5Ghz
Old 24th January 2020, 02:00   #58409  |  Link
tp4tissue
tp4tissue's Avatar
Originally Posted by Siso View Post
In short, I'll stay to 8 bit.
Since you own a colorimeter, you can test both and see if your accuracy increases/ decreases/ contrast/ gradient smoothness etc.
Ghetto | 2500k 5Ghz
Old 24th January 2020, 02:37   #58410  |  Link
nsnhd
By switching madVR's dithering off I can see 10bit gradient files smoother by 10bit path. Hope that some browsers can take advantage of it when playing videos, but I'm not sure.
You have to connect via Displayport to have 444/60Hz 10bit and some newer driver versions don't like it.
nsnhd is offline   Reply With Quote
Old 24th January 2020, 03:05   #58411  |  Link
yeah and what else should happen if you disable dithering?
Old 24th January 2020, 04:19   #58412  |  Link
nsnhd
I haven't noticed anything else except 10bit path playing gradient files smother than 8bit path. I just did that for testing only, and always enable dithering in madVR. I have to find out how to test videos such as football matches in browsers to see if 10bit path might have any effect.
Old 24th January 2020, 04:25   #58413  |  Link
that's not a "test" how could there be another result.
you have to test if 8 bit dithering or 10 bit dithering is smoother.
yuor test is comparable to taking a shower and figuring out if you get wet or not.
Old 24th January 2020, 06:21   #58414  |  Link
nsnhd
Yeah, it's not a test, just what I can see. I don't know how to test browsers such as Edge or Chrome which don't tell about bit depth and dithering options/settings.
Old 24th January 2020, 07:05   #58415  |  Link
if the web browser doesn't dither(they don't) 10 bit rendering would be always better but it's not that easy to render 10 bit so they generally don't do that.
10 bit rendering with dithering on a screen that doesn't support it will always win against 8 bit none dithering. so what is the point of looking at 8 bit none dithered ever why should 10 bit none dithered not always be better? i mean the screen doesn't even matter in this case.
Old 24th January 2020, 07:31   #58416  |  Link
IngramAU
Managed to get MadVR to accept a 24hz custom mode by going for 23.999xxx hopefully after a few runs I can get it closer to 24. Not sure why I can't start off from my EDID it just won't accept it with an unknown error.
Old 24th January 2020, 15:27   #58417  |  Link
mclingo
There is a well documented bug with AMD HDR API which causes this, its nothing to do with tone mapping, AMD's private API isnt sending BT2020, we have to use windows HDR API for now.
I'm already using MADVR's tone mapping, however I have to turn on WINDOWS HDR first which isnt ideal but there is no fix in sight for this bug yet.
Old 24th January 2020, 16:45   #58418  |  Link
Asmodian
I wanted to expand on this because it is an interesting and more subtle point than I thought.
With dithering disabled you are not reality testing your 8 vs 10 bit paths. 10 bit will always look smoother even if, with dithering, 8 bit would look smoother.
Old 24th January 2020, 18:55   #58419  |  Link
VBB
VBB's Avatar
If you're unsure whether your display is 8-bit or 10-bit, there really isn't a test to determine that 100% anyway. But if you know the bit depth, you can certainly test for banding in different desktop and TV modes. And for that, I would recommend disabling dithering in madVR. You still can't be sure that the video card itself doesn't do any dithering, but it's a start. Just make sure to turn it back on when you're done testing.
Henry | LG OLED65C7P | Denon AVR-X3500H | ELAC Uni-Fi x7 | ELAC Debut 2.0 SUB3030 x2 | NVIDIA SHIELD TV Pro 2019 | Plex
VBB is offline   Reply With Quote
Old 24th January 2020, 19:15   #58420  |  Link
mrmojo666
@Mclingo, I'm very curious to follow this bt2020 bug, could you please lnk something regardig the documentation you are referring to?
AMD Ry 1500x - 8GB - RX460 4GB
TV Philips 55pus6501+ Marantz 1608 avr
WIN10(1903) 4K/444RGB
Mediaportal - Mpc-hc
MADVR-D3D11/10bit
