28th March 2015, 13:21 | #1201 | Link | |
Software Developer
LameXP v4.11 RC-4
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 5th April 2015 at 20:19. |
5th April 2015, 20:22 | #1202 | Link | |
Software Developer
LameXP v4.11 has been released
https://github.com/lordmulder/LameXP/releases/latest Quote:
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 5th April 2015 at 20:35. |
5th April 2015, 21:12 | #1203 | Link |
47.952fps@71.928Hz
Thanks for the update, quite busy!
Happy Easter to you too.
Win10 (x64) build 19041 NVIDIA GeForce GTX 1060 3GB (GP106) 3071MB/GDDR5 | (r435_95-4) NTSC | DVD: R1 | BD: A AMD Ryzen 5 2600 @3.4GHz (6c/12th, I'm on AVX2 now!)
5th April 2015, 22:38 | #1206 | Link |
Software Developer
I assume with "standalone version" you mean a binary that has portable mode enabled by default
Well, here we go: http://sourceforge.net/projects/lame...0.zip/download
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 5th April 2015 at 23:09. |
6th April 2015, 10:50 | #1208 | Link |
Thanks for your work.
I've noticed a minor issue (unless it's wanted or i misunderstand the purpose of display), it probably exists since a long time. I have an i7@980 with 6 cores with HT. But, after install, and "Choose based on core" is checked, the cursor is on 4 (when i would expect 6 in that case). Is it normal ? |
6th April 2015, 11:59 | #1209 | Link | |
6th April 2015, 13:04 | #1210 | Link | |
Software Developer
The slider currently defaults to 4, yes. But that is completely unrelated to the number of parallel threads that will be used if you let the program decide. Also note that the heuristic, which is used to automatically decide the number of parallel threads (based on the number of CPU's), is not a simple "1:1" mapping. Looks more like this: http://i.imgur.com/YnQAvU5.png
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 6th April 2015 at 13:09. |
6th April 2015, 13:39 | #1212 | Link |
Software Developer
Nope, works perfectly fine on my Windows 8.1 machine:
http://i.imgur.com/AqXWCkh.jpg Is this problem reproducible? If so, what are your system specifications? Does the debug console show any helpful info?
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 6th April 2015 at 18:53. Reason: fixed typo |
6th April 2015, 15:24 | #1213 | Link |
@ TOM_SK
Ha, the guru strikes again... Just for the fun of it, can you try to change your display color depth from 32bit to 16bit and see what happens? The reason I ask is that on my machine LameXP only works with 16bit colors, with 32bit colors I get exactly this error. Cheers manolito |
6th April 2015, 18:30 | #1214 | Link | ||
Software Developer
And this can be virtually anything! Like an access violation, a division by zero, an illegal instruction or whatever. We won't know without further details... Here is a new Debug build, which might provide some insight on what's going on: http://sourceforge.net/projects/muld...0.exe/download Please use the Windows Debugger (WinDbg) for creating a proper stack trace: https://www.sendspace.com/file/xepka0
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 6th April 2015 at 18:36. |
6th April 2015, 20:44 | #1215 | Link | |
Converting 85 songs flac to mp3 VBR/quality level 1/algorithm-better quality. 61 seconds based on core and 50 seconds using 12 cores(HT). And much faster than version 4.10, seems to have a better use of the instances. Last edited by soneca; 6th April 2015 at 22:04. |
7th April 2015, 02:26 | #1216 | Link |
Minor point about latest version:
The FAQ.html file needs to be updated. For the qaac addon it still links to the deprecated version from January 2014. The Manual.html file has the correct links... Cheers manolito |
7th April 2015, 02:35 | #1217 | Link | ||
Software Developer
(There's also an FAQ section in the new manual file)
8th April 2015, 02:03 | #1219 | Link | |
Cheers manolito P.S. A little bit Off-Topic... The latest SoX downloads 14.4.2 at SourceForge only offer dynamic versions containing dozens of library DLLs. (The previous version 14.4.1 war almost static, only 2 additional DLLs required). Now the current LameXP version contains a patched SoX version 14.4.2 which not only has DynamicAudioNormalizer built in, but it also is absolutely static, no separate DLLs required. Great! Can I use this version to replace SoX in my plugins, or are there any catches? |
8th April 2015, 19:43 | #1220 | Link | ||
Software Developer
Does anybody use that encoder nowadays, given that people generally seems to favor QAAC and given that Winamp (where the encoder DLL was taken from) is gone for good? Quote:
My binary is kind of a "minimal" build, with all the optional lib's disabled. That's because I don't use SoX for encoding/decoding or for other fancy stuff. If you don't mind about a few missing optional features, there's nothing to worry. (BTW: Also some of the libraries included with the official SoX binaries are specific to MinGW. My binary is created with MSVC/ICL, and with the static C++ Runtime)
Go to https://standforukraine.com/ to find legitimate Ukrainian Charities 🇺🇦✊ Last edited by LoRd_MuldeR; 8th April 2015 at 19:46. |
aac, aotuv, flac, lame, lamexp, mp3, mp4, ogg, oggenc, opus, vorbis |
