Old 6th November 2013, 08:50   #61  |  Link
Cedvano
I confirm this error on Win 7 / 64Bits.
Cedvano is offline   Reply With Quote
Old 6th November 2013, 09:59   #62  |  Link
tymoxa
Originally Posted by frencher View Post
And CABAC ?
CABAC is ON by default.
tymoxa is offline   Reply With Quote
Old 6th November 2013, 10:36   #63  |  Link
videofan3d
My command:
FRIMDecode mvc -i CombinedMVC.h264 -o \\.\pipe\TMP.yuv | FRIMEncode.exe mvc -i \\.\pipe\TMP_L.yuv -i \\.\pipe\TMP_R.yuv -viewoutput -o output_L.h264 -o output_R.h264 -w 1920 -h 1080 -dstw 1280 -dsth 720 -f 23.976 -vbr 10000 20000 -u 4
pause
The errors I get:
ERROR: Cannot open input file \\.\pipe\TMP_L.yuv
ERROR: File reader initialization failed.
ERROR: Cannot start encoding process.
I am on Windows 7 /64 bit.
All files are in the same folder. Does it have to be a special folder? Root directory?
There are two issues:
1. failure above is related to timing. Encoding process is trying to read from named-pipe which Decoding process didn't open yet
2. beside of this, there is bug when reading end of pipe.
I'll check it and fix it.
videofan3d is offline   Reply With Quote
Old 6th November 2013, 15:00   #64  |  Link
Sharc
Thanks! Glad you traced the cause.
Old 7th November 2013, 10:01   #65  |  Link
Sharc
Why dont use FRIMTranscode.exe with both output: output_L.h264 and output_R.h264
We can use FRIMtranscode.exe to produce a re-encoded CombinedMVC.h264:
FRIMTranscode.exe -i::mvc CombinedMVC.h264 -o::mvc TranscodedCombinedMVC.h264 -w 1920 -h 1080 -f 23.976 -l 4 -b 8000 -u 4
The transcoded .h264 can then be remuxed with the new tsMuxeR.
FRIMTranscode.exe so far seems not support -vbr or any of the other advanced options which are available with FRIMEncode.exe. However it avoids the huge *.yuv intermediate files and could be a workaround until the fix for named pipe becomes available.
Old 7th November 2013, 10:30   #66  |  Link
videofan3d
Pipe-fix will be available soon, likely on Friday night, so you can test it over weekend.
FRIOM Transcoder modification (cbr, vbr, gop, ...) is on roadmap.
Old 7th November 2013, 10:35   #67  |  Link
Sharc
Wow! Good News. Just take your time .... no hurry.
Old 7th November 2013, 11:16   #68  |  Link
colinhunt
Fantastic! Thank you very much for all your hard work.
Old 7th November 2013, 19:23   #69  |  Link
HWK
HWK's Avatar
videofan3d can you add support for frame serving through directshowmvcsource plugin, currently when I open avs file in encoder I get message can't determine number of frames. I tired SBS as well and same thing is happening. However If I open file in virtual dub it correctly display how many frames video has and frame rate as well.
Old 7th November 2013, 20:13   #70  |  Link
videofan3d
I don't understand.
Please describe your needs what do you want to achieve.
Avisynth is mighty tool (and well proven), I use for interractions between all my videoapplications without difficulties. Whenever I had a problem - it was always caused by mistake in my avs-script .
Old 7th November 2013, 20:38   #71  |  Link
videofan3d
Frim 1.11
there is new version FRIM 1.11
FRIM Encoder 1.11
- fixed bug in handling named pipes (.yuv)
FRIM Decoder 1.11
- separate main and dependent views on input are supported
FRIMDecode mvc -i input_L.h264 -i input_R.h264 -o output.yuv
Old 7th November 2013, 21:04   #72  |  Link
frencher
French Love
Yeah i test your update NOW !!!
It's possible to compile all *.exe to x64 for increase speed please.
Thank
2013-11-29 MVC Player Free v0.0.2.6 BD & 3D BD's Player, Demuxer v0.0.0.8b, Recoder. Tutorial
Demo for MVC Player Free: Trailer 3D
3DBD's Free - v0.0.0.0005.exe Old
Programing free for all.
frencher is offline   Reply With Quote
Old 7th November 2013, 21:11   #73  |  Link
videofan3d
Unfortunately, MSVC x64-compiler is not free...
Old 7th November 2013, 21:40   #74  |  Link
frencher
French Love
There seems to have the better with pipe
By FrimEncoder against crashes during encoding with avisynth or MVC track is not decoded to give a black image instead of the right view (MVC).
A sync problem or Memory buffer
Old 7th November 2013, 21:43   #75  |  Link
videofan3d
How do you run it? Please provide me with details...
Old 7th November 2013, 22:10   #76  |  Link
colinhunt
How much does it cost? Perhaps we could pass a hat around...
Old 7th November 2013, 22:11   #77  |  Link
frencher
French Love
Avisynth Script:
LoadPlugin ("F:\MVC Player\MVCtoAVI.exe\DirectShowMVCSource.dll")
# Start AVS for CombinedMVC
File   = "G:\Video.mts"
Left   = DirectShowMVCSource(File,decodeleft=TRUE)
Right  = DirectShowMVCSource(File)
Video  = StackHorizontal(Left,Right) (3840x1080 @ 23.976 fps)
# End   AVS for CombinedMVC
Video  = Video.ConvertToYV12()
Return Video
Batch:
"F:\MVC Player\MVCtoAVI.exe\Tools\Frim MVC Decoder Encoder\FRIMEncode.exe" mvc -i "F:\MVC Player\MVCtoAVI.exe\Preview.avs" -avi -sbs 2 -viewoutput -o H:\L.h264 -o H:\R.h264 -b 60000 -u 4
Old 7th November 2013, 22:13   #78  |  Link
colinhunt
FRIM Decoder 1.11
Does this mean I can feed it demuxed h264 files directly from a 3DBD?
Old 7th November 2013, 22:17   #79  |  Link
HWK
HWK's Avatar
Avisynth Script:
Return Video
Batch:
Does it work for you? I tired with Directshowmvcplugin but no go for me and then I decied to send whole package to author for testing. Except magic path is stereoplayer.exe instead mvc toavi.exe
Old 7th November 2013, 22:17   #80  |  Link
HWK
HWK's Avatar
I would think so, give it a try and let us know how it goes for you.
encoders, mvc
