#23322 | Link |
@ raul124; RE: Worknstiff so what is your process to make a clean 3D with QuicSync and speed need it?
Unfortunately I was never able to get QuickSync to work using my 2nd gen Sandy Bridge 2600k, but at least no artifacts in the 3D. |
#23328 | Link |
This maybe self inflicted, but I have tried reinstalling all helper apps and doing a new BD_Rebuilder setup but still keep getting the FRIMDecode.exe has stopped. It seems that it's working on the first m2ts but as soon as it extracts the VID_00098 it fails. I can't remember if I have done any previous VC1 3D's so maybe thats the problem. I have checked and double checked that I have VC1 enabled for wmv9. Here are the logs:
[11/09/15] BD Rebuilder v0.50.11 [22:19:03] Source: THE_WIZARD_OF_OZ - Input BD size: 29.95 GB - Approximate total content: [02:04:13.278] - Target BD size: 22.95 GB - Windows Version: 6.1 [7601] - Quality: High Quality (Default), ABR - MVC 3D Output Mode enabled - Decoding/Frame serving: FRIMDecode - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=640 [22:19:05] PHASE ONE, Encoding - [22:19:05] Processing: VID_00017 (1 of 2) - [22:19:05] Extracting A/V streams [VID_00017] - [22:19:20] Reencoding video [VID_00017] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 8,159 frames - Bitrate: 6,934 Kbs - Using FRIMEncoder for MVC encoding - [22:19:20] Reencoding: VID_00017, Pass 1 of 1 - [22:24:46] Video Encode complete - [22:24:46] Processing audio tracks - [22:24:46] Multiplexing M2TS - [22:24:51] Scanning for 3D CLPI info... - [22:24:53] Processing: VID_00098 (2 of 2) - [22:24:53] Extracting A/V streams [VID_00098] - [22:36:34] Reencoding video [VID_00098] - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 146,377 frames - Bitrate: 20,819 Kbs - Using FRIMEncoder for MVC encoding - [22:36:34] Reencoding: VID_00098, Pass 1 of 1 [22:40:12] - Failed video encode, aborted [11/09/15] Checking System Settings - BD-Rebuilder v0.50.11 - Windows Version: 6.1 [7601] - Working Path Free Space: 89.31GB - AVISYNTH Version: 2.5.8.0, Ok - LAVFILTERS: Ok - AnyDVD settings check: Ok. - X264: Ok - AFTEN: Ok - FAAC: Ok - MP4BOX: Ok - WAVI: Ok - TSMUXER: Ok - FRIMEncode: Ok - FRIMDecode: Ok [11/09/15] Systems Settings Check complete INF-------------------------------------------------------------------------------- [Status] LABEL=THE_WIZARD_OF_OZ VERSION=v0.50.11 SOURCE_SIZE=32153578039 SOURCE_VIDEO_SIZE=30181324800 TARGET_SIZE=24641536000 REDUCTION=.751102972159791 RESIZE_1080=0 RESIZE_1440=0 AUDIO_TO_KEEP=eng;spa; KEEP_HD_AUDIO=-1 SUBS_TO_KEEP=eng;fra;fre;spa; BACKUP_MODE=0 MOVIEONLY_TYPE=0 USE_LAVF=0 INSTANCES=1 DGDECNV=0 DGDECIM=0 FRIMSOURCE=0 FFMS2=0 SSIF_MODE=-1 QUICK=0 ENCODE_STEP=1.5 COMPLETED=1 [00017] AUDIO= PGS= VIDEO2=0 V2MBRATE=0 M2TS_TARGET=317256666 RATE=6934 NSTART=27000000 NEND=42313423 NSIZE=180056064 FLINK=0 MLINK=0 [00098] AUDIO=1000010000000111 PGS=1111111111000000000000000100100 VIDEO2=0 V2MBRATE=0 M2TS_TARGET=22352026095 RATE=20819 |
#23329 | Link | |
I'm sorry, didn't know about the pictures situation. Here's the log of the problem: ---------------------- [11/10/15] BD Rebuilder v0.50.11 [14:03:14] Source: Test\BDMV\STREAM\00003.m2ts - Input BD size: 37,12 GB - Approximate total content: [03:04:01.697] - Target BD size: 22,95 GB - Windows Version: 6.2 [9200] - Quality: High Quality (Default), ABR - Decoding/Frame serving: DirectShow - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=640 [14:03:14] PHASE ONE, Encoding - [14:03:14] Processing: VID_00003 (1 of 1) - [14:03:14] Extracting A/V streams [VID_00003] [14:03:26]PHASE ONE aborted by user request ---------------------- [11/10/15] BD Rebuilder v0.50.11 [14:04:00] Source: Test\BDMV\STREAM\00003.m2ts - Input BD size: 37,12 GB - Approximate total content: [03:04:01.697] - Target BD size: 22,95 GB - Windows Version: 6.2 [9200] - Quality: High Quality (Default), ABR - Decoding/Frame serving: DirectShow - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=640 [14:04:01] PHASE ONE, Encoding - [14:04:01] Processing: VID_00003 (1 of 1) - [14:04:01] Extracting A/V streams [VID_00003] - Extracting video streams [VID_00003] - Extracting secondary video [VID_00003] - Extracting audio streams [VID_00003] - Error in attempt to extract audio/subs. - Reading buffer overflow. Possible container streams are not syncronized. Please, verify stream fps. File name:L:\Test\BDMV\STREAM\00003.m2ts - Error in attempt to extract audio/subs. - Reading buffer overflow. Possible container streams are not syncronized. Please, verify stream fps. File name: L:\Test\BDMV\STREAM\00003.m2ts [14:15:00] - Failed to retrieve audio, aborted |
#23330 | Link |
After some more investigation the only thing weird about the 00098 file is this:
![]() It seems like 16 audio streams and 31 text streams is a bit much, but it also has a weird second audio stream of only 192k mono. Maybe someone can enlighten me on why this would crash FRIM. I have since this failure used this same BD_Rebuilder install to do other 3D's and it works just fine on those other 3D movies. It must be something special about this specific m2ts that is choking FRIM. |
#23333 | Link |
Have done a new 3D encode (Minions 3D) without hardware encoding.
Takes me over 4 hours. But: I got artifacts! So what's the problem? How can it be fixed? So BDRB is useless for me, because i can't encode BD50->BD25 without getting artifacts. Is it possible to get the "old way" working again to get an encode with SSIF folder/files? |
#23335 | Link |
Using SW Player, because of HTPC
And no, i dont want to burn to use encodes with hw player.... Also already tested with hardware player like i wrote before and got also artifacts Checked the hidden.txt file but can not find any option for old way encoding Just 3D method hsbs, hou, anaglyph And output 3D iso for movie only encode |
#23336 | Link |
@ KeVe1983 RE: i dont want to burn to use encodes with hw player....
Most HW Blu-ray players will let you use Folders or even ISO's for playback. That will rule out SW players that are notoriously problematic with 3D, that's why jdobbs won't accept bugs re-guarding them for playback. And output 3D iso for movie only encode? FROM the CHANGES.txt April 7th, 2014 - v0.47.04 - Implemented 3D Full Backup Mode. Note that BD-RB converts 3D method so that the SSIF folder is no longer required -- the method is 100% compliant with the BD standard. (v0.47.03) - Due to the changes in the way 3D is handled, BD-RB no longer outputs to ISO by default on movie-only 3D encodes. It can be enabled by using the OUTPUT_3D_ISO hidden option. Note: This option only applies to movie-only 3D encodes. (v0.47.03) - Made in-mux (single M2TS) 3D multiplexing mode the default on full-backup 3D. This can be changed back with the hidden option FORCE_INMUX_3D=0. - Modified 3D movie-only mode so it also now uses the in-mux structure for BD-3D output. |
#23338 | Link |
Yes, maybe thats the problem, but this is not the solution.
Otherwise it should be clearly stated that 3D BD25 encodes are just working fine with hardware players. Oh sorry, they also did not work fine with all hardware players, like i said and tested before. So it should be clearly stated that 3D BD25 encodes are just working fine with some special kind of hardware players. I have a HTPC for playing all my files (TV-Shows, Movies, Bluray Discs) Why should i buy an external hardware player? Why should i buy blank bluray discs? (Btw. HDD capacity is cheaper) So if BDRB is useless there are only 2 options: - Backing up complete discs which need more disc space - Using ***Fab for encoding which has very poor quality in complete bd25 encodes even on highest quality settings Or maybe it's possible to get BDRB working the old way with SSIF folder/files. That would fix all issues for playback with software players. |
#23339 | Link |
Special hardware? Yeah right, my 3-4yr old panny DMP-BD100 plays them fine. No "special" hardware whatsoever. Sure, HDD may be cheaper but it's also riskier. I'd rather have 1 scratched disc i have to rebuild then a couple hundred lost when a harddrive crashes.
And i know the feeling about DVDCrap, 3D quality sucked when i tried it. 90% of the discs i tried it would fail at one point or another during the encode, and the other 10% of the time where it did go through the encode didn't work at all or there were FAR MORE pixellation issues than BDRB output now. SSIF structure IS available (at least for movie-only, not sure about full disc) as detailed in the hiddenopts.txt file. |
#23340 | Link |
I remember that my parents had a Sony BD Player and my BDRB 3D encodes where fine. now they have a Philips BD player and have these artifacts. So there must be a diffence between some players.
I'm controlling my HTPC with a remote and i can access and play all my files so easily. So i just don't want an extra hardware player. I also like Bluray menues and extras, so movie only is normally no option. But i'll try an Movie only encode with FORCE_INMUX_3D=0 + OUTPUT_3D_ISO later. Maybe jdobbs can say if FORCE_INMUX_3D=0 will also work on bd25, or implement this in a futre update. Fab is really crap! Did a hardware encode and it takes me 90 Minutes for a disc which is pretty okay for me. But the picture was extremly pixelated in scenes with high bitrates. So i did an "HQ" encode which took me 8+ hours. But the result isn't even better than the fast quality setting. |
