#27327 | Link |
@Jdobbs and others interested. I have an update on that issue where i was unable to get Intel QuickSync to work with BDRB while having my GTX 1080 being used for actual display.
Now: as to the update. After doing some research last monday (again), i read one on of the sites that even though the iGPU would be enabled in the motherboard BIOS that it would shut itself off if no display was connected. So i though, "i wonder if there's something to simulate an attached display". So i went onto Amazon (UK), and entered "HDMI dummy plug". Lo and behold, there was. Multiple ones. So i looked through a couple and ordered this one: https://www.amazon.co.uk/gp/product/B072PV6K8J It arrived today, i just got home, grabbed it, plugged it straight in to the onboard hdmi. Instantly an "Intel HD Graphics" icon popped up in my system tray and when i checked windows control panel > Display, there was indeed a "third monitor". So i though, i wonder if it'll work. If it doesn't back to amazon. So i loaded a 3D iso in VCD. Fired up BDRB and placed the following in the ini file "FRIM_SW_DECODE=0" and "FRIM_SW_ENCODE=0" to let everything being handled automatically. Pressed "Backup" and after about 5 min of demuxing, where it would first stall for about 10-15sec and then fail, after mere seconds the FPS started ticking... 10, 20, 30 (passed that 88 someone mentioned) and it's peaking out at 116,8!!!! fps on "Sin_City_2_3D". So i guess it worked! Long story short, if you fail to enable FRIM quicksync with bdrb on 3D sources with a discrete graphics card used for your monitors. Grab a $10 hdmi or DVI dummy plug and install that. Problem solved! Now to hope there won't be any graphical glitches (or has that problem that was present in early builds with hardware encoding being used) been solved? ** edit ** FPS capped out at 117.11FPS. Not bad coming from 20-24 FPS. Thats nearly x5. Multipluxing the wanted streams back together took a whopping 33 seconds ![]() Last edited by Ch3vr0n; 18th May 2018 at 16:26. |
#27329 | Link | |
Lol and the build to ISO on my samsung 960 Pro took a whopping 50 seconds
![]() That only leave's this @Jdobbs Quote:
**edit** nupe. Setting 0/0 results in severe pixellation issues. Guess i have some tinkering to do to find out which settings work best. Last edited by Ch3vr0n; 18th May 2018 at 18:06. |
#27330 | Link |
@ Ch3vr0n; RE: severe pixellation issues. Same here also. The quicksync encodes all have some pretty serious crosstalk issues. Wonder if this is why Clone doesn't do full 3D backup. Kudos to BD_Rebuilder for PERFECT 3D backups, even if slow software FRIM.
#27332 | Link |
0/0 and 1/0, result in pixellations. Trying 0/1 next. Are those dll's included in the current release of bdrb? If not, care to link them? Maybe my FRIM could use an update but there's no link to an officially supported version in 1st post. Found this though https://www.videohelp.com/software/FRIM. Are those the ones or are you using others. (x86 or x64) You also say dlls plural, i only have frimsource.dll in bdrb folder.
#27333 | Link | |
![]() Join Date: Oct 2001
#27334 | Link | |
1) You have an internal GPU chipset and 2) The internal GPU is an Intel chipset. |
#27336 | Link | ||
![]() @jdobbs i did some looking into the Intel Media SDK and found this https://forum.doom9.org/showthread.php?t=170315 Starting post 6 and beyond it becomes interesting. The glitching might be specific to the right eye stream. The fix might be Quote:
#27337 | Link |
@jdobbs
In archive x264 mode, is each of the hidden and non-hidden full-backup related settings applied? Is it exactly like a full-backup mode except for using fix crf value for all of the titles including extras and secondary video streams as well? Archive_AUDIO is only for x265 mode? In x264 mode, Archive_CRF parameter overrides all other CRF values concurrently set as well? If I leave ARCHIVE_QUALITY on default value while using non-auto quality settings, will my quality settings be picked up by BD-RB? This feature sounds very promising anyway for my archiving purposes. Thank you very much for the help. |
#27338 | Link | |
#27339 | Link |
No idea if it was confirmed. I stopped reading after I read about the switch. Figured I'd let you know immediately. There's only one way to find out if it'll work and that's to try it with bdrb.
Sent from my Nexus 6P with Tapatalk |
#27340 | Link |
Help with Special Characters
Having just acquired a new PC for editing, was forced to migrate to Win 10. With this O.S. I suffer a constant drawback with Multiavchd ( I've been using this software for many years for multiepisodic BD's with satisfactory results): it doesn't accept my menu image and always uses its default.
Sorry for the digresion. Decided to try a way to do it with BD-Rebuilder that I copied and kept years ago. When I import the MKV files set in the same folder with the name of the BD I want (all mkv's are compliant), the process always aborts when it enounters latin accentuated words, in this specific case, of 12 files, 4: -Satélite -Tecnología -Área -Titánico I'm sure there must be a way to solve it, but I wasn't able to locate it. Would appreciate any help. Thanx ![]() |
