24th June 2020, 23:07 | #29501 | Link | |
[Edit] Ok, I see. It was part of the "3 frigg'n MONTHS behind" post. I guess I just missed that part. Last edited by jdobbs; 24th June 2020 at 23:10. |
26th June 2020, 14:02 | #29502 | Link |
Does anyone out there have some suggestions for a command line (for NVEncC.exe) that will create an .hevc file that is compatible with UHD blu-ray? I can create one that will compile and play (in UHD and HDR), but any attempts to fast forward/rewind or chapter skip will result in a blank screen (sound only). I've been beating my head against the wall for a couple days now -- and any help would be appreciated.
Thanks. |
26th June 2020, 16:08 | #29503 | Link | |
https://rigaya34589.blog.fc2.com/ |
26th June 2020, 16:35 | #29504 | Link | |
I was under the impression that people have actually done UHD-BD encodes with this encoder. I'm hoping they can provide me with something that points out what I'm missing. With this specific behavior I thought that maybe it wasn't creating I frames at the right distances/places, but I brought the resulting HEVC stream up with an HEVC browser and it looks like they are at the right places. I'm thinking now that maybe it's missing some of the supplementary information, but I'm not really sure? I guess I can do some comparisons to X265 output and see. But even if that is it -- I'd still need some way to add it. Last edited by jdobbs; 26th June 2020 at 16:44. |
26th June 2020, 20:08 | #29505 | Link | |
https://github.com/rigaya/NVEnc/issues |
27th June 2020, 17:42 | #29506 | Link | |
27th June 2020, 22:25 | #29507 | Link | |
Mediainfo doesn't show it (to me) ... can only be seen in VLC Player: Video Resolution: 3840x2160 Buffer dimensions: 3840x2176 With CU Size set to 32 and 2160 isn't divisible by 32, result is set to 2176 which could end up in UHD incompatibility ... In the original mt2s the values are identical. So .. 2 possibilities ... setting CU size to 16x16 (if possible) or crop away 16 pix vertically and hope its still compatible Just an idea ... |
27th June 2020, 22:25 | #29508 | Link |
Thanks for confirming it. My guess is there is some supplementary header information missing in the i-frame since that is what is used for FF/REW & CHAP jumps. I'm looking to see if I can find anything and possibly fix it myself. I can't find anything in the command line options that might change it significantly. Of course BD-RB fixing it would mean that after an encode I'd have to scan and rewrite the .hevc file (which can add some time to the process). I posted and error report on the site Sharc listed, hopefully someone will actually see it and respond -- but it looks like there are quite a bit of other reports there as well.
28th June 2020, 01:15 | #29509 | Link | |
There's a discussion on this topic at this link. I'm not sure if there is a solution in the works... [Edit]@cartman0208 The encoder allows me to set the CU to 16 (--cu-max 16) - but it seems to have no affect on the SPS value (as it still says 3840x2176 with a bottom offset of 8). The Blu-Ray spec specifically states that these values aren't allowed -- but my guess is that the player's hardware allows it (per the H.265 standard), and that's why the video is playing back. For right now I'm going to pretend this isn't the issue -- but I'll investigate further. Last edited by jdobbs; 28th June 2020 at 01:49. |
28th June 2020, 04:01 | #29510 | Link | |
28th June 2020, 11:25 | #29511 | Link | |
What I didn't try was my second suggestion ... initially crop away 16 pixel to a height of 2144, which is divisibly by 32... Too small should be less of a problem then too big... or does the BluRay standard say EXACTLY 2160px in height? I'm still wild guessing here, but maybe the screen can't display the oversize and stays blank ... Last edited by cartman0208; 28th June 2020 at 11:47. |
28th June 2020, 13:41 | #29513 | Link | |
28th June 2020, 22:07 | #29515 | Link |
Looking at the output from NVENCC, I'm guessing (but only guessing) that this may be the issue:
According to "White Paper Blu-ray Disc Read-Only Format Coding constraints on HEVC video streams for BD-ROM Version 3.0", page 6, each GOP (Group of Pictures) of the HEVC stream must start with an IDR (of course) -- and will contain one SPS (Sequence Parameter Set), one VPS (Video Parameter Set), and at least one PPS (Picture Parameter Set), and no more than 30 PPSs. In dumping out the HEVC stream I'm finding that only the first GOP (the first IDR frame and following P/B frames in the file) meets this requirement. All the others IDR frames (start of GOP) I've looked at only have an AUD (Access Unit Delimeter) and a couple SEI's (Supplemental Enhancement Information) preceding the IDR slice. I'll have to do some finagling with the stream to find out if this is truly the issue -- but it could make sense and explain why the stream can start playing from the beginning (the IDR that has the required information) but can't step into any of the others (FF/REW and CHAPTER SKIPS). You never know, this may not be the problem at all... but I guess I'm going to have to find out somehow. In X265 you create a stream that contains the SPS/VPS/PPS in every GOP by using the --repeat-headers command line option. I'm hoping the same thing can be done in NVENCC. I've added this information to my Issue Report at GITHUB. Hopefully someone with a little more HEVC/UHD-BD knowledge than me can confirm or deny this as the cause of the issue I'm seeing. [Edit] In the meantime, I'm going to see how hard it would be for me to to scan and insert the headers via a software routine -- or if it is even possible. Unfortunately that would require me to read through the entire HEVC file and write a new one -- which requires significant processing time. In the end I may find out it isn't even the problem! Last edited by jdobbs; 28th June 2020 at 22:52. |
29th June 2020, 01:54 | #29516 | Link | |
That was it. I wrote some code to insert the SPS/VPS/PPS headers into the IDR of each GOP and... it fixed the issue. Fast Forward, Rewind and Chapter jumps now work. I'll add code into BD-RB to correct the HEVC stream after encoding. It looks like it will add about 15 minutes or so to a job. But that's not bad considering how much time is saved using the NVENCC encoder. I just ran a complete job on a 2 hour and 22 minute UHD/HDR movie and it finished the encoding portion in less than 30 minutes (using the fastest setting). I have to add supporting code for several subroutines before BD-RB is ready for a testing release -- expect it in the next week or so. I will also update my issue information on GITHUB and hopefully all the will have to do is add a "--repeat-headers" command line function and make my workaround unneeded. |
29th June 2020, 12:51 | #29520 | Link |
Yes. It was only an issue when authored into BD format and played on a Blu-Ray player. On a PC it had worked fine. I didn't test it, but I would assume an MKV or MP4 would probably have played even on the BD unit. The issue (needing the headers in each GOP) is related to the container type used in an authored BD.
