#29621 | Link | |
![]() Actually a lot of parameters can just be copied ... like colormatrix, master-display and so on, even the audio... https://github.com/rigaya/NVEnc/blob..._Options.en.md Doesn't that make your job a lot easier? |
#29622 | Link | |
![]() Join Date: Oct 2001
As for the other settings that can be copied... they are readily available in a BD structure and BD-RB already has the code to extract it and use it. My attention-to-detail tendencies also make me want to have control over things like that rather than "trust" other software. Just a note on that. In my testing, I'm finding (as you might expect) that X265 is significantly more efficient than the NVIDIA hardware encoder. For example, if you encode some sources with a CQM of 25 using the hardware encoder you will get a file that is twice as large as one created by X265 with a CRF of 25. Of course you also have to factor in that the hardware encode is about 20-40x faster... Last edited by jdobbs; 15th July 2020 at 14:09. |
#29623 | Link | |
#29624 | Link | |
More on the "--multipass" thing: It turns out that setting --vbrhq mode automatically sets the encoder to do 2 pass-full. So I'm not sure that there is actually any additional capability associated with that parameter other than it may provide a bit of granularity (with the ability to set 2pass-quarter). |
#29625 | Link | |
#29626 | Link |
hmm i wonder if the AMD Ryzen Threadripper 3970X Processor (32 Core / 64 Threads , 128 MB Cache, 4.5 GHz Boost) would bring x265 times down ? its only 1.8k for the chip :P
#29627 | Link |
Aging Video Hobbyist
The discussion of quality settings makes me smile. My first BD backup/conversion, in Oct 2008 before BD-RB was born iirc, was Live Free or Die Hard which as you all know is action-packed. Yet when compressed to less than 4GB DVD-size it looked flippin' awesome the couple times I played it. I will have to break it out sometime and see how it holds-up 12 years later!
#29628 | Link |
Test Release of BD-RB -- with NVENC support
I've created a test release (v0.61.06) of BD Rebuilder for anyone who would like to experiment and report any issues they see with the new support for NVIDIA/NVENC support.
Please note that in order to use the new capability you must run BD-RB on a system that has an NVIDIA card installed that supports NVENC. You can find out more about which cards can be used at this link. BD-RB does a check when you attempt to select the NVENC encoder (under the SETTINGS menu). There were a considerable number of changes to this release, so this version should be considered "for testing purposes only", so I'm not updating the first post of this thread -- please try it and let me know your experiences and report any bugs you find. BD-RB v0.61.06 Thanks. Last edited by jdobbs; 17th July 2020 at 16:45. |
#29629 | Link | |
(had to restore and exclude this) Last edited by Mark_Venture; 17th July 2020 at 17:33. |
#29630 | Link |
First encode looks pretty awesome, but I wanted to compare more closely, so I tried AviSynth interleave (first time for me) on the m2ts files
Immediately I noticed random artifacts on the reencoded file. Code:
a=DirectShowSource("U:\FullDisc\OLYMPUS_HAS_FALLEN\BDMV\STREAM\00021.m2ts").Subtitle("O", align=2, size=30, text_color=$ffffff) b=DirectShowSource("U:\BD-Output\OLYMPUS_HAS_FALLEN\BDMV\STREAM\00021.m2ts").Subtitle("NV", align=2, size=30, text_color=$ffffff) return interleave(a, b) Any Hints from the AviSynth pro's? |
#29631 | Link |
First encode of ALT-Movie Only (MKV Container, HEVC, NO_Resize, Intact Audio) of Avengers Endgame was quick. ABout 1hr 21 min.
[07/17/20] BD Rebuilder v0.61.06 [12:35:56] Source: AVENGERS_ENDGAME-4K_00004 - Input BD size: 59.49 GB - Approximate total content: [03:01:11.527] - Windows Version: 6.2 [9200] - MOVIE-ONLY/ALTERNATE OUTPUT mode enabled - Mode: MKV Container, HEVC, NO_RESIZE, Intact Audio - Quality: High Quality (Default) - Decoding/Frame serving: NVENCC - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=640 [12:35:59] PHASE ONE, Encoding - [12:35:59] Processing: VID_00055 (1 of 1) - [12:35:59] Extracting A/V streams [VID_00055] - [12:56:49] Reencoding video [VID_00055] - Source Video: HEVC, 3840x2160 - Rate/Length: 23.976fps, 260,656 frames - [12:56:49] Reencoding: VID_00055, Pass 1 of 1 - [13:45:26] Video Encode complete - [13:45:26] Processing audio tracks - Track 4352 (eng): Keeping original audio - Track 4353 (eng): Keeping original audio [13:45:26]PHASE ONE complete [13:45:26]PHASE TWO - Rebuild Started - [13:45:26] Building ALTERNATE OUTPUT Structure [13:56:22] - Encode and Rebuild complete [13:56:22] JOB: AVENGERS_ENDGAME-4K finished. using the following ini... Code:
[Options] VERSION=0.61.0.6 ENCODER=1 MODE=3 ENCODE_QUALITY=2 ONEPASS_ENCODING=0 AUTO_QUALITY=0 AUDIO_TO_KEEP=eng; SUBS_TO_KEEP=eng; SD_CONVERT=0 OPEN_GOP=0 RESIZE_1080=0 RESIZE_1440=0 RESIZE_720=0 DEINTERLACE=1 SD_TO_1080=0 IGNORE_3D=0 CONVERT_WIDE=0 DTS_REENCODE=0 AC3_REENCODE=0 AC3_640=1 AC3_192=0 KEEP_HD_AUDIO=1 DECODER=3 AVCHD=1 REMOVE_WORKFILES=0 REMOVE_OUTPUT=0 USE_FILTERS=0 BDMV_CERT_ONLY=0 IVTC_PULLDOWN=0 ASSUME_DVD_PAL=0 FRIMSOURCE=0 COMPLETION_BEEP=0 OUTPUT_SBS=1 NEROAAC=0 SUPTITLE=0 AUDIO_TRACK_LIMIT=0 SUBTITLE_TRACK_LIMIT=0 CUSTOM_TARGET_SIZE=23500 PRIORITY_CLASS=0 TARGET_SIZE=23500 MOVIEONLY_TYPE=40 ALTCRF=19 ALT_TARGET=8096 ALTMETHOD=0 ALTAUTOCROP=0 QUICK_EXTRAS=1 AUDIO_DRC=0 PGSTOSRT=0 ALT_CRF_TARGET=1024 FRIM_SW_DECODE=0 FRIM_SW_ENCODE=0 NVENC_CAPABLE=1 [Paths] SupTitlePath=C:\Program Files (x86)\AviSynth\plugins\SupTitle.dll SOURCE_PATH=H:\BLURAY\AVENGERS_ENDGAME-4K\ WORKING_PATH=F:\BLURAY-WORKING\ DGIndexNV=D:\BD_Rebuilder\dgdecnv\DGIndexNV.exe DGDecNV=D:\BD_Rebuilder\dgdecnv\DGDecodeNV.dll Code:
General Unique ID : 220642287505551334163210721554557699978 (0xA5FE28AA6D37327D898374BC265A078A) Complete name : F:\BluRay-Working\AVENGERS_ENDGAME-4K.mkv Format : Matroska Format version : Version 2 File size : 27.7 GiB Duration : 3 h 1 min Overall bit rate mode : Variable Overall bit rate : 21.9 Mb/s Encoded date : UTC 2020-07-17 17:45:32 Writing application : mkvmerge v9.7.1 ('Pandemonium') 32bit Writing library : libebml v1.3.4 + libmatroska v1.4.5 Video ID : 1 Format : HEVC Format/Info : High Efficiency Video Coding Format profile : Main 10@L5@High HDR format : SMPTE ST 2086, HDR10 compatible Codec ID : V_MPEGH/ISO/HEVC Duration : 3 h 1 min Bit rate : 16.1 Mb/s Width : 3 840 pixels Height : 2 160 pixels Display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 23.976 (23976/1000) FPS Original frame rate : 23.976 (24000/1001) FPS Color space : YUV Chroma subsampling : 4:2:0 (Type 2) Bit depth : 10 bits Bits/(Pixel*Frame) : 0.081 Stream size : 20.3 GiB (73%) Default : Yes Forced : No Color range : Limited Color primaries : BT.2020 Transfer characteristics : PQ Matrix coefficients : BT.2020 non-constant Mastering display color primaries : Display P3 Mastering display luminance : min: 0.0050 cd/m2, max: 4000 cd/m2 Audio #1 ID : 2 Format : MLP FBA 16-ch Format/Info : Meridian Lossless Packing FBA with 16-channel presentation Commercial name : Dolby TrueHD with Dolby Atmos Codec ID : A_TRUEHD Duration : 3 h 1 min Bit rate mode : Variable Bit rate : 4 777 kb/s Maximum bit rate : 8 430 kb/s Channel(s) : 8 channels Channel layout : L R C LFE Ls Rs Lb Rb Sampling rate : 48.0 kHz Frame rate : 1 200.000 FPS (40 SPF) Compression mode : Lossless Delay relative to video : 1 ms Stream size : 6.05 GiB (22%) Language : English Default : Yes Forced : No Number of dynamic objects : 13 Bed channel count : 1 channel Bed channel configuration : LFE Audio #2 ID : 3 Format : AC-3 Format/Info : Audio Coding 3 Commercial name : Dolby Digital Codec ID : A_AC3 Duration : 3 h 1 min Bit rate mode : Constant Bit rate : 640 kb/s Channel(s) : 6 channels Channel layout : L R C LFE Ls Rs Sampling rate : 48.0 kHz Frame rate : 31.250 FPS (1536 SPF) Compression mode : Lossy Stream size : 829 MiB (3%) Service kind : Complete Main Default : No Forced : No Audio #3 ID : 4 Format : AC-3 Format/Info : Audio Coding 3 Commercial name : Dolby Digital Codec ID : A_AC3 Duration : 3 h 1 min Bit rate mode : Constant Bit rate : 320 kb/s Channel(s) : 2 channels Channel layout : L R Sampling rate : 48.0 kHz Frame rate : 31.250 FPS (1536 SPF) Compression mode : Lossy Stream size : 415 MiB (1%) Language : English Service kind : Complete Main Default : No Forced : No Text ID : 5 Format : PGS Muxing mode : zlib Codec ID : S_HDMV/PGS Codec ID/Info : Picture based subtitle format used on BDs/HD-DVDs Duration : 3 h 0 min Bit rate : 11.5 kb/s Count of elements : 5266 Stream size : 14.9 MiB (0%) Language : English Default : No Forced : No Menu 00:00:00.000 : en:00:00:00.000 00:08:06.068 : en:00:08:06.068 00:20:01.867 : en:00:20:01.867 00:26:15.448 : en:00:26:15.448 00:36:57.340 : en:00:36:57.340 00:43:20.764 : en:00:43:20.764 00:48:44.338 : en:00:48:44.338 00:57:36.911 : en:00:57:36.911 01:07:12.778 : en:01:07:12.778 01:16:02.683 : en:01:16:02.683 01:26:25.597 : en:01:26:25.597 01:32:20.284 : en:01:32:20.284 01:38:55.971 : en:01:38:55.971 01:48:12.527 : en:01:48:12.527 01:57:27.081 : en:01:57:27.081 02:05:00.409 : en:02:05:00.409 02:15:06.598 : en:02:15:06.598 02:25:50.616 : en:02:25:50.616 02:34:38.102 : en:02:34:38.102 02:43:04.065 : en:02:43:04.065 02:49:05.510 : en:02:49:05.510 03:01:11.277 : en:03:01:11.277 Playback on my 1080p monitor looked good. Will check on my 4K TV as soon as I get a chance to step away from my desk. I also just started a Full Backup to BD-25.. Will post results in a little bit. NOTE: my graphics card is an EVGA GTX 1660ti XC Ultra Gaming 06G-P4-1267-KR (full PC spec's HERE ) Last edited by Mark_Venture; 17th July 2020 at 19:30. |
#29632 | Link | |
#29634 | Link | |
Not that it matters, it's just a question. |
#29635 | Link | |
I think BD-RB has always been like that (also with x264/x265) to be compliant with disc standards. Seems to work for Alternate Encoding though ![]() |
#29636 | Link | ||
I am working on that ability -- to create a 1080p HEVC (UHD format) disc -- but I disabled that code for this release because I haven't tested it very well. Quote:
But, just as an aside... I have tried other formats (720p and 480p) using HEVC and UHD (V3) disc output and they also play on my Sony player -- so I might put a hidden option that allows HEVC there as well. It would be a great non-standard-but-working capability for creating series discs, since HEVC looks a lot better at lower bitrates. I'm usually hesitant to step out of the standard -- but I'd bet that most UHD players will accept it since the format/type tables have settings for it. Last edited by jdobbs; 17th July 2020 at 22:33. |
#29637 | Link | |
Would be a nice addition, because my SamsungTV can't play DTS and some older SmartTV models had trouble playing AAC ... AC3 just plays everywhere ![]() |
#29638 | Link | |
[00041] caption=MKV Container, HEVC, NO_RESIZE, Auto-AC3 vEncoder=1 vBitrate=1500 vKeyint=Auto aBitrate=* aType=0 vFormat=7 cType=1 I used [00041] because the default ALTERNATE.TXT file has 40 entries in it. Just adjust if yours has more or fewer. You could also replace one of the existing presets if you'd like that better. Honestly I thought I'd put one in there. I'm surprised that I didn't. Last edited by jdobbs; 17th July 2020 at 23:22. |
#29640 | Link | ||
UHD_V3_MODE=1 ...to your INI file. I haven't tested it much, but I'm pretty sure it would only work in movie-only mode right now. Don't forget to reset it to 0 after playing with it -- as it will try to make normal BD backups into UHD format. [Edit] Nope... sorry. I just ran a test on a 1080p source and, while it played, BD-RB failed to add the "--repeat-headers" parameter in the encode and FF/REW/CHAP isn't working (for 1080p output). I fixed it for the next release. Last edited by jdobbs; 18th July 2020 at 21:43. |
