11th September 2010, 20:55 | #9481 | Link | |
11th September 2010, 21:40 | #9482 | Link |
No no,I didn't touch it.
So,first try with Avatar all ok,I re-try with Robin Hood and same problem,I changed also the destination folder.. Here it is : MUXOPT --no-pcr-on-video-pid --new-audio-pes --demux --vbr --vbv-len=500 V_MPEG4/ISO/AVC, "F:\RHOOD\ROBIN_HOOD_G51\BDMV\STREAM\50214.m2ts", fps=23.976, track=4113 A_DTS, "J:\RH PROVAAAA\WORKFILES\50214.M2TS", track=4354, lang=ita S_HDMV/PGS, "J:\RH PROVAAAA\WORKFILES\50214.M2TS",fps=23.976, track=4610,lang=ita Log: [22:27:16] BD Rebuilder v0.34.09 (beta) - Source: ROBIN_HOOD_G51 - Input BD size: 34,53 GB - Approximate total content: [02:35:49.715] - Target BD size: 22,66 GB - Windows Version: 6.1 [7600] - MOVIE-ONLY mode enabled - Auto Quality: Good (Very Fast), ABR - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=640 [22:27:16] PHASE ONE, Encoding - [22:27:16] Extracting A/V streams [VID_50214] - Extracting A/V to M2TS [VID_50214] - Extracting A/V from M2TS [VID_50214] - Error in attempt to extract audio/subs. - H.264 stream does not contain fps field. Muxing fps=23.976 - Error in attempt to extract audio/subs. - H.264 stream does not contain fps field. Muxing fps=23.976 [22:36:09] - Failed to retrieve audio, aborted |
11th September 2010, 23:45 | #9483 | Link | |
Are there a lot of parts to the MOVIE_ONLY encode? Just as a test, try running BD-RB as administrator and see if you get the same error. If not, it means you need to give privileges to the output folder. Last edited by jdobbs; 11th September 2010 at 23:49. |
12th September 2010, 00:37 | #9484 | Link |
CPU usage
If CPU usage is normal at 98%-100% in the second pass, isn't idle priority supposed to allow you to do other things in the mean time while encoding via 2nd pass? It doesn't seem like BD Rebuilder is doing this. I'm on a Quad Core CPU with 8gb of ram and have always had this problem. It's smooth as normal on the 1st pass no matter the priority level set, but on 2nd pass is horrible on any priority level, including idle.
Anyone else having this issue? It would be nice to multitask if this is indeed an issue or have a pause button set so the x264 task is not at 100%. |
12th September 2010, 03:37 | #9485 | Link |
Something broke
I think something broke in the last 0.34.09 update.
Made a full BD25 backup of Monsters vs. Aliens Region A. Previous versions made perfect back up (except out of sync PIP audio to video as previously reported and patiently waiting for fix). Played perfect in Power DVD 10 and Panasonic BD35 standalone. Now I do full back up and there is no PIP secondary video but there is audio when playing on Panasonic player. It will not play in Power DVD at all. I tried this with the new setting "Use x264's internal LAVF for decoding" both on and off with the same results. Here is the log file: Code:
----------------------- [18:05:13] BD Rebuilder v0.34.09 (beta) - Source: MONSTERS_VS_ALIENS - Input BD size: 37.85 GB - Approximate total content: [02:31:42.351] - Target BD size: 22.90 GB - Windows Version: 5.2 [3790] - Auto Quality: Good (Very Fast), ABR - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=640 [18:05:13] PHASE ONE, Encoding - [18:05:13] Extracting A/V streams [VID_00071] - [18:05:43] Reencoding: VID_00071 (1 of 6) - [18:05:43] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 29.970fps, 11,368 frames - [18:05:43] Reencoding: VID_00071, Pass 1 of 1 - [18:12:34] Video Encode complete - [18:12:34] Reencoding audio tracks (if req'd) - [18:12:34] Multiplexing M2TS - [18:12:57] Extracting A/V streams [VID_00078] - [18:13:32] Reencoding: VID_00078 (2 of 6) - [18:13:32] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 29.970fps, 12,381 frames - [18:13:32] Reencoding: VID_00078, Pass 1 of 1 - [18:21:13] Video Encode complete - [18:21:13] Reencoding audio tracks (if req'd) - [18:21:13] Multiplexing M2TS - [18:21:31] Extracting A/V streams [VID_00073] - [18:23:09] Reencoding: VID_00073 (3 of 6) - [18:23:09] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 19,177 frames - [18:23:09] Reencoding: VID_00073, Pass 1 of 1 - [18:34:16] Video Encode complete - [18:34:16] Reencoding audio tracks (if req'd) - [18:34:16] Multiplexing M2TS - [18:34:37] Extracting A/V streams [VID_00072] - [18:36:07] Reencoding: VID_00072 (4 of 6) - [18:36:07] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 19,177 frames - [18:36:07] Reencoding: VID_00072, Pass 1 of 1 - [18:45:11] Video Encode complete - [18:45:11] Reencoding audio tracks (if req'd) - [18:45:11] Multiplexing M2TS - [18:45:27] Extracting A/V streams [VID_00011] - [18:46:42] Reencoding: VID_00011 (5 of 6) - [18:46:42] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 29.970fps, 31,425 frames - [18:46:42] Reencoding: VID_00011, Pass 1 of 1 - [19:03:34] Video Encode complete - [19:03:34] Reencoding audio tracks (if req'd) - [19:03:34] Multiplexing M2TS - [19:04:01] Extracting A/V streams [VID_00024] - [19:17:30] Reencoding: VID_00024 (6 of 6) - [19:17:30] Reencoding secondary video [TRK_02] - [19:25:30] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 135,745 frames - Bitrate: 10,471 Kbs - [19:25:30] Reencoding: VID_00024, Pass 1 of 1 - [20:32:57] Video Encode complete - [20:32:57] Reencoding audio tracks (if req'd) - [20:32:57] Multiplexing M2TS [20:43:45]PHASE ONE complete [20:43:45]PHASE TWO - Rebuild Started - [20:43:45] Rebuilding BD file Structure [20:47:20] - Encode and Rebuild complete [20:47:20] BURNING BD structure to disc - ImgBurn completed successfully - WORKFILES folder removed. [21:25:59]JOB: MONSTERS_VS_ALIENS finished. Code:
[Status] LABEL=MONSTERS_VS_ALIENS VERSION=v0.34.09 (beta) SOURCE_SIZE=40636279727 SOURCE_VIDEO_SIZE=34025797632 TARGET_SIZE=24589107200 REDUCTION=.528382179293624 RESIZE_1080=0 AUDIO_TO_KEEP=eng; SUBS_TO_KEEP=eng; BACKUP_MODE=0 MOVIEONLY_TYPE=0 USE_LAVF=0 QUICK=1 ENCODE_STEP=0 COMPLETED=6 REBUILD_COMPLETE=1 [00071] AUDIO=1 PGS=100 M2TS_TARGET=485729885 NSIZE=615364608 FLINK=0 MLINK=0 [00078] AUDIO=1 PGS=100 M2TS_TARGET=533506861 NSIZE=764362752 FLINK=0 MLINK=0 [00073] AUDIO=100 PGS=100 M2TS_TARGET=1114222581 NSIZE=828530688 FLINK=0 MLINK=0 [00072] AUDIO=100 PGS=100 M2TS_TARGET=1119085659 NSIZE=743847936 FLINK=0 MLINK=0 [00011] AUDIO=1 PGS=100 M2TS_TARGET=1341251681 NSIZE=1591517184 FLINK=0 MLINK=0 [00024] AUDIO=10011 PGS=11001001 M2TS_TARGET=13435001937 RATE=10471 NSIZE=12523001856 FLINK=0 MLINK=0 Moviewatcher666 Last edited by jdobbs; 12th September 2010 at 03:44. |
12th September 2010, 03:45 | #9486 | Link | |
12th September 2010, 13:14 | #9490 | Link | |
----------------------- [13:56:44] BD Rebuilder v0.34.09 (beta) - Source: ROBIN_HOOD_G51 - Input BD size: 34,53 GB - Approximate total content: [02:35:49.715] - Target BD size: 22,66 GB - Windows Version: 6.1 [7600] - MOVIE-ONLY mode enabled - Auto Quality: Good (Very Fast), ABR - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=640 [13:56:46] PHASE ONE, Encoding - [13:56:46] Extracting A/V streams [VID_50214] - Extracting A/V to M2TS [VID_50214] - Extracting A/V from M2TS [VID_50214] - Error in attempt to extract audio/subs. - Reading buffer overflow. Possible container streams are not syncronized. Please, verify stream fps. File name: F:\RH PROVA\WORKFILES\50214.M2TS - Error in attempt to extract audio/subs. - Reading buffer overflow. Possible container streams are not syncronized. Please, verify stream fps. File name: F:\RH PROVA\WORKFILES\50214.M2TS [14:06:31] - Failed to retrieve audio, aborted Sorry but I'm a beginner,how do give privileges to a folder? Last edited by Lord Axl; 12th September 2010 at 13:42. |
12th September 2010, 14:08 | #9491 | Link | |
12th September 2010, 19:58 | #9493 | Link | |
is this correct? (just to be sure ) |
12th September 2010, 23:27 | #9498 | Link |
- AVISYNTH Version: 2.5.7.0, Ok - HAALI Splitter: Ok - FFDSHOW: 3326, Ok - WIN7 preferred AVC CODEC: Ok - WIN7 preferred VC-1 CODEC: Ok - WIN7 preferred MPEG2 CODEC: Ok - FFDSHOW VC-1 set to "wmv9", Ok - FFDSHOW MPEG2 set to "libavcodec": Ok - FFDSHOW AVC set to "libavcodec": Ok - BD Rebuilder v0.34.0.9, Ok - X264: Ok - AFTEN: Ok - FAAC: Ok - MP4BOX: Ok - WAVI: Ok - TSMUXER: Ok ----------------------- [00:18:04] BD Rebuilder v0.34.09 (beta) - Source: NO_ES_TAN_FACIL - Input BD size: 33,05 GB - Approximate total content: [02:00:16.834] - Target BD size: 22,90 GB - Windows Version: 6.1 [7600] - AVS Filtering is enabled - Quality: Highest (Very Slow), CRF - Audio Settings: AC3=1 DTS=0 HD=1 Kbs=640 [00:18:05] PHASE ONE, Encoding - [00:18:05] Extracting A/V streams [VID_00010] after - AVS Filtering is enabled - Quality: Highest (Very Slow), CRF - Audio Settings: AC3=1 DTS=0 HD=1 Kbs=640 [00:18:05] PHASE ONE, Encoding - [00:18:05] Extracting A/V streams [VID_00010] - [00:25:18] Reencoding: VID_00010 (1 of 1) - [00:25:18] Collecting video information - [00:25:18] Keeping original video (no reencode) - [00:25:18] Reencoding audio tracks (if req'd) - [00:25:18] Multiplexing M2TS - Error in attempt to multiplex: MUX_00010.meta - SmartLabs tsMuxeR. Version 1.10.6 http://www.smlabs.net [00:25:26] - Failed to build structure, aborted I do not function or co windows 7 x64, xp. I need instructions to set up the program well. ism is always wrong to ...... I've tried various different folders rips ... thank you very much |
13th September 2010, 01:53 | #9499 | Link | |
13th September 2010, 14:34 | #9500 | Link |
Today I've tried to burn all the ROBIN HOOD disc on a BD-RE 50 Gb rewritable,without reencoding with RD-Reb,1:1 copy.
The disc is playing flawless on my PS3,so it wasn't a bad rip I think.Maybe BD-Reb has some problems with movies with a lot of Movie-Only files?Just asking |
