15th September 2010, 01:19 | #9521 | Link |
@ RB_Newbie: Quote:I've had 3 audio out of sync results. I also just had the issue on "That Evening Sun".
Me too, I tried the Clown_BD path, but for some reason the resulting Blueray output would not load into BD_Rebuilder, something to the effect of error 6205: not BD format. This has started to happen more often lately that output from both multiAVCHD and Clown_BD is not recognised as BD. I finally had to use tsMuxerGUI after BD_Rebuilder finished to delay the audio and get back in sync, (after about 5 tries). I think that the problem I had with Mary & Max and Girl With Dragon was that I couldn't run it thru Clown_BD because these disks had audio streams that were not recognised as compliant. It is hard to keep the audio if it isn't detected. I second the motion to be able to blank some short m2ts files. |
15th September 2010, 01:36 | #9522 | Link | |
15th September 2010, 01:42 | #9523 | Link | |
[Edit] I just started "The Girl with the Dragon Tattoo" in movie-only as a test. I'd deleted it from my hard drive, so its copying again. Good movie, by the way, a little disturbing but still good. Last edited by jdobbs; 15th September 2010 at 02:34. |
15th September 2010, 02:43 | #9524 | Link |
@jdobbs
Here's a link to the thread I spoke of earlier (regarding "The Girl with the Dragon Tattoo"): http://forum.doom9.org/showthread.ph...29#post1421929 Do read the entire thread - it contains only 4 or 5 posts - and confirms that my "fix" worked properly. Sorry, I didn't follow up to see if the OP followed my advice to post in your sub-forum - He/She didn't... |
15th September 2010, 02:46 | #9525 | Link | |
15th September 2010, 03:04 | #9526 | Link |
Hello everyone. Not sure if this is a bug, but I haven't been able to run it down any other way so I've got to bother you good folks. I've been using BD Rebuilder for about 6 mos now. Recently I've completed the build of a new PC using an AMD 1090T 6-core. Sure does wonders for my encode time, but the app is only using about 50% of available CPU. As far as I can see nothing else is throttling it. Is it some hidden option I need to set? Have I hit the wall?
Anybody have any idea why I'm not getting (close to) 100% CPU utilization on X264? Thanks for your time. MOBO: ASUS M4A79TD PRO/USBB3 MEM: 4x2G Patriot PVS34G1333ELKRT VGA: MSI 460GTX 1GD5 OC HDD: 4-disk software RAID 0 array - Samsung HD103SJ PS: Corsair 850TX Windows 7 64-bit Home Premium BD_Rebuilder v0.34.08 |
15th September 2010, 03:10 | #9527 | Link | |
After viewing the above link, it does not appear BD-RB does any reencoding, but keeps the original intact. I only see one m2ts audio file was reencoded, I think. Looks like a demux then remux.
So why would there be an audio async from this? Quote:
15th September 2010, 06:11 | #9528 | Link |
Millenium trilogy
-1 The Girl with the Dragon Tattoo -2 The Girl Who Played with Fire -3 The Girl Who Kicked the Hornet's Nest Same problems here with Canadian (Québec/French) version of "The Girl Who Kicked the Hornet's Nest/La reine du palais des courants d'air" - single M2TS - 1x ac3 5.1 Swedish - 1x ac3 5.1 French - 1x DTS-HD + MLP 5.1 French - 2x sub (PGS) French The playlist is the problem, take a look on original mpls w/bdedit... start time 10 min. on mpls movie start time at (10.19.186) on mpls color bar & other pic. 4 3 2 1 (19.186 sec.) and finally the yellow bird audio & sub,s out of sync for 19.186 sec.
DVD Rebuilder user Last edited by Elvis Gratton; 15th September 2010 at 16:59. |
15th September 2010, 16:55 | #9530 | Link |
I fixed the out-of-sync audio issue related to "The Girl with the Dragon Tattoo" and the other similar discs. It'll be included in the next release.
I apparently did a full backup when testing that disc because I was able to repeat the issue in movie-only. Actually it is an issue with the source, not in BD-RB -- as all M2TS files in a single MPLS should have the same audio characteristics... but it's fixed anyway. |
15th September 2010, 17:20 | #9531 | Link | |
15th September 2010, 18:34 | #9532 | Link | |
@jdobbs
Glad to hear that you've resolved it ;>} |
15th September 2010, 21:48 | #9533 | Link |
- Windows Version: 6.1 [7600]
- AVISYNTH Version: 2.5.7.0, Ok - HAALI Splitter: Ok - FFDSHOW: 3326, Ok - WIN7 preferred AVC CODEC: Ok - WIN7 preferred VC-1 CODEC: Ok - WIN7 preferred MPEG2 CODEC: Ok - FFDSHOW VC-1 set to "wmv9", Ok - FFDSHOW MPEG2 set to "libavcodec": Ok - FFDSHOW AVC set to "libavcodec": Ok - BD Rebuilder v0.34.0.9, Ok - X264: Ok - AFTEN: Ok - FAAC: Ok - MP4BOX: Ok - WAVI: Ok - TSMUXER: Ok [22:37:55] BD Rebuilder v0.34.09 (beta) - Source: NO_ES_TAN_FACIL - Input BD size: 33,05 GB - Approximate total content: [02:00:16.834] - Target BD size: 22,90 GB - Windows Version: 6.1 [7600] - Quality: Highest (Very Slow), Two Pass - Audio Settings: AC3=1 DTS=0 HD=1 Kbs=640 [22:37:56] PHASE ONE, Encoding - [22:37:56] Extracting A/V streams [VID_00010] [22:37:56] PHASE ONE, Encoding - [22:37:56] Extracting A/V streams [VID_00010] - [22:45:01] Reencoding: VID_00010 (1 of 1) - [22:45:01] Collecting video information - [22:45:01] Keeping original video (no reencode) - [22:45:01] Reencoding audio tracks (if req'd) - [22:45:01] Multiplexing M2TS - Error in attempt to multiplex: MUX_00010.meta - SmartLabs tsMuxeR. Version 1.10.6 http://www.smlabs.net [22:45:06] - Failed to build structure, aborted still gives me the problem although I have disabled the filters comentastes me. that can happen now. thank you very much |
15th September 2010, 23:44 | #9535 | Link | |
@jdobbs
I ask because, if I remember correctly (regarding my post about my earlier experience with "Tattoo"), initially the subs were in lockstep with the audiostreams - at first, out of synch just like the audio and then when the 11 seconds of silent video were separated from the movie-only, video, audio, and subs were all in synch... |
16th September 2010, 00:53 | #9536 | Link | |
I've fixed it and just finished watching it back. The sound and subs are in-sync now. Last edited by jdobbs; 16th September 2010 at 00:58. |
16th September 2010, 01:51 | #9537 | Link | |
Damn, that's really to bad. I've donated several times, and just did it again, and will also do so in the future.
Your work is very much appreciated, hopefully people will wake up, and contribute to your work. //JJ Quote:
Good Luck JJ |
16th September 2010, 14:29 | #9540 | Link |
BD Rebuilder v0.34.10 (beta)
I have updated the first post of this thread with a link to the latest release of BD-RB (v0.34.10). Changes for this release:
- Corrected an error in which the SETUP dialog was not correctly initializing the "Keep only BDMV and CERTIFICATE folders" checkbox upon load. - Created a workaround for an issue in which some poorly authored multi-part sources that have a leading M2TS without audio can result in audio that is out-of-sync on movie-only backups. - Created a workaround for an issue in which some poorly authored multi-part sources that have a leading M2TS without subtitles can result in a movie-only backup in which subs do not exist. - Other minor corrections and cosmetic fixes. |
