28th September 2010, 13:50 | #9701 | Link | |
As for the other issue... I'd need to see logs. |
28th September 2010, 14:26 | #9702 | Link |
jdobbs... if a bluray contents already have 6ch ac3... how can I tell BD-RB not to reencode that and just keep that sound track untouched? I can use multiavchd to blank out the DTS so that way it doesn't get converted.
28th September 2010, 16:39 | #9703 | Link |
1. Don't use multiAVCHD to blank out the DTS, just deselect it in BD-RB -- in running the disc through multiAVCHD first you are "preprocessing" and I won't respond to bug reports because I wouldn't be able to determine if it is caused by BD-RB or multiAVCHD. "Blanking out" audio is a good way to cause issues, and frankly self-inflicted problems are not why I've created a bug thread.
2. You select "Do not reencode AC3" from the SETUP dialog. Last edited by jdobbs; 28th September 2010 at 16:42. |
28th September 2010, 16:48 | #9704 | Link |
To all:
multiAVCHD is a nice software program. I use it sometimes as well. But, as with all powerful editing programs, it gives you the ability to change many things pretty much at your discretion. That can result in lots and lots of potential issues. Feel free to use multiAVCHD on a disc and then run BD-RB against the output, it gives you lots of capability. But, DO NOT POST ANY BUGS YOU MAY ENCOUNTER when you do that. Only report bugs that you experience against a commercial sources should be reported. It simply makes me spend time chasing bugs that cannot be fixed -- I've done this for many years, and have learned this lesson many times. I would also appreciate honesty in reporting. I have also chased bugs many times in which someone "neglected" to inform me (or more often chose to conceal) that a source is preprocessed. If you can't follow this rule -- don't use the software. You are causing headaches for yourself and delaying beta developement of BD-RB. Last edited by jdobbs; 28th September 2010 at 16:51. |
28th September 2010, 17:33 | #9705 | Link | |
28th September 2010, 17:56 | #9706 | Link |
jdobbs.. thank you for your respond but this is not considered a bug report when I made that post. I just want to simply ask how to let BD-RB keep the original AC3 so that it doesn't "waste" time to re-encode a AC3 that's already made. Also I didn't want to create another thread because like last time, someone said I was selfish or so to make a post just for myself because I didn't "read". Thanks again jdobbs!
BTW... I'm doing a BD9 encode that's why I ask you because that option to keep AC3 only is for bluray output only correct? |
28th September 2010, 18:22 | #9707 | Link | ||
29th September 2010, 02:00 | #9708 | Link |
jdobbs, I don't know why do you take it offensive when someone mention anything about time. Especially when they are clearly NOT complaining. I put it in quotation mark so that way you know that I don't mean anything offensive or complaining, but still you get worked up. I apologize for posting question in the bug reports only thread. Next time I will just continue from my own thread previously. Thanks again.
30th September 2010, 01:17 | #9709 | Link | |
Hi there, I'm using the latest Beta v0.34.08 and I've been experiencing this problem with several certain disk backups since I started using BD-RB, most recently with Sherlock Holmes. It isn't a random occurance, some originals just work, others don't
If any more information is needed, PM me, and I will provide it and update this post. Thanks in advance! EDIT: I followed Capsbackup's advice below, I was unaware there was an update (I thought I had set up notifications for new versions, but I guess it doesn't work). Everything works now! Last edited by ammauric; 1st October 2010 at 15:11. Reason: Correction |
30th September 2010, 01:50 | #9710 | Link | |
@ammauric;
the most current version is BD-RBV03411. There were some fixes regarding CRF encoding with this newer version. Quote:
2nd October 2010, 09:02 | #9712 | Link |
Legion :Audio PGS Size Too Large
Hi
I have done a lot of movies without problems, but when I try to do Legion I have the following message: Audio PGS Size Too Large If you continue or cancel it fails to make the movie. Here is the information: Code:
---------------------- [09:06:39] BD Rebuilder v0.34.11 (beta) - Source: OLD - Input BD size: 36,47 GB - Approximate total content: [02:42:40.084] - Target BD size: 4,36 GB - Windows Version: 6.1 [7600] - Quality: Highest (Very Slow), Two Pass - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=640 [09:06:39] PHASE ONE, Encoding - [09:06:39] Extracting A/V streams [VID_00205] - [09:06:40] Reencoding: VID_00205 (1 of 18) - [09:06:40] Collecting video information - Source Video: MPEG-2, 1920x1080 - Rate/Length: 23,976fps, 120 frames - [09:06:40] Reencoding: VID_00205, Pass 1 of 1 - [09:06:41] Video Encode complete - [09:06:41] Reencoding audio tracks (if req'd) - [09:06:41] Multiplexing M2TS - [09:06:41] Extracting A/V streams [VID_00104] - [09:06:42] Reencoding: VID_00104 (2 of 18) - [09:06:42] Collecting video information - Source Video: MPEG-2, 1920x1080 - Rate/Length: 29,970fps, 270 frames - [09:06:42] Reencoding: VID_00104, Pass 1 of 1 - [09:06:44] Video Encode complete - [09:06:44] Reencoding audio tracks (if req'd) - [09:06:44] Multiplexing M2TS - [09:06:44] Extracting A/V streams [VID_00000] - [09:06:45] Reencoding: VID_00000 (3 of 18) - [09:06:45] Collecting video information - Source Video: MPEG-2, 1920x1080 - Rate/Length: 23,976fps, 346 frames - [09:06:45] Reencoding: VID_00000, Pass 1 of 1 - [09:06:48] Video Encode complete - [09:06:48] Reencoding audio tracks (if req'd) - [09:06:48] Multiplexing M2TS - [09:06:49] Extracting A/V streams [VID_04999] - [09:06:52] Reencoding: VID_04999 (4 of 18) - [09:06:52] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 720 frames - [09:06:52] Reencoding: VID_04999, Pass 1 of 1 - [09:07:08] Video Encode complete - [09:07:08] Reencoding audio tracks (if req'd) - [09:07:08] Multiplexing M2TS - [09:07:09] Extracting A/V streams [VID_00081] - [09:07:13] Reencoding: VID_00081 (5 of 18) - [09:07:13] Collecting video information - Source Video: MPEG-2, 1920x1080 - Rate/Length: 23,976fps, 1.440 frames - [09:07:13] Reencoding: VID_00081, Pass 1 of 1 - [09:07:21] Video Encode complete - [09:07:21] Reencoding audio tracks (if req'd) - [09:07:21] Multiplexing M2TS - [09:07:22] Extracting A/V streams [VID_00111] - [09:07:28] Reencoding: VID_00111 (6 of 18) - [09:07:28] Collecting video information - Source Video: MPEG-2, 1920x1080 - Rate/Length: 23,976fps, 1.451 frames - [09:07:28] Reencoding: VID_00111, Pass 1 of 1 - [09:07:41] Video Encode complete - [09:07:41] Reencoding audio tracks (if req'd) - [09:07:41] Multiplexing M2TS - [09:07:42] Extracting A/V streams [VID_00112] - [09:07:49] Reencoding: VID_00112 (7 of 18) - [09:07:49] Collecting video information - Source Video: MPEG-2, 1920x1080 - Rate/Length: 23,976fps, 1.653 frames - [09:07:49] Reencoding: VID_00112, Pass 1 of 1 - [09:08:03] Video Encode complete - [09:08:03] Reencoding audio tracks (if req'd) - [09:08:03] Multiplexing M2TS - [09:08:04] Extracting A/V streams [VID_00001] - [09:08:13] Reencoding: VID_00001 (8 of 18) - [09:08:13] Collecting video information - Source Video: MPEG-2, 1920x1080 - Rate/Length: 23,976fps, 1.383 frames - [09:08:13] Reencoding: VID_00001, Pass 1 of 1 - [09:08:26] Video Encode complete - [09:08:26] Reencoding audio tracks (if req'd) - [09:08:26] Multiplexing M2TS - [09:08:32] Extracting A/V streams [VID_00022] - [09:08:41] Reencoding: VID_00022 (9 of 18) - [09:08:41] Collecting video information - Source Video: MPEG-2, 1920x1080 - Rate/Length: 23,976fps, 1.527 frames - [09:08:41] Reencoding: VID_00022, Pass 1 of 1 - [09:08:56] Video Encode complete - [09:08:56] Reencoding audio tracks (if req'd) - [09:08:56] Multiplexing M2TS - [09:09:02] Extracting A/V streams [VID_00114] - [09:09:11] Reencoding: VID_00114 (10 of 18) - [09:09:11] Collecting video information - Source Video: MPEG-2, 1920x1080 - Rate/Length: 23,976fps, 2.803 frames - [09:09:11] Reencoding: VID_00114, Pass 1 of 1 - [09:09:35] Video Encode complete - [09:09:35] Reencoding audio tracks (if req'd) - [09:09:35] Multiplexing M2TS - [09:09:38] Extracting A/V streams [VID_00115] - [09:09:47] Reencoding: VID_00115 (11 of 18) - [09:09:47] Collecting video information - Source Video: MPEG-2, 1920x1080 - Rate/Length: 23,976fps, 2.906 frames - [09:09:47] Reencoding: VID_00115, Pass 1 of 1 - [09:10:11] Video Encode complete - [09:10:11] Reencoding audio tracks (if req'd) - [09:10:11] Multiplexing M2TS - [09:10:13] Extracting A/V streams [VID_00113] - [09:10:24] Reencoding: VID_00113 (12 of 18) - [09:10:24] Collecting video information - Source Video: MPEG-2, 1920x1080 - Rate/Length: 23,976fps, 2.413 frames - [09:10:24] Reencoding: VID_00113, Pass 1 of 1 - [09:10:46] Video Encode complete - [09:10:46] Reencoding audio tracks (if req'd) - [09:10:46] Multiplexing M2TS - [09:10:49] Extracting A/V streams [VID_00116] - [09:11:01] Reencoding: VID_00116 (13 of 18) - [09:11:01] Collecting video information - Source Video: MPEG-2, 1920x1080 - Rate/Length: 23,976fps, 3.499 frames - [09:11:01] Reencoding: VID_00116, Pass 1 of 1 - [09:11:32] Video Encode complete - [09:11:32] Reencoding audio tracks (if req'd) - [09:11:32] Multiplexing M2TS - [09:11:36] Extracting A/V streams [VID_00117] - [09:11:49] Reencoding: VID_00117 (14 of 18) - [09:11:49] Collecting video information - Source Video: MPEG-2, 1920x1080 - Rate/Length: 23,976fps, 3.006 frames - [09:11:49] Reencoding: VID_00117, Pass 1 of 1 - [09:12:17] Video Encode complete - [09:12:17] Reencoding audio tracks (if req'd) - [09:12:17] Multiplexing M2TS - [09:12:20] Extracting A/V streams [VID_00303] - [09:13:15] Reencoding: VID_00303 (15 of 18) - [09:13:15] Collecting video information - Source Video: MPEG-2, 1920x1080 - Rate/Length: 23,976fps, 15.753 frames - [09:13:15] Reencoding: VID_00303, Pass 1 of 1 - [09:15:27] Video Encode complete - [09:15:27] Reencoding audio tracks (if req'd) - [09:15:27] Multiplexing M2TS - [09:15:36] Extracting A/V streams [VID_00302] - [09:16:36] Reencoding: VID_00302 (16 of 18) - [09:16:36] Collecting video information - Source Video: MPEG-2, 1920x1080 - Rate/Length: 23,976fps, 16.598 frames - [09:16:36] Reencoding: VID_00302, Pass 1 of 1 - [09:19:00] Video Encode complete - [09:19:00] Reencoding audio tracks (if req'd) - [09:19:00] Multiplexing M2TS - [09:19:09] Extracting A/V streams [VID_00301] - [09:21:09] Reencoding: VID_00301 (17 of 18) - [09:21:09] Collecting video information - Source Video: MPEG-2, 1920x1080 - Rate/Length: 23,976fps, 34.126 frames - [09:21:10] Reencoding: VID_00301, Pass 1 of 1 - [09:26:16] Video Encode complete - [09:26:16] Reencoding audio tracks (if req'd) - [09:26:16] Multiplexing M2TS - [09:26:35] Extracting A/V streams [VID_00011] - [09:41:54] Reencoding: VID_00011 (18 of 18) - [09:41:54] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23,976fps, 144.048 frames - Bitrate: 2.253 Kbs - [09:41:54] Reencoding: VID_00011, Pass 1 of 2 - [10:43:01] Reencoding: VID_00011, Pass 2 of 2 - [12:26:58] Video Encode complete - [12:26:58] Reencoding audio tracks (if req'd) - [12:26:58] Multiplexing M2TS - Error in attempt to multiplex: MUX_00011.meta - Can't open file: I:\BLURAY\LEGION\WORKFILES\VID_00011_2.AVS.264 [12:26:59] - Failed to build structure, aborted Last edited by jdobbs; 2nd October 2010 at 14:56. |
2nd October 2010, 12:40 | #9713 | Link |
Check the smaller m2ts files in the list for many audio tracks. Occasionally you find discs which on the extra tracks there are loads of english audios - they aren't used but use up space and do confuse the programme. I usually select 'only one audio track' in setup and then manually add commentary tracks etc in the main stream.
2nd October 2010, 12:48 | #9714 | Link |
Robin Hood
Anyone had an Idea what could be causing this ? Files were dumped to my HD through latest version of my (registered) anyDVD HD:
----------------------- [07:38:43] BD Rebuilder v0.34.11 (beta) - Source: ROBIN_HOOD - Input BD size: 29,94 GB - Approximate total content: [02:35:48.713] - Target BD size: 23,93 GB - Windows Version: 6.1 [7600] - MOVIE-ONLY mode enabled - Quality: Highest (Very Slow), Two Pass - Audio Settings: AC3=0 DTS=0 HD=1 Kbs=640 [07:38:43] PHASE ONE, Encoding - [07:38:43] Extracting A/V streams [VID_00810] - Extracting A/V to M2TS [VID_00810] - Extracting A/V from M2TS [VID_00810] - Error in attempt to extract audio/subs. - Reading buffer overflow. Possible container streams are not syncronized. Please, verify stream fps. File name: E:\TEMP\WORKFILES\00810.M2TS - Error in attempt to extract audio/subs. - Reading buffer overflow. Possible container streams are not syncronized. Please, verify stream fps. File name: E:\TEMP\WORKFILES\00810.M2TS [07:45:29] - Failed to retrieve audio, aborted |
2nd October 2010, 14:57 | #9715 | Link | |
2nd October 2010, 15:01 | #9716 | Link | |
2nd October 2010, 16:24 | #9718 | Link |
I just wonder if the huge number of segments is a purposeful method of getting around TSMUXER's capability? I mean 140... that's almost a segment change every minute. I can't imagine angle changes or "director's cut" types of differences requiring that many pieces?
2nd October 2010, 17:43 | #9719 | Link |
And I thought 51 pieces was a lot for the US Region 1 disk, lol. I tried the disk with Clown to put all of them into one big m2ts like I always used to do with multi m2ts movies and was surprised that after tsMuxeR combined them it also found tons of audio overlaps that caused a big audio delay of almost 20 seconds. I played with different ways to fix it and finally gave up and let BD_Rebuilder have a go at it. I was happy to see that it plays without any glitches at all. I even previewed the breaks where the m2ts files are joined and even in slow motion there is no hesitation, play back is extremely smooth and the audio transitions are fluid. Thanks jdobbs, the latest version really is a big improvment in the way it handles these movies that are chopped and stirred. Some of those m2ts files were like only 3 or 4 hundred frames long!, WHY??
2nd October 2010, 17:56 | #9720 | Link | ||
