22nd December 2010, 16:56 | #10601 | Link | |
The only interesting part is that it wasn't giving me an error when I was assigning an illegal value to it (logic says it should) -- but it was for others. That is really strange. |
22nd December 2010, 17:06 | #10602 | Link |
SSIF folder, sounds farmiliar. You don't happen to be working on a version that can strip 2D from 3D discs are ya Its weird indeed, if it was giving it for others, maybe something's wrong with your setup and not ours ^^ jk
22nd December 2010, 19:17 | #10603 | Link |
Yes, that's the intent of ignoring the SSIF. I figured I needed to start getting out ahead of the 3D bubble. By ignoring the SSIF you prevent yourself from counting the same file content twice when you are doing directory scans.
23rd December 2010, 01:01 | #10605 | Link |
Question on preserving chapters
Hi - just backed up a couple Blu-rays with BD Rebuilder v0.36.06 and they look fantastic. I noticed that there is no chapter information in the final BD folder, and I was wondering if I might be doing something incorrectly. I'm using the Beauty and the Beast recent release:
1) Copy disc to hard disk via AnyDVD 2) Use BD Rebuilder, Movie-Only mode, to create new movie-only BD folder on hard disk. When I open the folder in MPC-HC I don't see any chapters. Further, if I use ImgBurn to create an ISO, mount that as a virtual drive, and open the drive in MPC-HC I still don't see any chapters. I'll post my settings if it helps at all: [Options] VERSION=0.36.0.6 MODE=1 ENCODE_QUALITY=2 ONEPASS_ENCODING=0 AUTO_QUALITY=1 AUTO_BIAS=2 TARGET_SIZE=4469 AUDIO_TO_KEEP=eng; SUBS_TO_KEEP= SD_CONVERT=0 OPEN_GOP=0 RESIZE_1080=0 DEINTERLACE=0 SD_TO_1080=0 CONVERT_WIDE=0 DTS_REENCODE=0 AC3_REENCODE=0 AC3_640=1 AC3_192=0 KEEP_HD_AUDIO=0 AVCHD=0 REMOVE_WORKFILES=0 MOVIE_ONLY_LOOP=1 REMOVE_OUTPUT=0 USE_FILTERS=0 BDMV_CERT_ONLY=0 USE_LAVF=0 IVTC_PULLDOWN=1 ASSUME_DVD_PAL=0 AUDIO_TRACK_LIMIT=0 SUBTITLE_TRACK_LIMIT=1 CUSTOM_TARGET_SIZE=23450 PRIORITY_CLASS=0 QUICK_EXTRAS=0 MOVIEONLY_TYPE=0 ALTCRF=20 ALTMETHOD=0 |
23rd December 2010, 01:09 | #10606 | Link | |
I do movie-only encodes all the time -- and they are very definitely there (and match the original). The only way I could see a movie-only encode occuring without chapters would be if the original had none. The only time I've ever seen that happen is when there was some preprocessing (editing) going on. I'm running a movie-only backup of "SALT" now just to ensure nothing has regressed. Last edited by jdobbs; 23rd December 2010 at 01:24. |
23rd December 2010, 01:14 | #10607 | Link | |
I tried using MakeMKV to produce a single .mkv file (it purports to keep the chapter info) but still can't use chapter navigation. Ah well, I'll live with the chapters for now. Thanks for the great piece of software. |
23rd December 2010, 02:31 | #10608 | Link | |
23rd December 2010, 07:55 | #10610 | Link |
I did a full backup of the new movie "Salt" with the new .36.0.9 at fastest settings, and all went well. Quality looks good, and it finished in under 4 hours.
Well...almost all went well. I got that "wavi.exe has stopped working" error twice. At least It was early on in the encoding process Thankfully it wasn't the second job in a batch process I might have been told this before, but now I've discovered it for myself. "Keep HD audio" seems to put a stop to the "wavi.exe has stopped working" error. Gotta love a search engine LOL! Last edited by omegaman7; 23rd December 2010 at 09:42. |
23rd December 2010, 12:23 | #10611 | Link | |
Open ffdshow Video Decoder Configuration, Then, under DirectShow Control click the "edit" button next to "use ffdshow only in", and type in wavi.exe. |
23rd December 2010, 17:57 | #10613 | Link | |
23rd December 2010, 18:08 | #10615 | Link |
hello,
if i use the alternative output option DL DVD 720x576 and the source has 24000/1001 fps, the video stream was asynchronous with the audio streams. i like this option because there is no other tool wich gives this quality. i hope you can fix this problem and implement the subtitle option too. |
23rd December 2010, 18:15 | #10616 | Link | |
23rd December 2010, 18:23 | #10617 | Link |
i tryed this option with three diffrent sources and and all has the same error.
the option assume pal for dvd output was selected. here is my ini [Options] VERSION=0.36.0.9 MODE=1 ENCODE_QUALITY=3 ONEPASS_ENCODING=0 AUTO_QUALITY=0 TARGET_SIZE=8032 AVSFilter01=LoadPlugin("D:\+++\asharp.dll") AVSFilter02=asharp(2,3,1.3,hqbf=true) AVSFilter03=tweak(sat=1.09) AUDIO_TO_KEEP=deu;eng; SUBS_TO_KEEP=deu; AUTO_BIAS=2 MKV_INTERMEDIATE=1 SHOW_ENCODER=0 HC_PROFILE=BEST SD_CONVERT=0 OPEN_GOP=1 RESIZE_1080=0 DEINTERLACE=0 SD_TO_1080=0 CONVERT_WIDE=0 DTS_REENCODE=0 AC3_REENCODE=0 AC3_640=1 AC3_192=0 KEEP_HD_AUDIO=1 AVCHD=0 REMOVE_WORKFILES=0 MOVIE_ONLY_LOOP=1 REMOVE_OUTPUT=0 USE_FILTERS=1 BDMV_CERT_ONLY=0 USE_LAVF=1 IVTC_PULLDOWN=1 ASSUME_DVD_PAL=1 AUDIO_TRACK_LIMIT=1 SUBTITLE_TRACK_LIMIT=1 CUSTOM_TARGET_SIZE=23450 MOVIEONLY_TYPE=2 ALTCRF=20 ALTMETHOD=0 [Paths] SOURCE_PATH=G:\ WORKING_PATH=C:\USERS\+++\DESKTOP\AVCHD\ |
23rd December 2010, 19:35 | #10619 | Link | |
Give me some time to recreate the circumstances |
23rd December 2010, 21:53 | #10620 | Link |
Any ideas on this one? Thanks
----------------------- [14:39:53] BD Rebuilder v0.36.09 (beta) - Source: TZ_4 - Input BD size: 34.05 GB - Approximate total content: [05:35:12.642] - Target BD size: 22.95 GB - Windows Version: 6.1 [7600] - Auto Quality: Good (Very Fast), Two Pass - Audio Settings: AC3=1 DTS=1 HD=1 Kbs=640 [14:39:53] PHASE ONE, Encoding - [14:39:53] Extracting A/V streams [VID_00007] - [14:39:59] Reencoding: VID_00007 (1 of 10) - [14:39:59] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 722 frames - Bitrate: 16,896 Kbs - [14:39:59] Reencoding: VID_00007, Pass 1 of 2 - [14:40:26] Reencoding: VID_00007, Pass 2 of 2 - [14:40:57] Video Encode complete - [14:40:57] Reencoding audio tracks (if req'd) - [14:40:57] Multiplexing M2TS - [14:41:00] Extracting A/V streams [VID_00019] - [14:41:08] Reencoding: VID_00019 (2 of 10) - [14:41:08] Collecting video information - Source Video: MPEG-4 (AVC), 1920x1080 - Rate/Length: 23.976fps, 722 frames - Bitrate: 16,897 Kbs - [14:41:08] Reencoding: VID_00019, Pass 1 of 2 - [14:41:36] Reencoding: VID_00019, Pass 2 of 2 - [14:42:07] Video Encode complete - [14:42:07] Reencoding audio tracks (if req'd) - [14:42:07] Multiplexing M2TS - [14:42:10] Extracting A/V streams [VID_00003] - Error in attempt to extract audio/subs. - AV frame too large (65504 bytes). Increase AV buffer. [14:42:16] - Failed to retrieve audio, aborted - Windows Version: 6.1 [7600] - AVISYNTH Version: 2.5.7.0, Ok - HAALI Splitter: Ok - FFDSHOW: 3326, Ok - WIN7 preferred AVC CODEC: Ok - WIN7 preferred VC-1 CODEC: Ok - WIN7 preferred MPEG2 CODEC: Ok - FFDSHOW VC-1 set to "wmv9", Ok - FFDSHOW MPEG2 set to "libavcodec": Ok - FFDSHOW AVC set to "ffmpeg-mt": Ok - BD Rebuilder v0.36.0.9, Ok - X264: Ok - AFTEN: Ok - FAAC: Ok - MP4BOX: Ok - WAVI: Ok - TSMUXER: Ok |
