Old 9th July 2012, 03:49   #15321  |  Link
omegaman7
omegaman7's Avatar
Indeed. I just preordered TNG season 1. I'm having a heck of a time getting the TOS discs the way I want them. I'm probably just gonna strip the titles one at a time, and then use Multiavchd to reincorporate them. Even then, I may not be happy. I'm picky LOL! Ultimately, perhaps I'll burn double layer backups :S
Old 9th July 2012, 06:26   #15322  |  Link
A.Fenderson
BD-invalid 480p primary video stream, & error 2403 ... CorrectMPLS() 00006 2403
Problem disc: Lord of the Rings Extended, Return of the King, feature disc #2 (part two).
Error Condition (popup): "BD Rebuilder experienced an error 2403 [19:29:13] CorrectMPLS() 00006 2403".
This occurs when the rebuild process is practically 100% complete. The first time this happened, I reran BD-RB and chose to continue with the existing project (many times): it always failed at the exact same point (that log is still available upon request). I therefore reripped the disc (via Any DVD-HD, up-to-date, and with no subsequent preprocessing of any kind): this second rip is the one used in the present error report. Upon request of jdobbs I can run checksums of each of the two rips to verify whether they are bit-identical.
The resultant build looks complete from rough eye-balling, and if it's selected as *input* for BD-RB it is accepted as a valid BD source. When burned to BD-RE, though, a quick (not comprehensive) check via chapter skip etc shows that it played fine (menus work, audio & video both good, navigation, etc) with the exception of one 5-minute & 50-second segment that is an easter-egg accessible from the (full) main menu (aka "disc menu") thus: Special Features > (picture of One Ring). In my Panasonic DMP-BD45, selecting this goes briefly to a black screen then returns to the menu. In Cyberlink Power DVD 8, I instead get a completely black, no-audio segment of the proper length (5min 50s) followed by a return to the menu. I have verified that the stream in question is on the disc and plays perfectly when opened in Media Player Classic Home Theater and/or VLC: it is an SD-resolution clip that is originally in MPEG-2 480i, and after reeencode is AVC 480p29.97, which seems to be an invalid format for a primary video stream according to info found in this thread. Note that "Use DEINTERLACER on interlaced sources" was chosen in the setup menu, and I believe it's the default option: in this case it was applied despite the fact that it seems to have brought the resultant clip out of BD-compliant format for a primary video stream.
BD-REBUILDER.LOG:
[07/06/12] BD Rebuilder v0.40.10 (beta)
[12:17:04] Source:  THE_RETURN_OF_THE_KING_EXT_PT2
  - Input BD size: 37.27 GB
  - Approximate total content: [02:24:11.117]
  - Target BD size: 22.95 GB
  - Windows Version: 5.1 [2600]
  - Quality: Highest (Very Slow), Two Pass
[12:17:04] PHASE ONE, Encoding
 - [12:17:04] Processing: VID_00007 (1 of 2)
 - [12:17:04] Extracting A/V streams [VID_00007]
 - [12:17:14] Reencoding video [VID_00007]
   - Source Video: MPEG-2, 720x480
   - Rate/Length: 29.970fps, 10,503 frames
   - Bitrate: 2,352 Kbs
 - [12:17:14] Reencoding: VID_00007, Pass 1 of 2
 - [12:19:57] Reencoding: VID_00007, Pass 2 of 2
 - [12:29:49] Video Encode complete
 - [12:29:49] Processing audio tracks
 - [12:29:49] Multiplexing M2TS
 - [12:29:55] Processing: VID_00008 (2 of 2)
 - [12:29:55] Extracting A/V streams [VID_00008]
 - [12:38:28] Reencoding video [VID_00008]
   - Rate/Length: 23.976fps, 195,056 frames
   - Bitrate: 19,688 Kbs
 - [12:38:28] Reencoding: VID_00008, Pass 1 of 2
 - [17:38:03] Reencoding: VID_00008, Pass 2 of 2
 - [19:05:41] Video Encode complete
 - [19:05:41] Processing audio tracks
   - Track 4354 (eng): Keeping original audio
   - Track 4355 (eng): Keeping original audio
   - Track 4356 (eng): Keeping original audio
   - Track 4357 (eng): Keeping original audio
 - [19:05:41] Multiplexing M2TS
[19:29:05]PHASE ONE complete
[19:29:05]PHASE TWO - Rebuild Started
 - [19:29:05] Rebuilding BD file Structure
 - [19:29:13] CorrectMPLS() 00006  2403
[03:48:50] - Aborted at user request
Note that I never clicked the Abort button, simply the OK button on the pop-up error message.
THE_RETURN_OF_THE_KING_EXT_PT2.INF:
[Status]
LABEL=THE_RETURN_OF_THE_KING_EXT_PT2
VERSION=v0.40.10 (beta)
SOURCE_SIZE=40020441711
SOURCE_VIDEO_SIZE=39798835200
TARGET_SIZE=24641536000
REDUCTION=.613584024916388
RESIZE_1080=0
AUDIO_TO_KEEP=eng;
KEEP_HD_AUDIO=0
SUBS_TO_KEEP=eng;
BACKUP_MODE=0
MOVIEONLY_TYPE=0
USE_LAVF=0
INSTANCES=1
DGDECNV=0
QUICK=0
ENCODE_STEP=0
COMPLETED=2
REBUILD_COMPLETE=0
[00007]
AUDIO=1
PGS=100
SCAN=0
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=121902201
RATE=2352
SPLITS=1
NSTART=27000000
NEND=42769440
NSIZE=121878528
FLINK=0
MLINK=0
[00008]
AUDIO=101111
PGS=10011110
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=24298027288
RATE=19688
SPLITS=1
NSTART=27000000
NEND=393144480
NSIZE=23746486272
FLINK=0
MLINK=0
Inspect.exe results:
- HAALI Splitter: [1.11.96.14], Ok
- FFDSHOW: [3882], Ok
- FFDSHOW VC-1 set "disabled", WMP11, Ok
- FFDSHOW MPEG2 set to "libavcodec":  Ok
- FFDSHOW AVC set to "libavcodec":  Ok
- AnyDVD settings check: Ok.
- BD Rebuilder v0.40.0.10, Ok
- X264:  Ok
- AFTEN:  Ok
- FAAC:  Ok
- MP4BOX:  Ok
- WAVI:  Ok
- TSMUXER:  Ok
Thanks for your time.
edit:
@Audiophile1178: if I recall correctly, even playing from the original discs, the seamless branching feature in ST:TOS to allow switching between the original and updated effects doesn't actually work as intended (or at least as I imagined it should)--I believe I had to make the change in the pop-up menu and then restart the chapter for it ever to work properly.
Last edited by A.Fenderson; 9th July 2012 at 06:29. Reason: add reply to Audiophile1178
A.Fenderson is offline   Reply With Quote
Old 11th July 2012, 20:57   #15323  |  Link
asiafan
now i gotta q to you all which BD player u are using when talk bout Samsung which of samsung player will be playing *.m2ts and *.ts files i got BDP 3600 [doesnt matter region] this player is from 2009 and got problems with 50GB disc when u reach layer change and 25 reencoded [freezing disc need pause and play] when LG dont have any of this crappy issues and play all perfect.
asiafan is offline   Reply With Quote
Old 12th July 2012, 19:29   #15324  |  Link
AmigaFuture
AmigaFuture's Avatar
The Incredibles Part 1.
Hello,
"The Incredibles" is missing/silent 1st audio for movie and "Boundin'" extra. The Commentary for "Boundin'" does play. Everything else is functioning. I selected Full Backup.
I've tried with PowerDVD 12 and my LG BD590.
BD-REBUILDER.LOG
[07/10/12] BD Rebuilder v0.40.10 (beta)
[18:52:42] Source:  INCREDIBLES
  - Input BD size: 40.25 GB
  - Approximate total content: [03:27:54.752]
  - Windows Version: 6.1 [7600]
  - Quality: Good (Very Fast), Two Pass
  - Decoding/Frame serving: DirectShow [4-way]
  - Audio Settings: AC3=0 DTS=1 HD=0 Kbs=448
[18:52:44] PHASE ONE, Encoding
 - [18:52:44] Processing: VID_00451 (1 of 59)
 - [18:52:44] Extracting A/V streams [VID_00451]
 - [18:52:51] Reencoding video [VID_00451]
   - Source Video: MPEG-2, 1920x1080
   - Rate/Length: 23.976fps, 7,200 frames
   - Bitrate: 3,572 Kbs
 - [18:52:51] Reencoding: VID_00451, Pass 1 of 2
 - [18:53:32] Reencoding: VID_00451, Pass 2 of 2
 - [18:54:15] Video Encode complete
 - [18:54:15] Processing audio tracks
 - [18:54:15] Multiplexing M2TS
 - [18:54:20] Processing: VID_00470 (2 of 59)
 - [18:54:20] Extracting A/V streams [VID_00470]
 - [18:54:26] Reencoding video [VID_00470]
   - Rate/Length: 23.976fps, 613 frames
   - Bitrate: 20,107 Kbs
 - [18:54:26] Reencoding: VID_00470, Pass 1 of 2
 - [18:54:34] Reencoding: VID_00470, Pass 2 of 2
 - [18:54:42] Video Encode complete
 - [18:54:42] Processing audio tracks
   - Track 4353 (eng): Keeping original audio
   - Track 4359 (eng): Keeping original audio
   - Track 4360 (eng): Keeping original audio
 - [18:54:45] Multiplexing M2TS
 - [18:54:49] Processing: VID_00471 (3 of 59)
 - [18:54:49] Extracting A/V streams [VID_00471]
 - [18:54:56] Reencoding video [VID_00471]
   - Rate/Length: 23.976fps, 918 frames
   - Bitrate: 15,001 Kbs
 - [18:54:56] Reencoding: VID_00471, Pass 1 of 2
 - [18:55:06] Reencoding: VID_00471, Pass 2 of 2
 - [18:55:16] Video Encode complete
 - [18:55:16] Processing audio tracks
 - [18:55:19] Multiplexing M2TS
 - [18:55:24] Processing: VID_00472 (4 of 59)
 - [18:55:24] Extracting A/V streams [VID_00472]
 - [18:55:43] Reencoding video [VID_00472]
   - Rate/Length: 23.976fps, 5,794 frames
   - Bitrate: 16,041 Kbs
 - [18:55:43] Reencoding: VID_00472, Pass 1 of 2
 - [18:56:52] Reencoding: VID_00472, Pass 2 of 2
 - [18:58:01] Video Encode complete
 - [18:58:01] Processing audio tracks
 - [18:58:05] Multiplexing M2TS
 - [18:58:19] Processing: VID_00473 (5 of 59)
 - [18:58:19] Extracting A/V streams [VID_00473]
 - [18:58:32] Reencoding video [VID_00473]
   - Rate/Length: 23.976fps, 3,720 frames
   - Bitrate: 15,768 Kbs
 - [18:58:32] Reencoding: VID_00473, Pass 1 of 2
 - [18:59:17] Reencoding: VID_00473, Pass 2 of 2
 - [19:00:02] Video Encode complete
 - [19:00:02] Processing audio tracks
 - [19:00:06] Multiplexing M2TS
 - [19:00:16] Processing: VID_00474 (6 of 59)
 - [19:00:16] Extracting A/V streams [VID_00474]
 - [19:00:49] Reencoding video [VID_00474]
   - Rate/Length: 23.976fps, 10,885 frames
   - Bitrate: 14,606 Kbs
 - [19:00:49] Reencoding: VID_00474, Pass 1 of 2
 - [19:02:51] Reencoding: VID_00474, Pass 2 of 2
 - [19:04:54] Video Encode complete
 - [19:04:54] Processing audio tracks
 - [19:05:00] Multiplexing M2TS
 - [19:05:20] Processing: VID_00475 (7 of 59)
 - [19:05:20] Extracting A/V streams [VID_00475]
 - [19:06:03] Reencoding video [VID_00475]
   - Rate/Length: 23.976fps, 16,124 frames
   - Bitrate: 15,671 Kbs
 - [19:06:03] Reencoding: VID_00475, Pass 1 of 2
 - [19:09:10] Reencoding: VID_00475, Pass 2 of 2
 - [19:12:22] Video Encode complete
 - [19:12:22] Processing audio tracks
 - [19:12:29] Multiplexing M2TS
 - [19:12:59] Processing: VID_00476 (8 of 59)
 - [19:12:59] Extracting A/V streams [VID_00476]
 - [19:13:56] Reencoding video [VID_00476]
   - Rate/Length: 23.976fps, 18,414 frames
   - Bitrate: 15,694 Kbs
 - [19:13:56] Reencoding: VID_00476, Pass 1 of 2
 - [19:17:34] Reencoding: VID_00476, Pass 2 of 2
 - [19:21:14] Video Encode complete
 - [19:21:14] Processing audio tracks
 - [19:21:21] Multiplexing M2TS
 - [19:21:55] Processing: VID_00477 (9 of 59)
 - [19:21:55] Extracting A/V streams [VID_00477]
 - [19:22:56] Reencoding video [VID_00477]
   - Rate/Length: 23.976fps, 19,817 frames
   - Bitrate: 15,928 Kbs
 - [19:22:56] Reencoding: VID_00477, Pass 1 of 2
 - [19:26:50] Reencoding: VID_00477, Pass 2 of 2
 - [19:30:48] Video Encode complete
 - [19:30:48] Processing audio tracks
 - [19:30:56] Multiplexing M2TS
 - [19:31:32] Processing: VID_00478 (10 of 59)
 - [19:31:32] Extracting A/V streams [VID_00478]
 - [19:31:36] Reencoding video [VID_00478]
   - Rate/Length: 23.976fps, 316 frames
   - Bitrate: 21,135 Kbs
 - [19:31:36] Reencoding: VID_00478, Pass 1 of 2
 - [19:31:41] Reencoding: VID_00478, Pass 2 of 2
 - [19:31:46] Video Encode complete
 - [19:31:46] Processing audio tracks
 - [19:31:48] Multiplexing M2TS
 - [19:31:52] Processing: VID_00479 (11 of 59)
 - [19:31:52] Extracting A/V streams [VID_00479]
 - [19:32:22] Reencoding video [VID_00479]
   - Rate/Length: 23.976fps, 9,194 frames
   - Bitrate: 15,479 Kbs
Old 12th July 2012, 19:32   #15325  |  Link
AmigaFuture
The Incredibles Part 2.
- [19:32:22] Reencoding: VID_00479, Pass 1 of 2
 - [19:34:12] Reencoding: VID_00479, Pass 2 of 2
 - [19:36:03] Video Encode complete
 - [19:36:03] Processing audio tracks
 - [19:36:08] Multiplexing M2TS
 - [19:36:26] Processing: VID_00480 (12 of 59)
 - [19:36:26] Extracting A/V streams [VID_00480]
 - [19:39:40] Reencoding video [VID_00480]
   - Rate/Length: 23.976fps, 52,583 frames
   - Bitrate: 16,557 Kbs
 - [19:39:40] Reencoding: VID_00480, Pass 1 of 2
 - [19:50:35] Reencoding: VID_00480, Pass 2 of 2
 - [20:01:39] Video Encode complete
 - [20:01:40] Processing audio tracks
 - [20:01:58] Multiplexing M2TS
 - [20:03:31] Processing: VID_00481 (13 of 59)
 - [20:03:31] Extracting A/V streams [VID_00481]
 - [20:03:40] Reencoding video [VID_00481]
   - Rate/Length: 23.976fps, 2,145 frames
   - Bitrate: 16,142 Kbs
 - [20:03:40] Reencoding: VID_00481, Pass 1 of 2
 - [20:04:07] Reencoding: VID_00481, Pass 2 of 2
 - [20:04:34] Video Encode complete
 - [20:04:34] Processing audio tracks
 - [20:04:37] Multiplexing M2TS
 - [20:04:44] Processing: VID_00482 (14 of 59)
 - [20:04:44] Extracting A/V streams [VID_00482]
 - [20:05:13] Reencoding video [VID_00482]
   - Rate/Length: 23.976fps, 10,969 frames
   - Bitrate: 14,530 Kbs
 - [20:05:13] Reencoding: VID_00482, Pass 1 of 2
 - [20:07:06] Reencoding: VID_00482, Pass 2 of 2
 - [20:09:01] Video Encode complete
 - [20:09:01] Processing audio tracks
 - [20:09:14] Multiplexing M2TS
 - [20:09:34] Processing: VID_00483 (15 of 59)
 - [20:09:34] Extracting A/V streams [VID_00483]
 - [20:09:41] Reencoding video [VID_00483]
   - Rate/Length: 23.976fps, 1,407 frames
   - Bitrate: 14,908 Kbs
 - [20:09:41] Reencoding: VID_00483, Pass 1 of 2
 - [20:09:57] Reencoding: VID_00483, Pass 2 of 2
 - [20:10:13] Video Encode complete
 - [20:10:13] Processing audio tracks
 - [20:10:16] Multiplexing M2TS
 - [20:10:21] Processing: VID_00484 (16 of 59)
 - [20:10:21] Extracting A/V streams [VID_00484]
 - [20:10:29] Reencoding video [VID_00484]
   - Rate/Length: 23.976fps, 1,174 frames
   - Bitrate: 15,736 Kbs
 - [20:10:29] Reencoding: VID_00484, Pass 1 of 2
 - [20:10:44] Reencoding: VID_00484, Pass 2 of 2
 - [20:10:58] Video Encode complete
 - [20:10:58] Processing audio tracks
 - [20:11:02] Multiplexing M2TS
 - [20:11:07] Processing: VID_00485 (17 of 59)
 - [20:11:07] Extracting A/V streams [VID_00485]
 - [20:11:14] Reencoding video [VID_00485]
   - Rate/Length: 23.976fps, 1,020 frames
   - Bitrate: 15,340 Kbs
 - [20:11:14] Reencoding: VID_00485, Pass 1 of 2
 - [20:11:26] Reencoding: VID_00485, Pass 2 of 2
 - [20:11:38] Video Encode complete
 - [20:11:38] Processing audio tracks
 - [20:11:42] Multiplexing M2TS
 - [20:11:47] Processing: VID_00486 (18 of 59)
 - [20:11:47] Extracting A/V streams [VID_00486]
 - [20:11:57] Reencoding video [VID_00486]
   - Rate/Length: 23.976fps, 2,232 frames
   - Bitrate: 19,754 Kbs
 - [20:11:57] Reencoding: VID_00486, Pass 1 of 2
 - [20:12:29] Reencoding: VID_00486, Pass 2 of 2
 - [20:13:00] Video Encode complete
 - [20:13:00] Processing audio tracks
 - [20:13:03] Multiplexing M2TS
 - [20:13:11] Processing: VID_00487 (19 of 59)
 - [20:13:11] Extracting A/V streams [VID_00487]
 - [20:13:17] Reencoding video [VID_00487]
   - Rate/Length: 23.976fps, 735 frames
   - Bitrate: 15,365 Kbs
 - [20:13:17] Reencoding: VID_00487, Pass 1 of 2
 - [20:13:26] Reencoding: VID_00487, Pass 2 of 2
 - [20:13:35] Video Encode complete
 - [20:13:35] Processing audio tracks
 - [20:13:38] Multiplexing M2TS
 - [20:13:43] Processing: VID_00488 (20 of 59)
 - [20:13:43] Extracting A/V streams [VID_00488]
 - [20:13:55] Reencoding video [VID_00488]
   - Rate/Length: 23.976fps, 3,863 frames
   - Bitrate: 14,736 Kbs
 - [20:13:55] Reencoding: VID_00488, Pass 1 of 2
 - [20:14:41] Reencoding: VID_00488, Pass 2 of 2
 - [20:15:27] Video Encode complete
 - [20:15:27] Processing audio tracks
 - [20:15:31] Multiplexing M2TS
 - [20:15:40] Processing: VID_00489 (21 of 59)
 - [20:15:40] Extracting A/V streams [VID_00489]
 - [20:15:47] Reencoding video [VID_00489]
   - Rate/Length: 23.976fps, 999 frames
   - Bitrate: 14,869 Kbs
 - [20:15:47] Reencoding: VID_00489, Pass 1 of 2
 - [20:15:59] Reencoding: VID_00489, Pass 2 of 2
 - [20:16:11] Video Encode complete
 - [20:16:11] Processing audio tracks
 - [20:16:13] Multiplexing M2TS
 - [20:16:19] Processing: VID_00490 (22 of 59)
 - [20:16:19] Extracting A/V streams [VID_00490]
 - [20:16:24] Reencoding video [VID_00490]
   - Rate/Length: 23.976fps, 622 frames
   - Bitrate: 15,617 Kbs
 - [20:16:24] Reencoding: VID_00490, Pass 1 of 2
 - [20:16:31] Reencoding: VID_00490, Pass 2 of 2
 - [20:16:38] Video Encode complete
 - [20:16:38] Processing audio tracks
 - [20:16:40] Multiplexing M2TS
 - [20:16:45] Processing: VID_00491 (23 of 59)
 - [20:16:45] Extracting A/V streams [VID_00491]
 - [20:16:50] Reencoding video [VID_00491]
   - Rate/Length: 23.976fps, 782 frames
   - Bitrate: 15,778 Kbs
 - [20:16:50] Reencoding: VID_00491, Pass 1 of 2
 - [20:16:59] Reencoding: VID_00491, Pass 2 of 2
 - [20:17:08] Video Encode complete
 - [20:17:08] Processing audio tracks
 - [20:17:11] Multiplexing M2TS
 - [20:17:16] Processing: VID_00492 (24 of 59)
 - [20:17:16] Extracting A/V streams [VID_00492]
 - [20:17:22] Reencoding video [VID_00492]
   - Rate/Length: 23.976fps, 671 frames
   - Bitrate: 17,953 Kbs
 - [20:17:22] Reencoding: VID_00492, Pass 1 of 2
 - [20:17:31] Reencoding: VID_00492, Pass 2 of 2
 - [20:17:40] Video Encode complete
 - [20:17:40] Processing audio tracks
 - [20:17:43] Multiplexing M2TS
 - [20:17:47] Processing: VID_00493 (25 of 59)
 - [20:17:47] Extracting A/V streams [VID_00493]
 - [20:17:53] Reencoding video [VID_00493]
   - Rate/Length: 23.976fps, 698 frames
   - Bitrate: 16,018 Kbs
 - [20:17:53] Reencoding: VID_00493, Pass 1 of 2
 - [20:18:03] Reencoding: VID_00493, Pass 2 of 2
 - [20:18:12] Video Encode complete
 - [20:18:12] Processing audio tracks
 - [20:18:14] Multiplexing M2TS
 - [20:18:19] Processing: VID_00494 (26 of 59)
 - [20:18:19] Extracting A/V streams [VID_00494]
 - [20:18:24] Reencoding video [VID_00494]
   - Rate/Length: 23.976fps, 359 frames
   - Bitrate: 20,554 Kbs
 - [20:18:24] Reencoding: VID_00494, Pass 1 of 2
 - [20:18:29] Reencoding: VID_00494, Pass 2 of 2
 - [20:18:34] Video Encode complete
 - [20:18:34] Processing audio tracks
 - [20:18:36] Multiplexing M2TS
 - [20:18:41] Processing: VID_00497 (27 of 59)
 - [20:18:41] Extracting A/V streams [VID_00497]
 - [20:19:02] Reencoding video [VID_00497]
   - Rate/Length: 23.976fps, 6,823 frames
   - Bitrate: 13,465 Kbs
 - [20:19:02] Reencoding: VID_00497, Pass 1 of 2
 - [20:20:34] Reencoding: VID_00497, Pass 2 of 2
 - [20:22:07] Video Encode complete
 - [20:22:07] Processing audio tracks
 - [20:22:07] Multiplexing M2TS
 - [20:22:19] Processing: VID_00501 (28 of 59)
 - [20:22:19] Extracting A/V streams [VID_00501]
 - [20:22:25] Reencoding video [VID_00501]
   - Rate/Length: 23.976fps, 1,040 frames
   - Bitrate: 15,506 Kbs
 - [20:22:25] Reencoding: VID_00501, Pass 1 of 2
 - [20:22:39] Reencoding: VID_00501, Pass 2 of 2
 - [20:22:53] Video Encode complete
 - [20:22:53] Processing audio tracks
 - [20:22:56] Multiplexing M2TS
 - [20:23:01] Processing: VID_00502 (29 of 59)
 - [20:23:01] Extracting A/V streams [VID_00502]
 - [20:23:16] Reencoding video [VID_00502]
   - Rate/Length: 23.976fps, 5,113 frames
   - Bitrate: 15,659 Kbs
 - [20:23:16] Reencoding: VID_00502, Pass 1 of 2
 - [20:24:21] Reencoding: VID_00502, Pass 2 of 2
 - [20:25:27] Video Encode complete
 - [20:25:27] Processing audio tracks
 - [20:25:32] Multiplexing M2TS
 - [20:25:43] Processing: VID_00503 (30 of 59)
 - [20:25:43] Extracting A/V streams [VID_00503]
 - [20:25:47] Reencoding video [VID_00503]
   - Rate/Length: 23.976fps, 264 frames
   - Bitrate: 16,673 Kbs
Old 12th July 2012, 19:34   #15326  |  Link
AmigaFuture
The Incredibles Part 3.
 - [20:25:47] Reencoding: VID_00503, Pass 1 of 2
 - [20:25:51] Reencoding: VID_00503, Pass 2 of 2
 - [20:25:54] Video Encode complete
 - [20:25:54] Processing audio tracks
 - [20:25:57] Multiplexing M2TS
 - [20:26:01] Processing: VID_00504 (31 of 59)
 - [20:26:01] Extracting A/V streams [VID_00504]
 - [20:26:05] Reencoding video [VID_00504]
   - Rate/Length: 23.976fps, 363 frames
   - Bitrate: 13,933 Kbs
 - [20:26:05] Reencoding: VID_00504, Pass 1 of 2
 - [20:26:11] Reencoding: VID_00504, Pass 2 of 2
 - [20:26:15] Video Encode complete
 - [20:26:15] Processing audio tracks
 - [20:26:16] Multiplexing M2TS
 - [20:26:21] Processing: VID_00505 (32 of 59)
 - [20:26:21] Extracting A/V streams [VID_00505]
 - [20:26:28] Reencoding video [VID_00505]
   - Bitrate: 15,508 Kbs
 - [20:26:28] Reencoding: VID_00505, Pass 1 of 2
 - [20:26:42] Reencoding: VID_00505, Pass 2 of 2
 - [20:26:56] Video Encode complete
 - [20:26:56] Processing audio tracks
 - [20:26:59] Multiplexing M2TS
 - [20:27:04] Processing: VID_00506 (33 of 59)
 - [20:27:04] Extracting A/V streams [VID_00506]
 - [20:27:08] Reencoding video [VID_00506]
   - Bitrate: 15,279 Kbs
 - [20:27:08] Reencoding: VID_00506, Pass 1 of 2
 - [20:27:11] Reencoding: VID_00506, Pass 2 of 2
 - [20:27:15] Video Encode complete
 - [20:27:15] Processing audio tracks
 - [20:27:17] Multiplexing M2TS
 - [20:27:21] Processing: VID_00508 (34 of 59)
 - [20:27:21] Extracting A/V streams [VID_00508]
 - [20:27:28] Reencoding video [VID_00508]
   - Bitrate: 15,513 Kbs
 - [20:27:28] Reencoding: VID_00508, Pass 1 of 2
 - [20:27:42] Reencoding: VID_00508, Pass 2 of 2
 - [20:27:56] Video Encode complete
 - [20:27:56] Processing audio tracks
 - [20:27:58] Multiplexing M2TS
 - [20:28:04] Processing: VID_00509 (35 of 59)
 - [20:28:04] Extracting A/V streams [VID_00509]
 - [20:28:30] Reencoding video [VID_00509]
   - Rate/Length: 23.976fps, 6,820 frames
   - Bitrate: 19,006 Kbs
 - [20:28:30] Reencoding: VID_00509, Pass 1 of 2
 - [20:30:06] Reencoding: VID_00509, Pass 2 of 2
 - [20:31:43] Video Encode complete
 - [20:31:43] Processing audio tracks
 - [20:31:43] Multiplexing M2TS
 - [20:31:58] Processing: VID_00510 (36 of 59)
 - [20:31:58] Extracting A/V streams [VID_00510]
 - [20:33:14] Reencoding video [VID_00510]
   - Rate/Length: 23.976fps, 31,865 frames
   - Bitrate: 12,696 Kbs
 - [20:33:14] Reencoding: VID_00510, Pass 1 of 2
 - [20:41:51] Reencoding: VID_00510, Pass 2 of 2
 - [20:49:13] Video Encode complete
 - [20:49:13] Processing audio tracks
 - [20:49:13] Multiplexing M2TS
 - [20:49:51] Processing: VID_00511 (37 of 59)
 - [20:49:51] Extracting A/V streams [VID_00511]
 - [20:49:58] Reencoding video [VID_00511]
   - Bitrate: 14,967 Kbs
 - [20:49:58] Reencoding: VID_00511, Pass 1 of 2
 - [20:50:13] Reencoding: VID_00511, Pass 2 of 2
 - [20:50:29] Video Encode complete
 - [20:50:29] Processing audio tracks
 - [20:50:32] Multiplexing M2TS
 - [20:50:38] Processing: VID_00512 (38 of 59)
 - [20:50:38] Extracting A/V streams [VID_00512]
 - [20:50:44] Reencoding video [VID_00512]
   - Bitrate: 15,789 Kbs
 - [20:50:44] Reencoding: VID_00512, Pass 1 of 2
 - [20:50:59] Reencoding: VID_00512, Pass 2 of 2
 - [20:51:14] Video Encode complete
 - [20:51:14] Processing audio tracks
 - [20:51:17] Multiplexing M2TS
 - [20:51:22] Processing: VID_00513 (39 of 59)
 - [20:51:22] Extracting A/V streams [VID_00513]
 - [20:51:29] Reencoding video [VID_00513]
   - Bitrate: 15,339 Kbs
 - [20:51:29] Reencoding: VID_00513, Pass 1 of 2
 - [20:51:41] Reencoding: VID_00513, Pass 2 of 2
 - [20:51:53] Video Encode complete
 - [20:51:53] Processing audio tracks
 - [20:51:56] Multiplexing M2TS
 - [20:52:01] Processing: VID_00514 (40 of 59)
 - [20:52:01] Extracting A/V streams [VID_00514]
 - [20:52:11] Reencoding video [VID_00514]
   - Bitrate: 19,735 Kbs
 - [20:52:11] Reencoding: VID_00514, Pass 1 of 2
 - [20:52:43] Reencoding: VID_00514, Pass 2 of 2
 - [20:53:14] Video Encode complete
 - [20:53:15] Processing audio tracks
 - [20:53:18] Multiplexing M2TS
 - [20:53:26] Processing: VID_00515 (41 of 59)
 - [20:53:27] Extracting A/V streams [VID_00515]
 - [20:53:32] Reencoding video [VID_00515]
   - Bitrate: 15,341 Kbs
 - [20:53:32] Reencoding: VID_00515, Pass 1 of 2
 - [20:53:42] Reencoding: VID_00515, Pass 2 of 2
 - [20:53:51] Video Encode complete
 - [20:53:51] Processing audio tracks
 - [20:53:53] Multiplexing M2TS
 - [20:53:58] Processing: VID_00516 (42 of 59)
 - [20:53:58] Extracting A/V streams [VID_00516]
 - [20:54:11] Reencoding video [VID_00516]
   - Bitrate: 14,621 Kbs
 - [20:54:11] Reencoding: VID_00516, Pass 1 of 2
 - [20:54:56] Reencoding: VID_00516, Pass 2 of 2
 - [20:55:43] Video Encode complete
 - [20:55:43] Processing audio tracks
 - [20:55:47] Multiplexing M2TS
 - [20:55:56] Processing: VID_00517 (43 of 59)
 - [20:55:56] Extracting A/V streams [VID_00517]
 - [20:56:03] Reencoding video [VID_00517]
   - Bitrate: 14,843 Kbs
 - [20:56:03] Reencoding: VID_00517, Pass 1 of 2
 - [20:56:15] Reencoding: VID_00517, Pass 2 of 2
 - [20:56:27] Video Encode complete
 - [20:56:27] Processing audio tracks
 - [20:56:30] Multiplexing M2TS
 - [20:56:35] Processing: VID_00518 (44 of 59)
 - [20:56:35] Extracting A/V streams [VID_00518]
 - [20:56:41] Reencoding video [VID_00518]
   - Bitrate: 15,621 Kbs
 - [20:56:41] Reencoding: VID_00518, Pass 1 of 2
 - [20:56:48] Reencoding: VID_00518, Pass 2 of 2
 - [20:56:55] Video Encode complete
 - [20:56:55] Processing audio tracks
 - [20:56:58] Multiplexing M2TS
 - [20:57:02] Processing: VID_00519 (45 of 59)
 - [20:57:02] Extracting A/V streams [VID_00519]
 - [20:57:07] Reencoding video [VID_00519]
   - Bitrate: 15,777 Kbs
 - [20:57:07] Reencoding: VID_00519, Pass 1 of 2
 - [20:57:16] Reencoding: VID_00519, Pass 2 of 2
 - [20:57:25] Video Encode complete
 - [20:57:25] Processing audio tracks
 - [20:57:28] Multiplexing M2TS
 - [20:57:33] Processing: VID_00520 (46 of 59)
 - [20:57:33] Extracting A/V streams [VID_00520]
 - [20:57:38] Reencoding video [VID_00520]
   - Bitrate: 16,004 Kbs
 - [20:57:38] Reencoding: VID_00520, Pass 1 of 2
 - [20:57:47] Reencoding: VID_00520, Pass 2 of 2
 - [20:57:56] Video Encode complete
 - [20:57:56] Processing audio tracks
 - [20:57:59] Multiplexing M2TS
 - [20:58:03] Processing: VID_00521 (47 of 59)
 - [20:58:03] Extracting A/V streams [VID_00521]
 - [20:58:08] Reencoding video [VID_00521]
   - Bitrate: 15,319 Kbs
 - [20:58:08] Reencoding: VID_00521, Pass 1 of 2
 - [20:58:18] Reencoding: VID_00521, Pass 2 of 2
 - [20:58:27] Video Encode complete
 - [20:58:27] Processing audio tracks
 - [20:58:29] Multiplexing M2TS
 - [20:58:34] Processing: VID_00522 (48 of 59)
 - [20:58:34] Extracting A/V streams [VID_00522]
 - [20:58:39] Reencoding video [VID_00522]
   - Bitrate: 20,600 Kbs
 - [20:58:39] Reencoding: VID_00522, Pass 1 of 2
 - [20:58:44] Reencoding: VID_00522, Pass 2 of 2
 - [20:58:49] Video Encode complete
 - [20:58:49] Processing audio tracks
 - [20:58:51] Multiplexing M2TS
 - [20:58:55] Processing: VID_00523 (49 of 59)
 - [20:58:55] Extracting A/V streams [VID_00523]
 - [20:59:02] Reencoding video [VID_00523]
   - Bitrate: 14,902 Kbs
 - [20:59:02] Reencoding: VID_00523, Pass 1 of 2
 - [20:59:18] Reencoding: VID_00523, Pass 2 of 2
 - [20:59:33] Video Encode complete
 - [20:59:33] Processing audio tracks
 - [20:59:36] Multiplexing M2TS
 - [20:59:42] Processing: VID_00524 (50 of 59)
 - [20:59:42] Extracting A/V streams [VID_00524]
 - [20:59:48] Reencoding video [VID_00524]
   - Bitrate: 15,795 Kbs
 - [20:59:48] Reencoding: VID_00524, Pass 1 of 2
 - [21:00:03] Reencoding: VID_00524, Pass 2 of 2
 - [21:00:18] Video Encode complete
 - [21:00:18] Processing audio tracks
 - [21:00:21] Multiplexing M2TS
 - [21:00:27] Processing: VID_00525 (51 of 59)
 - [21:00:27] Extracting A/V streams [VID_00525]
 - [21:00:34] Reencoding video [VID_00525]
 - [21:00:34] Reencoding: VID_00525, Pass 1 of 2
 - [21:00:46] Reencoding: VID_00525, Pass 2 of 2
 - [21:00:58] Video Encode complete
 - [21:00:58] Processing audio tracks
 - [21:01:01] Multiplexing M2TS
 - [21:01:06] Processing: VID_00526 (52 of 59)
 - [21:01:06] Extracting A/V streams [VID_00526]
 - [21:01:16] Reencoding video [VID_00526]
   - Bitrate: 19,761 Kbs
 - [21:01:17] Reencoding: VID_00526, Pass 1 of 2
 - [21:01:49] Reencoding: VID_00526, Pass 2 of 2
 - [21:02:20] Video Encode complete
 - [21:02:20] Processing audio tracks
 - [21:02:24] Multiplexing M2TS
 - [21:02:32] Processing: VID_00527 (53 of 59)
 - [21:02:32] Extracting A/V streams [VID_00527]
 - [21:02:37] Reencoding video [VID_00527]
   - Bitrate: 15,345 Kbs
Old 12th July 2012, 19:37   #15327  |  Link
AmigaFuture
The Incredibles Part 4.
 - [21:02:37] Reencoding: VID_00527, Pass 1 of 2
 - [21:02:46] Reencoding: VID_00527, Pass 2 of 2
 - [21:02:55] Video Encode complete
 - [21:02:55] Processing audio tracks
 - [21:02:58] Multiplexing M2TS
 - [21:03:03] Processing: VID_00528 (54 of 59)
 - [21:03:03] Extracting A/V streams [VID_00528]
 - [21:03:09] Reencoding video [VID_00528]
   - Bitrate: 15,786 Kbs
 - [21:03:09] Reencoding: VID_00528, Pass 1 of 2
 - [21:03:18] Reencoding: VID_00528, Pass 2 of 2
 - [21:03:26] Video Encode complete
 - [21:03:26] Processing audio tracks
 - [21:03:29] Multiplexing M2TS
 - [21:03:34] Processing: VID_00529 (55 of 59)
 - [21:03:34] Extracting A/V streams [VID_00529]
 - [21:03:40] Reencoding video [VID_00529]
   - Bitrate: 15,307 Kbs
 - [21:03:40] Reencoding: VID_00529, Pass 1 of 2
 - [21:03:49] Reencoding: VID_00529, Pass 2 of 2
 - [21:03:58] Video Encode complete
 - [21:03:58] Processing audio tracks
 - [21:04:00] Multiplexing M2TS
 - [21:04:05] Processing: VID_00530 (56 of 59)
 - [21:04:05] Extracting A/V streams [VID_00530]
 - [21:04:10] Reencoding video [VID_00530]
   - Bitrate: 20,593 Kbs
 - [21:04:10] Reencoding: VID_00530, Pass 1 of 2
 - [21:04:15] Reencoding: VID_00530, Pass 2 of 2
 - [21:04:20] Video Encode complete
 - [21:04:20] Processing audio tracks
 - [21:04:22] Multiplexing M2TS
 - [21:04:27] Blanking: VID_00532 (57 of 59)
 - [21:04:27] Blanking: VID_00543 (58 of 59)
 - [21:04:27] Blanking: VID_00545 (59 of 59)
[21:04:27]PHASE ONE complete
[21:04:27]PHASE TWO - Rebuild Started
 - [21:04:27] Rebuilding BD file Structure
[21:04:43] - Encode and Rebuild complete
[21:04:43] JOB: INCREDIBLES finished.
INCREDIBLES.INF
[Status]
LABEL=INCREDIBLES
SOURCE_SIZE=43213623797
SOURCE_VIDEO_SIZE=42366523392
REDUCTION=.561632951914413
RESIZE_1080=0
AUDIO_TO_KEEP=eng;
KEEP_HD_AUDIO=0
SUBS_TO_KEEP=eng;
BACKUP_MODE=0
MOVIEONLY_TYPE=0
USE_LAVF=0
INSTANCES=4
DGDECNV=0
QUICK=0
ENCODE_STEP=0
COMPLETED=56
REBUILD_COMPLETE=1
[00451]
AUDIO=
PGS=
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=144234675
RATE=3572
SPLITS=1
NSTART=27000000
NEND=40511623
NSIZE=77672448
FLINK=0
MLINK=0
[00470]
AUDIO=111000011
PGS=100110000101
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=76194307
RATE=20107
SPLITS=1
NSTART=27000000
NEND=28149120
NSIZE=70041600
FLINK=-1
MLINK=0
[00471]
AUDIO=111000011
PGS=100110000101
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=88996304
RATE=15001
SPLITS=1
NSTART=27000000
NEND=28722240
NSIZE=80603136
FLINK=-1
MLINK=0
[00472]
AUDIO=111000011
PGS=100110000101
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=589623372
RATE=16041
SPLITS=1
NSTART=27000000
NEND=37873440
NSIZE=539811840
FLINK=-1
MLINK=0
[00473]
AUDIO=111000011
PGS=100110000101
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=373914911
RATE=15768
SPLITS=1
NSTART=27000000
NEND=33981120
NSIZE=341680128
FLINK=-1
MLINK=0
[00474]
AUDIO=111000011
PGS=100110000101
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=1020339809
RATE=14606
SPLITS=1
NSTART=27000000
NEND=47429280
NSIZE=932696064
FLINK=-1
MLINK=0
[00475]
AUDIO=111000011
PGS=100110000101
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=1610853455
RATE=15671
SPLITS=1
NSTART=27000000
NEND=57261600
NSIZE=1472833536
FLINK=-1
MLINK=0
[00476]
AUDIO=111000011
PGS=100110000101
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=1840592352
RATE=15694
SPLITS=1
NSTART=27000000
NEND=61560000
NSIZE=1682921472
FLINK=-1
MLINK=0
[00477]
AUDIO=111000011
PGS=100110000101
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=2002632499
RATE=15928
SPLITS=1
NSTART=27000000
NEND=64193760
NSIZE=1831428096
FLINK=-1
MLINK=0
[00478]
AUDIO=111000011
PGS=100110000101
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=41125119
RATE=21135
SPLITS=1
NSTART=27000000
NEND=27591840
NSIZE=37453824
FLINK=-1
MLINK=0
[00479]
AUDIO=111000011
PGS=100110000101
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=909293706
RATE=15479
SPLITS=1
NSTART=27000000
NEND=44255520
NSIZE=830724096
FLINK=-1
MLINK=0
[00480]
AUDIO=111000011
PGS=100110000101
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=5504230386
RATE=16557
SPLITS=1
NSTART=27000000
NEND=125690400
NSIZE=5037527040
FLINK=-1
MLINK=0
[00481]
AUDIO=111000011
PGS=100110000101
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=219321316
RATE=16142
SPLITS=1
NSTART=27000000
NEND=31024800
NSIZE=199882752
FLINK=-1
MLINK=0
[00482]
AUDIO=111000011
PGS=100110000101
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=1020343260
RATE=14530
SPLITS=1
NSTART=27000000
NEND=47587680
NSIZE=990093312
FLINK=0
MLINK=0
[00483]
AUDIO=111000011
PGS=100110000101
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=135311235
RATE=14908
SPLITS=1
NSTART=27000000
NEND=29639520
NSIZE=123635712
FLINK=-1
MLINK=0
[00484]
AUDIO=111000011
PGS=100110000101
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=117229709
RATE=15736
SPLITS=1
NSTART=27000000
NEND=29203200
NSIZE=106549248
FLINK=-1
MLINK=0
[00485]
AUDIO=111000011
PGS=100110000101
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=100566410
RATE=15340
SPLITS=1
NSTART=27000000
NEND=28913760
NSIZE=89880576
FLINK=-1
MLINK=0
[00486]
AUDIO=111000011
PGS=100110000101
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=274273281
RATE=19754
SPLITS=1
NSTART=27000000
NEND=31188960
NSIZE=250245120
FLINK=-1
MLINK=0
[00487]
AUDIO=111000011
PGS=100110000101
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=72098359
RATE=15365
SPLITS=1
NSTART=27000000
NEND=28378080
NSIZE=65077248
FLINK=-1
MLINK=0
[00488]
AUDIO=111000011
PGS=100110000101
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=365578085
RATE=14736
SPLITS=1
NSTART=27000000
NEND=34248960
NSIZE=333557760
FLINK=-1
MLINK=0
[00489]
AUDIO=111000011
PGS=100110000101
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=94903856
RATE=14869
SPLITS=1
NSTART=27000000
NEND=28874880
NSIZE=87250944
FLINK=-1
MLINK=0
[00490]
AUDIO=111000011
PGS=100110000101
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=61580708
RATE=15617
SPLITS=1
NSTART=27000000
NEND=28166400
NSIZE=55842816
FLINK=-1
MLINK=0
[00491]
AUDIO=111000011
PGS=100110000101
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=78126684
RATE=15778
SPLITS=1
NSTART=27000000
NEND=28467360
NSIZE=71448576
FLINK=-1
MLINK=0
[00492]
AUDIO=111000011
PGS=100110000101
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=75179810
RATE=17953
SPLITS=1
NSTART=27000000
NEND=28258560
NSIZE=68603904
FLINK=-1
MLINK=0
[00493]
AUDIO=111000011
PGS=100110000101
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=70804356
RATE=16018
SPLITS=1
NSTART=27000000
NEND=28308960
NSIZE=64438272
FLINK=-1
MLINK=0
[00494]
AUDIO=111000011
PGS=100110000101
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=45997469
RATE=20554
SPLITS=1
NSTART=27000000
NEND=27672480
NSIZE=42117120
FLINK=-1
MLINK=0
[00497]
AUDIO=100
PGS=10
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=543608650
RATE=13465
SPLITS=1
NSTART=27000000
NEND=39804480
NSIZE=529035264
FLINK=0
MLINK=0
[00501]
AUDIO=11001
PGS=1100
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=97267566
RATE=15506
SPLITS=1
NSTART=27000000
NEND=28951200
NSIZE=87859200
FLINK=-1
MLINK=0
[00502]
AUDIO=11001
PGS=1100
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=482607655
RATE=15659
SPLITS=1
NSTART=27000000
NEND=36596160
NSIZE=438429696
FLINK=-1
MLINK=0
[00503]
AUDIO=11001
PGS=1100
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=26442506
RATE=16673
SPLITS=1
NSTART=27000000
NEND=27495360
NSIZE=23384064
FLINK=-1
MLINK=0
[00504]
AUDIO=11001
PGS=1100
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=30641975
RATE=13933
SPLITS=1
NSTART=27000000
NEND=27681120
NSIZE=30437376
FLINK=0
MLINK=0
[00505]
AUDIO=11001
PGS=1100
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=97274468
RATE=15508
SPLITS=1
NSTART=27000000
NEND=28951200
NSIZE=87939072
FLINK=-1
MLINK=0
[00506]
AUDIO=11001
PGS=1100
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=24379004
RATE=15279
SPLITS=1
NSTART=27000000
NEND=27495360
NSIZE=21596160
FLINK=-1
MLINK=0
[00508]
AUDIO=11001
PGS=1100
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=97308975
RATE=15513
SPLITS=1
NSTART=27000000
NEND=28951200
NSIZE=87914496
FLINK=-1
MLINK=0
[00509]
AUDIO=1
PGS=100
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=743468171
RATE=19006
SPLITS=1
NSTART=27000000
NEND=39800160
NSIZE=723732480
FLINK=0
MLINK=0
[00510]
AUDIO=1
PGS=100
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=2346495500
RATE=12696
SPLITS=4
NSTART=27000000
NEND=86806621
NSIZE=2285574144
FLINK=0
MLINK=0
[00511]
AUDIO=111000011
PGS=100110000101
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=135777076
RATE=14967
SPLITS=1
NSTART=27000000
NEND=29639520
NSIZE=123801600
FLINK=-1
MLINK=0
[00512]
AUDIO=111000011
PGS=100110000101
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=117574776
RATE=15789
SPLITS=1
NSTART=27000000
NEND=29203200
NSIZE=107028480
FLINK=-1
MLINK=0
[00513]
AUDIO=111000011
PGS=100110000101
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=100562959
RATE=15339
SPLITS=1
NSTART=27000000
NEND=28913760
NSIZE=90802176
FLINK=-1
MLINK=0
[00514]
AUDIO=111000011
PGS=100110000101
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=274035185
RATE=19735
SPLITS=1
NSTART=27000000
NEND=31188960
NSIZE=249630720
FLINK=-1
MLINK=0
[00515]
AUDIO=111000011
PGS=100110000101
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=71998289
RATE=15341
SPLITS=1
NSTART=27000000
NEND=28378080
NSIZE=64917504
FLINK=-1
MLINK=0
[00516]
AUDIO=111000011
PGS=100110000101
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=363090150
RATE=14621
SPLITS=1
NSTART=27000000
NEND=34248960
NSIZE=331210752
FLINK=-1
MLINK=0
[00517]
AUDIO=111000011
PGS=100110000101
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=94758927
RATE=14843
SPLITS=1
NSTART=27000000
NEND=28874880
NSIZE=86999040
FLINK=-1
MLINK=0
[00518]
AUDIO=111000011
PGS=100110000101
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=61594510
RATE=15621
SPLITS=1
NSTART=27000000
NEND=28166400
NSIZE=55511040
FLINK=-1
MLINK=0
[00519]
AUDIO=111000011
PGS=100110000101
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=78119783
RATE=15777
SPLITS=1
NSTART=27000000
NEND=28467360
NSIZE=71626752
FLINK=-1
MLINK=0
[00520]
AUDIO=111000011
PGS=100110000101
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=67843679
RATE=16004
SPLITS=1
NSTART=27000000
NEND=28258560
NSIZE=62035968
FLINK=-1
MLINK=0
[00521]
AUDIO=111000011
PGS=100110000101
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=68071423
RATE=15319
SPLITS=1
NSTART=27000000
NEND=28308960
NSIZE=61962240
FLINK=-1
MLINK=0
[00522]
AUDIO=111000011
PGS=100110000101
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=46090637
RATE=20600
SPLITS=1
NSTART=27000000
NEND=27672480
NSIZE=42037248
FLINK=-1
MLINK=0
[00523]
AUDIO=111000011
PGS=100110000101
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=135262925
RATE=14902
SPLITS=1
NSTART=27000000
NEND=29639520
NSIZE=123543552
FLINK=-1
MLINK=0
[00524]
AUDIO=111000011
PGS=100110000101
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=117616184
RATE=15795
SPLITS=1
NSTART=27000000
NEND=29203200
NSIZE=106868736
FLINK=-1
MLINK=0
[00525]
AUDIO=111000011
PGS=100110000101
VIDEO2=0
V2MBRATE=0
RATE=15340
SPLITS=1
NSTART=27000000
NEND=28913760
NSIZE=89942016
FLINK=-1
MLINK=0
[00526]
AUDIO=111000011
PGS=100110000101
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=274359548
RATE=19761
SPLITS=1
NSTART=27000000
NEND=31188960
NSIZE=249937920
FLINK=-1
MLINK=0
[00527]
AUDIO=111000011
PGS=100110000101
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=72015543
RATE=15345
SPLITS=1
NSTART=27000000
NEND=28378080
NSIZE=65132544
FLINK=-1
MLINK=0
[00528]
AUDIO=111000011
PGS=100110000101
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=78157740
RATE=15786
SPLITS=1
NSTART=27000000
NEND=28467360
NSIZE=71700480
FLINK=-1
MLINK=0
[00529]
AUDIO=111000011
PGS=100110000101
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=68023114
RATE=15307
SPLITS=1
NSTART=27000000
NEND=28308960
NSIZE=61949952
FLINK=-1
MLINK=0
[00530]
AUDIO=111000011
PGS=100110000101
VIDEO2=0
V2MBRATE=0
M2TS_TARGET=46076835
RATE=20593
SPLITS=1
NSTART=27000000
NEND=27672480
NSIZE=42098688
FLINK=-1
MLINK=0
Old 12th July 2012, 19:41   #15328  |  Link
AmigaFuture
The Incredibles Part 5.
BDREBUILDER.INI
[Options]
VERSION=0.40.0.10
MODE=0
ENCODE_QUALITY=0
MULTIPROCESS=4
MKV_MUXSUPS=1
ENABLE_TEST=1
ONEPASS_ENCODING=0
AUTO_QUALITY=0
AUDIO_TO_KEEP=eng;
SUBS_TO_KEEP=eng;
SD_CONVERT=0
OPEN_GOP=0
RESIZE_1080=0
DEINTERLACE=1
SD_TO_1080=0
CONVERT_WIDE=0
DTS_REENCODE=1
AC3_REENCODE=0
AC3_640=0
AC3_192=0
KEEP_HD_AUDIO=0
AVCHD=1
REMOVE_WORKFILES=0
MOVIE_ONLY_LOOP=0
REMOVE_OUTPUT=0
USE_FILTERS=0
BDMV_CERT_ONLY=0
USE_LAVF=0
IVTC_PULLDOWN=0
ASSUME_DVD_PAL=0
UNMASK_CHAPTER=0
COMPLETION_BEEP=0
DGDECNV=0
AUDIO_TRACK_LIMIT=0
SUBTITLE_TRACK_LIMIT=0
CUSTOM_TARGET_SIZE=23500
MOVIEONLY_TYPE=10
ALTCRF=20
ALT_TARGET=7600
ALTMETHOD=2
ALTAUTOCROP=0
VERBOSE_STATUS=1
TARGET_SIZE=23500
AUTO_BURN=0
ENABLE_BLANKING=1
QUICK_EXTRAS=0
[Paths]
SOURCE_PATH=J:\!BLU-RAY RIPS\INCREDIBLES\
WORKING_PATH=E:\BLU-RAY\REBUILDER\
Old 13th July 2012, 07:09   #15329  |  Link
sonate
There are times when I make a menu and movie backup, inadvertently hitting a wrong menu button will infrequently but surely end up dead ending any further navigation out of that particular item and or calling the main menu. Is there any way I can easily disable or deactivate a particular menu button to avoid the problem all together? If anyone knows, would you please steer me to where I can find how to accomplish this.
sonate is offline   Reply With Quote
Old 13th July 2012, 08:57   #15330  |  Link
omegaman7
omegaman7's Avatar
Bug? Perhaps. I'll let you be the judge of that
I'm reprocessing, but I don't believe that to be the issue. I'm running Harry potter 7 Pt 1, and I want to output to MKV. When I go to the setup menu to remove the spanish audio, and then return to the BD rebuilder main window, it seems to default back to the original chosen playlist. Which by the way, is the incorrect playlist. I had to manually choose the appropriate playlist. Going to setup, after choosing "other movie only playlist", will default back to the programs playlist decision. Thankfully I noticed the run time was incorrect LOL! You may already be aware of this though.
I'm running it FROM optical disc, but that shouldn't be the problem. At least I wouldn't think so :S
Old 13th July 2012, 14:05   #15331  |  Link
The SETUP menu represents global settings. So when you change anything in SETUP -- the disc is reread and you are starting from scratch... (just like exiting and restarting BD-RB). That's why the default playlist is selected again. If you want to change anything in SETUP -- you should always do that first.
Old 13th July 2012, 14:06   #15332  |  Link
jwjohnson
It's been that way for as long as I can remember. If you make any other changes after selecting "other movie only playlist" it will revert to the default playlist. It would be nice if it stuck on the one you selected. I've just altered my workflow so that's the last thing I check before starting the encode.
EDIT: Posted while JDobbs was writing his reply.
jwjohnson is offline   Reply With Quote
Old 13th July 2012, 16:17   #15333  |  Link
bikerman
hi
running windows 7 64 bit sp1, never had a problem with previous releases of bdrebuilder, but the latest version (04010) causes a BSD ... anyone else had this, and any ideas how to get around it?
bikerman is offline   Reply With Quote
Old 13th July 2012, 16:59   #15334  |  Link
check cpu stability in LinX. check memory in memtest86
Old 13th July 2012, 17:02   #15335  |  Link
omegaman7
omegaman7's Avatar
That's EXACTLY why I figured you were aware That makes perfect sense.
Old 13th July 2012, 17:32   #15336  |  Link
bikerman
I have change the 'compatability' mode to windows xp sp3, and so far I have not had a BSoD... fingers crossed ...
Old 13th July 2012, 17:51   #15337  |  Link
bikerman
ok, that didn't work... 2 mins after I posted my last message I got BSod again.... (
Old 13th July 2012, 23:58   #15338  |  Link
HiQ123
I have a problem with Pirates of the Caribbean.
Log:
[07.13.12] BD Rebuilder v0.40.10 (beta)
[23:56:07] Source: PIRATES1_DEU
- Input BD size: 33,18 GB
- Approximate total content: [03:35:38.583]
- Target BD size: 22,95 GB
- Windows Version: 6.1 [7601]
- MOVIE and MENUS mode enabled
- SHUTDOWN at completion enabled
- Auto Quality: Better (Faster), Two Pass
[23:56:08] PHASE ONE, Encoding
- [23:56:08] Processing: VID_00001 (1 of 31)
- [23:56:08] Extracting A/V streams [VID_00001]
- Error in attempt to extract audio/subs.
- AV frame too large (57344 bytes). Increase AV buffer.
[00:09:47] - Failed to retrieve audio, aborted
Inspect.exe:
- FFDSHOW AVC set to "ffmpeg-mt": Ok
- X264: Ok
- AFTEN: Ok
- FAAC: Ok
- MP4BOX: Ok
- WAVI: Ok
- TSMUXER: Ok
Is it because the audio stream is in LPCM ?
HiQ123 is offline   Reply With Quote
Old 14th July 2012, 14:06   #15339  |  Link
JJB
"AV frame too large (57344 bytes). Increase AV buffer"
Usually indicates a bad rip.
JJB is offline   Reply With Quote
Old 14th July 2012, 14:12   #15340  |  Link
HiQ123
Hm, okay
