Old 28th September 2016, 08:25   #14541  |  Link
zazon
Hey Everybody -
The last couple Blu rays I've bought seem to have the audio off for a half second or so for last half of the movie. Anything I can look into to fix this? Thanks for any help.
zazon is offline   Reply With Quote
Old 30th September 2016, 04:25   #14542  |  Link
Jake802
I am have this problem lately too. Stuff is finishing out of sync.
Jake802 is offline   Reply With Quote
Old 30th September 2016, 13:17   #14543  |  Link
slalom
slalom's Avatar
Check fps on job window. If it is not correct, press Avisynth, then >, and select output speed, assume -> x.xx fps
Re-run the job
Xeon E5-2680 v2 @ 3.1GHz 16GB
Sony Vaio VPC-F13Z1E/B
Old 1st October 2016, 19:00   #14544  |  Link
Jake802
Thanks I will try that, Thanks again for the help.
Old 1st October 2016, 19:16   #14545  |  Link
Jake802
I am having a problem with the cover option too. I hit the Cover Button and I get a Popup JPEG Error 53 Msg, Hit Ok and then the Cover Search Option comes up. I do my search and when I select my choice, I then get a popup with an Cannot Open AVI Msg. I hit OK and the whole thing freezes up.
Old 4th October 2016, 06:29   #14546  |  Link
zazon
Re-run the job
Thank you for the reply. If the movie is synced for the first half, but not the second half, how would changing the FPS fix this? I'm assuming FPS is a constant, though I don't know much. Thanks again.
Old 4th October 2016, 09:50   #14547  |  Link
slalom
slalom's Avatar
My suggestion was in the case where the fps where different in the job and the file
I can't help you with the other
Old 9th October 2016, 13:58   #14548  |  Link
magmo23
How to solve issue
If the solution is to unistall codecs then how am I supposed to be able to use the ripbot264 application?
AviSynth Error message or other decoding problem (avs2avi.exe/avs2yuv.exe crashes)
Uninstall all codec packs , AviSynth , Haali Media Spliter , ffdshow. XP users also must install Windows Media Player 11!
magmo23 is offline   Reply With Quote
Old 10th October 2016, 15:23   #14549  |  Link
Just install what is required by RipBot264. Nothing more , nothing less.
Old 10th October 2016, 20:05   #14550  |  Link
byteshare
ByteShare
byteshare's Avatar
Any chance to include QTGMC (3.33) for better Deinterlace/decomb?
Or Temporal Degrain for better denoise?
Both are filters for AVISynth and AVISynth+
Or, any help on how to make it work myself. I know I can manually edit the avisynth script, but I don't know how to make it work with Distributed Encoding (so that all the right plugins get to the other machines.
Last edited by byteshare; 14th October 2016 at 18:05. Reason: carification+an idea
Old 11th October 2016, 08:51   #14551  |  Link
klopsknoedel
This should help to solve your problems: http://forum.doom9.org/showthread.ph...96#post1524496
klopsknoedel is offline   Reply With Quote
Old 11th October 2016, 21:23   #14552  |  Link
byteshare
ByteShare
byteshare's Avatar
I've been having this issue as well with some jobs.
As others have suggested it was the FPS being different. I just changed the FPS in MKVtoolNix and that fixed my problem without having to re-do my job.
I has also seen the issue where the audio gets stretched, ie double or more.
For the later issue I just use another program to process the audio or copy in the source audio and call it a day.
Old 14th October 2016, 00:18   #14553  |  Link
ismail0100
Today try this pro for hevc 10bit and i like it. Thank u
ismail0100 is offline   Reply With Quote
Old 15th October 2016, 13:31   #14554  |  Link
magmo23
But thats what I have done, and the errors occures anyway. I dont get it?
Old 15th October 2016, 13:35   #14555  |  Link
What error? Screenshots?
Old 24th October 2016, 15:23   #14556  |  Link
lemaireus
E-AC3 Decoding Error
Each time I load a video with 224kbps E-AC-3 track into Ripbot I get the following error:
The source is .mkv video with 224k E-AC-3 audio (for some reason E-AC-3 640k does not create any problem). The only way out then is to load the video after demuxing the audio track, and remux the audio once the video has been encoded. The audio works perfectly well using this workaround.
Any ideas? The AC-3 header problem appears only when loading the file in Ripbot: Mediainfo works fine with the same file, as does playback, and MKVToolnix processing.
lemaireus is offline   Reply With Quote
Old 24th October 2016, 20:15   #14557  |  Link
byteshare
ByteShare
byteshare's Avatar
Try re-muxing it with most recent MKVToolnix, and if that doesn't work remux it without audio and use another application to process audio. I've had this issue from time to time.
This last part is only a temporary solution, hopefully Atak_Snajpera can figure it out and fix.
Old 24th October 2016, 20:36   #14558  |  Link
sneaker_ger
Is it trying to use nicaudio? I think nicaudio never got E-AC-3/DD+ support so you need to use a different audio source filter.
Old 25th October 2016, 04:35   #14559  |  Link
lemaireus
Try re-muxing it with most recent MKVToolnix...
That is exactly what I have been doing, as I mentioned in my post: I demux the audio, encode the video, and then mux the original audio back in using MKVToolnix. But I was hoping may be someone has been able to find a better solution via an audio decoder update?
I don't think Ripbot is using nicaudio for audio processing, is it? Also, I don't get the issue when the audio is 640k E-AC-3/DD+.
Old 25th October 2016, 06:31   #14560  |  Link
sneaker_ger
I believe it's still shipped but I don't know when it is used. There should be a log or scripts available to show it, right?
