7th March 2017, 16:30 | #14741 | Link | |
x86 14.0.23918 x64 14.0.24215 it doesn't happen on everything, I have found a pattern either... |
7th March 2017, 17:05 | #14742 | Link | |
ByteShare
x86: 14.0.23.026.0 x64: 14.0.23.026.0 Those are the versions you should be on if you install from: https://www.microsoft.com/en-us/down....aspx?id=48145 Unless you did the update: Microsoft Visual C++ 2015 Redistributable Update 3 https://www.microsoft.com/en-us/down....aspx?id=53587 If it is just some files and not other than find a file that is affected and post the media info to see if maybe there is something else I/we can see about the video. Last edited by byteshare; 7th March 2017 at 17:10. |
7th March 2017, 23:27 | #14743 | Link | |
15th March 2017, 18:59 | #14746 | Link |
New auto crop method beta test.
Main features -Slightly faster (1.5x-2x faster) -more accurate (less chance for over cropped frame) http://www.mediafire.com/file/d73d7k...tocrop_algo.7z
17th March 2017, 15:06 | #14748 | Link |
The speed up will bigger if you have 16 Thread CPU (for example Ryzen 7). Realistically it is around 50%.
18th March 2017, 16:27 | #14750 | Link |
I've tested with Underworld (2003) and borders where correctly detected.
25th March 2017, 12:57 | #14752 | Link |
Async output caused by VC-1 to H.264 encoding
as the title mentions I have some problems archiving BDs if the video-codec is VC-1. It seems like transcoding (or just decoding) is slowing down the video-track (maybe duplicated frames or anything else). So the resulting file is going out of sync during playback. Also I have to choose wmv9 as decoder. AviSynth crashes with libavcodec (ffshdow). It's quite frustrating as I recognized it a little bit late. I'm currently archiving my complete blu-ray - collection and some of the older ones are VC-1 - encoded. I hope some of you guys have an idea how to fix this problem. Kind Regards klopsknoedel My Environment: OS: Windows 10 Pro x64 Version 1607 Build 14393 CPU: Core i7 - 4770k Memory: 16GB AviSynth 2.6ST ffdshow 1.3.4531 MatroskaSplitter 23/06/2013 |
25th March 2017, 13:37 | #14753 | Link |
I will need some big sample (1GiB) to reproduce this issue.
25th March 2017, 18:24 | #14756 | Link |
Try now.
27th March 2017, 20:50 | #14758 | Link |
I am getting an error when my .mkv file demuxes "m2AudioAC3Source: "G:\Temp\RipBot264temp\job1\1_audio_English.ac3" without a valid AC-3 header in first 1MB
(G:\Temp\RipBot264temp\job1\getinfo.avs, line 4)" The audio file in this .mkv is Eac3 How can I get this to demux and mux properly in ripbot? is there an update for this? |
27th March 2017, 21:19 | #14759 | Link |
Cut out few minute sample and send me prepared .mkv. I will check what is going there.
