Old 17th December 2016, 19:41   #41561  |  Link
Oguignant
Oguignant's Avatar
Originally Posted by har3inger View Post
Most TV's/players nowadays implement something called digital noise removal, which smooth over your image to varying degrees and remove grain, often at the cost of removing detail at the same time.
madvr doesn't currently have anything that removes grain from images. At least not yet. There should be custom scripts out there that do it that may or may not work together with madvr.
Ok! Thks
Someone who has a script to share?
"To infinity, and beyond!"
Oguignant is offline   Reply With Quote
Old 17th December 2016, 21:14   #41562  |  Link
Asmodian
Originally Posted by Oguignant View Post
Ok! Thks
Denoising is a difficult problem and I have still not found a good script that can denoise in real time without damaging quality a lot.
Removing strong film grain, as found in older movies, with real time denoisers also removes most of the texture detail making skin and cloth look terrible. There is a reason the remaster left the grain in.
If you like a smoother look and don't mind the loss of texture detail this is one area where the dedicated hardware in modern TVs does a very good job compared to currently available software tools.
madVR options explained
Old 17th December 2016, 21:23   #41563  |  Link
CruNcher
CruNcher's Avatar
Depends on how advanced the Dedicated Hardware IP is they can totally beat Software, especially in balance terms on Denoising Quality/Performance/Power
Motion Compensated Denoising can be very efficient overall and actually is the most efficient when implemented in Dedicated Hardware there was also a nice new evaluation of it's Performance based on HEVC actually.
It is about Time
Old 17th December 2016, 23:23   #41564  |  Link
Oguignant
Oguignant's Avatar
On my tv, when I use 4k 60mhz resolution per hdmi, the noise reduction and mpeg noise reduction are disabled. I do not know why.
The noise reduction by nvidia works only if i choose nvidia cuvid as hardware decoder?
In the panel of nvidia, I always use the options of noise reduction and edge enhancement, by the media player. And Use inverse telecine enabled. It's okay like this? Or should I enable it to do it nvidia?
Old 18th December 2016, 00:06   #41565  |  Link
Magik Mark
Guys
Made some experiments.
When in exclusive mode I get frame drops every 3minutes. However, this is corrected using reclock
When I'm out of FSE no frame drops regardless which audio renderer is being utilized as long as display refresh rate is the same or very close from that of the video's
Why is frame drops happening in FSE even if the refresh rate of the display is the same of that of the video? Is there a setting that can be tweaked. I'll be using a x64 player and reclock is only x86
Old 18th December 2016, 00:39   #41566  |  Link
Georgel
Visual Novel Dev.
Georgel's Avatar
@madshi
Can we get a force 200% scaling for Jinc in image upscaling?
After about 100 tests I came to the conclusion that anything but Jinc will add a bit of grain to edges while watching anime.
Jinc seems the most rounded, cleanest algorithm, but I want to force a 200% upscaling still using Jinc to get the most out of it. NNEDI and NGU work very well with human and life-like content, but not with anime... At least not in my tests / setup...
Georgel is offline   Reply With Quote
Old 18th December 2016, 01:04   #41567  |  Link
Oguignant
Oguignant's Avatar
Mpc-hc Internal subtitle render
Loses image quality if I use the internal subtitle rendering of mpc-hc? Which one should I use anyway?
Old 18th December 2016, 01:05   #41568  |  Link
sneaker_ger
No, not at all.
Old 18th December 2016, 01:08   #41569  |  Link
Oguignant
Oguignant's Avatar
No, not at all.
And performance?
Old 18th December 2016, 01:10   #41570  |  Link
sneaker_ger
Compared to no subtitles? Very little.
Compared to other subtitle renderers? Depends but does not matter mostly. Sometimes on complex ASS scripts can be slower/faster than other renderers. It is usually not worth to use other subtitle renderer.
Old 18th December 2016, 01:41   #41571  |  Link
Georgel
Visual Novel Dev.
Georgel's Avatar
XYsub seems to do some tricks better than the internal renderer, but no noticeable performance difference so far.
(Especially for Anime and floating text over the image, like translated signs, XySub seems to do things a bit better than the internal renderer. )
Old 18th December 2016, 01:50   #41572  |  Link
xy subfilter and assfilter mod are using the "new subtitle interface" if you care about correct colors in subtitles than this is needed.
rendering complex subtitles at UHD is kind of impossible without assfilter mod.
Old 18th December 2016, 02:18   #41573  |  Link
Oguignant
Oguignant's Avatar
Thks, I appreciate the help. It's my weekend of "learning to use madvr"
Old 18th December 2016, 02:29   #41574  |  Link
Asmodian
I don't have much experiance with those features, sorry. I always disable them. I am not interested in real time noise reduction and believe the resulting picture is usually worse than without it.
madVR will bypass all of Nvidia's video (damage) algorithms unless using DXVA2 decoding, I am not sure about CUVID. You can try turning on denoising in Nvidia's control panel to see if you like the resulting picture more.
I really like assfilter mod. It has been working perfectly for me and I appreciate the performance and that the correct calibration is applied to subtitles. It did help with some issues I had with xysubfilter and UHD subtitles.
Old 18th December 2016, 02:39   #41575  |  Link
Georgel
Visual Novel Dev.
Georgel's Avatar
Is it possible to use madVR on a very noisy source to smooth out the noise but keep sharpness on edges?
Something like watching horriblesubs rips which are TV rips, and are very very noisy but to at least lower the noise but keep edges clean (?)
Old 18th December 2016, 02:39   #41576  |  Link
Oguignant
Oguignant's Avatar
I enabled them and saw no difference. So I leave them disabled. Only activate "Use inverse telecine".
For now I will continue to use internal subtitle render. Work fine for me. I have very little uhd content (only 10 or 15 uhd movies, and almost 400 fhd) I do not find where to download uhd content from torrent.
Note: I learned how to use the profiles. Wow surprisingly helpful.
Old 18th December 2016, 02:44   #41577  |  Link
these are not TV rip (forum rules) and they are not noisy and if there is noisy there is a reason for that.
Old 18th December 2016, 03:15   #41578  |  Link
Georgel
Visual Novel Dev.
Georgel's Avatar
Was using it as an example since I avoid watching anything like a TV rip (better buy Blu Rays for anime that you really love), but there are series where the whole series has a bit of grain / noise over that I would still want to try and filter out.
Old 18th December 2016, 03:32   #41579  |  Link
plasma
Use ffdshow raw video filter as external filter under mpc hc. It renders the image before madvr. It has some decent denoising option.
After you denoised the image with its options you can use the madvr settings such as nnedi3, edge thinning and (very little adaptive sharpen). ngu can amplify input artefacts
plasma is offline   Reply With Quote
Old 18th December 2016, 08:47   #41580  |  Link
Oguignant
Oguignant's Avatar
Hdr passthrough
The hdr passthrough option does not work yet? My TV (lg oled 65ef9500) when it detects HDR content, activates HDR Mode (netflix, anazon, and local playback). But not with madvr. Why?
