Old 3rd October 2019, 12:23   #6801  |  Link
tebasuna51
tebasuna51's Avatar
Originally Posted by imsrk48 View Post
Sir I Want to Post My Log File But I Don't Know where to do this in web browser
Zip the log file and attach the zip (Go Advanced -> Additional Options -> Attach Files) or use pastebin
Old 3rd October 2019, 12:52   #6802  |  Link
imsrk48
imsrk48's Avatar
okay sir soon I'll post my log file
imsrk48 is offline   Reply With Quote
Old 6th October 2019, 09:19   #6803  |  Link
imsrk48
imsrk48's Avatar
MeGUI Giving Error When Trying to Update 2911 to 2913
Old 6th October 2019, 09:19   #6804  |  Link
imsrk48
imsrk48's Avatar
Something ReadOnlyMemory Error.
Old 6th October 2019, 14:44   #6805  |  Link
StainlessS
StainlessS's Avatar
Again, post your log, will give better information than your, half error message.
You trying to update MeGUI on a write protected SD Card ? [the full size SD cards have a sliding switch to write protect them].
I sometimes post sober.
Old 6th October 2019, 19:43   #6806  |  Link
imsrk48
imsrk48's Avatar
no all are non protected disk. and today morning I'll post log file too.
Old 6th October 2019, 21:28   #6807  |  Link
StainlessS
StainlessS's Avatar
By the way imsrk48, back in May, then again in September you posted in Avisynth Usage forum
Please suggest me script for add .png logo on a video.
I posted a soilution for you, but you dont seem to have seen it, I also PM'ed you bout it, but you dont seem to receive PM via your Tapatalk thingy.
Here:- https://forum.doom9.org/showthread.p...66#post1884066
Old 7th October 2019, 04:38   #6808  |  Link
imsrk48
imsrk48's Avatar
No I Have Seen That. Just Forgot About Mention Again Sorry for that but I'm Everytime checking my Tapatalk
Old 4th November 2019, 21:40   #6809  |  Link
kuchikirukia
The mouseover tooltip in the x264 GUI says that qpmin and qpmax are ignored in constant quality mode. They're not.
kuchikirukia is offline   Reply With Quote
Old 8th November 2019, 05:33   #6810  |  Link
THEAST
Not sure if MeGUI is still under active development but I have two feature requests:
- Possibility to close any active window in MeGUI, except the main window, using the Escape key. This will make navigating around MeGUI, especially when using the AVS script creator, much easier.
- Ctrl + G as shortcut for the "Go to Frame" option when video preview is open, similar to MPC-HC and VitrualDub.
THEAST is offline   Reply With Quote
Old 9th November 2019, 19:38   #6811  |  Link
Barough
Barough's Avatar
MKVToolNix v40.0 is released
https://mkvtoolnix.download/windows/releases/40.0.0/
x264 0.158.2988 7817004
http://www.mediafire.com/file/rz2nn7...GCC920.7z/file
Old 10th November 2019, 01:34   #6812  |  Link
kedautinh12
I try access to megui.org but can't, why??
Old 10th November 2019, 08:57   #6813  |  Link
kedautinh12
My Megui still 2896, how update to 2913??
Old 10th November 2019, 10:33   #6814  |  Link
tebasuna51
tebasuna51's Avatar
Megui -> Options -> Extended -> Auto Update -> Use development update server -> Save
Megui -> Tools -> Update -> Show all packages -> Enable all packages -> Update
Old 11th November 2019, 06:21   #6815  |  Link
kedautinh12
Old 12th November 2019, 05:59   #6816  |  Link
kedautinh12
But, in Megui x64 i have error when close megui "The profile could not be saved. If you ignore this problem, data may be lost"
Old 12th November 2019, 09:58   #6817  |  Link
tebasuna51
tebasuna51's Avatar
Put the full path of your MeGUI folder.
Do you have rigths to write in that folder?
Old 13th November 2019, 08:26   #6818  |  Link
In general, do not install MeGUI inside the UAC protected "Program Files". It saves configuration files in its own installation directory, instead of %PROGRAMDATA% or %APPDATA% (legacy issue of ages before Vista).
Old 13th November 2019, 14:09   #6819  |  Link
stax76
stax76's Avatar
I've implemented an update routine for mpv.net this week and what I've discovered is that if you move a folder to 'Program Files' using File Explorer than this folder is writable without admin rights!
Old 13th November 2019, 20:55   #6820  |  Link
mini-moose
x264 binaries are now here:
https://artifacts.videolan.org/x264/release-win64/
https://artifacts.videolan.org/x264/release-win32/
Zathor, may want to update on megui
mini-moose is offline   Reply With Quote
