Old 3rd December 2017, 23:44   #3781  |  Link
jinkazuya
This may be impossible in all the cases where the original authors did not provide sources of their plugins, or did not document their algorithms detailed enough to reprogram them. But where it is possible, a lot of efforts were already invested to implement them. The AviSynth Wiki lists many successful attempts. If you know some missing ones, always provide links to their original location, optimally with sources. A few special plugins may even be easily resembled using very generic tools like convolution or LUT functions.
Specifically regarding "RedAverage", Average is reported to do the same, just faster.
I know, but I would like to use the detailsharpen function. Unfortunately that function requires the RedAverage plugin.
jinkazuya is offline
Old 3rd December 2017, 23:52   #3782  |  Link
You mean this script function? I bet this could be rewritten to use more portable/compatible kernel or plugin functions.
LigH is online now
Old 4th December 2017, 01:50   #3783  |  Link
jinkazuya
Yes...This is the one I am talking about. I am a noob when it comes to scripting. But it seems nowadays less people are creating new scripts or plugins for video encodes. There used to be a lot more.
Old 5th December 2017, 21:41   #3784  |  Link
Myrsloik
Professional Code Monkey
Myrsloik's Avatar
I just tried to compile avisynth.h with /permissive- in Visual Studio 15.5. It fails. When are you going to change it to be valid C++ code?
Fun fact: this is now the default setting for new projects
Myrsloik is offline
Old 6th December 2017, 07:33   #3785  |  Link
pinterf
I have read about it but not yet tried.
pinterf is offline
Old 6th December 2017, 16:57   #3786  |  Link
pinterf
I have tried. So what's your problem?
pinterf is offline
Old 6th December 2017, 18:23   #3787  |  Link
Myrsloik
Myrsloik's Avatar
4>C:\VapourSynth\AviSynthPlus\avs_core\include\avisynth.h(670): error C3447: third operand to the conditional operator ?: is of type 'void', but the second operand is neither a throw-expression nor of type 'void'
Basically a wall of this whenever you compile a plugin, compiling the core will obviously work since then the proper functions are provided. I even checked out the latest version from your MT branch to test it.
AVFS (and probably any plugin/api user) shows this problem.
Myrsloik is offline
Old 6th December 2017, 18:27   #3788  |  Link
pinterf
Ah. Then will try with a plugin. I only had syntax error in a win 7.1 sdk header which i commented out (because the 141xp toolset uses this sdk).
pinterf is offline
Old 8th December 2017, 17:07   #3789  |  Link
pinterf
Thanks, now it should be OK. There were other surprises as well.
pinterf is offline
Old 8th December 2017, 20:19   #3790  |  Link
Myrsloik
Myrsloik's Avatar
Works. As a bonus you can now easily use clang-cl to compile plugins too.
Myrsloik is offline
Old 10th December 2017, 00:32   #3791  |  Link
lordsmurf
lordsmurf's Avatar
I had to reinstall 2.6, and use SEt's MT dll.
I could never get the 32-bit + MT to work, and then tmedian2 was not available. That was a deal breaker.
The + x64 worked perfectly.
Back in town.
If you want my advice, then find me at the DigitalFAQ forum. Glad to assist.
lordsmurf is offline
Old 10th December 2017, 10:20   #3792  |  Link
pinterf
What was the problem? Memory issues at large thread count?
pinterf is offline
Old 11th December 2017, 21:39   #3793  |  Link
Anyone compiled a new build?
ryrynz is offline
Old 19th December 2017, 18:45   #3794  |  Link
pinterf
New version.
Avisynth Plus r2574
- Finally with an installer (x86/x64 in one package), thanks to Groucho2004. This is the first time I'm providing installer, there can be glitches. One of the installer comes with the current Visual Studio C++ x86 and x64 Redistributables. In theory the VS2017 redistributables superseed and are compatible with the VS2015 one. Please note that original Avisynth documentation and filter SDK is not provided, they are not up to date.
- A fix for MaskHS, reported by sneaker_ger, thanks for the report.
- The other things are mainly Expr related.
There was a bugfix in jit that took some time to understand and caused many grey hairs.
And new "why not" features to have my entertainment as well
The idea for introducing variables came for an earlier test Expr script, in which abs(x-y) was used and computed at least four times. Variables are temporary registers inside an Expr that can be saved, saved and popped from stack and reused many times. A variable is an uppercase letter from A to Z.
The other feature is the pixel-relative addressing. Clip variables can be shifted by (constant) x and y offset.
Both of this two features were found later in davidhorman's great rgba_rpn/y8_rpn filter: https://forum.doom9.org/showthread.php?t=172601
Two other Expr feature idea then was adopted from his filter: 'frameno' and 'time' ('n' and 't' in his version - in Expr lowercase letters are clip references)
Example: Mandelbrot zoomer, syntax rewritten from the above topic
a="X dup * Y dup * - A + T^ X Y 2 * * B + 2 min Y^ T 2 min X^ "
b=a+a
c=b+b
blankclip(width=960,height=640,length=1600,pixel_type="YUV420P8")
Expr("sxr 3 * 2 - -1.2947627 - 1.01 frameno ^ / -1.2947627 + A@ X^ syr 2 * 1 - 0.4399695 "+\
"- 1.01 frameno ^ / 0.4399695  + B@ Y^ "+c+c+c+c+c+b+a+"X dup * Y dup * + 4 < 0 255 ?","128","128")
Changes since r2544
# Fix
Fix: MaskHS created inverse mask. Regression after r2173
Fix: jitasm code generation at specific circumstances in Expr filter
# Build
Build: changed avisynth.h, strict C++ conformity with Visual Studio 2017 /permissive- flag
# Other
Installer in two flavours: simple or full (with Microsoft Visual C++ Redistributables)
# New
Expr tweaks:
  - Indexable source clip pixels by relative x,y positions.
  Syntax: x[a,b] where
  'x': source clip letter a..z
  'a': horizontal shift. -width < a < width
  'b': vertical shift. -height < b < height
  'a' and 'b' should be constant. e.g.: "x[-1,-1] x[-1,0] x[-1,1] y[0,-10] + + + 4 /"
  When requested pixels come from off-screen the off-screen values are cloned from the appropriate top-bottom-left-right edge.
  Optimized version requires SSSE3 (and no AVX2 version is available). On non-SSSE3 CPUs falls back to C.
  - sin cos tan asin acos atan (no SSE2/AVX2 optimization, when they appear in Expr a slower C code runs the expression)
  - % (modulo). result = x - trunc(x/d)*d.
  Note: internally everything is calculated as a 32 bit float.
  A float can only hold a 24 bit integer number, don't expect 32 bit accuracy here.
  - Variables: uppercase letters A..Z for storing and reuse temporary results, frequently used computations.
  Store, result can still be used from stack: A@ .. Z@
  Store and remove from stack: A^ .. Z^
  Use: A..Z
  Example: "x y - A^ x y 0.5 + + B^ A B / C@ x +"
  - 'frameno' : use current frame number in expression. 0 <= frameno < clip_frame_count
  - 'time' : calculation: time = frameno/clip_frame_count. Use relative time position in expression. 0 <= time < frameno/clip_frame_count
  - 'width', 'height': currently processed plane width and height
pinterf is offline
Old 19th December 2017, 19:26   #3795  |  Link
Example: Mandelbrot zoomer...
Bringing another level of "Synth" into AviSynth.
And installers!
LigH is online now
Old 19th December 2017, 19:45   #3796  |  Link
Groucho2004
New version.
Avisynth Plus r2574
Thank you.
Nice, I can retire my installer.
Groucho's Avisynth Stuff
Groucho2004 is offline
Old 19th December 2017, 21:42   #3797  |  Link
real.finder
Thanks pinterf
so now it's time for lut/expr upscale things?
See My Avisynth Stuff
real.finder is offline
Old 19th December 2017, 22:14   #3798  |  Link
pinterf
Maybe. As you see I have implemented many masktools syntax elements in Expr: missing functions, modulo, similarly looking operators, basic scaling support. They are mostly similar but by now masktools lut is a bit behind Expr (e.g. variables).
pinterf is offline
Old 19th December 2017, 22:29   #3799  |  Link
real.finder
masktools syntax especially for float need to change
https://github.com/pinterf/masktools/issues/1
Old 19th December 2017, 23:55   #3800  |  Link
GMJCZP
GMJCZP's Avatar
Thank you pinterf!
A small observation: the only difference I notice with the old avisynth installer is that had by default activated "Select Association", while this installer does not have it.
EDIT: When I tried to directly open a script, instead of starting notepad the Windows Media Player was opened.
As I set the default program the notepad, the file icon naturally changed. To fix it I had to use a program called FileTypesMan, but I suppose the idea is for the installer to do it just like the old avisynth.
By law and justice!
GMJCZP's Arsenal
GMJCZP is offline
