#3241 | Link |
I already contacted Mediainfo developers some years ago. They told me that this has to do with the first and the last frames of the video. For mp4 container it only uses the middle frames, but for this dash container with mp4 extension it includes all frames resulting in variable framerate vbr which is not true. They told me to spend money to get this fixed.
Can you check these dash files with special tools. Maybe you know something, I don't. And if you mux the videostream of the dash file to a mkv, MediaInfo tells us 23.976 cfr. Quite strange thing, but I think we should check this very deep. |
#3242 | Link |
"The custom timing feature is usable, but not without its quirks. Adding a custom resolution is straightforward. Setting the vertical parameters to values similar to the ones in the screenshot above achieves desired results, but the 23 Hz resolution gets saved as 24 Hz."
Source: http://www.anandtech.com/show/5969/z...-640-review-/5 I tried that also, but same happened. If the Information is not up to date let me know. I want to learn ![]() Is there any better than hd4600? Still 23.972 or have the New nvidias true 23.976? Would be nice to know that. Otherwise i must buy one test and send back which i don't want to do. |
#3243 | Link |
of cause they have proper 23p.
but even with the clock from my HD 4400 i get a repeated frame every ~13 min. you can buy 10 gtx 960 all and they will not have the same clock same for onboard sound/sound cards. aiming for the theoretical perfect clock of 23.97602 hz doesn't really help at all. you have to match the reference clock with is usually the audio clock and it is very unlikely to be 23.97602hz. |
#3246 | Link |
What version MPC-BE ?? upload a video, or short sample. But - don't use forums - use external file uploaders.
AMD Ryzen 5 3600 /GIGABYTE B450 Gaming X /AMD Radeon R9 16Gb@3200 /Kingston 500Gb M.2 /GTX 1650 /Samsung U28R550UQI /OLED Philips 55OLED707 /Yamaha RX-V471 + NS-555 + NS-C444 + NS-333 + YST-SW215 |
#3247 | Link | |
Is there someone looking on this ? TIA
#3248 | Link | |
MPC-BE in K-Lite? Anyway. I recommend not using K-Lite. Better you use MPC-HC with integrated LAV Filters https://mpc-hc.org/ https://nightly.mpc-hc.org/ Or you can use MPC-BE with internal Filters and if you want set ffdshow or LAV Filters as external Filters. But don't have to, the internal are very nice. Then we can talk here ... |
#3249 | Link | |
I checked the muxed MKV with MediaInfo in advanced mode under debug: . . . Duration : 225017 Duration : 3mn 45s Duration : 3mn 45s 17ms Duration : 00:03:45.017 Duration : 00:03:45.017 (00:03:45;01) Frame rate : 23.976 Frame rate : 23.976 fps Frame count : 5395 . . . If I calculate the time 225017ms diveded with number of frames 5395, then I get 41,708433734939759036144578313253ms then 1/x and then x 1000 --> 23,97596626032699751574325495407 which is quite exact 23.976 and not 23.974 |
#3250 | Link |
@Klaus1189
Your method will not work for VFR video. In addition, it requires the analysis of the entire file. DefaultDuration parameter recorded in the header of your file.
MPC-BE 1.6.5 and Nightly builds | VideoRenderer | ImageSource | ScriptSource | BassAudioSource |
#3252 | Link |
unable to load subtitle with xysub filter if subtitle is a external file.
If subtitle is embedded,it loads with xy subfilter properly.
Win 7 Ultimate x64 Core i5 2500K 4.2Ghz,Asus p8z68 v pro gen 3 Corsair 2x4GB DDR3 @1600Mhz Asus Gtx 960 strix OC |
#3253 | Link |
https://www.sendspace.com/file/yn9yfz
Almost all subtitles between 00:21 and 01:30 are shown later than they should be. (using build 721) VLC: normal MPC-HC: normal MPC-HC with Xysubfilter: normal MPC-BE: has this problem MPC-BE with XySubfilter: has this problem |
#3254 | Link |
#3257 | Link |
Updated german Translation. I sent you a pm
Feature request: Delay timer like MPC-HC has it. I made a request there some time ago and they added it. Reason: Every TV or monitor needs some seconds when switching from one refresh rate to another. Please use also the delay when switching between D3D-fullscreen and window-mode. This is very important. I think the time should be adjustable since the time the displays need is different from one to another. |
#3258 | Link |
@Klaus1189
I do not understand what kind of delay in question. Like madVR? There screen flashes after a few seconds switching to full screen. This will not happen, because bad idea.
#3259 | Link |
a TV needs a long time to change refresh rates.
if you change the refresh rate from 60 hz to 23 hz the screen can be black for over a sec but audio is still played. with other words there should be an option to delay playback when the refresh rate changed. |
#3260 | Link |
Exactly. The feature they added for me is located here
If set to 0 it is like now, but for users like me this option is very important. No flashing ![]() Note that I set it to 8 secs (!!) so the video starts after the OSD Info of my Samsung monitor and on my Samsung TV disappears. |
