#9701 | Link |
I confirmed that there are VTS_01_1.VOB and VTS_01_0.IFO files. When I specify and open the IFO file from 「Open File/URL...」 Hardware decoded. Specify a folder from 「Open DVD/Blu-ray...」 and play It seems that hardware decoding is not possible. |
#9702 | Link | |
But initially you were talking about playing VOB files. There are no problems with this. ![]()
MPC-BE 1.6.5 and Nightly builds | VideoRenderer | ImageSource | ScriptSource | BassAudioSource |
#9703 | Link |
When I checked with MPC-HC, I confirmed that VIDEO_TS.IFO can be selected and hardware decoded.
Also, with MPC-BE, I found that VIDEO_TS.IFO is useless and VTS_01_0.IFO can be hardware decoded. There is no problem with MPC-HC, so I will use this one. |
#9704 | Link |
Question - why need HW for DVD decoding ? You use very-very old CPU that cant' decoding MPEG2 video ?
![]() Internal DVD decoder don't support HW decoding, that's all.
AMD Ryzen 5 3600 /GIGABYTE B450 Gaming X /AMD Radeon R9 16Gb@3200 /Kingston 500Gb M.2 /GTX 1650 /Samsung U28R550UQI /LG 47LM620T /Yamaha RX-V471 + NS-555 + NS-C444 + NS-333 + YST-SW215 Last edited by Aleksoid1978; 13th November 2022 at 13:44. |
#9705 | Link | |
But that's okay, but I wanted to use the iGPU (UHD Graphics 730) because it can do hardware MPEG2 decoding. Since MPC-HC can perform hardware decoding, even MPC-BE can I wish I could. |
#9706 | Link |
I repeat once again - the player can hardware accelerate mpeg2, but don't support when open it as a DVD. And that won't change. Let's close this discussion.
AMD Ryzen 5 3600 /GIGABYTE B450 Gaming X /AMD Radeon R9 16Gb@3200 /Kingston 500Gb M.2 /GTX 1650 /Samsung U28R550UQI /LG 47LM620T /Yamaha RX-V471 + NS-555 + NS-C444 + NS-333 + YST-SW215 |
#9708 | Link |
@hirahi. I think there is an important detail maybe lost in translation. You can have hardware decoding on DVDs but you have to use LAV filters instead of internal filters !!!
MPC-BE feature wishlist: 1) DiscID 2) Two independent volume control sliders in the UI when using dual-audio-out. |
#9709 | Link | |
But mpeg 2 is really very easy to decode, especially for very new CPUs. |
#9710 | Link |
MPC-BE 1.6.5.3 stable with digital signature.
MPC-BE Nightly builds: main file store, alternative MEGA, Google Drive, Pcloud, Filen Drive, Icedrive Night builds are provided by volunteers. Also new and old versions can be found on VideoHelp.com. Donate. Last edited by v0lt; 16th January 2023 at 04:30. |
#9711 | Link |
Can't build MPC-BE anymore, please help (VS 2022 17.4.1)
Build started... 1>------ Build started: Project: ffmpeg, Configuration: Release x64 ------ 2>------ Skipped Build: Project: DeCSSFilter, Configuration: Release x64 ------ 2>Project not selected to build for this solution configuration 1>make.exe: Nothing to be done for `all'. 3>------ Build started: Project: mpc-be, Configuration: Release x64 ------ 3>git version 2.38.1.windows.1 3>The revision number is up to date. 3>Generating code 3>Previous IPDB not found, fall back to full compilation. 3> link!RaiseException()+0x69 3> link!RaiseException()+0x69 3> link!InvokeCompilerPassW()+0x889db 3> link!InvokeCompilerPassW()+0xa7843 3> 3>D:\MPC-BE\src\ExtLib\MediaInfo\MediaInfo\TimeCode.cpp(72): fatal error C1001: Internal compiler error. 3>(compiler file 'D:\a\_work\1\s\src\vctools\Compiler\Utc\src\p2\main.c', line 224) 3> To work around this problem, try simplifying or changing the program near the locations listed above. 3>If possible please provide a repro here: https://developercommunity.visualstudio.com 3>Please choose the Technical Support command on the Visual C++ 3> Help menu, or open the Technical Support help file for more information 3>Done building project "mpc-be.vcxproj" -- FAILED. ========== Build: 1 succeeded, 1 failed, 68 up-to-date, 1 skipped ========== ========== Elapsed 00:29.236 ========== https://msdn.microsoft.com/query/dev...C1001)&rd=true
Intel UHD Graphics 750; Windows 10 19045.2364 x64 |
#9712 | Link | |
VS 2022 17.3.6 working
#9713 | Link |
Use the following tools:
VS 2019 v16.11.21 VS 2022 v17.3.6
#9715 | Link |
Hi again. Thanks for fixing the 3D issues. I have another 3D issue which has been here for a while but I forgot about it when the eye switch mixup happened. When using 3D top/bottom, the top and bottom panels shift to the side a few millimetres for some scene changes and there's a little gap between the two on the left top and the right bottom. You can see what I am talking about in the Original Image, but to make it clear I have also Blown up image highlighting the gap. Normally this makes no actual difference when viewing, except when watching with subtitles. Because the top and bottom panels are not in line, the top and bottom subtitles get mixed up and unreadable.
Does anyone have any ideas as to what is going on? Last edited by Enet47; 21st November 2022 at 00:25. |
#9718 | Link |
No and no.
#9719 | Link | |
And the deinterlacing will be done in the video renderer. If you have to force deinterlacing, then something is wrong with your video.
