Old 18th August 2007, 09:12   #61  |  Link
wyrd
wyrd's Avatar
Thanks clsid.
I've mirrored your build too.(very belatedly...)
http://tirnanog.fate.jp/mirror/Misc%...c_20070810.rar
Regards
wyrd is offline   Reply With Quote
Old 18th August 2007, 17:10   #62  |  Link
Delerue
Can anyone play this video using MPC internal MPEG1 decoder without stutter? The first stutter occurs at 0:10/0:11. I can't, even with FFDShow (neither libavcodec nor libmpeg2).
Cheers
Delerue is offline   Reply With Quote
Old 19th August 2007, 09:31   #63  |  Link
boyumeow
boyumeow's Avatar
Is it possible to use clsid patches on mpc hc or can I? by using vc2005? Was hoping clsid could do his update to casimir mpc hc since I do not know how to. Thks.
boyumeow is offline   Reply With Quote
Old 22nd August 2007, 14:31   #64  |  Link
delude101
Hey
First i want to say thanks for all your efforts.
I just have one little thing to report, the shader selections don't get saved. I use 16-235 to 0-255 filter, but i have to reselect it every time i launch MPC... small annoyance.
delude101 is offline   Reply With Quote
Old 22nd August 2007, 14:42   #65  |  Link
Demi9OD
Demi9OD's Avatar
I have seeking issues in XP+.net 3.0 with EVR. Any time I try to seek when outputting either EVR mode the player locks. Is there a fix for this?
Demi9OD is offline   Reply With Quote
Old 22nd August 2007, 14:47   #66  |  Link
Sharktooth
Mr. Sandman
Sharktooth's Avatar
XP has no EVR... so... what are you trying to do?
Sharktooth is offline   Reply With Quote
Old 22nd August 2007, 15:07   #67  |  Link
Kado
Otaku
Kado's Avatar
@Sharktooth
XP has EVR if you install dotNET v3.0, and is listed in casimir's mpc builds under output.
In the school, the three guys met. Their relation had been changed in the season, and turned into three love stories.
Kado is offline   Reply With Quote
Old 22nd August 2007, 15:44   #68  |  Link
Demi9OD
Demi9OD's Avatar
And it works just fine until I try to seek :P
Old 22nd August 2007, 16:34   #69  |  Link
clsid
This thread is not about Casimir's mod
My build has no support for EVR.
MPC-HC 2.4.2
Old 22nd August 2007, 21:39   #70  |  Link
Kado
Otaku
Kado's Avatar
Is EVR better than Haali? VMR9 is used to get hw decoding acceleration with the proper filters but i don't think you can get HW acceleration with EVR in XP, so why use it? unless your graphics card does not have shader model 2.
@Demi9OD
Works fine here. try this tread maybe casimir can help you.
Old 23rd August 2007, 20:52   #71  |  Link
Sharktooth
Mr. Sandman
Sharktooth's Avatar
Sorry, my bad (however EVR in .net 3 makes me laugh... damn M$...).
Old 24th August 2007, 00:09   #72  |  Link
Leak
ffdshow/AviSynth wrangler
Leak's Avatar
I'd hazard a guess that .NET 3 has added some classes related to DirectShow that depend on EVR...
I guess adding EVR was easier than churning out more classes for VMR9 and/or the video overlay just for XP. Now if only .NET 3.5 came with DirectX 10 for Windows XP...
np: Funkstörung - Like A Poet (ft. Enik) (Disconnected)
now playing: [artist] - [track] ([album])
Leak is offline   Reply With Quote
Old 24th August 2007, 03:46   #73  |  Link
Sharktooth
Mr. Sandman
Sharktooth's Avatar
uhm... i dont think M$ wants that just because the only reason to install Vista is to get DX10...
however what does EVR have that overlay doesnt (DXVA apart)?
Old 24th August 2007, 08:25   #74  |  Link
Leak
Leak's Avatar
Custom presenters and applying pixel shaders to the video comes to mind, not to mention the much tighter timing if you compare both in MPC HC...
Old 24th August 2007, 12:55   #75  |  Link
Sharktooth
Mr. Sandman
Sharktooth's Avatar
interesting. i made it work with my video card (nvidia GF6600), but unless i get it in fullscreen mode it has a lot of tearing problems AND it's also slower than overlay.
Old 24th August 2007, 14:26   #76  |  Link
Leak
Leak's Avatar
Well, I'm talking about MPC with EVR custom presenter and fullscreen D3D mode of course. Compare MPC HC's jitter graph for VMR and EVR...
np: Underworld - Rez (Second Toughest In The Infants (Disc 2))
Old 24th August 2007, 17:06   #77  |  Link
clsid
A new build is available in the opening post.
Biggest change is a FLV parsing fix. (big thanks to Moitah)
I have also compiled and uploaded a bundle of stand-alone filters.
MPC-HC 2.4.2
Old 24th August 2007, 17:52   #78  |  Link
LoRd_MuldeR
Software Developer
LoRd_MuldeR's Avatar
Thanks and mirrored
http://mulder.dummwiedeutsch.de/pub/...2007-08-24.zip
Old 24th August 2007, 17:56   #79  |  Link
Taurus
Taurus's Avatar
Thanks, will give the FLV parser a try and report back.
Cheers
Taurus
Just tested on a few clips: And what can I say: It Works!
The build in splitter and the external one are doing fine.
Thank you, clsid! And of course Moitah.
Old 25th August 2007, 06:53   #80  |  Link
wyrd
wyrd's Avatar
Thanks for your new build(specifically filters).
I've mirrored too
http://tirnanog.fate.jp/mirror/Misc%...lsid/20070824/
media player classic, mpc, vsfilter
