Old 17th April 2024, 02:39   #10501  |  Link
hirahi
When using MPC-BE 1.7.0.17 and setting the renderer to MPC Video Renderer 0.8.0.2224 or later, noise occurs on the screen and the image
is not displayed properly.
There is no problem with MPC-HC 2.2.1.
OS:Windows11 home
CPU core i5 12400
GPU Intel UHD Graphics 730
Momory DDR4 3200 32GB
hirahi is offline   Reply With Quote
Old 17th April 2024, 03:43   #10502  |  Link
Aleksoid1978
Aleksoid1978's Avatar
So - where is screenshots ?
What's video - any of some specifics ?
Show filters list.
AMD Ryzen 7 7700 /ASRock B650M Pro RS /G.Skill RIPJAWS 32 ГБ /Kingston 500Gb M.2 /RTX 4060 /Samsung U28R550UQI /OLED Philips 55OLED707 /Yamaha RX-V471 + NS-555 + NS-C444 + NS-333 + YST-SW215
Old 18th April 2024, 01:40   #10503  |  Link
hirahi
screenshot is below.
http://hirahi.cloudfree.jp/archive/mpc_be.png
video is an MPEG2 VOB file
MPC-BE standard filters are used.
Old 18th April 2024, 02:30   #10504  |  Link
Aleksoid1978
Fixed in MPC-BE video decoder.
P.S. Fixed also in MPC VR.
Old 18th April 2024, 05:07   #10505  |  Link
hirahi
MPC-BE 1.7.0.19+MPC Video Renderer 0.8.0.2227
I confirmed that the video was displayed correctly.
Old 19th April 2024, 15:43   #10506  |  Link
wyup
LAV Filters advantage over included in MPC-BE
Sorry if this has been answered before, but I've always been curious as to what advantage comes from using external LavFilters over recent MPC-BE internal filters (source, video, audio), specially MPC Video Decoder 1.7.0.
In the latter settings, is there any advantage on using D3D12cb over default 'D3D11, DXVA2'? I tried the former on Intel graphics and the green line graph on 'Ctrl + J' mas more jagged.
wyup is offline   Reply With Quote
Old 19th April 2024, 15:51   #10507  |  Link
v0lt
There are no advantages other than special use. Copyback mode will always be slower than native modes.
Old 20th April 2024, 01:55   #10508  |  Link
Sunspark
@wyup The LAV filter splitter is much better because it allows for more control of subtitles, audio, etc. if you've taken the time to dial in some settings, which I have. In the BE player, I use it as an external filter.. but for decoders in BE, I use the BE video and audio decoders.
Copy-back still has a use-case, depending on the renderer, e.g. inverse-telecining of a DVD, but this doesn't really apply to most people anymore.
Sunspark is offline   Reply With Quote
Old 20th April 2024, 04:28   #10509  |  Link
Aleksoid1978
What LAV Splitter better for subtitles, audio ?
Old 20th April 2024, 07:02   #10510  |  Link
automatic stream selection. AFAIK there is nothing like that in mpc-be.
the option to disable hardware decoding niece but very good reasons to do so.
there is also the "issue" with hardware decoding and madVR.
where the d3d11 -> d3d9 interop cost more then a copyback operation...
with a dvd you are usually better of using software decode.
Old 20th April 2024, 13:41   #10511  |  Link
Aleksoid1978
What you mean?
See this - https://github.com/Aleksoid1978/MPC-...ack-preference ?
Old 20th April 2024, 14:56   #10512  |  Link
Grimsdyke
I have a few mp4 files that makes MPC-BE + internal filters crash but no problems with LAV splitters. So LAV seem to be more "tolerant" on problematic video files.
MPC-BE feature wishlist: 1) DiscID
2) Two independent volume control sliders in the UI when using directsound dual-audio-out.
Old 20th April 2024, 15:07   #10513  |  Link
Klaus1189
Upload a sample for devs. Maybe worth to take a look at such files.
Old 20th April 2024, 17:55   #10514  |  Link
v0lt
Name the version MPC-BE to be more specific. Please provide your problematic samples or take them from here.
We can also remember that recent releases of LAV Filters had problems.
added:
There are reports that MPC-BE 1.7.0.20 has problems with some files after updating FFmpeg. We haven't reproduced the problem yet.
added:
Problem with VP9 fixed in MPC-BE 1.7.0.22.
Old 20th April 2024, 20:03   #10515  |  Link
cool where?
added:
well yes ffmpeg had problem with "hevc".
that's why lav had issues and if you use the same version lavfilter used at the time you should have the same issue.
Old 21st April 2024, 13:59   #10516  |  Link
Celio1080p
Hello everyone.
Guys, mpc-be is only seeing 4 audio files in a video that i have here.
Fallout series.
But, if i open the video with mkvtoolnix, i can see 32 audio files.
There's anyway to force MPC-BE to show them all ?
I tried the Windows Media Player 2022 in Windows 11 Pro, my main PC, and it showed all audio files.
But i prefer MPC-BE, far superior.
Sorry my english.
Celio1080p is offline   Reply With Quote
Old 21st April 2024, 18:22   #10517  |  Link
Sunspark
One way to fix is in the settings for external filters to add lav splitter and lav splitter source. Mark both as prefer and checked.
In the settings for internal filters, uncheck everything on the source filters tab.
Old 21st April 2024, 22:52   #10518  |  Link
Aleksoid1978
Originally Posted by Celio1080p View Post
Hello everyone.
Fallout series.
Sorry my english.
Upload file or give torrent link.
Old 22nd April 2024, 02:32   #10519  |  Link
Celio1080p
https://gofile.io/d/3VrPlm
There. Download to check it. I don't know why MPC-BE can't see the audio files. But Windows Media Player 2022 can. MediaInfo can.
MkvToolNix can.
Old 22nd April 2024, 02:43   #10520  |  Link
Aleksoid1978
MkvToolNix can.
It's simple - most of the audio tracks and subtitles are simply turned off, you can check in MKVToolnix - "Track enabled" flag, it is in the "No" state.
LAV Splitter doesn't show them either.
