Old 22nd June 2009, 00:29   #3441  |  Link
LowDead
Elit Amans
No clue.
@LowDead
It plays through from end-to-end? Nothing missing? If so, it has to be saturation... otherwise the size would be a lot large with a 15.5Mbs bitrate set. It may be hitting qpmin (I'm believe it defaults to 10). You could look at the stats file and see what q you are getting. If it is predominately 10, then this is definitely the reason for the undersize.
The q's are approx. around 20 and qpmin is set to 10. Cannot check right now if it plays through. The last encode seemed to be complete (full runtime in mpc). Now I'm doing a new encode with the same config but with latest build. Tomorrow I want to test what happens if I do COMPLETE FULL backup (with ALL audio and sub tracks) to see how BD-RB will behave. If it is saturation it should end up around 21gig as all the tracks are about 10gb. But what will happen with calculations? BD-RB will "see" that it needs to lower the bitrate and it will undersize even more? That test will be interesting
Also.. Can someone more do a new test with Benjamin Button (US and EUR). Full BD25 encodes with best quality. This could answer if something is different between the both versions and also it could rule out that I'm a complete idiot and/or my system is messed up ^^
Quick update: The encode just finished. Worked flawlessly with v0.23.02. Exact same config and setup as before. 24GB, 97% filled BD25
//LD
Old 22nd June 2009, 01:51   #3442  |  Link
setarip_old
setarip_old's Avatar
@jdobbs
I just used v.0.23.02 (as is, with the "tools" included in the zip) to process a "movie-only" version of "Speed Racer" (2008 movie), a VC-1 format BluRay.
No anomalies were noted - The progress bars performed and displayed properly throughout the conversion and the VC-1 video was properly converted and compressed.
This is now the second movie I've processed with this version, with no problems noted...
Old 22nd June 2009, 03:06   #3443  |  Link
Hehehe... I'm working on PiP (secondary audio/video) right now. I've also added some code to make target sizing more accurate (thanks to some good research I got from lithiumus).
Good to know 23.2 seems to be working out well.
Old 22nd June 2009, 03:33   #3444  |  Link
Capsbackup
PIP ?? Well that would be awesome!! If you can complete this task, I'll place you up there with that prophet that parted the waters!! LOL
I have always been impressed with your software programing skills, and this would just be another great achievement. I appreciate your efforts.
Old 22nd June 2009, 09:48   #3445  |  Link
PurpleMan
jdobbs,
I asked before (twice I think) and didn't get a reply.
I was wondering if there is a reason for not using the dgdecode tools (DGAVCDecode, DGVC1Decode) with BD-Rebuilder?
That would achieve consistency in the decoding process on various platforms and boxes.
Thanks again!
PurpleMan is offline   Reply With Quote
Old 22nd June 2009, 12:01   #3446  |  Link
spida_singh
I tried a full backup of Kung Fu Panda UK Disc, encoding went through fine apart from actually building the structure. Is there anyway I can build the structure manually?
BD-Rebuilder Code:
[21:23:49] BD Rebuilder v0.23.02 (beta)
  - Source:  KUNG_FU_PANDA_EN
  - Input BD size: 44.48 GB
  - Approximate total content: [03:26:24.671]
  - Target BD size: 8.94 GB
[21:23:49] PHASE ONE, Encoding
 - [21:23:49] Extracting A/V streams [VID_00004]
 - Audio/PGS sizing issue.  Continued...
 - [21:37:05] Reencoding: VID_00004 (1 of 52)
 - [23:16:54] Extracting A/V streams [VID_00005]
 - [23:18:07] Reencoding: VID_00005 (2 of 52)
 - [23:57:56] Extracting A/V streams [VID_00006]
 - [23:58:33] Reencoding: VID_00006 (3 of 52)
 - [00:19:36] Extracting A/V streams [VID_00007]
 - [00:19:46] Reencoding: VID_00007 (4 of 52)
 - [00:24:19] Extracting A/V streams [VID_00008]
 - [00:24:39] Reencoding: VID_00008 (5 of 52)
 - [00:31:43] Extracting A/V streams [VID_00009]
 - [00:32:08] Reencoding: VID_00009 (6 of 52)
 - [00:41:02] Extracting A/V streams [VID_00010]
 - [00:41:22] Reencoding: VID_00010 (7 of 52)
 - [00:48:17] Extracting A/V streams [VID_00011]
 - [00:49:00] Reencoding: VID_00011 (8 of 52)
 - [01:07:33] Extracting A/V streams [VID_00012]
 - [01:07:59] Reencoding: VID_00012 (9 of 52)
 - [01:17:50] Extracting A/V streams [VID_00013]
 - [01:18:16] Reencoding: VID_00013 (10 of 52)
 - [01:27:41] Extracting A/V streams [VID_00014]
 - [01:28:01] Reencoding: VID_00014 (11 of 52)
 - [01:36:56] Extracting A/V streams [VID_00015]
 - [01:37:09] Reencoding: VID_00015 (12 of 52)
 - [01:43:27] Extracting A/V streams [VID_00016]
 - [01:43:51] Reencoding: VID_00016 (13 of 52)
 - [01:54:39] Extracting A/V streams [VID_00017]
 - [01:54:47] Reencoding: VID_00017 (14 of 52)
 - [01:57:50] Extracting A/V streams [VID_00018]
 - [01:58:03] Reencoding: VID_00018 (15 of 52)
 - [02:02:47] Extracting A/V streams [VID_00019]
 - [02:02:56] Reencoding: VID_00019 (16 of 52)
 - [02:06:43] Extracting A/V streams [VID_00020]
 - [02:06:52] Reencoding: VID_00020 (17 of 52)
 - [02:10:26] Extracting A/V streams [VID_00021]
 - [02:10:32] Reencoding: VID_00021 (18 of 52)
 - [02:12:39] Extracting A/V streams [VID_00022]
 - [02:12:47] Reencoding: VID_00022 (19 of 52)
 - [02:16:05] Extracting A/V streams [VID_00023]
 - [02:16:30] Reencoding: VID_00023 (20 of 52)
 - [02:27:36] Extracting A/V streams [VID_00024]
 - [02:27:51] Reencoding: VID_00024 (21 of 52)
 - [02:34:22] Extracting A/V streams [VID_00026]
 - [02:34:55] Reencoding: VID_00026 (22 of 52)
 - [02:49:55] Extracting A/V streams [VID_00104]
 - [02:50:02] Reencoding: VID_00104 (23 of 52)
 - [02:53:21] Extracting A/V streams [VID_00105]
 - [02:53:28] Reencoding: VID_00105 (24 of 52)
 - [02:57:01] Extracting A/V streams [VID_00107]
 - [02:57:06] Reencoding: VID_00107 (25 of 52)
 - [02:59:38] Extracting A/V streams [VID_00108]
 - [02:59:48] Reencoding: VID_00108 (26 of 52)
 - [03:04:11] Extracting A/V streams [VID_00109]
 - [03:04:21] Reencoding: VID_00109 (27 of 52)
 - [03:08:36] Extracting A/V streams [VID_00110]
 - [03:08:44] Reencoding: VID_00110 (28 of 52)
 - [03:12:39] Extracting A/V streams [VID_00111]
 - [03:12:46] Reencoding: VID_00111 (29 of 52)
 - [03:16:26] Extracting A/V streams [VID_00121]
 - [03:16:30] Reencoding: VID_00121 (30 of 52)
 - [03:19:23] Extracting A/V streams [VID_00122]
 - [03:19:24] Reencoding: VID_00122 (31 of 52)
 - [03:20:01] Extracting A/V streams [VID_00123]
 - [03:20:13] Reencoding: VID_00123 (32 of 52)
 - [03:26:23] Extracting A/V streams [VID_00142]
 - [03:26:27] Reencoding: VID_00142 (33 of 52)
 - [03:29:41] Extracting A/V streams [VID_00143]
 - [03:29:41] Reencoding: VID_00143 (34 of 52)
 - [03:29:56] Extracting A/V streams [VID_00146]
 - [03:30:01] Reencoding: VID_00146 (35 of 52)
 - [03:32:34] Extracting A/V streams [VID_00147]
 - [03:32:35] Reencoding: VID_00147 (36 of 52)
 - [03:33:04] Extracting A/V streams [VID_00148]
 - [03:33:08] Reencoding: VID_00148 (37 of 52)
 - [03:35:37] Extracting A/V streams [VID_00149]
 - [03:35:38] Reencoding: VID_00149 (38 of 52)
 - [03:36:27] Extracting A/V streams [VID_00150]
 - [03:36:29] Reencoding: VID_00150 (39 of 52)
 - [03:37:50] Extracting A/V streams [VID_00151]
 - [03:37:52] Reencoding: VID_00151 (40 of 52)
 - [03:38:45] Extracting A/V streams [VID_00152]
 - [03:38:45] Reencoding: VID_00152 (41 of 52)
 - [03:38:51] Extracting A/V streams [VID_00153]
 - [03:38:55] Reencoding: VID_00153 (42 of 52)
 - [03:40:49] Extracting A/V streams [VID_00154]
 - [03:40:53] Reencoding: VID_00154 (43 of 52)
 - [03:42:47] Extracting A/V streams [VID_00155]
 - [03:42:51] Reencoding: VID_00155 (44 of 52)
 - [03:44:44] Extracting A/V streams [VID_00156]
 - [03:44:48] Reencoding: VID_00156 (45 of 52)
 - [03:46:42] Extracting A/V streams [VID_00157]
 - [03:46:46] Reencoding: VID_00157 (46 of 52)
 - [03:48:39] Extracting A/V streams [VID_00158]
 - [03:48:40] Reencoding: VID_00158 (47 of 52)
 - [03:48:46] Extracting A/V streams [VID_00159]
 - [03:48:46] Reencoding: VID_00159 (48 of 52)
 - [03:48:52] Extracting A/V streams [VID_00160]
 - [03:48:53] Reencoding: VID_00160 (49 of 52)
 - [03:48:59] Extracting A/V streams [VID_00161]
 - [03:48:59] Reencoding: VID_00161 (50 of 52)
 - [03:49:05] Extracting A/V streams [VID_00162]
 - [03:49:05] Reencoding: VID_00162 (51 of 52)
 - [03:49:12] Extracting A/V streams [VID_00612]
 - [03:49:12] Reencoding: VID_00612 (52 of 52)
 - Error in attempt to multiplex: MUX_00612.meta
[03:49:14] - Failed to build structure, aborted
[Status]
LABEL=KUNG_FU_PANDA_EN
VERSION=v0.23.02 (beta)
SOURCE_SIZE=47758113690
SOURCE_VIDEO_SIZE=40742940672
TARGET_SIZE=9594470400
REDUCTION=6.33066081990637E-02
RESIZE_1080=0
AUDIO_TO_KEEP=eng;
SUBS_TO_KEEP=eng;
BACKUP_MODE=0
QUICK=0
ENCODE_STEP=4
COMPLETED=51
[00004]
AUDIO=1000000000
PGS=10000000000000000
M2TS_TARGET=1550574245
NSIZE=6541873152
FLINK=0
MLINK=0
[00005]
AUDIO=1
PGS=01000000
M2TS_TARGET=124170639
RATE=899
NSIZE=130873344
FLINK=0
MLINK=0
[00006]
AUDIO=1
PGS=01000000
M2TS_TARGET=66745593
RATE=891
NSIZE=70508544
FLINK=0
MLINK=0
[00007]
AUDIO=1
PGS=01000000
M2TS_TARGET=18046382
RATE=846
NSIZE=18991104
FLINK=0
MLINK=0
[00008]
AUDIO=1
PGS=01000000
M2TS_TARGET=34843828
RATE=914
NSIZE=36599808
FLINK=0
MLINK=0
[00009]
AUDIO=1
PGS=01000000
M2TS_TARGET=45099036
RATE=910
NSIZE=47407104
FLINK=0
MLINK=0
[00010]
AUDIO=1
PGS=01000000
M2TS_TARGET=35079924
RATE=913
NSIZE=36851712
FLINK=0
MLINK=0
[00011]
AUDIO=1
PGS=01000000
M2TS_TARGET=77381979
RATE=903
NSIZE=81186816
FLINK=0
MLINK=0
[00012]
AUDIO=1
PGS=01000000
M2TS_TARGET=50149238
RATE=913
NSIZE=52733952
FLINK=0
MLINK=0
[00013]
AUDIO=1
PGS=01000000
M2TS_TARGET=48198236
RATE=910
NSIZE=50743296
FLINK=0
MLINK=0
[00014]
AUDIO=1
PGS=01000000
M2TS_TARGET=36208673
RATE=904
NSIZE=37976064
FLINK=0
MLINK=0
[00015]
AUDIO=1
PGS=
M2TS_TARGET=22554769
RATE=928
NSIZE=23666688
FLINK=0
MLINK=0
[00016]
AUDIO=1
PGS=01000000
M2TS_TARGET=42197426
RATE=901
NSIZE=44249088
FLINK=0
MLINK=0
[00017]
AUDIO=1000000
PGS=01000000000000
M2TS_TARGET=14331465
RATE=1027
NSIZE=15009792
FLINK=0
MLINK=0
[00018]
AUDIO=1000000
PGS=01000000000000
M2TS_TARGET=21848814
RATE=983
NSIZE=22751232
FLINK=0
MLINK=0
[00019]
AUDIO=1000000
PGS=01000000000000
M2TS_TARGET=16678036
RATE=994
NSIZE=17399808
FLINK=0
MLINK=0
[00020]
AUDIO=1000000
PGS=01000000000000
M2TS_TARGET=15749209
RATE=976
NSIZE=16422912
FLINK=0
MLINK=0
[00021]
AUDIO=1000000
PGS=01000000000000
M2TS_TARGET=9252870
RATE=982
NSIZE=9787392
FLINK=0
MLINK=0
[00022]
AUDIO=1000000
PGS=01000000000000
M2TS_TARGET=14643797
RATE=1006
NSIZE=15249408
FLINK=0
MLINK=0
[00023]
AUDIO=1
PGS=01000000
M2TS_TARGET=44057801
RATE=892
NSIZE=46239744
FLINK=0
MLINK=0
[00024]
AUDIO=1
PGS=01000000
M2TS_TARGET=27549350
RATE=892
NSIZE=28901376
FLINK=0
MLINK=0
[00026]
AUDIO=0100000
PGS=01000000
M2TS_TARGET=63355455
RATE=979
NSIZE=66232320
FLINK=0
MLINK=0
[00104]
AUDIO=1000000
PGS=01000000
M2TS_TARGET=12223325
RATE=1012
NSIZE=12736512
FLINK=0
MLINK=0
[00105]
AUDIO=1000000
PGS=01000000
M2TS_TARGET=13114812
RATE=1010
NSIZE=13688832
FLINK=0
MLINK=0
[00107]
AUDIO=0100000
PGS=01000000
M2TS_TARGET=9638714
RATE=1005
NSIZE=10033152
FLINK=0
MLINK=0
[00108]
AUDIO=1000000
PGS=01000000
M2TS_TARGET=18584697
RATE=1011
NSIZE=19365888
FLINK=0
MLINK=0
[00109]
AUDIO=1000000
PGS=01000000
M2TS_TARGET=19039386
RATE=1008
NSIZE=19783680
FLINK=0
MLINK=0
[00110]
AUDIO=1000000
PGS=01000000
M2TS_TARGET=15315913
RATE=1011
NSIZE=15962112
FLINK=0
MLINK=0
[00111]
AUDIO=1000000
PGS=01000000
M2TS_TARGET=13006682
RATE=1013
NSIZE=13584384
FLINK=0
MLINK=0
[00121]
AUDIO=1
PGS=01000000
M2TS_TARGET=6707932
RATE=504
NSIZE=9431040
FLINK=0
MLINK=0
[00122]
AUDIO=1
PGS=01000000
M2TS_TARGET=1738632
RATE=484
NSIZE=1898496
FLINK=0
MLINK=0
[00123]
AUDIO=1000000
PGS=01000000
M2TS_TARGET=23859327
RATE=998
NSIZE=24803328
FLINK=0
MLINK=0
[00142]
AUDIO=1
PGS=01000000
M2TS_TARGET=7385882
RATE=504
NSIZE=8828928
FLINK=0
MLINK=0
[00143]
AUDIO=1
PGS=01000000
M2TS_TARGET=558152
RATE=442
NSIZE=626688
FLINK=0
MLINK=0
[00146]
AUDIO=1
PGS=01000000
M2TS_TARGET=7205406
RATE=489
NSIZE=7944192
FLINK=0
MLINK=0
[00147]
AUDIO=1
PGS=01000000
M2TS_TARGET=1262162
RATE=472
NSIZE=1406976
FLINK=0
MLINK=0
[00148]
AUDIO=1
PGS=01000000
M2TS_TARGET=7768614
RATE=502
NSIZE=8558592
FLINK=0
MLINK=0
[00149]
AUDIO=1
PGS=01000000
M2TS_TARGET=2815262
RATE=504
NSIZE=3102720
FLINK=0
MLINK=0
[00150]
AUDIO=1
PGS=01000000
M2TS_TARGET=3774427
RATE=501
NSIZE=4141056
FLINK=0
MLINK=0
[00151]
AUDIO=1
PGS=01000000
M2TS_TARGET=2798926
RATE=500
NSIZE=3078144
FLINK=0
MLINK=0
[00152]
AUDIO=1
PGS=01000000
M2TS_TARGET=158694
RATE=568
NSIZE=178176
FLINK=0
MLINK=0
[00153]
AUDIO=1
PGS=01000000
M2TS_TARGET=6551183
RATE=488
NSIZE=7163904
FLINK=0
MLINK=0
[00154]
AUDIO=1
PGS=01000000
M2TS_TARGET=6570630
RATE=490
NSIZE=7225344
FLINK=0
MLINK=0
[00155]
AUDIO=1
PGS=01000000
M2TS_TARGET=6563629
RATE=490
NSIZE=7139328
FLINK=0
MLINK=0
[00156]
AUDIO=1
PGS=01000000
M2TS_TARGET=6547293
RATE=488
NSIZE=7206912
FLINK=0
MLINK=0
[00157]
AUDIO=1
PGS=01000000
M2TS_TARGET=6584633
RATE=492
NSIZE=7243776
FLINK=0
MLINK=0
[00158]
AUDIO=1
PGS=01000000
M2TS_TARGET=163361
RATE=590
NSIZE=178176
FLINK=0
MLINK=0
[00159]
AUDIO=1
PGS=01000000
M2TS_TARGET=159083
RATE=570
NSIZE=172032
FLINK=0
MLINK=0
[00160]
AUDIO=1
PGS=01000000
M2TS_TARGET=159472
RATE=572
NSIZE=172032
FLINK=0
MLINK=0
[00161]
AUDIO=1
PGS=01000000
M2TS_TARGET=160639
RATE=577
NSIZE=178176
FLINK=0
MLINK=0
[00162]
AUDIO=1
PGS=01000000
M2TS_TARGET=158694
RATE=568
NSIZE=178176
FLINK=0
MLINK=0
[00612]
AUDIO=0100000
PGS=01000000000000
M2TS_TARGET=5056
Meta file in question
MUXOPT --no-pcr-on-video-pid --new-audio-pes --blu-ray --vbr --auto-chapters=5 --vbv-len=500
V_MPEG4/ISO/AVC, "I:\VIDEOS\MOVIES\KUNG.FU.PANDA\WORKFILES\VID_00612.AVS.MKV", fps=23.976, track=1, insertSEI, contSPS
A_AC3, "I:\VIDEOS\MOVIES\KUNG.FU.PANDA\WORKFILES\00612.track_4353.AC3", lang=eng
S_HDMV/PGS, "I:\VIDEOS\MOVIES\KUNG.FU.PANDA\WORKFILES\00612.track_4609.sup", fps=23.976, lang=eng
regards
spida_singh is offline   Reply With Quote
Old 22nd June 2009, 12:15   #3447  |  Link
Originally Posted by PurpleMan View Post
jdobbs,
Thanks again!
Yes. It would require someone to buy/donate something before they can use BD-RB. If you have to buy something -- it is no longer freeware.
BTW, I fully support Neuron2's concept of a required donation. That's what I do for DVD Rebuilder Professional Edition as well. It has been my experience to date that if you don't require it you will be very disappointed. People just generally want a free ride.
Old 22nd June 2009, 13:25   #3448  |  Link
gizzin
lol, keep up the good work jdobbs.
gizzin is offline   Reply With Quote
Old 22nd June 2009, 14:54   #3449  |  Link
tekmobile
Webmaster
Just got a encoder fail on doing the second pass of a very small file that BD-RB says needs doing because its part of another playlist
a screengrab of x264 shows this error as its reason
avis [info]: 1920x1080 @ 23.98 fps (6 frames)
x264 [info]: using SAR=1/1
x264 [info]: using cpu capabilities: MMX2 SSE2Slow
x264 [error]: requested bitrate is too low. estimated minimum is 28 kbps
x264 [error]: x265_encoder_open failed
LASTCMD.txt
"F:\BD_Rebuilder\tools\x264.exe" "F:\OUTPUT\WORKFILES\VID_00057.AVS" --bitrate 5 --level 4.1 --sar 1:1 --fps 24000/1001 --aud --vbv-bufsize 25000 --keyint 24 --min-keyint 1 --vbv-maxrate 35000 --filter 0,0 --subme 7 --me umh --ref 3 --bframes 3 --direct auto --8x8dct --weightb --trellis 1 --psy-rd 1.0:0.2 --aq-strength 0.8 --threads auto --thread-input --progress --no-psnr --no-ssim --stats "F:\OUTPUT\WORKFILES\VID_00057.AVS.MKV.stats" --pass 2 --output "F:\OUTPUT\WORKFILES\VID_00057.AVS.MKV"
The M2TS ReEncoded before this one was pretty much identical just a black screen but this one encoded without problems
To sort it I copied and renamed the MKV encoded in the previous step since it was pretty much the same size/content to match the one that failed and changed the step in the BDREBUILDER.INF file so it would skip the encoding of the file and proceed to the multiplexing of the MKV I copied/renamed it then completed ok
tekmobile is offline   Reply With Quote
Old 22nd June 2009, 15:46   #3450  |  Link
liquidskin76
liquidskin76's Avatar
@jdobbs
Just curious (again!)... how does BD-RB handle forced subs in Movie Only encodes? By forced, i mean subs that automatically appear when a foreign language is spoken in an english language film?
Kill Bill 1 is an example.
Cheers
liquidskin76 is offline   Reply With Quote
Old 22nd June 2009, 18:36   #3451  |  Link
Category 5
Originally Posted by liquidskin76 View Post
@jdobbs
Cheers
When i did KB1 I have to manually add the second sub stream before backing up, and then use "Correct BD" to force them to on. It would be cool if there was a switch in BD-Rebuilder to allow selecting and forcing of these streams, but I know of no way yet.
Category 5 is offline   Reply With Quote
Old 22nd June 2009, 19:20   #3452  |  Link
PurpleMan
You must have misunderstood something. I wasn't talking about the nVidia based DG tools, but rather the FREE libavcodec based ones.
There are 2 versions:
DGAVCDecode (freeware, libavcodec) vs. DGAVCDecodeNV (donation-ware, nvidia powered)
DGVC1Decode (freeware, libavcodec) vs. DGVC1DecodeNV (donation-ware, nvidia powered)
So I was wondering why not use the FREE libavcodec based ones, like you use in DVD Rebuilder (dgdecode). That way you can be sure EVERYONE are using the same decoder and no directshow compatibility issues. Not even under Windows 7.
Old 22nd June 2009, 19:30   #3453  |  Link
There is no DGVC1Dec that uses libavcodec.
And DGAVCDec that uses libavcodec fails on some PAFF streams. The newer libavcodec versions have regressions that make accurate random access impossible, otherwise I would have updated long ago.
Old 22nd June 2009, 20:10   #3454  |  Link
aquanash
June 20th, 2009 - v0.23.02
- Corrected an error in which a file may incorrectly
  be flagged as no reencode and cause oversizing.
Wow, that was quick! I will test this fix later tonight.
aquanash is offline   Reply With Quote
Old 22nd June 2009, 20:28   #3455  |  Link
aquanash
What is "Correct BD"? I can't seem to find anything on it. I've been using BDedit to manually add the SetStream command to force subtitles. I agree this would be a great feature to add to BD-Rebuilder and also auto detection of forced subtitles if possible.
Old 22nd June 2009, 22:27   #3456  |  Link
PurpleMan
Thank you for clarifying!
Old 22nd June 2009, 23:56   #3457  |  Link
Category 5
This wa courtesy of deank who helped when I had the same problem, but here is a link to the tool
http://forum.doom9.org/showthread.php?t=146412
Old 23rd June 2009, 01:21   #3458  |  Link
LASTCMD.txt
That ain't good. I'll fix it. I think logic dictates that specifying a bitrate of 5 may be too low, eh?
Old 23rd June 2009, 01:21   #3459  |  Link
@jdobbs
Cheers
Right now it doesn't.
Old 23rd June 2009, 04:14   #3460  |  Link
GaPony
FWIW, I always make sure all English subs are selected (since I never know which is which) and they seem to be working pretty consistently for the movies I've done. It's not often that I've needed to turn them on.
GaPony is offline   Reply With Quote
