Old 26th June 2009, 10:38   #3501  |  Link
isoss
Originally Posted by stef73 View Post
just done the day the earth stood still full disk to bd25 and it works spot on on both ps3 (i know wooohooooo!) been a coulpe of months since ps3 played a backup and on my BD35 1080p/24 it looks awesome guys
how did you do it, it don't work white me
can you tel me what your settings are?
isoss is offline   Reply With Quote
Old 27th June 2009, 16:02   #3502  |  Link
PurpleMan
@jdobbs
Another bug report: Did "con air" using latest bd-rb. Main movie is split across 3 m2ts files (00000.m2ts, 00008.m2ts, 00009.m2ts).
I have no idea why (no feature on the disc suggests a reason of why it's split)
Anyway, BD-RB output (bd25 full backup) hangs on playback in the point where the movie switches from 00000 to 00008.
PurpleMan is offline   Reply With Quote
Old 27th June 2009, 23:41   #3503  |  Link
PurpleMan
Originally Posted by PurpleMan View Post
@jdobbs
Sorry, my bad. Turns out it was a powerdvd problem.
However, a different problem does exist - there is an audio gap noticeable in the movie when it swtiches from 00000 to 00008.
I reported this issue on a different title before (I think it was on the movie 21).
Old 28th June 2009, 02:49   #3504  |  Link
kanerulz69
Banned
encode failed error?
never had any problems with any other movies but this one "DAY_EARTH_STOOD_STILL" this is the log file
[21:49:17] BD Rebuilder v0.23.02 (beta)
- Source: DAY_EARTH_STOOD_STILL
- Input BD size: 39.64 GB
- Approximate total content: [03:16:31.237]
- Target BD size: 22.46 GB
[21:49:19] PHASE ONE, Encoding
- [21:49:19] Extracting A/V streams [VID_00254]
- [21:49:20] Reencoding: VID_00254 (1 of 15)
- Encode failed. Retrying.
- Reached retry limit. Aborting.
[21:49:21] - Failed video encode, aborted
kanerulz69 is offline   Reply With Quote
Old 28th June 2009, 09:33   #3505  |  Link
user822
can you post mediainfo of "VID_00254"?
user822 is offline   Reply With Quote
Old 28th June 2009, 11:20   #3506  |  Link
kanerulz69
Banned
what is mediainfo?
Old 28th June 2009, 11:20   #3507  |  Link
drmih
I have done this disc fine but I'm currently re-doing The Godfather II (I had blank disc issues with the first one I did) and have also had an Encode Failed. I have gone back to an earlier version of bd-r and it's doing the troublesome file at the moment.
**The Godfather II completed fine using 21.01
Old 28th June 2009, 11:41   #3508  |  Link
Furiousflea
Bare in mind there are different regional versions of "The Day The Earth Stood Still" (They have different BD+ protection and differ more than most releases)...Also maybe the people who got it to work are talking about the 50s version
Furiousflea is offline   Reply With Quote
Old 28th June 2009, 11:56   #3509  |  Link
drmih
Quite right. I have done the Region A version of the new film to full disc on both dvd-9 and bd-25.
On mine 00254.m2ts is a diddy file, second to last on the disc (00255 is the last and is also small). If all you require is to complete the disc just advance on manually and copy them.
Old 28th June 2009, 12:45   #3510  |  Link
kanerulz69
Banned
im doing quicker encode on extras, there is no way for it to finished properly the way your saying with jus coping them
Old 28th June 2009, 12:50   #3511  |  Link
kanerulz69
Banned
yes this is the new one, us blu-ray, so does this mean bd-rb cant do this movie?
Old 28th June 2009, 13:08   #3512  |  Link
LowDead
Elit Amans
Benjamin Button EUR full complete backup went oversize by maybe 1%, just enough not to fit the disc. So it was no saturation before. Something must have gone wrong in 0.23.01 and fixed in 0.23.02.
INF:
[Status]
LABEL=THE_CURIOUS_CASE_OF_BENJAMIN_BUTTON
VERSION=v0.23.02 (beta)
SOURCE_SIZE=43982327792
SOURCE_VIDEO_SIZE=43839043584
TARGET_SIZE=24117248000
REDUCTION=.546863294270175
RESIZE_1080=0
AUDIO_TO_KEEP=all
SUBS_TO_KEEP=all
BACKUP_MODE=0
QUICK=0
ENCODE_STEP=0
COMPLETED=2
REBUILD_COMPLETE=1
[00001]
AUDIO=1111111111
PGS=1111111111111111111111111
M2TS_TARGET=23874570400
RATE=10293
NSIZE=24838674432
FLINK=0
MLINK=0
[00015]
AUDIO=
PGS=
M2TS_TARGET=99393392
RATE=2156
NSIZE=88571904
FLINK=0
MLINK=0
LOG:
[20:52:13] BD Rebuilder v0.23.02 (beta)
- Source: THE_CURIOUS_CASE_OF_BENJAMIN_BUTTON
- Input BD size: 40,96 GB
- Approximate total content: [02:51:43.584]
- Target BD size: 22,46 GB
[20:52:13] PHASE ONE, Encoding
- [20:52:13] Extracting A/V streams [VID_00001]
- [21:11:43] Reencoding: VID_00001 (1 of 2)
- [08:14:48] Extracting A/V streams [VID_00015]
- [08:14:53] Reencoding: VID_00015 (2 of 2)
[08:22:24]PHASE ONE complete
[08:22:24]PHASE TWO - Rebuild Started
- [08:22:24] Rebuilding BD file Structure
[08:22:26] - Encode and Rebuild complete
[08:22:26]JOB: THE_CURIOUS_CASE_OF_BENJAMIN_BUTTON completed.
//LD
Old 28th June 2009, 16:07   #3513  |  Link
Furiousflea
That's exactly where I am. It works for the video, but not the audio. I can use EAC3TO to demux them (since TSMUXER can't) -- but then TSMUXER doesn't recognize them for remuxing and I'm right back where I started.
Why not demux the DTS Express track found on PIP tracks then encode it to AC3 with aften and mux that back in place of the DTS Express track and make modifications needed to the mpls\clpi files?
Using AC3 for PIP tracks is within the standards right?
Old 28th June 2009, 17:38   #3514  |  Link
Category 5
Originally Posted by Category 5 View Post
So the m2ts files, but what other files need to get copied over? the only ones that look important to me are the mpls files, but there are like 700 of those in the structure and only 392 of the m2ts.
EDIT - I added the M2Ts and incremented past in order to try rebuilding but got the message
"One or more reencoded files are missing (oo384.clpi)
EDIT2 - Added clpi files found in original directory and get "Failure to multiplex"
Any more ideas on what i can do to salvage this one before I erase it all and chalk it up to a fail? It looks like the structure is being rebuilt up to the inclusion of the 9 small problem files at the end. Can I just copy those into the new structure or are them some final important steps that will be missing? I think this is a seamless branching issue to be honest.
Category 5 is offline   Reply With Quote
Old 28th June 2009, 18:44   #3515  |  Link
tekmobile
Webmaster
The clpi file is created by tsmuxer not bd-rb and tsmuxer does not have the ability to set the correct PID of the secondary audio.
tekmobile is offline   Reply With Quote
Old 28th June 2009, 21:20   #3516  |  Link
drmih
????Why not?
Just copy the two files and clpi to the workfiles directory, increase the increment log by two and that should work.
Old 28th June 2009, 21:23   #3517  |  Link
drmih
As I said above I have done this and Region A is USA. It would have been an earlier version of br-rb, so perhaps drop back a couple of versions.
Old 28th June 2009, 21:26   #3518  |  Link
drmih
You need to copy the m2ts files from the original BMDV\STREAM to the working directory and also the corresponding clpi from BMDV\CLIPINF, then increment the .inf file for each one you have replaced.
Old 29th June 2009, 14:02   #3519  |  Link
I can't find anything that decodes it either (to reencode). It isn't recognized as standard DTS. Also, the only types of streams allowed for secondary audio are DTS Express and Dolby Digital Plus -- and I don't know of any freeware encoders for those.
Old 29th June 2009, 14:09   #3520  |  Link
Originally Posted by Kakashi Sensei View Post
I probably shouldn't report this yet till I try it with the latest version. But did a backup of Samurai 7 anime BD1 and the first encode i did with both TrueHD audio tracks came up over sized by about 4.5GB (BD25 Encode) then tried it a second time with only the english audio and it was about 4% over sized at 1.5GB.
Used BD-RB 22.02 but will try again tonight with the latest version see if I get the same resaults. If there is some specific info needed from BD-RB or someone is curious let me know.
I just used the standard settings. x264 mode, BD25, Slowest speed.
Great app btw, this is the only disk i've had a problem with trying to backup.
Thanks for the hard work JDobbs!
I've modified my muxing parameters for the next version to be more accurate. Dolby TrueHD is the cause of most oversizing. It isn't unusual to see 40% muxing overhead (in TSMUXER) on those streams.
