Old 3rd August 2013, 23:20   #17721  |  Link
Originally Posted by Ch3vr0n View Post
There seems to be an issue with the EU release of "Oblivion". (Volume name OBLIVION_G51 barcode 5050582938456) The main title VID_00023, keeps holding on "Completing remainder of DGDecNV indexing...". Can be like that for dozens of minutes till i finally abort the encode. At times resuming then instantly does that, it resumes with encoding (as if the indexing is done). No such issues when swapping to FFDshow
Interesting. Do you see that message often? I never see it, as the two processes (indexing and extracting) always takes the same amount of time. It's logical that they should both finish together due to disc read-buffering. I just put the message in to cover the possibility of a difference.
Old 3rd August 2013, 23:37   #17722  |  Link
Ch3vr0n
every now and then, not too often though. the extracting goes to 100%, then after a sec or to jumps to "completing remainder ..." and just sits there. Swap to FFDshow and the second the extracting is done it jumps to encoding as it should. and since i'm encoding from a anydvd ripped iso mounted in VCD it shouldn't happen. Doens't happen alot but it is not the first time i've seen it. Same disc did also gave me a fluke error for a sec "error detecting stream. MPEG 1 not supported" on one attempt. Though all streams are either mp4 avc or VC-1. That being said, that "completing" issue is usually fixed by swapping to ffdshow, but the drawback is all encoding has to be done again even for previously succesfully encoded streams since the frameserver is swapped.
Old 4th August 2013, 02:46   #17723  |  Link
gonca
I can confirm the completing remainder of indexing message
Old 4th August 2013, 14:25   #17724  |  Link
rogress
Failed to retrieve audio
Can't seem to get past a Failed to retrieve audio error. (First one I've had a problem with).
I've tried both of the audio streams that BD Rebuilder shows (see attached).
I've re-ripped it a few times, latest version of Any DVD
Any thoughts?
[08/04/13] BD Rebuilder v0.44.15 (beta)
[08:53:10] Source: MOUR_D1_00002
- Input BD size: 41.97 GB
- Approximate total content: [02:32:17.094]
- Windows Version: 5.1 [2600]
- Mode: MKV Container, 1280x720, 448Kbs DD5.1
[08:53:11] PHASE ONE, Encoding
- [08:53:11] Processing: VID_00000 (1 of 3)
- [08:53:11] Extracting A/V streams [VID_00000]
- Error in attempt to MKVMERGE.
[09:08:08] - Failed to retrieve audio, aborted
rogress is offline   Reply With Quote
Old 4th August 2013, 15:27   #17725  |  Link
Hmm... I'll take a look at it.
Old 5th August 2013, 00:54   #17726  |  Link
kshock
Same here.
[19:29:11] Source: STAR_TREK_S1D1
- Input BD size: 42.18 GB
- Approximate total content: [04:24:23.529]
- Target BD size: 22.95 GB
- Windows Version: 6.1 [7601]
- Quality: Highest (Very Slow), Two Pass
[19:29:19] PHASE ONE, Encoding
- [19:29:19] Processing: VID_00000 (1 of 88)
- [19:29:19] Extracting A/V streams [VID_00000]
[19:29:24] - Failed to retrieve audio, aborted
Win 7 Ultimate 64-bit
AMD Phenom II X6 1090T 3.20GHz
Gigabyte 890PA-UD3H
4 GB RAM
Pioneer BD-RW BDR-205
AMD Athlon 5050e 2.60
4 gig ram
kshock is offline   Reply With Quote
Old 5th August 2013, 02:04   #17727  |  Link
Ch3vr0n
Originally Posted by kshock View Post
Same here.
wrong not the same issue.
Different disc and you're doing a full disc backup while rogress is doing a movie only backup to mkv. However both logs seem to indicate an issue with mkvmerge.
Old 6th August 2013, 01:29   #17728  |  Link
Imperial Zeppelin
Back to HP6
Just loaded July Beta, had ST Generations go/with no problems using an AnyDVD HD image loaded on Daemon Tools. HP6 very different story, 2 separate images tried and directly off the BD using AnyDVD HD and I always get a
"Failed to retrieve audio, aborted" at 4.16% overall progress.
Tried rebooting between runs, continuing previous version, not continuing previous version, etc. Any insight?
Here's the log from a "virgin" start and then a "continuation."
[08/05/13] BD Rebuilder v0.44.15 (beta)
[20:07:21] Source: HARRY_POTTER_6
- Input BD size: 28.98 GB
- Approximate total content: [03:25:48.127]
- Target BD size: 21.92 GB
[20:07:23] PHASE ONE, Encoding
- [20:07:23] Processing: VID_00067 (1 of 17)
- [20:07:23] Extracting A/V streams [VID_00067]
- [20:07:35] Reencoding video [VID_00067]
- Rate/Length: 23.976fps, 2,824 frames
- [20:07:35] Reencoding: VID_00067, Pass 1 of 1
- [20:08:37] Video Encode complete
- [20:08:37] Processing audio tracks
- [20:08:37] Multiplexing M2TS
- [20:08:44] Processing: VID_00004 (2 of 17)
- [20:08:44] Extracting A/V streams [VID_00004]
- [20:08:56] Reencoding video [VID_00004]
- Rate/Length: 23.976fps, 2,998 frames
- [20:08:56] Reencoding: VID_00004, Pass 1 of 1
- [20:10:01] Video Encode complete
- [20:10:01] Processing audio tracks
- [20:10:01] Multiplexing M2TS
- [20:10:08] Processing: VID_00009 (3 of 17)
- [20:10:08] Extracting A/V streams [VID_00009]
- [20:10:20] Reencoding video [VID_00009]
- Rate/Length: 23.976fps, 2,991 frames
- [20:10:20] Reencoding: VID_00009, Pass 1 of 1
- [20:11:23] Video Encode complete
- [20:11:23] Processing audio tracks
- [20:11:23] Multiplexing M2TS
- [20:11:29] Processing: VID_00072 (4 of 17)
- [20:11:29] Extracting A/V streams [VID_00072]
- [20:11:41] Reencoding video [VID_00072]
- Rate/Length: 23.976fps, 3,021 frames
- [20:11:41] Reencoding: VID_00072, Pass 1 of 1
- [20:12:42] Video Encode complete
- [20:12:42] Processing audio tracks
- [20:12:42] Multiplexing M2TS
- [20:12:48] Processing: VID_00007 (5 of 17)
- [20:12:48] Extracting A/V streams [VID_00007]
- [20:13:00] Reencoding video [VID_00007]
- Rate/Length: 23.976fps, 3,062 frames
- [20:13:00] Reencoding: VID_00007, Pass 1 of 1
- [20:14:07] Video Encode complete
- [20:14:07] Processing audio tracks
- [20:14:07] Multiplexing M2TS
- [20:14:15] Processing: VID_00069 (6 of 17)
- [20:14:15] Extracting A/V streams [VID_00069]
- [20:14:28] Reencoding video [VID_00069]
- Rate/Length: 23.976fps, 3,590 frames
- [20:14:28] Reencoding: VID_00069, Pass 1 of 1
- [20:15:46] Video Encode complete
- [20:15:46] Processing audio tracks
- [20:15:46] Multiplexing M2TS
- [20:15:54] Processing: VID_00010 (7 of 17)
- [20:15:54] Extracting A/V streams [VID_00010]
- [20:16:09] Reencoding video [VID_00010]
- Rate/Length: 23.976fps, 3,154 frames
- [20:16:09] Reencoding: VID_00010, Pass 1 of 1
- [20:17:21] Video Encode complete
- [20:17:21] Processing audio tracks
- [20:17:21] Multiplexing M2TS
- [20:17:30] Processing: VID_00680 (8 of 17)
- [20:17:30] Extracting A/V streams [VID_00680]
[20:17:45] - Failed to retrieve audio, aborted
[20:17:56] Source: HARRY_POTTER_6
- Resuming from previously started job.
[20:17:58] PHASE ONE, Encoding
- [20:17:58] Processing: VID_00680 (8 of 17)
- [20:17:58] Extracting A/V streams [VID_00680]
[20:18:07] - Failed to retrieve audio, aborted
Phenom II 940
GA-MA790FS-DS5 plus ATI 480
4 x 2 GB Mushkin
Windows 7 64-bit
3.5 Terabytes Mass Storage
2 BD Burners, 2 DVD burners
Lots of other "Stuff"
Imperial Zeppelin is offline   Reply With Quote
Old 6th August 2013, 03:18   #17729  |  Link
@Imperial Zeppelin
I don't get that one. I can't see how MKVMERGE is even involved there. I'll have to look at the code.
[Edit] Ok... If that source is an interlaced VC-1 source than I can see where/why it is called. Can you check and see if the stream list shows a "**" next to that stream's framerate? Does the information area show "Converting field-based or secondary stream" when this is happening?
"Harry Potter 6" -- is that "The Half Blood Prince"?
Old 6th August 2013, 05:08   #17730  |  Link
AmigaFuture
AmigaFuture's Avatar
@ jdobbs
Correct about "Harry Potter 6".
Old 6th August 2013, 11:51   #17731  |  Link
Imperial Zeppelin
@Imperial Zeppelin
Yes, HP6 is Half Blood Prince.
Attached is what I see right before the failure, no mention of what you've asked. Just says "Extracting A/V streams: 00680.M2TS"
Thanks for the help. Anything else you need? For giggles I'm trying a "Movie Only" right now. I'm not putting much hope into it, but if interlacing is the problem, I'm thinking maybe some of the interlaced extra crap on the disc could be the cause.
Phenom II 940
4 x 2 GB Mushkin
Windows 7 64-bit
Old 6th August 2013, 18:03   #17732  |  Link
Imperial Zeppelin
Hey, my hunch paid off!!
When I did "Movie Only," it worked like a champ. Hope that helps and thanks!
Phenom II 940
4 x 2 GB Mushkin
Windows 7 64-bit
Old 6th August 2013, 23:08   #17733  |  Link
gonca
@Jdobbs
Here is the info you asked for from the Canadian version of Half Blood Prince.
It appears to be VC-1 1080p.
Old 7th August 2013, 00:01   #17734  |  Link
gonca
Here is a log for Harry Potter 6 with DGDecNV. Worked fine. Did notice that the video sequences were completely different.
[08/06/13] BD Rebuilder v0.44.15 (beta)
[18:10:21] Source:  HARRY_POTTER_6
  - Input BD size: 28.97 GB
  - Decoding/Frame serving: DGDecNV [4-way]
[18:10:21] PHASE ONE, Encoding
 - [18:10:21] Processing: VID_00000 (1 of 17)
 - [18:10:21] Extracting A/V streams [VID_00000]
 - [18:12:49] Reencoding video [VID_00000]
 - [18:12:49] Reencoding secondary video [TRK_02]
   - Rate/Length: 23.976fps, 220,841 frames
   - Bitrate: 14,132 Kbs
 - [18:17:07] Reencoding: VID_00000, Pass 1 of 1
 - [18:42:39] Video Encode complete
 - [18:42:39] Processing audio tracks
   - Track 6656 (eng): Keeping original audio
 - [18:42:39] Multiplexing M2TS
 - [18:45:45] Processing: VID_00001 (2 of 17)
 - [18:45:45] Extracting A/V streams [VID_00001]
 - [18:45:51] Reencoding video [VID_00001]
   - Rate/Length: 23.976fps, 4,965 frames
   - Bitrate: 7,813 Kbs
 - [18:45:51] Reencoding: VID_00001, Pass 1 of 1
 - [18:46:26] Video Encode complete
 - [18:46:26] Processing audio tracks
 - [18:46:26] Multiplexing M2TS
 - [18:46:30] Processing: VID_00003 (3 of 17)
 - [18:46:30] Extracting A/V streams [VID_00003]
 - [18:46:36] Reencoding video [VID_00003]
   - Rate/Length: 23.976fps, 4,029 frames
   - Bitrate: 7,831 Kbs
 - [18:46:36] Reencoding: VID_00003, Pass 1 of 1
 - [18:47:04] Video Encode complete
 - [18:47:04] Processing audio tracks
 - [18:47:04] Multiplexing M2TS
 - [18:47:08] Processing: VID_00004 (4 of 17)
 - [18:47:08] Extracting A/V streams [VID_00004]
 - [18:47:14] Reencoding video [VID_00004]
   - Bitrate: 7,789 Kbs
 - [18:47:14] Reencoding: VID_00004, Pass 1 of 1
 - [18:47:35] Video Encode complete
 - [18:47:35] Processing audio tracks
 - [18:47:35] Multiplexing M2TS
 - [18:47:39] Processing: VID_00005 (5 of 17)
 - [18:47:39] Extracting A/V streams [VID_00005]
 - [18:47:44] Reencoding video [VID_00005]
   - Rate/Length: 23.976fps, 3,965 frames
   - Bitrate: 7,846 Kbs
 - [18:47:44] Reencoding: VID_00005, Pass 1 of 1
 - [18:48:12] Video Encode complete
 - [18:48:12] Processing audio tracks
 - [18:48:12] Multiplexing M2TS
 - [18:48:16] Processing: VID_00006 (6 of 17)
 - [18:48:16] Extracting A/V streams [VID_00006]
 - [18:48:21] Reencoding video [VID_00006]
   - Rate/Length: 23.976fps, 4,075 frames
   - Bitrate: 7,902 Kbs
 - [18:48:21] Reencoding: VID_00006, Pass 1 of 1
 - [18:48:50] Video Encode complete
 - [18:48:50] Processing audio tracks
 - [18:48:50] Multiplexing M2TS
 - [18:48:54] Processing: VID_00007 (7 of 17)
 - [18:48:54] Extracting A/V streams [VID_00007]
 - [18:48:59] Reencoding video [VID_00007]
   - Bitrate: 7,767 Kbs
 - [18:48:59] Reencoding: VID_00007, Pass 1 of 1
 - [18:49:21] Video Encode complete
 - [18:49:21] Processing audio tracks
 - [18:49:21] Multiplexing M2TS
 - [18:49:25] Processing: VID_00008 (8 of 17)
 - [18:49:25] Extracting A/V streams [VID_00008]
 - [18:49:30] Reencoding video [VID_00008]
   - Rate/Length: 23.976fps, 4,239 frames
   - Bitrate: 7,837 Kbs
 - [18:49:30] Reencoding: VID_00008, Pass 1 of 1
 - [18:50:00] Video Encode complete
 - [18:50:00] Processing audio tracks
 - [18:50:00] Multiplexing M2TS
 - [18:50:04] Processing: VID_00009 (9 of 17)
 - [18:50:04] Extracting A/V streams [VID_00009]
 - [18:50:10] Reencoding video [VID_00009]
   - Bitrate: 7,817 Kbs
 - [18:50:10] Reencoding: VID_00009, Pass 1 of 1
 - [18:50:30] Video Encode complete
 - [18:50:30] Processing audio tracks
 - [18:50:30] Multiplexing M2TS
 - [18:50:34] Processing: VID_00010 (10 of 17)
 - [18:50:34] Extracting A/V streams [VID_00010]
 - [18:50:40] Reencoding video [VID_00010]
   - Bitrate: 10,002 Kbs
 - [18:50:40] Reencoding: VID_00010, Pass 1 of 1
 - [18:51:02] Video Encode complete
 - [18:51:02] Processing audio tracks
 - [18:51:02] Multiplexing M2TS
 - [18:51:06] Processing: VID_00067 (11 of 17)
 - [18:51:06] Extracting A/V streams [VID_00067]
 - [18:51:12] Reencoding video [VID_00067]
   - Bitrate: 7,853 Kbs
 - [18:51:12] Reencoding: VID_00067, Pass 1 of 1
 - [18:51:32] Video Encode complete
 - [18:51:32] Processing audio tracks
 - [18:51:32] Multiplexing M2TS
 - [18:51:35] Processing: VID_00068 (12 of 17)
 - [18:51:35] Extracting A/V streams [VID_00068]
 - [18:51:41] Reencoding video [VID_00068]
   - Rate/Length: 23.976fps, 4,312 frames
   - Bitrate: 7,828 Kbs
 - [18:51:41] Reencoding: VID_00068, Pass 1 of 1
 - [18:52:11] Video Encode complete
 - [18:52:11] Processing audio tracks
 - [18:52:11] Multiplexing M2TS
 - [18:52:15] Processing: VID_00069 (13 of 17)
 - [18:52:15] Extracting A/V streams [VID_00069]
 - [18:52:21] Reencoding video [VID_00069]
   - Bitrate: 7,755 Kbs
 - [18:52:21] Reencoding: VID_00069, Pass 1 of 1
 - [18:52:46] Video Encode complete
 - [18:52:46] Processing audio tracks
 - [18:52:46] Multiplexing M2TS
 - [18:52:50] Processing: VID_00070 (14 of 17)
 - [18:52:50] Extracting A/V streams [VID_00070]
 - [18:52:56] Reencoding video [VID_00070]
   - Rate/Length: 23.976fps, 5,320 frames
   - Bitrate: 7,833 Kbs
 - [18:52:56] Reencoding: VID_00070, Pass 1 of 1
 - [18:53:34] Video Encode complete
 - [18:53:34] Processing audio tracks
 - [18:53:34] Multiplexing M2TS
 - [18:53:38] Processing: VID_00071 (15 of 17)
 - [18:53:38] Extracting A/V streams [VID_00071]
 - [18:53:44] Reencoding video [VID_00071]
   - Rate/Length: 23.976fps, 4,942 frames
   - Bitrate: 7,696 Kbs
 - [18:53:44] Reencoding: VID_00071, Pass 1 of 1
 - [18:54:18] Video Encode complete
 - [18:54:18] Processing audio tracks
 - [18:54:18] Multiplexing M2TS
 - [18:54:23] Processing: VID_00072 (16 of 17)
 - [18:54:23] Extracting A/V streams [VID_00072]
 - [18:54:28] Reencoding video [VID_00072]
   - Bitrate: 7,770 Kbs
 - [18:54:28] Reencoding: VID_00072, Pass 1 of 1
 - [18:54:50] Video Encode complete
 - [18:54:50] Processing audio tracks
 - [18:54:50] Multiplexing M2TS
 - [18:54:54] Processing: VID_00680 (17 of 17)
 - [18:54:54] Extracting A/V streams [VID_00680]
 - [18:55:00] Reencoding video [VID_00680]
 - [18:55:00] Reencoding secondary video [TRK_02]
   - Rate/Length: 23.976fps, 14,498 frames
   - Bitrate: 1,940 Kbs
 - [18:55:05] Reencoding: VID_00680, Pass 1 of 1
 - [18:56:45] Video Encode complete
 - [18:56:45] Processing audio tracks
 - [18:56:45] Multiplexing M2TS
[18:56:49]PHASE ONE complete
[18:56:49]PHASE TWO - Rebuild Started
 - [18:56:49] Rebuilding BD file Structure
[18:56:50] - Encode and Rebuild complete
 - WORKFILES folder removed.
[18:56:51] JOB: HARRY_POTTER_6 finished.
Old 7th August 2013, 00:50   #17735  |  Link
gonca
With DirectShow same results as before
[18:58:03] Source:  HARRY_POTTER_6
  - Decoding/Frame serving: DirectShow [6-way]
[18:58:03] PHASE ONE, Encoding
 - [18:58:03] Processing: VID_00000 (1 of 17)
 - [18:58:03] Extracting A/V streams [VID_00000]
 - [19:00:11] Reencoding video [VID_00000]
 - [19:00:11] Reencoding secondary video [TRK_02]
 - [19:06:58] Reencoding: VID_00000, Pass 1 of 1
 - [19:29:54] Video Encode complete
 - [19:29:54] Processing audio tracks
 - [19:29:54] Multiplexing M2TS
 - [19:32:03] Processing: VID_00001 (2 of 17)
 - [19:32:03] Extracting A/V streams [VID_00001]
 - [19:32:08] Reencoding video [VID_00001]
 - [19:32:08] Reencoding: VID_00001, Pass 1 of 1
 - [19:32:52] Video Encode complete
 - [19:32:52] Processing audio tracks
 - [19:32:52] Multiplexing M2TS
 - [19:32:57] Processing: VID_00003 (3 of 17)
 - [19:32:57] Extracting A/V streams [VID_00003]
 - [19:33:01] Reencoding video [VID_00003]
 - [19:33:01] Reencoding: VID_00003, Pass 1 of 1
 - [19:33:32] Video Encode complete
 - [19:33:32] Processing audio tracks
 - [19:33:32] Multiplexing M2TS
 - [19:33:36] Processing: VID_00004 (4 of 17)
 - [19:33:36] Extracting A/V streams [VID_00004]
 - [19:33:40] Reencoding video [VID_00004]
 - [19:33:40] Reencoding: VID_00004, Pass 1 of 1
 - [19:34:08] Video Encode complete
 - [19:34:08] Processing audio tracks
 - [19:34:08] Multiplexing M2TS
 - [19:34:12] Processing: VID_00005 (5 of 17)
 - [19:34:12] Extracting A/V streams [VID_00005]
 - [19:34:20] Reencoding video [VID_00005]
 - [19:34:20] Reencoding: VID_00005, Pass 1 of 1
 - [19:34:57] Video Encode complete
 - [19:34:57] Processing audio tracks
 - [19:34:57] Multiplexing M2TS
 - [19:35:01] Processing: VID_00006 (6 of 17)
 - [19:35:01] Extracting A/V streams [VID_00006]
 - [19:35:05] Reencoding video [VID_00006]
 - [19:35:05] Reencoding: VID_00006, Pass 1 of 1
 - [19:35:36] Video Encode complete
 - [19:35:36] Processing audio tracks
 - [19:35:36] Multiplexing M2TS
 - [19:35:40] Processing: VID_00007 (7 of 17)
 - [19:35:40] Extracting A/V streams [VID_00007]
 - [19:35:44] Reencoding video [VID_00007]
 - [19:35:44] Reencoding: VID_00007, Pass 1 of 1
 - [19:36:12] Video Encode complete
 - [19:36:12] Processing audio tracks
 - [19:36:12] Multiplexing M2TS
 - [19:36:16] Processing: VID_00008 (8 of 17)
 - [19:36:16] Extracting A/V streams [VID_00008]
 - [19:36:21] Reencoding video [VID_00008]
 - [19:36:21] Reencoding: VID_00008, Pass 1 of 1
 - [19:36:58] Video Encode complete
 - [19:36:58] Processing audio tracks
 - [19:36:58] Multiplexing M2TS
 - [19:37:03] Processing: VID_00009 (9 of 17)
 - [19:37:03] Extracting A/V streams [VID_00009]
 - [19:37:07] Reencoding video [VID_00009]
 - [19:37:07] Reencoding: VID_00009, Pass 1 of 1
 - [19:37:34] Video Encode complete
 - [19:37:34] Processing audio tracks
 - [19:37:34] Multiplexing M2TS
 - [19:37:38] Processing: VID_00010 (10 of 17)
 - [19:37:38] Extracting A/V streams [VID_00010]
 - [19:37:42] Reencoding video [VID_00010]
 - [19:37:42] Reencoding: VID_00010, Pass 1 of 1
 - [19:38:11] Video Encode complete
 - [19:38:11] Processing audio tracks
 - [19:38:11] Multiplexing M2TS
 - [19:38:15] Processing: VID_00067 (11 of 17)
 - [19:38:15] Extracting A/V streams [VID_00067]
 - [19:38:20] Reencoding video [VID_00067]
 - [19:38:20] Reencoding: VID_00067, Pass 1 of 1
 - [19:38:46] Video Encode complete
 - [19:38:46] Processing audio tracks
 - [19:38:46] Multiplexing M2TS
 - [19:38:50] Processing: VID_00068 (12 of 17)
 - [19:38:50] Extracting A/V streams [VID_00068]
 - [19:38:55] Reencoding video [VID_00068]
 - [19:38:55] Reencoding: VID_00068, Pass 1 of 1
 - [19:39:35] Video Encode complete
 - [19:39:35] Processing audio tracks
 - [19:39:35] Multiplexing M2TS
 - [19:39:39] Processing: VID_00069 (13 of 17)
 - [19:39:39] Extracting A/V streams [VID_00069]
 - [19:39:44] Reencoding video [VID_00069]
 - [19:39:44] Reencoding: VID_00069, Pass 1 of 1
 - [19:40:16] Video Encode complete
 - [19:40:16] Processing audio tracks
 - [19:40:16] Multiplexing M2TS
 - [19:40:20] Processing: VID_00070 (14 of 17)
 - [19:40:20] Extracting A/V streams [VID_00070]
 - [19:40:25] Reencoding video [VID_00070]
 - [19:40:25] Reencoding: VID_00070, Pass 1 of 1
 - [19:41:09] Video Encode complete
 - [19:41:09] Processing audio tracks
 - [19:41:09] Multiplexing M2TS
 - [19:41:13] Processing: VID_00071 (15 of 17)
 - [19:41:13] Extracting A/V streams [VID_00071]
 - [19:41:18] Reencoding video [VID_00071]
 - [19:41:18] Reencoding: VID_00071, Pass 1 of 1
 - [19:41:58] Video Encode complete
 - [19:41:58] Processing audio tracks
 - [19:41:58] Multiplexing M2TS
 - [19:42:02] Processing: VID_00072 (16 of 17)
 - [19:42:02] Extracting A/V streams [VID_00072]
 - [19:42:06] Reencoding video [VID_00072]
 - [19:42:06] Reencoding: VID_00072, Pass 1 of 1
 - [19:42:31] Video Encode complete
 - [19:42:31] Processing audio tracks
 - [19:42:31] Multiplexing M2TS
 - [19:42:35] Processing: VID_00680 (17 of 17)
 - [19:42:35] Extracting A/V streams [VID_00680]
 - [19:42:42] Reencoding video [VID_00680]
 - [19:42:42] Reencoding secondary video [TRK_02]
   - Bitrate: 1,942 Kbs
 - [19:42:55] Reencoding: VID_00680, Pass 1 of 1
 - [19:44:17] Video Encode complete
 - [19:44:17] Processing audio tracks
 - [19:44:17] Multiplexing M2TS
[19:44:21]PHASE ONE complete
[19:44:21]PHASE TWO - Rebuild Started
 - [19:44:21] Rebuilding BD file Structure
[19:44:24] - Encode and Rebuild complete
[19:44:26] JOB: HARRY_POTTER_6 finished.
Old 7th August 2013, 04:02   #17736  |  Link
AmigaFuture
Hello JDobbs,
Any news about "Live Free or Die Hard (4)" extas not being kept correctly using Movie & Menus? Thanks.
Old 7th August 2013, 12:00   #17737  |  Link
Sharc
Similar issue here with "Jack the giant slayer" - movie only, using dgdecnv2045: Audio extraction goes to 100% and then just sits there. Reverting to the previous Version of dgdecnv 2044 seems to solve the problem. Something for neuron2?
Old 7th August 2013, 13:17   #17738  |  Link
Try making the project (also demuxing the audio) manually with DGIndexNV (not through Rebuilder) and report the result.
Old 7th August 2013, 15:48   #17739  |  Link
Sharc
Works and finishes normally. CPU load down to Zero after finishing. Nothing unusual observed.
Old 7th August 2013, 16:28   #17740  |  Link
Then it is apparently not something for neuron2, unless there is some strange interaction with BDRebuilder. I'll wait for jdobbs to weigh in on it.
