Welcome to Doom9's Forum, THE in-place to be for everyone interested in DVD conversion. Before you start posting please read the forum rules. By posting to this forum you agree to abide by the rules. Domains: forum.doom9.org / forum.doom9.net / forum.doom9.se |
#4521 | Link | |
![]() Join Date: Oct 2001
jdobbs.softworks@gmail.com |
#4522 | Link | |
[Edit] I never use the "Highest" setting, and I just was reminded why -- the encode of Valkyrie is only 38% complete after encoding all night. Ugghhh.
jdobbs.softworks@gmail.com Last edited by jdobbs; 11th August 2009 at 15:12. |
#4523 | Link | |
#4524 | Link |
How is NSIZE being calculated?
It appears that VALKYRIE.INF is generated by BD-RB prior to invoking x264, no? If this is true then isn't this guiding the setup initialization for x264 thus if the inputs are different then one would expect the outputs to be different as well. [Status] LABEL=VALKYRIE VERSION=v0.26.03 (beta) SOURCE_SIZE=42911885717 SOURCE_VIDEO_SIZE=42544183296 TARGET_SIZE=24117248000 REDUCTION=.55823249476346 RESIZE_1080=0 AUDIO_TO_KEEP=eng; SUBS_TO_KEEP=all BACKUP_MODE=0 QUICK=0 ENCODE_STEP=0 COMPLETED=10 REBUILD_COMPLETE=1 [00074] AUDIO=10000 PGS=11111010 M2TS_TARGET=13775500522 RATE=10005 NSIZE=13321525248 FLINK=0 MLINK=0 ... [Status] LABEL=VALKYRIE VERSION=v0.27.01 (beta)...........................Note: The only difference here was SOURCE_SIZE=42911885717.................................[x] Quick Encode for Extras SOURCE_VIDEO_SIZE=42544183296.......................[x] Remove WORKFILES.... TARGET_SIZE=24117248000 REDUCTION=.55823249476346 RESIZE_1080=0 AUDIO_TO_KEEP=eng; SUBS_TO_KEEP=all BACKUP_MODE=0 QUICK=1 ENCODE_STEP=0 COMPLETED=10 REBUILD_COMPLETE=1 [00074] AUDIO=10000 PGS=11111010 M2TS_TARGET=16838596203 RATE=13160 NSIZE=3913721856 FLINK=0 MLINK=0 ... [Status] LABEL=VALKYRIE VERSION=v0.28.02 (beta) SOURCE_SIZE=42911885717 SOURCE_VIDEO_SIZE=42544183296 TARGET_SIZE=24117248000 REDUCTION=.55823249476346 RESIZE_1080=0 AUDIO_TO_KEEP=eng; SUBS_TO_KEEP=all BACKUP_MODE=0 QUICK=0 ENCODE_STEP=2 COMPLETED=1 [00074] AUDIO=10000 PGS=11111010 M2TS_TARGET=13775500522..............<-- Sames as v0.26.03 RATE=10005 NSIZE=4591945728 FLINK=0 MLINK=0 ... Note: v0.26.03 the job finished with expected output size. v0.27.01 the job finished with significant reduction in output size. v0.28.02 the job failed to complete. Last edited by leChameleon; 11th August 2009 at 17:37. Reason: Added v0.27.01 *.INF information. |
#4525 | Link |
No it isn't generated prior to X264, it is updated as the encodes progress. NSIZE isn't calculated. It is the size in bytes of the output file. It shows how close the encoder hit the target. If you are that far off, something is certainly wrong. The problem is that I have no reports of that level of undersizing from anyone but you. Can you post your BDREBUILDER.INI file for the v0.28.xx encodes?
M2TS_TARGET is the target size of the resulting M2TS. NSIZE is typically close to it, but it can deviate based upon the size of other parts of the M2TS (audio, subs, secondary video/audio). [Edit] I deleted my comments related to sizing here because I just realized this encode is using "Faster encode for extras" which is SUPPOSED to result in deviations from the target size (in order to keep a constant quality value). The differences are adjusted when the large (usually main-movie) sections are encoded.
jdobbs.softworks@gmail.com Last edited by jdobbs; 11th August 2009 at 16:44. |
#4527 | Link |
Is there any option to save a debug log to see exactly what all the commands are output to x264 from BD-RB?
If so this may help us run the same command string in various supporting x264 builds to see what's going on there. |
#4528 | Link | |
Trying to back up lakeview terrace, using the latest version, to bd25, and im getting this error.
BD rebuilder experienced an error 2202[18:39:38]RebuildBDFiles() 00052 2202. Quote:
#4529 | Link | |
a) CRF sequence - Analyzing 24.85 10.00 21.70 19.60 18.40 17.80 [17.85] => much better than before b) Movie fills DVD-5 to 94% => no oversize although final CRF is even lower than with v0.28.02 c) Video/audio (448 ac3) still out of sync (Audio and subs are in sync) |
#4530 | Link | |
sorry if im not very good at explaining what im doing. |
#4531 | Link |
ffdshow needed in Windows 7?
Sorry for this slightly offtopic question:
Is ffdshow still nessessary in Windows 7? I did *not* install it (just avisynth and haali) and BD Rebuilder did work without a problem. The BD9 result was 600MB undersized though. Could the missing ffdshow be the reason for that? Would it be advisable to install ffdshow even in Win7? Thanks in advance. S. |
#4532 | Link |
I'm not sure resuming a job started with a different version is very useful... maybe trying some different settings with the current version would be more productive, if you're trying to get a good copy of a problematic movie.
#4533 | Link |
VALKYRIE v0.28.03 Highest encoder setting.
![]() [Status] LABEL=VALKYRIE VERSION=v0.28.03 (beta) SOURCE_SIZE=42911885717 SOURCE_VIDEO_SIZE=42544183296 TARGET_SIZE=24117248000 REDUCTION=.55823249476346 RESIZE_1080=0 AUDIO_TO_KEEP=eng; SUBS_TO_KEEP=all BACKUP_MODE=0 QUICK=0 ENCODE_STEP=2 COMPLETED=1 [00074] AUDIO=10000 PGS=11111010 M2TS_TARGET=13775500522 RATE=10005 NSIZE=3915626496 FLINK=0 MLINK=0 [00172] AUDIO=1 PGS= M2TS_TARGET=493466521 RATE=6451 ----------------------- [09:41:56] BD Rebuilder v0.28.03 (beta) - Source: VALKYRIE - Input BD size: 39.96 GB - Approximate total content: [05:24:24.653] - Target BD size: 22.46 GB [09:41:56] PHASE ONE, Encoding - [09:41:56] Extracting A/V streams [VID_00074] - [09:50:26] Reencoding: VID_00074 (1 of 10) - [09:50:26] Collecting video information - Video: 1920x1080, 23.976fps, 173,130 frames - Bitrate: 10,005 Kbs - [09:50:26] Reencoding: VID_00074, Pass 1 of 2 - [10:50:46] Reencoding: VID_00074, Pass 2 of 2 - [11:30:39] Video Encode complete - [11:30:39] Reencoding audio tracks (if req'd) - [11:30:39] Multiplexing M2TS - [11:32:23] Extracting A/V streams [VID_00172] - [11:32:38] Reencoding: VID_00172 (2 of 10) - [11:32:38] Collecting video information - Video: 1920x1080, 29.970fps, 16,429 frames - Bitrate: 6,451 Kbs - [11:32:38] Reencoding: VID_00172, Pass 1 of 2 - Encode failed. Retrying. - Encode failed. Retrying. - [11:32:56] Reencoding: VID_00172, Pass 2 of 2 - Encode failed. Retrying. - Encode failed. Retrying. - Reached retry limit. Aborting. [11:32:58] - Failed video encode, aborted "D:\Downloads\BD-RB\BD-RBV02803\BD_Rebuilder\tools\x264.exe" "J:\BD25 4\VALKYRIE (2008)\BD-RBV02803\WORKFILES\VID_00172.AVS" --preset slow --ref 4 --b-adapt 1 --bitrate 6451 --level 4.1 --sar 1:1 --fps 30000/1001 --aud --vbv-bufsize 25000 --keyint 24 --min-keyint 1 --ipratio 1.1 --pbratio 1.1 --vbv-maxrate 35000 --threads auto --thread-input --stats "J:\BD25 4\VALKYRIE (2008)\BD-RBV02803\WORKFILES\VID_00172.AVS.MKV.stats" --pass 2 --output "J:\BD25 4\VALKYRIE (2008)\BD-RBV02803\WORKFILES\VID_00172.AVS.MKV" avis [info]: 1920x1080 @ 29.97 fps (16429 frames) x264 [info]: using SAR=1/1 x264 [info]: using cpu capabilities: MMX2 SSE2Fast SSSE3 FastShuffle SSE4.2 x264 [error]: 2nd pass has more frames than 1st pass (16429 vs 64) x264 [error]: x264_encoder_open failed Directory of J:\Bd25 4\Valkyrie (2008)\BD-RBV02803\WORKFILES 08/11/2009 11:32 AM <DIR> . 08/11/2009 11:32 AM <DIR> .. 08/11/2009 11:32 AM 40,208 00074.clpi 08/11/2009 11:32 AM 3,915,626,496 00074.m2ts 08/11/2009 09:50 AM 3,326,385,148 00074.track_4352.dts 08/11/2009 09:50 AM 29,028,564 00074.track_4608.sup 08/11/2009 09:50 AM 24,495,097 00074.track_4609.sup 08/11/2009 09:50 AM 27,215,553 00074.track_4610.sup 08/11/2009 09:50 AM 22,068,786 00074.track_4611.sup 08/11/2009 09:50 AM 14,099,704 00074.track_4612.sup 08/11/2009 09:50 AM 26,646,806 00074.track_4614.sup 08/11/2009 11:32 AM 15,349,376 00172.track_4352.ac3 08/11/2009 09:41 AM 897 AUD_00074.meta 08/11/2009 09:50 AM 262 AUD_00074_4352.AVS 08/11/2009 11:32 AM 266 AUD_00172.meta 08/11/2009 12:10 PM 262 AUD_00172_4352.AVS 08/11/2009 11:30 AM 946 MUX_00074.meta 08/11/2009 09:50 AM 184 VID_00074.AVS 08/11/2009 11:30 AM 21,625,441 VID_00074.AVS.MKV 08/11/2009 10:50 AM 14,011,638 VID_00074.AVS.MKV.stats 08/11/2009 12:10 PM 309 VID_00172.AVS 08/11/2009 12:11 PM 0 VID_00172.AVS.MKV 08/11/2009 11:32 AM 5,668 VID_00172.AVS.MKV.stats 08/11/2009 11:32 AM 375,383 VID_00172.AVS.MKV.stats.mbtree Last edited by leChameleon; 11th August 2009 at 23:06. |
#4534 | Link | |
#4535 | Link | |
![]() D:\Downloads\BD-RB\BD-RBV02802\BD_Rebuilder\BDREBUILDER.INI ------------------------------------------------------- [Options] RESIZE=0 MODE=0 QUICK_EXTRAS=0 ENCODE_QUALITY=3 TARGET_SIZE=23000 PRIORITY_CLASS=0 VERBOSE_STATUS=1 AUDIO_TO_KEEP=eng; SUBS_TO_KEEP=all COLOR_BOOST=0 RESIZE_1080=0 DTS_REENCODE=0 AC3_REENCODE=0 AC3_640=1 KEEP_HD_AUDIO=1 AVCHD=1 REMOVE_WORKFILES=0 AUDIO_TRACK_LIMIT=0 SUBTITLE_TRACK_LIMIT=0 CUSTOM_TARGET_SIZE=23450 [Paths] SOURCE_PATH=F:\TEMP - VALKYRIE (2008)\VALKYRIE\ WORKING_PATH=J:\BD25 4\VALKYRIE (2008)\BD-RBV02802\ D:\Downloads\BD-RB\BD-RBV02803\BD_Rebuilder\BDREBUILDER.INI ------------------------------------------------------- [Options] RESIZE=0 MODE=0 QUICK_EXTRAS=0 PRIORITY_CLASS=0 ENCODE_QUALITY=2 VERBOSE_STATUS=1 TARGET_SIZE=23000 AUDIO_TO_KEEP=eng; SUBS_TO_KEEP=all COLOR_BOOST=0 RESIZE_1080=0 DTS_REENCODE=0 AC3_REENCODE=0 AC3_640=1 KEEP_HD_AUDIO=1 AVCHD=1 REMOVE_WORKFILES=0 AUDIO_TRACK_LIMIT=1 SUBTITLE_TRACK_LIMIT=1 CUSTOM_TARGET_SIZE=23450 [Paths] SOURCE_PATH=F:\TEMP - VALKYRIE (2008)\VALKYRIE\ WORKING_PATH=J:\BD25 4\VALKYRIE (2008)\BD-RBV02803_HQ\ Note: BD-RBV02803's INI may have changed as I'm running a test with "High Quality" now on VALKYRIE to see if this has the same problem, but I think that's the only chance as I'm trying to keep a controlled environment here for us. Hence the _HQ folder extension. Last edited by leChameleon; 11th August 2009 at 22:42. |
#4536 | Link |
VALKYRIE v0.28.03 High Quality encoder setting.
![]() D:\Downloads\BD-RB\BD-RBV02803\BD_Rebuilder\BDREBUILDER.INI -------------------------------------------------------------------- [Options] RESIZE=0 MODE=0 QUICK_EXTRAS=0 PRIORITY_CLASS=0 ENCODE_QUALITY=2 VERBOSE_STATUS=1 TARGET_SIZE=23000 AUDIO_TO_KEEP=eng; SUBS_TO_KEEP=all COLOR_BOOST=0 RESIZE_1080=0 DTS_REENCODE=0 AC3_REENCODE=0 AC3_640=1 KEEP_HD_AUDIO=1 AVCHD=1 REMOVE_WORKFILES=0 AUDIO_TRACK_LIMIT=1 SUBTITLE_TRACK_LIMIT=1 CUSTOM_TARGET_SIZE=23450 [Paths] SOURCE_PATH=F:\TEMP - VALKYRIE (2008)\VALKYRIE\ WORKING_PATH=J:\BD25 4\VALKYRIE (2008)\BD-RBV02803_HQ\ J:\Bd25 4\Valkyrie (2008)\BD-RBV02803_HQ\VALKYRIE.INF -------------------------------------------------------------------- [Status] LABEL=VALKYRIE VERSION=v0.28.03 (beta) SOURCE_SIZE=42911885717 SOURCE_VIDEO_SIZE=42544183296 TARGET_SIZE=24117248000 REDUCTION=.55823249476346 RESIZE_1080=0 AUDIO_TO_KEEP=eng; SUBS_TO_KEEP=all BACKUP_MODE=0 QUICK=0 ENCODE_STEP=2 COMPLETED=1 [00074] AUDIO=10000 PGS=11111010 M2TS_TARGET=13775500522 RATE=10005 NSIZE=5565782016 FLINK=0 MLINK=0 [00172] AUDIO=1 PGS= M2TS_TARGET=493466521 RATE=6451 J:\Bd25 4\Valkyrie (2008)\BD-RBV02803_HQ\BD-REBUILDER.LOG -------------------------------------------------------------------- [12:23:32] BD Rebuilder v0.28.03 (beta) - Source: VALKYRIE - Input BD size: 39.96 GB - Approximate total content: [05:24:24.653] - Target BD size: 22.46 GB [12:23:32] PHASE ONE, Encoding - [12:23:32] Extracting A/V streams [VID_00074] - [12:32:24] Reencoding: VID_00074 (1 of 10) - [12:32:24] Collecting video information - Video: 1920x1080, 23.976fps, 173,130 frames - Bitrate: 10,005 Kbs - [12:32:24] Reencoding: VID_00074, Pass 1 of 2 - [13:32:21] Reencoding: VID_00074, Pass 2 of 2 - [15:01:28] Video Encode complete - [15:01:29] Reencoding audio tracks (if req'd) - [15:01:29] Multiplexing M2TS - [15:03:35] Extracting A/V streams [VID_00172] - [15:03:49] Reencoding: VID_00172 (2 of 10) - [15:03:49] Collecting video information - Video: 1920x1080, 29.970fps, 16,429 frames - Bitrate: 6,451 Kbs - [15:03:49] Reencoding: VID_00172, Pass 1 of 2 - [15:03:53] Reencoding: VID_00172, Pass 2 of 2 - Encode failed. Retrying. - Encode failed. Retrying. - Reached retry limit. Aborting. [15:04:04] - Failed video encode, aborted D:\Downloads\BD-RB\BD-RBV02803\BD_Rebuilder\LASTCMD.TXT -------------------------------------------------------------------- "D:\Downloads\BD-RB\BD-RBV02803\BD_Rebuilder\tools\x264.exe" "J:\BD25 4\VALKYRIE (2008)\BD-RBV02803_HQ\WORKFILES\VID_00172.AVS" --preset medium --bitrate 6451 --level 4.1 --sar 1:1 --fps 30000/1001 --aud --vbv-bufsize 25000 --keyint 24 --min-keyint 1 --ipratio 1.1 --pbratio 1.1 --vbv-maxrate 35000 --threads auto --thread-input --stats "J:\BD25 4\VALKYRIE (2008)\BD-RBV02803_HQ\WORKFILES\VID_00172.AVS.MKV.stats" --pass 2 --output "J:\BD25 4\VALKYRIE (2008)\BD-RBV02803_HQ\WORKFILES\VID_00172.AVS.MKV" avis [info]: 1920x1080 @ 29.97 fps (16429 frames) x264 [info]: using SAR=1/1 x264 [info]: using cpu capabilities: MMX2 SSE2Fast SSSE3 FastShuffle SSE4.2 x264 [error]: 2nd pass has more frames than 1st pass (16429 vs 64) x264 [error]: x264_encoder_open failed J:\Bd25 4\Valkyrie (2008)\BD-RBV02803_HQ\WORKFILES -------------------------------------------------------------------- 08/11/2009 03:03 PM <DIR> . 08/11/2009 03:03 PM <DIR> .. 08/11/2009 03:03 PM 40,720 00074.clpi 08/11/2009 03:03 PM 5,565,782,016 00074.m2ts 08/11/2009 12:32 PM 3,326,385,148 00074.track_4352.dts 08/11/2009 12:32 PM 29,028,564 00074.track_4608.sup 08/11/2009 12:32 PM 24,495,097 00074.track_4609.sup 08/11/2009 12:32 PM 27,215,553 00074.track_4610.sup 08/11/2009 12:32 PM 22,068,786 00074.track_4611.sup 08/11/2009 12:32 PM 14,099,704 00074.track_4612.sup 08/11/2009 12:32 PM 26,646,806 00074.track_4614.sup 08/11/2009 03:03 PM 15,349,376 00172.track_4352.ac3 08/11/2009 12:23 PM 897 AUD_00074.meta 08/11/2009 12:32 PM 262 AUD_00074_4352.AVS 08/11/2009 03:03 PM 266 AUD_00172.meta 08/11/2009 03:03 PM 262 AUD_00172_4352.AVS 08/11/2009 03:01 PM 970 MUX_00074.meta 08/11/2009 12:32 PM 184 VID_00074.AVS 08/11/2009 03:01 PM 1,601,140,470 VID_00074.AVS.MKV 08/11/2009 01:32 PM 14,011,649 VID_00074.AVS.MKV.stats 08/11/2009 03:03 PM 309 VID_00172.AVS 08/11/2009 03:09 PM 0 VID_00172.AVS.MKV 08/11/2009 03:03 PM 5,669 VID_00172.AVS.MKV.stats 08/11/2009 03:03 PM 375,383 VID_00172.AVS.MKV.stats.mbtree 22 File(s) 10,666,648,091 bytes Last edited by leChameleon; 11th August 2009 at 23:15. |
#4537 | Link |
I'd report that to the X264 developers, as there's really nothing BD-RB can do about it.
#4539 | Link | |
Are you sure your source isn't corrupt or was dismounted during the rebuild?One idea: what is the label name of the BD? It shows at the top of the STREAM tab.
jdobbs.softworks@gmail.com Last edited by jdobbs; 12th August 2009 at 00:00. |
#4540 | Link |
And, of course, there are also the other usual suspects like version of windows, AVISYNTH, CODEC (probable) and "tinkering".
| Thread Tools | |
| Display Modes | |
