Domains: forum.doom9.org / forum.doom9.net / forum.doom9.se
Thread Tools Display Modes
Old 15th July 2023, 01:22   #41  |  Link
StainlessS
StainlessS's Avatar
I think you are using an old version, current is r134.6.
Yeah, probably bout 5 weeks since update.
Not odd, Whisper models doesn't support transcription of multilingual audio. ...
Well whether it supports it or not, some (but not all) of it (Spanish) was translated to English.
I sometimes post sober.
Old 15th October 2023, 02:00   #42  |  Link
VoodooFX
Video damager
VoodooFX's Avatar
Compiled Linux and Mac OS X executables. Enjoy it.
VoodooFX is offline   Reply With Quote
Old 5th December 2023, 10:52   #43  |  Link
xarzu
xarzu's Avatar
I got an error which, I assume, is due to the fact that my input is a 4 hour long video, or maybe I have too many windows open, or both.
xarzu is offline   Reply With Quote
Old 5th December 2023, 13:19   #44  |  Link
Emulgator
Big Bit Savings Now !
Emulgator's Avatar
I can only suggest to split long files into multiple jobs, it helps a great deal with everything whisper.
For sequences which are hard to guess: restrict a whisper job to only that part, and repeats or overlooked, bad guesses can be mended.
Old 5th December 2023, 19:58   #45  |  Link
VoodooFX
Video damager
VoodooFX's Avatar
No, that's irrelevant.
From the screenshot you can see that it's out of the video memory.
How much of VRAM there is in your GPU, and what is the model of your GPU?
Old 7th April 2024, 13:04   #46  |  Link
VoodooFX
Video damager
VoodooFX's Avatar
Released Standalone Faster-Whisper-XXL with the additional features.
You want to use them on movies or noisy podcasts containing music & ect.
Old 25th April 2024, 22:07   #47  |  Link
Yosho
I could use some help with the syntax if you wouldn't mind..
So far I've got C:\Users\Downloads\Faster-Whisper-XXL_r192.3.4_windows\Faster-Whisper-XXL\faster-whisper-xxl.exe "C:\Users\Downloads\blah.mkv" --language English -m large -d CPU -o "C:\Users\Downloads" -f srt --task transcribe
Additionally, is there a way to include this in subtitle edit by chance? Or would it need to be put in by the programmer themselves of the app?
Thanks for the help!
Yosho is offline   Reply With Quote
Old 26th April 2024, 01:13   #48  |  Link
VoodooFX
Video damager
VoodooFX's Avatar
I don't mind.
That you should ask the developer of Subtitle Edit.
Old 26th April 2024, 06:14   #49  |  Link
Yosho
Originally Posted by VoodooFX View Post
I don't mind.
Great, thanks! What am I missing from the commands I posted to run it to first download the _models and then do the transcription with the whisper?
Thank you for your help!
Old 26th April 2024, 11:07   #50  |  Link
VoodooFX
Video damager
VoodooFX's Avatar
What am I missing from the commands...
No idea what you are missing there, you tell me what you are missing... only the input is needed to run it.
I can tell you what I'm missing - I don't see you posting your problem, if you have any.
Old 26th April 2024, 15:46   #51  |  Link
Yosho
I figured it out.
I now have subtitles. They are out of sync, and needing to be synced to the dialog.
Do you have something you regularly use for automatic subtitle syncing, or advice on what's best in your educated opinion to use for automatic subtitle syncing?
Old 27th April 2024, 09:59   #52  |  Link
VoodooFX
Video damager
VoodooFX's Avatar
For me it produces mostly in sync results, can you share an audio sample where it's out of sync?
There is no perfect automatic subtitle syncing.
Old 21st January 2025, 05:58   #53  |  Link
VoodooFX
Video damager
VoodooFX's Avatar
If someone doesn't have fast CUDA GPU, you can use one for free in Colab.
EDIT: Look at the first post.
Old 22nd January 2026, 09:10   #54  |  Link
TR-9970X
TR-9970X's Avatar
Thanks for directing me here:-
So I have been spending a LOT of time with the 6 episode near 5 hour's of Das Boot.
Have downloaded so many variants, I'm getting lost & confused.
So to cut a very long story short, I got 2 different sets, as one was 1080p. and the 720p had the good dubbed engish audio, but each episode was minutes shorter, so I had to overcome that issue, and did, the audio overdub is preety damn good
So once I trimmed all the episodes of the useless intro, outro & recaps, I then wanted to transcribe the dubbed english audio. to get matching subtitles. as the original audio & english subs are crap.
I tried Whisper @ Google Colab, and that did a pretty good job on the majority, but there a few really tricky bits that I want to get as correct as I can, and this one I've sent you is a little song, either in French or German. and I just can't quite get it.
I tried to set up WhisperX on my PC, but I got stuck at some error that I couldn't get any help on. so I gave up.
Using SE, the only model that came close to getting this clip, was const-me large. ALL the other's didn't find anything
I'd really like to be able to post my final compilation somewhere for anyone that wants a good "ENGLISH" copy of Das Boot, the massive near 5 hours of it.
Here's the file, I sent a video, so you can see what you're dealing with.
https://www.mediafire.com/file/s8kbo...e+song.7z/file
BTW, I figured out how to use waveforms, what a godsend that is
Cheers & thanks again.
Main Systems:-
9970X on Gigabyte TRX50 AERO D
7970X on Asus Pro WS TRX50-Sage WiFi
9950X3D on MSI Carbon X670E
7950X on Gigabyte Aorus Elite B650
i9-13900KF on MSI Tomahawk B660
TR-9970X is offline   Reply With Quote
Old 22nd January 2026, 10:33   #55  |  Link
VoodooFX
Video damager
VoodooFX's Avatar
Originally Posted by TR-9970X View Post
The command used:
-m large-v2 --vad_method pyannote_v3 -o source --standard --max_gap 1 --realign --ff_vocal_extract mb-roformer --multilingual true --batched
Subs:
00:00:01,076 --> 00:00:01,701
Exactly.
2
00:00:03,608 --> 00:00:04,080
Me too.
3
00:00:04,705 --> 00:00:09,019
Avec les marins s'attendent, les ponts
cassant leur aveugle.
4
00:00:09,419 --> 00:00:14,500
Moi, je sais bien ce qui leur manque à
tous ces mondes et leurs généraux.
5
00:00:14,859 --> 00:00:21,917
Allez, je m'appelle la reine, la reine du
pays de la Rochelle.
6
00:00:22,120 --> 00:00:29,492
Côle bleu, sentinelle, m'appelle... M
'appelle la reine de la Rochelle.
7
00:00:32,447 --> 00:00:36,042
Come on now, he's too young to play games
with you, Monique, huh?
Why? There are retail English subs for it.
Old 22nd January 2026, 10:56   #56  |  Link
TR-9970X
TR-9970X's Avatar
The command used:
Subs:
Exactly.
2
Me too.
3
4
5
6
7
Of course I'm guessin' that's with your Pro version ??
Can it do translations??
I let Google translate, and now I should be able to add that.
I have searched far & wide, and all the English subtitles are crap, the dubbed english transcript is pretty much spot on.
And the 6 part Das Boot is pretty rare, as well.
So you've all but convinced me that your Pro version is pretty damn good.
So, not to be a pain, but how do I get it, how much is it going to cost me, and how to integrate it in SE.
Oh, and thanks for doing that little job for me so quickly
Main Systems:-
Old 22nd January 2026, 11:18   #57  |  Link
VoodooFX
Video damager
VoodooFX's Avatar
Yes.
Yes, it does translation to English.
Its translation is better than Google translate.
Look there: https://github.com/Purfview/whisper-...iscussions/456
Just copy it to the same folder where the regular version is in SE. (Delete the old files there, excluding the models)
The retail subs are for the original German audio, I guess you're comparing them to the dubbed audio, which is different from the original.
Old 22nd January 2026, 11:46   #58  |  Link
TR-9970X
TR-9970X's Avatar
Yes.
OK, so if you're minimum "donation" is £50, that calculates to nearly AU$100...is that correct ??
From what I've seen, the english that comes with the video, isn't that good, and the subtitles don't match either.
The dubbed english was done by the actors that were in the movie, so it's pretty good.
Main Systems:-
Old 22nd January 2026, 11:52   #59  |  Link
VoodooFX
Video damager
VoodooFX's Avatar
Yes, it should be around that.
Old 22nd January 2026, 11:57   #60  |  Link
TR-9970X
TR-9970X's Avatar
OK, well, I'm going to have to give that some serious thought.
Regards.
Main Systems:-
audio, openai, speech, subtitles, text
Thread Tools
