Old 30th January 2018, 19:46   #61  |  Link
nalor
Just uploaded release 0.61 - I think the major new feature is a massive speed boost because I changed AES functions to the libgcrypt library.
Additionally it's now possible to perform an ISO InPlace decryption and another new feature is to redirect all 'wrong' playlists to the correct playlist on discs with playlist obfuscation - you only need to know the correct playlist
Old 31st January 2018, 02:48   #62  |  Link
spotter
One can't just replace playlists. Many times it checks the file size and if not what it expects, fails.
spotter is offline   Reply With Quote
Old 31st January 2018, 18:16   #63  |  Link
nalor
You're right - my approach is not really a solution to the problem but more some kind of a small workaround.
On my pioneer player I noticed he's using the wrong playlist - and the wrong playlist is already played before e.g. the menu gets displayed (because some internal checks during execution failed and it decided to play one of the fake playlists).
I just remap all 'wrong' playlists to the correct one - and in this case the pioneer player plays the correct playlist instead of the wrong one.
I still don't get into the menu - but at least I can use my Pioneer player and don't need my pi to play the disc.
And as I have only a few of those discs I don't know how good it's really working - it's just something I've tried a few month ago and it's still in the application
Old 13th March 2018, 14:02   #64  |  Link
frankio
I've used this precious tool on a few BDs (even BD+ ones) in ISO2ISO mode and it worked a treat, thank you!
Today I've stumbled upon a title that BTAD refuses to decrypt giving me an unexplicable error about not being able to find AACS directory.
This is an excerpt from logfile:
PARTITION:
PartitionNr >0< StartBlock >00000288< BlockLength >24438208<
2018-03-13 10:20:07 # 262 # [I] main / legacy / Initialize Disc now
2018-03-13 10:20:07 # 262 # [I] main / legacy / VolumeName: RED_BIRD_2D_F2
2018-03-13 10:20:07 # 262 # [I] bluray_udf / BRUDF_FileSize /
++++ BRUDF_FileSize ++++ File >\AACS\Unit_Key_RO.inf< ++++
2018-03-13 10:20:07 # 262 # [I] bluray_aacs / BRAACS_getDiscID / UDF-Filesize Result for >\AACS\Unit_Key_RO.inf< - >#BRUDF_ERR_FILE_NOT_FOUND<
++++ BRUDF_FileSize ++++ File >\BTD!\Unit_Key_RO.inf< ++++
2018-03-13 10:20:07 # 262 # [I] bluray_aacs / BRAACS_getDiscID / UDF-Filesize Result for >\BTD!\Unit_Key_RO.inf< - >#BRUDF_ERR_FILE_NOT_FOUND<
++++ BRUDF_FileSize ++++ File >\ANY!\Unit_Key_RO.inf< ++++
2018-03-13 10:20:07 # 262 # [I] bluray_aacs / BRAACS_getDiscID / UDF-Filesize Result for >\ANY!\Unit_Key_RO.inf< - >#BRUDF_ERR_FILE_NOT_FOUND<
++++ BRUDF_FileSize ++++ File >\FAB!\Unit_Key_RO.inf< ++++
2018-03-13 10:20:07 # 262 # [I] bluray_aacs / BRAACS_getDiscID / UDF-Filesize Result for >\FAB!\Unit_Key_RO.inf< - >#BRUDF_ERR_FILE_NOT_FOUND<
2018-03-13 10:20:07 # 262 # [E] bluray_aacs / BRAACS_getDiscID / No current or former AACS directory could be found - not possible to calculate DiscID for >C:\BD-iso\enc\RED_BIRD_2D_F2.iso<
2018-03-13 10:20:07 # 262 # [I] main / legacy / ERROR! Couldn't get DiscID >#BRAACS_DiscIdInvalid<
2018-03-13 10:20:07 # 263 # [I] main / legacy / ERROR! Bluray_InitDisc failed! (-2)
2018-03-13 10:20:07 # 263 # [I] main / legacy / ERROR! DecryptIso2Iso failed for file >C:\BD-iso\enc\RED_BIRD_2D_F2.iso<
2018-03-13 10:20:07 # 263 # [I] main / legacy / Overall duration >0:00:00<
Obviously the AACS directory is present on the disc.
Now if I mount the ISO as a virtual drive and drop the drive letter onto BTAD executable (mode = 3) then everything goes smooth.
I suspect there's a problem with this specific ISO but I don't have a clue as I ripped it using the same method as others titles (linux dd command) and this one only is failing.
Please let me know if you need more logs, thank you.
frankio is offline   Reply With Quote
Old 15th March 2018, 00:20   #65  |  Link
nalor
Thanks for the report - really interesting, maybe I missed something when I wrote my own UDF interpreter ....
Please upload the first 20MB of your iso to e.g. tinyupload - this is all I need to check whats going wrong here.
Just wrote a small tool that saves the first 20MB of a file into a separate file inside the same directory - just drag the iso on the exe and you should get a '.20MB' file as result
SplitFirst20MB
Thanks!
Old 15th March 2018, 13:19   #66  |  Link
frankio
Here you go:
http://s000.tinyupload.com/index.php...96312963926920
BTW I could have spared you some coding time using dd to cut the beginning of the problematic ISO,
I really appreciate your effort though
While we're at it... any chance you can release a linux version eventually?
Right now I'm forced to use a windows system just because of this great tool.
Thank you for your support!
Old 15th March 2018, 18:53   #67  |  Link
nalor
Thanks for the upload!
Found the problem - I missed to take the 'LengthofImplementationUse' in the FileIdentifierDescriptor into account... this is usually always 0 and according to the OSTA UDF specification it should be set to the identifier of the application the last modified this descriptor.
So basically it's of no interest (just a text field - in your case it includes 'MEI' ) - I just need to skip it correctly when parsing the file structure
Will create a fixed release when I'm back home (hopefully this evening).
Regarding a linux release: purebasic is also available for linux, but I think it's not as easy as just recompiling it in linux .. maybe I will find some time to check it out.
Old 19th March 2018, 22:41   #68  |  Link
nalor
New Release with the fix available - took a little bit longer because I wanted to finally implement a 'Rip/Dump disc and test the iso' mode
Old 20th March 2018, 11:42   #69  |  Link
frankio
I tried the fixed version and now the decryption process starts but then, towards the end, it stops again with the following error:
++++ BRUDF_Close ++++ File >C:\BD-iso\enc\RED_BIRD_2D_F2.iso< ++++
2018-03-20 11:04:53 # 1385130 # [I] main / legacy / All blocks copied into >C:\RED_BIRD_2D_F2_decrypted.iso< - rename AACS folder to BTD! now
2018-03-20 11:04:54 # 1386157 # [I] bluray_udf / BRUDF_File_Rename /
++++ BRUDF_File_Rename ++++ Filename >\AACS< NewFilename >BTD!< iUndoHdl >0< ++++\n++++++++++++++++++++++++++++++++++++++++++++++++++
2018-03-20 11:04:54 # 1386157 # [I] bluray_udf / _UDF_readFileIdentifierDescriptor /
++++ _UDF_readFileIdentifierDescriptor ++++ Filename >\AACS< iAllowFidType >0< ++++
2018-03-20 11:04:54 # 1386157 # [I] bluray_udf / _UDF_readwriteFileIdentifierDescriptor /
++++ _UDF_readwriteFileIdentifierDescriptor ++++ Filename >\AACS< *FidToWrite >0< AllowFidType >0< iUndoHdl >0< ++++
2018-03-20 11:04:54 # 1386199 # [I] bluray_udf / _UDF_readwriteFileIdentifierDescriptor / File >\AACS< Size >0< FID/Part >1< FID\Block >3< FID\Offset >308< FID\Length >384<
2018-03-20 11:04:54 # 1386240 # [I] bluray_udf / BRUDF_ReadLogicalBlock / ###################### READ-BLOCK 323 # 0x00000000000A1800 LEN 384 Bytes ######################
2018-03-20 11:04:54 # 1386240 # [I] bluray_udf / _UDF_readwriteFileIdentifierDescriptor / ++++ File Identifier Descriptor ++++
2018-03-20 11:04:54 # 1386703 # [I] bluray_udf / _UDF_readwriteFileIdentifierDescriptor /   FileIdentifier ><
2018-03-20 11:04:54 # 1386703 # [E] bluray_udf / _UDF_readwriteFileIdentifierDescriptor / ERROR! Wrong File Identifier! Found >< Expected >AACS<
2018-03-20 11:04:54 # 1386704 # [I] bluray_udf / _UDF_readwriteFileIdentifierDescriptor / >>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>-716<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<
2018-03-20 11:04:54 # 1386704 # [E] bluray_udf / BRUDF_File_Rename / _UDF_readFileIdentifierDescriptor failed >#BRUDF_ERR_FID_ERROR<
2018-03-20 11:04:54 # 1386705 # [I] main / legacy / ERROR! Rename failed (-716) >#BRUDF_ERR_FID_ERROR<
2018-03-20 11:04:55 # 1387337 # [I] main / legacy / Delete destination file >C:\RED_BIRD_2D_F2_decrypted.iso<
2018-03-20 11:04:56 # 1387784 # [I] main / legacy / ERROR! DecryptIso2Iso failed for file >C:\BD-iso\enc\RED_BIRD_2D_F2.iso<
2018-03-20 11:04:56 # 1387784 # [I] main / legacy / Overall duration >0:22:58<
Feel free to ask for more info or samples!
I won't hold my breath then...
Old 21st March 2018, 19:57   #70  |  Link
nalor
Please try 0.63 - missed a 2nd location with the same problem
Old 22nd March 2018, 13:36   #71  |  Link
frankio
We're not there yet:
2018-03-22 11:12:50 # 1377261 # [I] main / legacy / All blocks copied into >C:\RED_BIRD_2D_F2_decrypted.iso< - rename AACS folder to BTD! now
2018-03-22 11:12:50 # 1377262 # [I] bluray_udf / BRUDF_File_Rename /
2018-03-22 11:12:50 # 1377262 # [I] bluray_udf / _UDF_readFileIdentifierDescriptor /
2018-03-22 11:12:50 # 1377262 # [I] bluray_udf / _UDF_readwriteFileIdentifierDescriptor /
2018-03-22 11:12:50 # 1377262 # [I] bluray_udf / _UDF_readwriteFileIdentifierDescriptor / File >\AACS< Size >0< FID/Part >1< FID\Block >3< FID\Offset >308< FID\Length >384<
2018-03-22 11:12:51 # 1377357 # [I] bluray_udf / BRUDF_ReadLogicalBlock / ###################### READ-BLOCK 323 # 0x00000000000A1800 LEN 384 Bytes ######################
2018-03-22 11:12:51 # 1377357 # [I] bluray_udf / _UDF_readwriteFileIdentifierDescriptor / ++++ File Identifier Descriptor ++++
2018-03-22 11:12:51 # 1377357 # [I] bluray_udf / _UDF_readwriteFileIdentifierDescriptor /   FileIdentifier >AACS<
2018-03-22 11:12:51 # 1377357 # [I] bluray_udf / _UDF_readwriteFileIdentifierDescriptor / Correct file found - read mode
2018-03-22 11:12:51 # 1377357 # [I] bluray_udf / _UDF_readwriteFileIdentifierDescriptor / >>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>41718056<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<
2018-03-22 11:12:51 # 1377357 # [E] bluray_udf / BRUDF_File_Rename / ERROR! Length of File Identifier different!
2018-03-22 11:12:51 # 1377358 # [I] main / legacy / ERROR! Rename failed (-729) >#BRUDF_ERR_RENAME_LEN<
2018-03-22 11:12:51 # 1377603 # [I] main / legacy / Delete destination file >C:\RED_BIRD_2D_F2_decrypted.iso<
2018-03-22 11:12:51 # 1378040 # [I] main / legacy / ERROR! DecryptIso2Iso failed for file >C:\BD-iso\enc\RED_BIRD_2D_F2.iso<
2018-03-22 11:12:51 # 1378041 # [I] main / legacy / Overall duration >0:22:52<
Old 24th March 2018, 20:57   #72  |  Link
nalor
please try 0.64 - this time I've tested my corrections myself, so I'm quite confident that it should work now
Old 27th March 2018, 12:02   #73  |  Link
frankio
Now everything's working as expected!
Thank you for your continued support
Old 27th March 2018, 12:49   #74  |  Link
nalor
Thanks for the feedback!
Gesendet von meinem E5823 mit Tapatalk
Old 1st April 2018, 20:02   #75  |  Link
qyot27
qyot27's Avatar
I was struggling for a good chunk of time yesterday evening to figure out why, despite having the libaacs-generated DiscID and VUK in my keydb.cfg file for the disc I was testing, I was still getting complaints about the Disc ID not being found there...it would appear that BlurayTestAndDecrypt is case-sensitive when it comes to the Disc ID (and probably the VUK too, but I didn't bother trying to test that part separately). libaacs uses lower-case letters when it generates its DiscID/VUK/VID backups, which means that you can't use its output as-is (well, aside from having to format the entire line like the others, but I didn't figure the case would be important...clearly it is).
95fpu85... wouldn't work, 'can't be found' error
95FPU85... would work fine
Old 1st April 2018, 20:06   #76  |  Link
nalor
You're right - I'm currently looking for an entry only in a case sensitive way, will change it for the next release
Old 15th October 2018, 03:00   #77  |  Link
spotter
download has been deleted from the server :/
Old 15th October 2018, 06:45   #78  |  Link
nalor
Will post a new release tonight.
Gesendet von meinem H8324 mit Tapatalk
Old 15th October 2018, 21:14   #79  |  Link
nalor
Posted Release 0.70 - mainly 1 new feature:
check of dvd vob & iso files
Old 25th November 2019, 23:48   #80  |  Link
LUR
Hi, trying to decrypt Star Wars Disc Collection:
2019-11-26 01:45:33 # 0 # [I] main /  / #############################################################################
2019-11-26 01:45:33 # 0 # [I] main /  /  ----------- BlurayTestAndDecrypt 0.70 -----------
2019-11-26 01:45:33 # 55 # [I] SETTINGS / _STG_CreateOrUpdate / Created ini file >C:\Users\LUR\Documents\WORK\BlurayTestAndDecrypt_0.70\BlurayTestAndDecrypt.ini<
2019-11-26 01:45:33 # 55 # [E] common_log / CMLOG_SetLogDirectory / new logdir invalid ><
2019-11-26 01:45:33 # 55 # [I] main /  / Read settings from file >C:\Users\LUR\Documents\WORK\BlurayTestAndDecrypt_0.70\BlurayTestAndDecrypt.ini<
2019-11-26 01:45:33 # 56 # [I] main /  / >> Mode         >0<
2019-11-26 01:45:33 # 56 # [I] main /  / >> DecryptDest  ><
2019-11-26 01:45:33 # 56 # [I] main /  / List of files being processed:
2019-11-26 01:45:33 # 56 # [I] main /  / Detected Drive >D:\<
2019-11-26 01:45:34 # 1643 # [I] main /  / Mode >4< saved in ini-file
2019-11-26 01:45:34 # 1643 # [I] main /  / #############################################################################
2019-11-26 01:45:34 # 1643 # [I] main /  / 1/1 - Srcdrive >D:\< Mode >Decrypt - ContinueOnError<
2019-11-26 01:45:34 # 1649 # [I] main / Bluray_InitDisc / VolumeName: ATTACK_OF_THE_CLONES
2019-11-26 01:45:34 # 1655 # [I] main / Bluray_InitDisc / DiscID:     F08E7A96834680A8BCE152387B9F8594748DA34D
2019-11-26 01:45:34 # 1658 # [I] main / Bluray_InitDisc / Disc is AACS protected - init necessary AACS values
2019-11-26 01:45:34 # 1659 # [I] main / Bluray_InitDisc / Use default AACS-KeyDB file instead >C:\Users\LUR\AppData\Roaming\aacs\keydb.cfg<
2019-11-26 01:45:34 # 1659 # [I] bluray_keydb / BRKDB_OpenFile / KeyDB file >C:\Users\LUR\AppData\Roaming\aacs\keydb.cfg< opened!
2019-11-26 01:45:34 # 1672 # [I] bluray_keydb / BRKDB_OpenFile / KeyDB file >C:\Users\LUR\AppData\Roaming\aacs\keydb.cfg< in memory now
2019-11-26 01:45:36 # 3250 # [I] bluray_keydb / _ParseMem / Removed duplicates for >0< discids from file >C:\Users\LUR\AppData\Roaming\aacs\keydb.cfg<
2019-11-26 01:45:36 # 3250 # [I] bluray_keydb / BRKDB_OpenFile / ParseMem result >1<
2019-11-26 01:45:36 # 3250 # [I] main / Bluray_InitDisc / VUK >9CC0FFB4974AC232B69B2DDEDAABACA2< available in KeyDB entry For disc
2019-11-26 01:45:36 # 3251 # [I] main / Bluray_InitDisc / VUK:        9CC0FFB4974AC232B69B2DDEDAABACA2
2019-11-26 01:45:36 # 3256 # [I] main / Bluray_InitDisc / UnitKeyCnt: 7
2019-11-26 01:45:36 # 3257 # [I] main / Bluray_InitDisc /  >>> UnitKey: 79EC0F4D8A1DFE0E1629116567B48A6B
2019-11-26 01:45:36 # 3257 # [I] main / Bluray_InitDisc /  >>> UnitKey: 85581552DC02679109AF39A4EA5077EB
2019-11-26 01:45:36 # 3258 # [I] main / Bluray_InitDisc /  >>> UnitKey: 53857DE5436B63EFA6BAD7B945433EAF
2019-11-26 01:45:36 # 3258 # [I] main / Bluray_InitDisc /  >>> UnitKey: 671F60BAA4F843411DB18FAB4EA74E1F
2019-11-26 01:45:36 # 3258 # [I] main / Bluray_InitDisc /  >>> UnitKey: 3675EDDA9998DAD0BA5B42C78F9048B9
2019-11-26 01:45:36 # 3259 # [I] main / Bluray_InitDisc /  >>> UnitKey: B9678AAC50E20FFFF706D5CC17C83A41
2019-11-26 01:45:36 # 3259 # [I] main / Bluray_InitDisc /  >>> UnitKey: F3F3C3D750810BC3B9810B6B88967E74
2019-11-26 01:45:36 # 3261 # [I] main / Bluray_InitDisc / Check if disc is BD+ protected
2019-11-26 01:45:36 # 3266 # [I] bluray_aacs / BRAACS_IsBDplusProtected / Directory >D:\BDSVM\< does exist and there is at least 1 .svm file in the folder >00000.svm< - disc is BP+ protected
2019-11-26 01:45:36 # 3266 # [I] main / Bluray_InitDisc / Disc is BD+ protected!
2019-11-26 01:45:36 # 3272 # [I] main / Bluray_InitDisc / BD+ details - Date 2011.07.11 Gen 11
2019-11-26 01:45:38 # 5409 # [I] main / ErrorHandler / A program error was detected:
Error Message:   Invalid memory access
Error Code:      -1073741819
Code Address:    4373540
Target Address:  12
Sourcecode line: 1178
Sourcecode file: U:\PUREBASIC\Bluray-Test\BlurayTest.pb
LUR is offline   Reply With Quote
